  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • MiKaM MiKa
    To Feji: You have speed 38400 Bd?
    FejiF
    FejiF
    Feji
    @MiKa
    It's a 56K version, I haven't try 38k yet.
    MiKaM 1 Reply Last reply
    • FejiF Feji
      @MiKa
      MiKaM
      MiKaM
      MiKa
      wrote on last edited by MiKa
      @Feji
      try 38400Bd it should work
      HW.h
      #ifndef BAUD_RATE
      #if F_CPU >= 16000000L
      #define BAUD_RATE 115200
      #elif F_CPU >= 8000000L
      #define BAUD_RATE 38400L
      #elif F_CPU >= 1000000L
      #define BAUD_RATE 9600L
      #elif F_CPU >= 128000L
      #define BAUD_RATE 4800L
      #define BAUD_RATE 1200L
      FejiF 1 Reply Last reply
      • MiKaM MiKa
        @Feji
        HW.h
        #ifndef BAUD_RATE
        FejiF
        FejiF
        Feji
        @MiKa
        My bad, it's a 38k version but I was trying to upload the sketch at 56k...
        • FejiF Feji
          @MiKa
          FejiF
          FejiF
          Feji
          @Feji
          After modifying the HW.h, it's work much better :). Obviously...
          Serial upload confirmed work at 57600.
          • W
            W
            Werwolfx
            wrote on last edited by Werwolfx
            Hello everybody.
            I have a problem with the update over the air.
            Version 2.1.0 mysensors
            Gateway on ESP8266 default sketh
            I downloaded the loader in atmega328p Arduino pro mini
            in MYSController choose firmware
            in logs
            [12.01.2017 20: 32: 50.118 Info] INFO BL version = 768
             [12.01.2017 20: 32: 50.118 Info] INFO Send FW info to node 4: type = A, version = 1, blocks = 0x0050, CRC = 0x46D4
             [12/01/2017 20: 32: 50.120 Info] TX 4, 0, 4, 0, 1; 0A0001005000D446
             [12/01/2017 20: 32: 52.205 Info] RX 0, 255, 3, 0, 2, 2.1.0
             [12.01.2017 20: 32: 53.724 Info] RX 10, 3, 1, 0, 0, 21.2
             [12/01/2017 20: 32: 53.736 Info] RX 4; 255; 3, 0, 6, 0
             [12/01/2017 20: 32: 53.737 Info] TX 4; 255; 3, 0; 6; M
            in arduino serial
            0 MCO: BGN: INIT NODE, CP = RNONA -, VER = 2.1.0
            3 TSM: INIT
            4 TSF: WUR: MS = 0
            11 TSM: INIT: TSP OK
            13 TSM: INIT: STATID = 4
            15 TSF: SID: OK, ID = 4
            16 TSM: FPAR
            53 TSF: MSG: SEND, 4-4-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, st = OK:
            592 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 8, pt = 1, l = 1, sg = 0: 0
            598 TSF: MSG: FPAR OK, ID = 0, D = 1
            2060 TSM: FPAR: OK
            2061 TSM: ID
            2062 TSM: ID: OK
            2064 TSM: UPL
            2069 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 24, pt = 1, l = 1, sg = 0, ft = 0, st = OK: 1
            2083 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 25, pt = 1, l = 1, sg = 0: 1
            2088 TSF: MSG: PONG RECV, HP = 1
            2092 TSM: UPL: OK
            2093 TSM: READY: ID = 4, PAR = 0, DIS = 1
            2113 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 4, t = 0, pt = 6, l = 10, sg = 0, ft = 0, st = OK: FFFFFFFFD0033C3E0300
            2131 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 15, pt = 6, l = 2, sg = 0, ft = 0, st = OK: 0100
            2138 TSF: MSG: READ, 0-0-4, s = 0, c = 4, t = 1, pt = 6, l = 8, sg = 0: 0A0001005000D446
            2144 OTA: FWP: UPDATE
            ! 2146 OTA: FWP: FLASH INIT FAIL
            2151 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 15, pt = 6, l = 2, sg = 0: 0100
            4074 TSF:! MSG: SEND, 4-4-0-0, s = 255, c = 0, t = 17, pt = 0, l = 5, sg = 0, ft = 0, st = NACK: 2.1. 0
            5727 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 6, pt = 1, l = 1, sg = 0, ft = 1, st = OK: 0
            5734 TSF: MSG: READ, 10-10-0, s = 3, c = 1, t = 0, pt = 7, l = 5, sg = 0: 21.2
            ! 5739 TSF: MSG: REL MSG, NREP
            5817 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 6, pt = 0, l = 1, sg = 0: M
            ! 7739 TSF: MSG: SEND, 4-4-0-0, s = 1, c = 0, t = 23, pt = 0, l = 0, sg = 0, ft = 0, st = NACK:
            8436 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 11, pt = 0, l = 9, sg = 0, ft = 1, st = OK: Yang Node
            8462 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 12, pt = 0, l = 4, sg = 0, ft = 0, st = OK: v1.0
            confuse line
            what could be the problem?
