  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.3k Views 11 Watching
  • R
    R
    Reza
    @marceloaqno
    i have error yet
    orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
    • M mihai.aldea
      @Tag Use this info:
      http://linux-sunxi.org/Sunxi-tools
      To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
      If you haven't done this before, it's quite simple.
      apt-get install sunxi-tools
      cd ~
      bin2fex /boot/script.bin > script.fex
      Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
      Then
      fex2bin script.fex > /boot/script.bin
      Reboot, then you should have the SPI1 active.
      Tag
      wrote on last edited by Tag
      #63
      @mihai.aldea
      Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
      [update]
      • modified the script file,
      • changed spi_used = 1
      • compiled back and rebooted
      just 1 device file in called spidev0.0 no new device files are created..... :(
      dmesg output:
      [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
      [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
      [    0.815569] spi spi0: master is unqueued, this is deprecated
      [    0.816776] spi spi1: master is unqueued, this is deprecated
      Thx, will keep you posted!
      • R Reza
        @marceloaqno
        i have error yet
        marceloaqno
        Code Contributor
        @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
        @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
        M R 2 Replies Last reply
        • M marceloaqno
          mihai.aldea
          Here it is
          root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
          [OK] init system detected: systemd
          [OK] Finished.
          root@opi-pc-1:~/rf24opi/MySensors# make
          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
          In file included from examples_linux/mysgw.cpp:77:0:
          ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                           from ./MySensors.h:294,
          compilation terminated.
          • M mihai.aldea
            Here it is
            [OK] Finished.
            marceloaqno
            Code Contributor
            wrote on last edited by marceloaqno
            #66
            @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
            rm -rf marceloaqno-spidev
            git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
            cd marceloaqno-spidev
            git checkout spidev
            ./configure
            make
            • M marceloaqno
              R
              R
              Reza
              @marceloaqno
              i have not any folder "gpio" in class folder .
              what am i do ? :(
              can you create a new topic with all steps after full fix on orange pi ?
              thank you. i follow this topic
                mihai.aldea
                wrote on last edited by mihai.aldea
                #68
                @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
                root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
                Cloning into 'marceloaqno-spidev'...
                fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
                Anyway, I found another way:
                git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                cd marceloaqno-spidev/
                git pull origin spidev
                ./configure
                make
                This time it compiled successfuly, but when I fired up mysgw all I got was:
                mysgw: Starting gateway...
                with no other output.
                Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
                For reference here's the gpio readall on my OPi PC:
                 +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                 | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                 |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                 |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                 |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                 |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
                 |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
                 |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
                 |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
                 |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                 |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
                 |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                 |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
                 |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
                 |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
                 |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                 |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
                 |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
                 |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                 |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
                 |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                 |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
                 +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                • M mihai.aldea
                  ./configure
                  make
                  Tag
                  #69
                  @mihai.aldea
                  Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
                  Look at mine:
                  root@orangepizero:~# gpio readall
                   |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
                   |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
                   |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
                   |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                   |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                   |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
                   |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
                   |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                  It is the same... and shows 40 pins while the OPI Zero only has 26.......
                  There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
                  • pansenP
                    pansenP
                    pansen
                    @marceloaqno: are you planning to create a pull request? also, like @Reza suggested i think it would be smart to gather all information somehwhere, unfortunately mysensors does not seem to have a wiki. can we write an article somehow? i could take care of that.
                    Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                    • pansenP pansen
                      marceloaqno
                      Code Contributor
                      #71
                      @mihai.aldea sorry about the github link mistake.
                      @pansen Yes, I will.
                      Is the orientation of the pins correct in the image?
                      • M marceloaqno
                        Tag
                        @marceloaqno
                        Nope pinout is reversed!,
                        The link below shows the correct one!
                        https://oshlab.com/orange-pi-zero-pinout/
                        • T Tag
                          @marceloaqno
                          marceloaqno
                          Code Contributor
                          #73
                          @Tag Oops, did I get it right this time (I reuploaded the image)?
