  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • M mihai.aldea
    If you used this wiring scheme:
    nRF24L01 | Orange Pi
    _________|________________
    VCC      | VCC3V3-EXT
    GND      | GND
    CSN      | SPI0_CS0 (SPI-CE0)
    CE       | PA7 (IO-7)
    MOSI     | SPI0_MOSI (SPI-MOSI)
    SCK      | SPI0_CLK (SPI-CLK)
    MISO     | SPI0_MISO (SPI-MISO)
    Then you should initialize the radio with:
    RF24 radio(7,0);
    Worked for me:
    root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
    RF24/examples/GettingStarted/
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
    RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
    TX_ADDR		 = 0x65646f4e32
    RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
    EN_AA		 = 0x3f
    EN_RXADDR	 = 0x02
    RF_CH		 = 0x4c
    RF_SETUP	 = 0x07
    CONFIG		 = 0x0e
    DYNPD/FEATURE	 = 0x00 0x00
    Data Rate	 = 1MBPS
    Model		 = nRF24L01+
    CRC Length	 = 16 bits
    PA Power	 = PA_MAX
     ************ Role Setup ***********
    Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
    Tag
    wrote on last edited by Tag
    #59
    @mihai.aldea
    Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
    Expansion Port
    The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
    2x13 Header
    1	3.3V	           2	5V
    3	TWI0_SDA / PA12	   4	5V
    5	TWI0_SCK / PA11	   6	GND
    7	PWM1 / PA06	       8	UART1_TX / PG06
    9	GND	               10	UART1_RX / PG07
    11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
    13	UART2_TX / PA00	   14	GND
    15	UART2_CTS / PA03   16	TWI1-SDA / PA19
    17	3.3V	           18	TWI1-SCK / PA18
    19	SPI1_MOSI / PA15   20	GND
    21	SPI1_MISO / PA16   22	UART2_RTS / PA02
    23	SPI1_CLK / PA14    24	SPI1_CS / PA13
    25	GND	               26	SIM_DET/PA_EINT10 / PA10
    From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
    If i look at /dev I only see spi0, which is most probably used for the onboard flash...
    root@orangepizero:/# ll /dev | grep -i spi
    crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
    So now i need to figure out a way to get SPI1 up and running
    • M marceloaqno
      @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
      #define MY_RF24_CE_PIN 7
      #define MY_RF24_CS_PIN 0
      mihai.aldea
      @marceloaqno Here's the output:
      ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                       from ./MySensors.h:294,
                       from examples_linux/mysgw.cpp:77:
      compilation terminated.
        mihai.aldea
        @Tag Use this info:
        http://linux-sunxi.org/Sunxi-tools
        To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
        If you haven't done this before, it's quite simple.
        apt-get install sunxi-tools
        cd ~
        bin2fex /boot/script.bin > script.fex
        Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
        Then
        fex2bin script.fex > /boot/script.bin
        Reboot, then you should have the SPI1 active.
        • R
          R
          Reza
          @marceloaqno
          i have error yet
          orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
          • M mihai.aldea
            @Tag Use this info:
            cd ~
            Then
            Tag
            #63
            @mihai.aldea
            Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
            [update]
            • modified the script file,
            • changed spi_used = 1
            • compiled back and rebooted
            just 1 device file in called spidev0.0 no new device files are created..... :(
            dmesg output:
            [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
            [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
            [    0.815569] spi spi0: master is unqueued, this is deprecated
            [    0.816776] spi spi1: master is unqueued, this is deprecated
            Thx, will keep you posted!
            • R Reza
              @marceloaqno
              i have error yet
              marceloaqno
              Code Contributor
              @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
              @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
              M R 2 Replies Last reply
              • M marceloaqno
                mihai.aldea
                Here it is
                root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
                [OK] init system detected: systemd
                [OK] Finished.
                root@opi-pc-1:~/rf24opi/MySensors# make
                gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                In file included from examples_linux/mysgw.cpp:77:0:
                • M mihai.aldea
                  Here it is
                  [OK] Finished.
                  marceloaqno
                  Code Contributor
                  wrote on last edited by marceloaqno
                  #66
                  @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
                  rm -rf marceloaqno-spidev
                  git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
                  cd marceloaqno-spidev
                  git checkout spidev
                  ./configure
                  make
                  • M marceloaqno
                    R
                    R
                    Reza
                    @marceloaqno
                    i have not any folder "gpio" in class folder .
                    what am i do ? :(
                    can you create a new topic with all steps after full fix on orange pi ?
                    thank you. i follow this topic
                      mihai.aldea
                      wrote on last edited by mihai.aldea
                      #68
                      @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
                      root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
                      Cloning into 'marceloaqno-spidev'...
                      fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
                      Anyway, I found another way:
                      git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                      cd marceloaqno-spidev/
                      git pull origin spidev
                      ./configure
                      make
                      This time it compiled successfuly, but when I fired up mysgw all I got was:
                      mysgw: Starting gateway...
                      with no other output.