            tekkaT 1 Reply Last reply
            • W Werwolfx
              Hello everybody.
              in logs
              in arduino serial
              3 TSM: INIT
              4 TSF: WUR: MS = 0
              16 TSM: FPAR
              2060 TSM: FPAR: OK
              2061 TSM: ID
              2062 TSM: ID: OK
              2064 TSM: UPL
              2092 TSM: UPL: OK
              confuse line
              tekkaT
              tekkaT
              tekka
              @Werwolfx
              Disable MY_OTA_FIRMWARE_FEATURE, this is only required for the external flash/dualoptiboot OTA method, MYSBootloader handles OTA updates offline.
              W 1 Reply Last reply
              • tekkaT tekka
                @Werwolfx
                W
                W
                Werwolfx
                @tekka oh, my mistake, thank you very much for your work.
                • W
                  W
                  Werwolfx
                  I try to disable MY_OTA_FIRMWARE_FEATURE in arduino/
                  but no effect =(
                  In arduino load example code PingpongSensor and add in sketch
                  #define MY_NODE_ID 4
                  MYSController log
                  14.01.2017 8:43:45	CLICK	Board with MYSBootloader=TRUE
                  14.01.2017 8:43:46	RX	10;5;1;0;17;841
                  14.01.2017 8:43:46	RX	10;6;1;0;39;3.66
                  14.01.2017 8:43:52	RX	0;255;3;0;2;2.1.0
                  14.01.2017 8:43:54	TX	4;0;3;0;13;0
                  14.01.2017 8:43:54	INFO	FW "TimeReporter" assigned to node 4
                  14.01.2017 8:43:57	RX	6;3;1;0;16;0
                  14.01.2017 8:43:57	RX	6;6;1;0;3;0
                  14.01.2017 8:43:57	RX	5;3;1;0;16;0
                  14.01.2017 8:43:57	RX	5;6;1;0;3;0
                  14.01.2017 8:43:57	RX	6;5;1;0;0;20.25
                  14.01.2017 8:44:00	RX	4;255;0;0;17;2.1.0
                  14.01.2017 8:44:00	CHILD	New child discovered, node id=4, child id=internal
                  14.01.2017 8:44:00	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                  14.01.2017 8:44:00	RX	4;255;3;0;6;0
                  14.01.2017 8:44:00	TX	4;255;3;0;6;M
                  14.01.2017 8:44:00	RX	4;1;0;0;23;
                  14.01.2017 8:44:00	CHILD	New child discovered, node id=4, child id=1
                  14.01.2017 8:44:00	DEBUG	Update child id=1, type=S_CUSTOM
                  14.01.2017 8:44:00	RX	4;255;3;0;12;v1.0
                  Arduino serial
                  38602 TSF:MSG:READ,0-0-4,s=0,c=3,t=13,pt=0,l=1,sg=0:0
                  0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  12 TSM:INIT:STATID=4
                  14 TSF:SID:OK,ID=4
                  16 TSM:FPAR
                  52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  153 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  157 TSF:MSG:FPAR OK,ID=0,D=1
                  2060 TSM:FPAR:OK
                  2061 TSM:ID
                  2062 TSM:ID:OK
                  2064 TSM:UPL
                  2067 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2081 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2086 TSF:MSG:PONG RECV,HP=1
                  2088 TSM:UPL:OK
                  2091 TSM:READY:ID=4,PAR=0,DIS=1
                  2122 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2128 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  2139 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                  2151 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  2170 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  2184 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                  2192 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Yang Node
                  2236 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v1.0
                  Yang NodeReady.