                          • T
                            Tag
                            @marceloaqno
                            Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... :( )
                            Used the follwing to for the radio:
                            RF24 radio(2,0);
                            Output from gettingstarted:
                            root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
                            RF24/examples/GettingStarted/
                            STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                            RX_ADDR_P0-1     = 0x0000000000 0xff00000000
                            RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
                            TX_ADDR          = 0xffffffffff
                            RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
                            EN_AA            = 0xff
                            EN_RXADDR        = 0xff
                            RF_CH            = 0xbc
                            RF_SETUP         = 0xff
                            CONFIG           = 0xff
                            DYNPD/FEATURE    = 0xff 0xff
                            Data Rate        = 1MBPS
                            Model            = nRF24L01
                            CRC Length       = 16 bits
                            PA Power         = PA_MAX
                             ************ Role Setup ***********
                            Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
                            • T Tag
                              @marceloaqno
                              RF24 radio(2,0);
                              EN_AA            = 0xff
                              EN_RXADDR        = 0xff
                              RF_CH            = 0xbc
                              RF_SETUP         = 0xff
                              CONFIG           = 0xff
                              Data Rate        = 1MBPS
                              Model            = nRF24L01
                              PA Power         = PA_MAX
                              marceloaqno
                              Code Contributor
                              #75
                              @Tag Could you fill this table with your current setup?
                              nRF24L01 | OrangePi  | OrangePi
                                       | phyPin    | GPIO
                              _________|_______________________
                              VCC      | 3V3-PWR   | 3V3-PWR
                              GND      | GND       | GND
                              CSN      |           |
                              CE       |           |
                              MOSI     | 19        | 15
                              SCK      | 23        | 14
                              MISO     | 21        | 16
                              • M marceloaqno
                                         | phyPin    | GPIO
                                GND      | GND       | GND
                                CSN      |           |
                                CE       |           |
                                MOSI     | 19        | 15
                                SCK      | 23        | 14
                                MISO     | 21        | 16
                                Tag
                                @marceloaqno
                                Sure here it is,
                                         | phyPin    | GPIO
                                GND      | GND       | GND
                                CSN      | 24        | 13
                                CE       | 22        | 2
                                MOSI     | 19        | 15
                                SCK      | 23        | 14
                                MISO     | 21        | 16
                                Radio seems to be recognised, still need to test data transfer...
                                • T Tag
                                  @marceloaqno
                                  Sure here it is,
                                           | phyPin    | GPIO
                                  GND      | GND       | GND
                                  CSN      | 24        | 13
                                  CE       | 22        | 2
                                  MOSI     | 19        | 15
                                  SCK      | 23        | 14
                                  MISO     | 21        | 16
                                  marceloaqno
                                  Code Contributor
                                  #77
                                  I created the draft for the official article: https://www.mysensors.org/build/orange
                                  mfalkviddM T R 3 Replies Last reply
                                  • M marceloaqno
                                    @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
                                    jirmJ 1 Reply Last reply
                                      jirmJ
                                      jirmJ
                                      jirm
                                      wrote on last edited by jirm
                                      #79
                                      @marceloaqno
                                      @mfalkvidd @Tag @pansen @Reza @mihai.aldea @hausinger
                                      Wooow woow woow !!!
                                      Only few days "off" and the problem to make work Mysensors on OPI are solved.
                                      So many many thanks to all people here that have been involved to make that OPI good little boards can work with Mysensors.
                                      This is the proof that when good people join can reach the most difficult achievements and all humanity can benefit.
                                      Awesome work !
                                      Regards
                                      • M marceloaqno
                                        Tag
                                        #80
                                        @marceloaqno
                                        Great work!!! the GPIO part most probably needs some additions for OPI zero on the topic of the spidev1.0 driver and the GPIO pins, send it to you once i got everything documented.
                                        Really many thanks for your hard work here!!
                                        • R
                                          R
                                          Reza