                      Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
                      For reference here's the gpio readall on my OPi PC:
                       +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                       | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                       |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                       |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                       |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                       |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
                       |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
                       |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
                       |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
                       |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                       |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
                       |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                       |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
                       |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
                       |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
                       |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                       |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
                       |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
                       |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                       |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
                       |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                       |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
                       +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                      • M mihai.aldea
                        ./configure
                        make
                        Tag
                        #69
                        @mihai.aldea
                        Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
                        Look at mine:
                        root@orangepizero:~# gpio readall
                         |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
                         |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
                         |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
                         |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                         |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                         |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
                         |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
                         |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                        It is the same... and shows 40 pins while the OPI Zero only has 26.......
                        There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
                        • pansenP
                          pansenP
                          pansen
                          @marceloaqno: are you planning to create a pull request? also, like @Reza suggested i think it would be smart to gather all information somehwhere, unfortunately mysensors does not seem to have a wiki. can we write an article somehow? i could take care of that.
                          Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                          • pansenP pansen
                            marceloaqno
                            Code Contributor
                            #71
                            @mihai.aldea sorry about the github link mistake.
                            @pansen Yes, I will.
                            Is the orientation of the pins correct in the image?
                            • M marceloaqno
                              Tag
                              @marceloaqno
                              Nope pinout is reversed!,
                              The link below shows the correct one!
                              https://oshlab.com/orange-pi-zero-pinout/
                              • T Tag
                                @marceloaqno
                                marceloaqno
                                Code Contributor
                                #73
                                @Tag Oops, did I get it right this time (I reuploaded the image)?
                                • T
                                  Tag
                                  @marceloaqno
                                  Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... :( )
                                  Used the follwing to for the radio:
                                  RF24 radio(2,0);
                                  Output from gettingstarted:
                                  root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
                                  STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                                  RX_ADDR_P0-1     = 0x0000000000 0xff00000000
                                  RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
                                  TX_ADDR          = 0xffffffffff
                                  RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
                                  EN_AA            = 0xff
                                  EN_RXADDR        = 0xff
                                  RF_CH            = 0xbc
                                  RF_SETUP         = 0xff
                                  CONFIG           = 0xff
                                  DYNPD/FEATURE    = 0xff 0xff
                                  Data Rate        = 1MBPS
                                  Model            = nRF24L01
                                  PA Power         = PA_MAX
                                  • T Tag
                                    @marceloaqno
                                    RF24 radio(2,0);
                                    EN_AA            = 0xff
                                    EN_RXADDR        = 0xff
                                    RF_CH            = 0xbc
                                    RF_SETUP         = 0xff
                                    CONFIG           = 0xff
                                    Data Rate        = 1MBPS
                                    Model            = nRF24L01
                                    PA Power         = PA_MAX
                                    marceloaqno
                                    Code Contributor
                                    #75
                                    @Tag Could you fill this table with your current setup?
                                    nRF24L01 | OrangePi  | OrangePi
                                             | phyPin    | GPIO
                                    _________|_______________________
                                    VCC      | 3V3-PWR   | 3V3-PWR
                                    GND      | GND       | GND
                                    CSN      |           |
                                    CE       |           |
                                    MOSI     | 19        | 15
                                    SCK      | 23        | 14
                                    MISO     | 21        | 16
                                    • M marceloaqno
                                               | phyPin    | GPIO
                                      GND      | GND       | GND
                                      CSN      |           |
                                      CE       |           |
                                      MOSI     | 19        | 15
                                      SCK      | 23        | 14
                                      MISO     | 21        | 16
                                      Tag
                                      @marceloaqno
                                      Sure here it is,
                                               | phyPin    | GPIO
                                      GND      | GND       | GND
                                      CSN      | 24        | 13
                                      CE       | 22        | 2
                                      MOSI     | 19        | 15
                                      SCK      | 23        | 14
                                      MISO     | 21        | 16
                                      Radio seems to be recognised, still need to test data transfer...
                                      • T Tag
                                        @marceloaqno
                                        Sure here it is,
                                                 | phyPin    | GPIO
                                        GND      | GND       | GND
                                        CSN      | 24        | 13
                                        CE       | 22        | 2
                                        MOSI     | 19        | 15
                                        SCK      | 23        | 14
                                        MISO     | 21        | 16
                                        marceloaqno
                                        Code Contributor
                                        #77
                                        I created the draft for the official article: https://www.mysensors.org/build/orange
                                        mfalkviddM T R 3 Replies Last reply
                                        • M marceloaqno
                                          @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
                                          jirmJ 1 Reply Last reply