                  2243 MCO:REG:REQ
                  2249 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                  2265 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  2269 MCO:PIM:NODE REG=1
                  2272 MCO:BGN:STP
                  2273 MCO:BGN:INIT OK,TSP=1
                  2315 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                  0_1484381990012_upload-678581ea-b243-4cea-8b4b-12fd2faf9c9b
                  • W Werwolfx
                    but no effect =(
                    MYSController log
                    Arduino serial
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    14 TSF:SID:OK,ID=4
                    16 TSM:FPAR
                    2060 TSM:FPAR:OK
                    2061 TSM:ID
                    2062 TSM:ID:OK
                    2064 TSM:UPL
                    2088 TSM:UPL:OK
                    Yang NodeReady.
                    2243 MCO:REG:REQ
                    2272 MCO:BGN:STP
                    tekkaT
                    tekkaT
                    tekka
                    @Werwolfx I don't see any MYSBootloader startup message in your log. Please re-download the .hex from the github repo to ensure you are on the most recent version and flash it following these instructions: https://www.mysensors.org/about/ota
                    • tekkaT tekka
                      W
                      W
                      Werwolfx
                      @tekka
                      i tryed it
                      My little instructions for Arduino Atmega328p 5v ext
                      1)download from https://github.com/mysensors/MySensorsBootloaderRF24
                      2)copy to arduino folder arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors and paste boards.txt
                      proMYSBL.name=ATmega328 16Mhz MYSBootloader
                      proMYSBL.upload.tool=avrdude
                      proMYSBL.upload.speed=115200
                      proMYSBL.build.mcu=atmega328p
                      proMYSBL.build.board=AVR_UNO
                      proMYSBL.build.core=arduino
                      3)In Arduino IDE select downloadex bootloader and burn it to Atmega
                      avrdude log
                      /home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
                      avrdude: Version 6.3, compiled on Dec 16 2016 at 12:32:01
                               System wide configuration file is "/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf"
                               User configuration file is "/home/werwolfx/.avrduderc"
                               Using Programmer              : usbasp
                               Programmer Type : usbasp
                               Description     : USBasp, http://www.fischl.de/usbasp/
                      avrdude: auto set sck period (because given equals null)
                      avrdude: warning: cannot set sck period. please check for usbasp firmware update.
                      avrdude: erasing chip
                      /home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -Uflash:w:/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
                      avrdude: verifying ...
                      Writing |  ***failed;
                      ################################################## | 100% 0.03s
                      avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                      This behaviour is deprecated and will result in an error in future version
                      You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                      avrdude: reading input file "0xF7"
                      avrdude: verifying lfuse memory against 0xF7:
                      avrdude: load data lfuse data from input file 0xF7:
                      avrdude: input file 0xF7 contains 1 bytes
                      avrdude done.  Thank you.
