  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T Tag
    @mihai.aldea
    You are right, took the letter P, which is 16.... but is should have been A.... (for the 4.x kernel)
    Updated the table!,
    Thx!!
    marceloaqno
    Code Contributor
    wrote on last edited by marceloaqno
    #55
    @Tag Does the TMRh20 works in the way your radio is currently connected?
    • M marceloaqno
      Tag
      wrote on last edited by Tag
      #56
      @marceloaqno
      The library compiled, but unfortunately i cannot get the examples for linux working.
      need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
      Maybe someone following this thread who has experince with this lib?
      if there is any progress from my side will keep you posted...
        mihai.aldea
        wrote on last edited by mihai.aldea
        #57
        If you used this wiring scheme:
        nRF24L01 | Orange Pi
        _________|________________
        VCC      | VCC3V3-EXT
        GND      | GND
        CSN      | SPI0_CS0 (SPI-CE0)
        CE       | PA7 (IO-7)
        MOSI     | SPI0_MOSI (SPI-MOSI)
        SCK      | SPI0_CLK (SPI-CLK)
        MISO     | SPI0_MISO (SPI-MISO)
        Then you should initialize the radio with:
        RF24 radio(7,0);
        Worked for me:
        root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
        RF24/examples/GettingStarted/
        STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
        RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
        RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
        TX_ADDR		 = 0x65646f4e32
        RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
        EN_AA		 = 0x3f
        EN_RXADDR	 = 0x02
        RF_CH		 = 0x4c
        RF_SETUP	 = 0x07
        CONFIG		 = 0x0e
        DYNPD/FEATURE	 = 0x00 0x00
        Data Rate	 = 1MBPS
        Model		 = nRF24L01+
        CRC Length	 = 16 bits
        PA Power	 = PA_MAX
         ************ Role Setup ***********
        Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
        M T 2 Replies Last reply
        • M mihai.aldea
          VCC      | VCC3V3-EXT
          GND      | GND
          CE       | PA7 (IO-7)
          RF24 radio(7,0);
          Worked for me:
          EN_AA		 = 0x3f
          EN_RXADDR	 = 0x02
          RF_CH		 = 0x4c
          RF_SETUP	 = 0x07
          CONFIG		 = 0x0e
          Data Rate	 = 1MBPS
          Model		 = nRF24L01+
          PA Power	 = PA_MAX
          marceloaqno
          Code Contributor
          @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
          #define MY_RF24_CE_PIN 7
          #define MY_RF24_CS_PIN 0
          • M mihai.aldea
            VCC      | VCC3V3-EXT
            GND      | GND
            CE       | PA7 (IO-7)
            RF24 radio(7,0);
            Worked for me:
            EN_AA		 = 0x3f
            EN_RXADDR	 = 0x02
            RF_CH		 = 0x4c
            RF_SETUP	 = 0x07
            CONFIG		 = 0x0e
            Data Rate	 = 1MBPS
            Model		 = nRF24L01+
            PA Power	 = PA_MAX
            Tag
            #59
            @mihai.aldea
            Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
            Expansion Port
            The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
            2x13 Header
            1	3.3V	           2	5V
            3	TWI0_SDA / PA12	   4	5V
            5	TWI0_SCK / PA11	   6	GND
            7	PWM1 / PA06	       8	UART1_TX / PG06
            9	GND	               10	UART1_RX / PG07
            11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
            13	UART2_TX / PA00	   14	GND
            15	UART2_CTS / PA03   16	TWI1-SDA / PA19
            17	3.3V	           18	TWI1-SCK / PA18
            19	SPI1_MOSI / PA15   20	GND
            21	SPI1_MISO / PA16   22	UART2_RTS / PA02
            23	SPI1_CLK / PA14    24	SPI1_CS / PA13
            25	GND	               26	SIM_DET/PA_EINT10 / PA10
            From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
            If i look at /dev I only see spi0, which is most probably used for the onboard flash...
            root@orangepizero:/# ll /dev | grep -i spi
            crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
            So now i need to figure out a way to get SPI1 up and running
            • M marceloaqno
              mihai.aldea
              @marceloaqno Here's the output:
              ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                               from ./MySensors.h:294,
                               from examples_linux/mysgw.cpp:77:
              compilation terminated.
                mihai.aldea
                @Tag Use this info:
                http://linux-sunxi.org/Sunxi-tools
                To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
                If you haven't done this before, it's quite simple.
                apt-get install sunxi-tools
                cd ~
                bin2fex /boot/script.bin > script.fex
                Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
                Then
                fex2bin script.fex > /boot/script.bin
                Reboot, then you should have the SPI1 active.
