  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T
    Tag
    wrote on last edited by Tag
    #50
    @marceloaqno
    Did some testing,
    Setup the GPIO pins:
    modprobe gpio-sunxi
    for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
    do echo "$A" > /sys/class/gpio/export
    done
    (The device files that are created by the commands above do not survive a reboot, so remember to execute the above commands after each reboot!)
    Hooked up an led between ground and i.e. pin 22, this pin is linked to GPIO2
    Then:
    echo out > /sys/class/gpio/gpio2/direction
    echo 1 > /sys/class/gpio/gpio2/value
    echo 0 > /sys/class/gpio/gpio2/value
    And eureka!! Led went on and off :D
    Did this for all GPIO ports used by mysgw, below is the verified pin / GPIO table
    Pin#  -  GPIO / NRF24
    22 - GPIO2   / CE
    23 - GPIO14  / SCK
    21 - GPIO16  / MISO
    24 - GPIO13  / CSN
    19 - GPIO15  / MOSI
    Tested all pins and led went on and off on all
    How i connected the radio: https://www.mysensors.org/build/raspberry (see the Pi1 part)
    How to setup GPIO: http://linux-sunxi.org/GPIO (3.x kernel part, and added pin 13/14/15/16)
    Pinout for the OPI Zero: https://i1.wp.com/oshlab.com/wp-content/uploads/2016/11/Orange-Pi-Zero-Pinout-banner2.jpg?fit=1200%2C628&ssl=1 (carefully look at the pin numbering!)
    Maybe it is usefull, I rebuild mysgw with NRF24 radio debugging enabled, this is the output I get:
    root@orangepizero:~/marceloaqno-spidev/bin# ./mysgw -d
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: RF24:write register, reg=0, value=14
    mysgw: RF24:write register, reg=3, value=3
    mysgw: RF24:write register, reg=4, value=95
    mysgw: RF24:write register, reg=5, value=76
    mysgw: RF24:write register, reg=6, value=39
    mysgw: RF24:write register, reg=16, value=115
    mysgw: RF24:write register, reg=29, value=6
    mysgw: RF24:read register, reg=6, value=0
    mysgw: RF24:read register, reg=5, value=0
    mysgw: !RF24:INIT:SANCHK FAIL
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: RF24:write register, reg=0, value=12
    mysgw: RF24:PD
    ^Cmysgw: Received SIGINT
    keeps looping, until ctrl-c is given.
    • T Tag
      @marceloaqno
      Hi!!, many thanks for the info!! really helpful!
      Made some progress. first I created this table based on this page: http://linux-sunxi.org/GPIO
      Pin - Num - Name - Calculated value A=1 ((1-1)*32 + Pin)
      CE / 22 / PA02 / 2
      SCK / 23 / PA14 / 14
      MISO / 21 / PA16 / 16
      CSN / 24 / PA13 / 13
      MOSI / 19 / PA15 / 15
      Now it is important that you know which kernel is used on your systems the 4.x architecture is different compared to the 3.x arch...
      If the 4.x kernel is used you need to use the calculated value for the GPIO pin numbering, i could not test that since I am using the 3.x kernel, so this is what i did:
      1. load the GPIO kernel module:
      modprobe gpio-sunxi
      1. Create the GPIO device files since these were not available on my system by default.
      for A in 1 2 3 4 5 6 7 8 9 10 11 12; do echo "$A" > /sys/class/gpio/export ; done
      This created the following entries in /sys/class/gpio
      root@orangepizero:~/marceloaqno-spidev/bin# ls -l /sys/class/gpio
      total 0
      --w------- 1 root root 4096 Jan  8 07:39 export
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio1 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio1
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio11 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio11
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio12 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio12
      lrwxrwxrwx 1 root root    0 Jan  8 07:32 gpio13 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio13
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio2 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio2
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio3 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio3
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio4 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio4
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio5 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio5
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio6 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio6
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio7 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio7
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio8 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio8
      lrwxrwxrwx 1 root root    0 Jan  8 07:16 gpio9 -> ../../devices/platform/sunxi-pinctrl/gpio/gpio9
      lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip0 -> ../../devices/platform/sunxi-pinctrl/gpio/gpiochip0
      --w------- 1 root root 4096 Jan  1  1970 unexport
      Modified mysgw.cpp to use:
      #define MY_RF24_CE_PIN 2
      #define MY_RF24_CS_PIN 13
      And did a clean build:
      make clean
      ./configure
      make
      Now some thing has changed! :)
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FAIL:PDT
      Will do some more testing with an LED today see if the GPIO pin numbering that was created is okay,
      will keep you posted!:
      mihai.aldea
      CE / 22 / PA02 / 482
      SCK / 23 / PA14 / 494
      MISO / 21 / PA16 / 496
      CSN / 24 / PA13 / 493
      MOSI / 19 / PA15 / 495
      Are you sure this is correct?