                      avrdude: reading input file "/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex"
                      avrdude: writing flash (32762 bytes):
                      avrdude: 32762 bytes of flash written
                      avrdude: verifying flash memory against /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
                      avrdude: load data flash data from input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
                      avrdude: input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex contains 32762 bytes
                      avrdude: 32762 bytes of flash verified
                      avrdude: reading input file "0x0F"
                      avrdude: verifying lock memory against 0x0F:
                      avrdude: load data lock data from input file 0x0F:
                      avrdude: input file 0x0F contains 1 bytes
                      1. I loaded test sketh WaterMeterPulssensor (from Mysensors example) to arduino
                        wait if the module is start and see to MYSController
                        in MYSController
                      14.01.2017 11:34:49	RX	5;6;1;0;3;0
                      14.01.2017 11:34:52	RX	10;5;1;0;17;5519
                      14.01.2017 11:34:52	RX	10;6;1;0;39;23.99
                      14.01.2017 11:34:57	RX	6;3;1;0;16;0
                      14.01.2017 11:34:58	RX	6;4;1;0;37;170
                      14.01.2017 11:34:58	RX	6;6;1;0;3;0
                      14.01.2017 11:34:58	RX	6;5;1;0;0;20.50
                      14.01.2017 11:35:01	RX	4;255;0;0;17;2.1.0
                      14.01.2017 11:35:01	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                      14.01.2017 11:35:01	RX	4;255;3;0;6;0
                      14.01.2017 11:35:01	TX	4;255;3;0;6;M
                      14.01.2017 11:35:02	RX	4;255;3;0;11;Water Meter
                      14.01.2017 11:35:02	RX	4;255;3;0;12;1.1
                      14.01.2017 11:35:02	RX	4;1;0;0;21;
                      14.01.2017 11:35:02	DEBUG	Update child id=1, type=S_WATER
                      14.01.2017 11:35:02	RX	4;1;2;0;24;
                      14.01.2017 11:35:08	RX	10;5;1;0;17;5462
                      14.01.2017 11:35:08	RX	10;6;1;0;39;23.75
                      14.01.2017 11:35:18	RX	7;3;1;0;16;0
                      14.01.2017 11:35:18	RX	7;4;1;0;37;192
                      14.01.2017 11:35:18	RX	7;6;1;0;3;0
                      14.01.2017 11:35:19	RX	5;3;1;0;16;0
                      14.01.2017 11:35:19	RX	5;4;1;0;37;34
                      14.01.2017 11:35:19	RX	5;6;1;0;3;0
                      5)in MYSController Assign FW Blink and Reboot
                      MYSController
                      14.01.2017 11:38:03	TX	4;0;3;0;13;0
                      14.01.2017 11:38:09	RX	4;255;0;0;17;2.1.0
                      14.01.2017 11:38:09	CHILD	New child discovered, node id=4, child id=internal
                      14.01.2017 11:38:09	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                      14.01.2017 11:38:09	RX	4;255;3;0;6;0
                      14.01.2017 11:38:09	TX	4;255;3;0;6;M
                      14.01.2017 11:38:09	RX	4;255;3;0;11;Water Meter
                      14.01.2017 11:38:09	RX	4;255;3;0;12;1.1
                      14.01.2017 11:38:09	RX	4;1;0;0;21;
                      14.01.2017 11:38:09	CHILD	New child discovered, node id=4, child id=1
                      14.01.2017 11:38:09	DEBUG	Update child id=1, type=S_WATER
                      14.01.2017 11:38:10	RX	4;1;2;0;24;
                      14.01.2017 11:38:14	RX	4;255;3;0;21;0
                      Serial
                      101794 TSF:MSG:READ,0-0-4,s=0,c=3,t=13,pt=0,l=1,sg=0:0
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSM:INIT:STATID=4
                      14 TSF:SID:OK,ID=4
                      16 TSM:FPAR
                      345 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      350 TSF:MSG:FPAR OK,ID=0,D=1
                      2060 TSM:FPAR:OK
                      2061 TSM:ID
                      2062 TSM:ID:OK
                      2064 TSM:UPL
                      2089 TSM:UPL:OK
                      2098 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2104 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2114 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                      2126 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      2157 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      2164 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Water Meter
                      2176 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                      2183 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=21,pt=0,l=0,sg=0,ft=0,st=OK:
                      2189 MCO:REG:REQ
                      2193 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      2245 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      2250 MCO:PIM:NODE REG=1
                      2252 MCO:BGN:STP
                      2255 TSF:MSG:SEND,4-4-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                      2262 MCO:BGN:INIT OK,TSP=1
                      2335 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                      2866 TSF:MSG:READ,0-0-4,s=1,c=1,t=24,pt=0,l=6,sg=0:400100
                      Received last pulse count from gw:400100
                      6381 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                      6386 TSF:MSG:BC
                      6637 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0```
                      • W Werwolfx
                        @tekka
                        i tryed it
                        avrdude log
                          in MYSController
                        MYSController
                        Serial
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        14 TSF:SID:OK,ID=4
                        16 TSM:FPAR
                        2060 TSM:FPAR:OK
                        2061 TSM:ID
                        2062 TSM:ID:OK
                        2064 TSM:UPL
                        2089 TSM:UPL:OK
                        2189 MCO:REG:REQ
                        2252 MCO:BGN:STP
                        6386 TSF:MSG:BC
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        #22
                        @Werwolfx but still no signs of MYSBootloader - what RF channel are you on?