                • R
                  R
                  Reza
                  @marceloaqno
                  i have error yet
                  orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
                  • M mihai.aldea
                    @Tag Use this info:
                    cd ~
                    Then
                    Tag
                    #63
                    @mihai.aldea
                    Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
                    [update]
                    • modified the script file,
                    • changed spi_used = 1
                    • compiled back and rebooted
                    just 1 device file in called spidev0.0 no new device files are created..... :(
                    dmesg output:
                    [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                    [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                    [    0.815569] spi spi0: master is unqueued, this is deprecated
                    [    0.816776] spi spi1: master is unqueued, this is deprecated
                    Thx, will keep you posted!
                    • R Reza
                      @marceloaqno
                      i have error yet
                      marceloaqno
                      Code Contributor
                      @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
                      @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
                      M R 2 Replies Last reply
                      • M marceloaqno
                        mihai.aldea
                        Here it is
                        root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
                        [OK] init system detected: systemd
                        [OK] Finished.
                        root@opi-pc-1:~/rf24opi/MySensors# make
                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                        In file included from examples_linux/mysgw.cpp:77:0:
                        • M mihai.aldea
                          Here it is
                          [OK] Finished.
                          marceloaqno
                          Code Contributor
                          #66
                          @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
                          rm -rf marceloaqno-spidev
                          git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
                          cd marceloaqno-spidev
                          git checkout spidev
                          ./configure
                          make
                          • M marceloaqno
                            R
                            R
                            Reza
                            @marceloaqno
                            i have not any folder "gpio" in class folder .
                            what am i do ? :(
                            can you create a new topic with all steps after full fix on orange pi ?
                            thank you. i follow this topic
                              mihai.aldea
                              #68
                              @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
                              root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
                              Cloning into 'marceloaqno-spidev'...
                              fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
                              Anyway, I found another way:
                              git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                              cd marceloaqno-spidev/
                              git pull origin spidev
                              ./configure
                              make
                              This time it compiled successfuly, but when I fired up mysgw all I got was:
                              mysgw: Starting gateway...
                              with no other output.
                              Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
                              For reference here's the gpio readall on my OPi PC:
                               +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                               | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                               |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                               |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                               |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                               |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
                               |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
                               |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
                               |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
                               |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                               |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
                               |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                               |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
                               |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
                               |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
                               |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                               |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
                               |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
                               |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                               |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
                               |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                               |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
                               +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                              • M mihai.aldea
                                ./configure
                                make
                                Tag
                                #69
                                @mihai.aldea
                                Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
                                Look at mine:
                                root@orangepizero:~# gpio readall
                                 |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
                                 |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
                                 |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
                                 |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                                 |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                                 |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
                                 |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
                                 |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                                It is the same... and shows 40 pins while the OPI Zero only has 26.......
                                There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
                                • pansenP
                                  pansenP
                                  pansen
                                  @marceloaqno: are you planning to create a pull request? also, like @Reza suggested i think it would be smart to gather all information somehwhere, unfortunately mysensors does not seem to have a wiki. can we write an article somehow? i could take care of that.
                                  Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                                  • pansenP pansen
                                    marceloaqno
                                    Code Contributor
                                    #71
                                    @mihai.aldea sorry about the github link mistake.
                                    @pansen Yes, I will.
                                    Is the orientation of the pins correct in the image?
                                    • M marceloaqno
                                      Tag
                                      @marceloaqno
                                      Nope pinout is reversed!,
                                      The link below shows the correct one!
                                      https://oshlab.com/orange-pi-zero-pinout/
                                      • T Tag
                                        @marceloaqno
                                        marceloaqno
                                        Code Contributor
                                        #73
                                        @Tag Oops, did I get it right this time (I reuploaded the image)?
                                        • T
                                          Tag
                                          @marceloaqno
                                          Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... :( )
                                          Used the follwing to for the radio:
                                          RF24 radio(2,0);
                                          Output from gettingstarted:
                                          root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
                                          STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                                          RX_ADDR_P0-1     = 0x0000000000 0xff00000000
                                          RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
                                          TX_ADDR          = 0xffffffffff
                                          RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
                                          EN_AA            = 0xff
                                          EN_RXADDR        = 0xff
                                          RF_CH            = 0xbc
                                          RF_SETUP         = 0xff
                                          CONFIG           = 0xff
                                          DYNPD/FEATURE    = 0xff 0xff
                                          Data Rate        = 1MBPS
                                          Model            = nRF24L01
                                          PA Power         = PA_MAX