      The formula is: (position of letter in alphabet - 1) * 32 + pin number
      For PA02 for instance the correct value is:
      PA02 = (1 - 1) * 32 + 02 = 2
      Actually you don't need to use the formula at all with the PA ports, all you have to do is use the trailing number.
      • M mihai.aldea
        Tag
        @mihai.aldea
        You are right, took the letter P, which is 16.... but is should have been A.... (for the 4.x kernel)
        Updated the table!,
        Thx!!
        • R
          R
          Reza
          wrote on last edited by Reza
          #53
          i have problem in build gateway on orangepi one
          root@OrangePI:~/marceloaqno-spidev# make
          Makefile:16: Makefile.inc: No such file or directory
          [Running configure]
          [OK] Finished.
          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
          g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
          g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
          drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
          drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
             (void)read (fd, &c, 1) ;
          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
          In file included from ./MySensors.h:294:0,
                           from examples_linux/mysgw.cpp:74:
          ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
            hwDigitalWrite(MY_RF24_CS_PIN, level);
          ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
            hwDigitalWrite(MY_RF24_CE_PIN, level);
          ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
            hwPinMode(MY_RF24_CE_PIN,OUTPUT);
          ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
            hwPinMode(MY_RF24_CS_PIN,OUTPUT);
          ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
           LOCAL void RF24_csn(const bool level)
          ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
           LOCAL void RF24_ce(const bool level)
          ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
          ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
            RF24_csn(LOW);
          ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
            RF24_csn(HIGH);
          ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
          ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
            RF24_ce(HIGH);
          ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
          ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
          ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
          ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
            RF24_ce(HIGH);
          ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
          ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
            RF24_ce(LOW);
          ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
            RF24_csn(HIGH);
          Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
          i want build a gateway with orangepi one with channel 0 . what am i do ? thank you
          • R Reza
            [Running configure]
            [OK] Finished.
              RF24_csn(LOW);
              RF24_csn(HIGH);
              RF24_ce(HIGH);
              RF24_ce(LOW);
              RF24_ce(LOW);
              RF24_ce(HIGH);
              RF24_ce(LOW);
              RF24_ce(LOW);
              RF24_csn(HIGH);
            marceloaqno
            Code Contributor
            @Reza You need to run:
            modprobe gpio-sunxi
            so that /sys/class/gpio/export is created.
            • T Tag
              @mihai.aldea
              Updated the table!,
              Thx!!
              marceloaqno
              Code Contributor
              wrote on last edited by marceloaqno
              #55
              @Tag Does the TMRh20 works in the way your radio is currently connected?
              • M marceloaqno
                Tag
                #56
                @marceloaqno
                The library compiled, but unfortunately i cannot get the examples for linux working.
                need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
                Maybe someone following this thread who has experince with this lib?
                if there is any progress from my side will keep you posted...
                  mihai.aldea
                  wrote on last edited by mihai.aldea
                  #57
                  If you used this wiring scheme:
                  nRF24L01 | Orange Pi
                  _________|________________
                  VCC      | VCC3V3-EXT
                  GND      | GND
                  CSN      | SPI0_CS0 (SPI-CE0)
                  CE       | PA7 (IO-7)
                  MOSI     | SPI0_MOSI (SPI-MOSI)
                  SCK      | SPI0_CLK (SPI-CLK)
                  MISO     | SPI0_MISO (SPI-MISO)
                  Then you should initialize the radio with:
                  RF24 radio(7,0);
                  Worked for me:
                  root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
                  RF24/examples/GettingStarted/
                  STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                  RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
                  RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
                  TX_ADDR		 = 0x65646f4e32
                  RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
                  EN_AA		 = 0x3f
                  EN_RXADDR	 = 0x02
                  RF_CH		 = 0x4c
                  RF_SETUP	 = 0x07
                  CONFIG		 = 0x0e
                  DYNPD/FEATURE	 = 0x00 0x00
                  Data Rate	 = 1MBPS
                  Model		 = nRF24L01+
                  CRC Length	 = 16 bits
                  PA Power	 = PA_MAX
                   ************ Role Setup ***********
                  Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
                  M T 2 Replies Last reply
                  • M mihai.aldea
                    VCC      | VCC3V3-EXT
                    GND      | GND
                    CE       | PA7 (IO-7)
                    RF24 radio(7,0);
                    Worked for me:
                    EN_AA		 = 0x3f
                    EN_RXADDR	 = 0x02
                    RF_CH		 = 0x4c
                    RF_SETUP	 = 0x07
                    CONFIG		 = 0x0e
                    Data Rate	 = 1MBPS
                    Model		 = nRF24L01+
                    PA Power	 = PA_MAX
                    marceloaqno
                    Code Contributor
                    @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
                    #define MY_RF24_CE_PIN 7
                    #define MY_RF24_CS_PIN 0
                    • M mihai.aldea
                      VCC      | VCC3V3-EXT
                      GND      | GND
                      CE       | PA7 (IO-7)
                      RF24 radio(7,0);
                      Worked for me:
                      EN_AA		 = 0x3f
                      EN_RXADDR	 = 0x02
                      RF_CH		 = 0x4c
                      RF_SETUP	 = 0x07
                      CONFIG		 = 0x0e
                      Data Rate	 = 1MBPS
                      Model		 = nRF24L01+
                      PA Power	 = PA_MAX
                      Tag
                      #59
                      @mihai.aldea
                      Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
                      Expansion Port
                      The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
                      2x13 Header
                      1	3.3V	           2	5V
                      3	TWI0_SDA / PA12	   4	5V
                      5	TWI0_SCK / PA11	   6	GND
                      7	PWM1 / PA06	       8	UART1_TX / PG06
                      9	GND	               10	UART1_RX / PG07
                      11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
                      13	UART2_TX / PA00	   14	GND
                      15	UART2_CTS / PA03   16	TWI1-SDA / PA19
                      17	3.3V	           18	TWI1-SCK / PA18
                      19	SPI1_MOSI / PA15   20	GND
                      21	SPI1_MISO / PA16   22	UART2_RTS / PA02
                      23	SPI1_CLK / PA14    24	SPI1_CS / PA13
                      25	GND	               26	SIM_DET/PA_EINT10 / PA10
                      From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
                      If i look at /dev I only see spi0, which is most probably used for the onboard flash...