                        • tekkaT tekka
                          W
                          W
                          Werwolfx
                          #23
                          @tekka
                          NRF24L01+
                          What is the "no signs of MYSBootloader"?
                          • W Werwolfx
                            @tekka
                            NRF24L01+
                            tekkaT
                            tekkaT
                            tekka
                            @Werwolfx As soon as the bootloader takes over, in your case after the reboot request (1), but before the MYS lib 2.1.0 init message (2):
                            (1) 14.01.2017 11:38:03 TX  4;0;3;0;13;0
                            (2) 14.01.2017 11:38:09 RX  4;255;0;0;17;2.1.0
                            it will send a I_FIRMWARE_CONFIG_REQUEST message to inform the controller about the currently loaded FW and request a new FW.
                            looks like this:
                            4;255;4;0;0;BE0001003003D8490102
                            This is missing in your case, therefore I'm wondering if you have incompatible radio settings. Please post your GW sketch and upload your MYSBootloader.hex file for further troubleshooting.
                            • tekkaT tekka
                              looks like this:
                              W
                              W
                              Werwolfx
                              #25
                              @tekka GW on esp8266 (default sketch) + NRF24L01+
                              on GW
                               * Version 1.0 - Henrik EKblad
                               * Contribution by Ivo Pullens (ESP8266 support)
                               * The EthernetGateway sends data received from sensors to the WiFi link.
                               * VERA CONFIGURATION:
                               * LED purposes:
                               * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
                               * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                               * nRF24L01+  ESP8266
                               * VCC        VCC
                               * CE         GPIO4
                               * CSN/CS     GPIO15
                               * SCK        GPIO14
                               * MISO       GPIO12
                               * MOSI       GPIO13
                               * GND        GND
                                * Inclusion mode button:
                              #define MY_BAUD_RATE 115200
                              #define MY_GATEWAY_ESP8266
                              #define MY_ESP8266_SSID "WiFI"
                              #define MY_ESP8266_PASSWORD "password[0_1484386469111_MYSBootloader.hex](/uploads/files/1484386469171-mysbootloader.hex) "
                              // Enable UDP communication
                              //#define MY_USE_UDP
                              // #define MY_ESP8266_HOSTNAME "sensor-gateway"
                              #define MY_PORT 5003
                              // Enable inclusion mode
                              // #define MY_INCLUSION_BUTTON_FEATURE
                              // Set blinking period
                              // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                              // Flash leds on rx/tx/err
                              #if defined(MY_USE_UDP)
                                #include <WiFiUdp.h>
                              #include <ESP8266WiFi.h>
                              In MYSController on mudule i click INFO
                              FW Update = no
                              Bootloader = N/A
                              may be problem in the Bootloader.hex?