                      root@orangepizero:/# ll /dev | grep -i spi
                      crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
                      So now i need to figure out a way to get SPI1 up and running
                      • M marceloaqno
                        mihai.aldea
                        @marceloaqno Here's the output:
                        ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                         from ./MySensors.h:294,
                                         from examples_linux/mysgw.cpp:77:
                        compilation terminated.
                          mihai.aldea
                          @Tag Use this info:
                          http://linux-sunxi.org/Sunxi-tools
                          To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
                          If you haven't done this before, it's quite simple.
                          apt-get install sunxi-tools
                          cd ~
                          bin2fex /boot/script.bin > script.fex
                          Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
                          Then
                          fex2bin script.fex > /boot/script.bin
                          Reboot, then you should have the SPI1 active.
                          • R
                            R
                            Reza
                            @marceloaqno
                            i have error yet
                            orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
                            • M mihai.aldea
                              @Tag Use this info:
                              cd ~
                              Then
                              Tag
                              #63
                              @mihai.aldea
                              Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
                              [update]
                              • modified the script file,
                              • changed spi_used = 1
                              • compiled back and rebooted
                              just 1 device file in called spidev0.0 no new device files are created..... :(
                              dmesg output:
                              [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                              [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                              [    0.815569] spi spi0: master is unqueued, this is deprecated
                              [    0.816776] spi spi1: master is unqueued, this is deprecated
                              Thx, will keep you posted!
                              • R Reza
                                @marceloaqno
                                i have error yet
                                marceloaqno
                                Code Contributor
                                @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
                                @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
                                M R 2 Replies Last reply
                                • M marceloaqno
                                  mihai.aldea
                                  Here it is
                                  root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
                                  [OK] Finished.
                                  root@opi-pc-1:~/rf24opi/MySensors# make
                                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                  g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                  g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                  g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                  g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                  g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                  g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                  g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                  g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                  g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                  g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                  In file included from examples_linux/mysgw.cpp:77:0:
                                  • M mihai.aldea
                                    Here it is
                                    [OK] Finished.
                                    marceloaqno
                                    Code Contributor
                                    #66
                                    @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
                                    rm -rf marceloaqno-spidev
                                    git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
                                    cd marceloaqno-spidev
                                    git checkout spidev
                                    ./configure
                                    make
                                    • M marceloaqno
                                      R
                                      R
                                      Reza
                                      @marceloaqno
                                      i have not any folder "gpio" in class folder .
                                      what am i do ? :(
                                      can you create a new topic with all steps after full fix on orange pi ?
                                      thank you. i follow this topic
                                        mihai.aldea
                                        #68
                                        @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
                                        root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
                                        Cloning into 'marceloaqno-spidev'...
                                        fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
                                        Anyway, I found another way:
                                        git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                                        cd marceloaqno-spidev/
                                        git pull origin spidev
                                        ./configure
                                        make
                                        This time it compiled successfuly, but when I fired up mysgw all I got was:
                                        with no other output.
                                        Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
                                        For reference here's the gpio readall on my OPi PC:
                                         +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                                         | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                                         |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                                         |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                                         |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                                         |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
                                         |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
                                         |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
                                         |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
                                         |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                                         |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
                                         |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                                         |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
                                         |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
                                         |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
                                         |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                                         |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
                                         |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
                                         |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                                         |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
                                         |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                                         |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
                                         +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                                        • M mihai.aldea
                                          ./configure
                                          make
                                          Tag
                                          #69
                                          @mihai.aldea
                                          Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
                                          Look at mine:
                                          root@orangepizero:~# gpio readall
                                           |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
                                           |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
                                           |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
                                           |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                                           |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                                           |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
                                           |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
                                           |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                                          It is the same... and shows 40 pins while the OPI Zero only has 26.......
                                          There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