                              0_1484386859986_upload-c59e469e-e015-4099-88d8-607a7408a1da
                              • W Werwolfx
                                on GW
                                 * LED purposes:
                                 * nRF24L01+  ESP8266
                                 * VCC        VCC
                                 * CE         GPIO4
                                 * CSN/CS     GPIO15
                                 * SCK        GPIO14
                                 * MISO       GPIO12
                                 * MOSI       GPIO13
                                 * GND        GND
                                FW Update = no
                                Bootloader = N/A
                                tekkaT
                                tekkaT
                                tekka
                                @Werwolfx Please also update the bootloader file.
                                W 2 Replies Last reply
                                • tekkaT tekka
                                  W
                                  W
                                  Werwolfx
                                  I'll update more than once, but there is no effect.
                                  avrdude writes that everything is OK
                                  I do not know what to do = (
                                  • W Werwolfx
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Werwolfx sorry, maybe I was not clear - please upload it here to the forum I will try to reproduce your setup.
                                    • tekkaT tekka
                                      W
                                      W
                                      Werwolfx
                                      #29
                                      @tekka If i ENABLE #define MY_OTA_FIRMWARE_FEATURE
                                      i see ST_FIRMWARE_CONFIG_REQUEST in MYSCONTROLLER logs!!!
                                      if i DISABLE //#define MY_OTA_FIRMWARE_FEATURE msg not in log
                                      i not have external flash/
                                      402	14.01.2017 21:29:28	TX	4 - Water Meter	N/A	C_INTERNAL	NO	I_REBOOT	0
                                      403	14.01.2017 21:29:28	RX	4	1	C_REQ	NO	V_VAR1
                                      408	14.01.2017 21:29:34	RX	4	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFF48044E100300
                                      409	14.01.2017 21:29:34	TX	4	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
                                      410	14.01.2017 21:29:34	RX	4	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_NODE	2.1.0
                                      411	14.01.2017 21:29:34	RX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	0
                                      412	14.01.2017 21:29:34	TX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	M
                                      414	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_NAME	Water Meter
                                      417	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_VERSION	1.1
                                      419	14.01.2017 21:29:34	RX	4 - Water Meter	1 - S_WATER	C_PRESENTATION	NO	S_WATER
                                      i load this HEX
                                      load from Arduino IDE 1.8.0
                                      0_1484418874223_MYSBootloader.hex
                                      board.txt
                                      proMYSBL.bootloader.low_fuses=0xFF
                                      proMYSBL.bootloader.extended_fuses=0xFE
                                      • W Werwolfx
                                        i load this HEX
                                        board.txt
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Werwolfx Ok, seems like you also upload the sketch via USBasp thereby erasing/overwriting the bootloader. Try uploading the sketch via serial or OTA after flashing the bootloader.
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          wrote on last edited by Mark Swift
                                          #31
                                          @tekka am I correct in thinking the HEX found on Github can be used with all Arduino's? I noticed my old folder has one hex for 16, 8 and 1Mhz?
                                          I'm using this board.txt
                                          menu.cpu=Processor
                                          MYSBL13.name=MYS Bootloader - atmega328p
                                          MYSBL13.upload.tool=arduino:avrdude
                                          MYSBL13.upload.protocol=arduino
                                          MYSBL13.upload.maximum_size=30720
                                          MYSBL13.upload.maximum_data_size=2048
                                          MYSBL13.bootloader.tool=arduino:avrdude
                                          MYSBL13.bootloader.unlock_bits=0x3F
                                          MYSBL13.bootloader.lock_bits=0x0F
                                          MYSBL13.build.mcu=atmega328p
                                          MYSBL13.build.board=AVR_PRO
                                          MYSBL13.build.core=arduino:arduino
                                          MYSBL13.build.variant=arduino:standard
                                          MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
                                          MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
                                          MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                          MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                          MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                          MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                                          MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                          MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
                                          MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
                                          MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                                          MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                                          MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                                          MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                                          MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                                          MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
                                          MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
                                          MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                                          MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                                          MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                                          MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                                          MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L```
