  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • M marceloaqno
    @Tag Does the TMRh20 works in the way your radio is currently connected?
    Tag
    wrote on last edited by Tag
    #56
    @marceloaqno
    The library compiled, but unfortunately i cannot get the examples for linux working.
    need to edit i.e. gettingstarted.cpp with the correct pin setting, have tried a lot, but either it says that the radio is not connected, and if used with incorrect settings it will not compile at all....
    Maybe someone following this thread who has experince with this lib?
    if there is any progress from my side will keep you posted...
      mihai.aldea
      wrote on last edited by mihai.aldea
      #57
      If you used this wiring scheme:
      nRF24L01 | Orange Pi
      _________|________________
      VCC      | VCC3V3-EXT
      GND      | GND
      CSN      | SPI0_CS0 (SPI-CE0)
      CE       | PA7 (IO-7)
      MOSI     | SPI0_MOSI (SPI-MOSI)
      SCK      | SPI0_CLK (SPI-CLK)
      MISO     | SPI0_MISO (SPI-MISO)
      Then you should initialize the radio with:
      RF24 radio(7,0);
      Worked for me:
      root@opi-pc-1:~/RF24-master/examples_linux# ./gettingstarted
      RF24/examples/GettingStarted/
      STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1	 = 0x65646f4e32 0x65646f4e31
      RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
      TX_ADDR		 = 0x65646f4e32
      RX_PW_P0-6	 = 0x20 0x20 0x00 0x00 0x00 0x00
      EN_AA		 = 0x3f
      EN_RXADDR	 = 0x02
      RF_CH		 = 0x4c
      RF_SETUP	 = 0x07
      CONFIG		 = 0x0e
      DYNPD/FEATURE	 = 0x00 0x00
      Data Rate	 = 1MBPS
      Model		 = nRF24L01+
      CRC Length	 = 16 bits
      PA Power	 = PA_MAX
       ************ Role Setup ***********
      Choose a role: Enter 0 for pong_back, 1 for ping_out (CTRL+C to exit)
      M T 2 Replies Last reply
      • M mihai.aldea
        VCC      | VCC3V3-EXT
        GND      | GND
        CE       | PA7 (IO-7)
        RF24 radio(7,0);
        Worked for me:
        EN_AA		 = 0x3f
        EN_RXADDR	 = 0x02
        RF_CH		 = 0x4c
        RF_SETUP	 = 0x07
        CONFIG		 = 0x0e
        Data Rate	 = 1MBPS
        Model		 = nRF24L01+
        PA Power	 = PA_MAX
        marceloaqno
        Code Contributor
        @mihai.aldea Could you try the repo I'm working on (https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev) adding your settings to the examples_linux/mysgw.cpp?
        #define MY_RF24_CE_PIN 7
        #define MY_RF24_CS_PIN 0
        • M mihai.aldea
          VCC      | VCC3V3-EXT
          GND      | GND
          CE       | PA7 (IO-7)
          RF24 radio(7,0);
          Worked for me:
          EN_AA		 = 0x3f
          EN_RXADDR	 = 0x02
          RF_CH		 = 0x4c
          RF_SETUP	 = 0x07
          CONFIG		 = 0x0e
          Data Rate	 = 1MBPS
          Model		 = nRF24L01+
          PA Power	 = PA_MAX
          Tag
          #59
          @mihai.aldea
          Hmmm.... checked the docs again and guess what. the 26 pin header on the OPI Zero has SPI1.... instead of SPI0
          Expansion Port
          The Orange Pi Zero has a 26-pin, 0.1" unpopulated connector with several low-speed interfaces.
          2x13 Header
          1	3.3V	           2	5V
          3	TWI0_SDA / PA12	   4	5V
          5	TWI0_SCK / PA11	   6	GND
          7	PWM1 / PA06	       8	UART1_TX / PG06
          9	GND	               10	UART1_RX / PG07
          11	UART2_RX / PA01	   12	SIM_CLK/PA_EINT7 / PA07
          13	UART2_TX / PA00	   14	GND
          15	UART2_CTS / PA03   16	TWI1-SDA / PA19
          17	3.3V	           18	TWI1-SCK / PA18
          19	SPI1_MOSI / PA15   20	GND
          21	SPI1_MISO / PA16   22	UART2_RTS / PA02
          23	SPI1_CLK / PA14    24	SPI1_CS / PA13
          25	GND	               26	SIM_DET/PA_EINT10 / PA10
          From http://linux-sunxi.org/Xunlong_Orange_Pi_Zero
          If i look at /dev I only see spi0, which is most probably used for the onboard flash...
          root@orangepizero:/# ll /dev | grep -i spi
          crw------- 1 root root    153,   0 Jan  8 11:12 spidev0.0
          So now i need to figure out a way to get SPI1 up and running
          • M marceloaqno
            mihai.aldea
            @marceloaqno Here's the output:
            ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                             from ./MySensors.h:294,
                             from examples_linux/mysgw.cpp:77:
            compilation terminated.
              mihai.aldea
              @Tag Use this info:
              http://linux-sunxi.org/Sunxi-tools
              To export /boot/script.bin, edit the output file and enable SPI1, then compile it back and reboot your OPi with the SPI1 active.
              If you haven't done this before, it's quite simple.
              apt-get install sunxi-tools
              cd ~
              bin2fex /boot/script.bin > script.fex
              Edit the script.fex file, find the [spi1] section and change spi_used = 0 to spi_used = 1. Save the file and exit.
              Then
              fex2bin script.fex > /boot/script.bin
              Reboot, then you should have the SPI1 active.
              • R
                R
                Reza
                @marceloaqno
                i have error yet
                orangepi is a good board. please work at this board and run mysensors gateway on this, i follow this topic when you can fix this on orange pi . thank you
                • M mihai.aldea
                  @Tag Use this info:
                  cd ~
                  Then
                  Tag
                  #63
                  @mihai.aldea
                  Yep already found it :) problem was the old version of the tools, it was not able to decompile the script.bin file...
                  [update]
                  • modified the script file,
                  • changed spi_used = 1
                  • compiled back and rebooted
                  just 1 device file in called spidev0.0 no new device files are created..... :(
                  dmesg output:
                  [    0.814287] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                  [    0.814316] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                  [    0.815569] spi spi0: master is unqueued, this is deprecated
                  [    0.816776] spi spi1: master is unqueued, this is deprecated
                  Thx, will keep you posted!
                  • R Reza
                    @marceloaqno
                    i have error yet
                    marceloaqno
                    Code Contributor
                    @Reza Was /sys/class/gpio/export created after modprobe gpio-sunxi?
                    @mihai-aldea Could you send the complete make and configure output so I can check if your system is correctly detected?
                    M R 2 Replies Last reply
                    • M marceloaqno
                      mihai.aldea
                      Here it is
                      root@opi-pc-1:~/rf24opi/MySensors# ./configure --soc=H3
                      [OK] init system detected: systemd
                      [OK] Finished.
                      root@opi-pc-1:~/rf24opi/MySensors# make
                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                      In file included from examples_linux/mysgw.cpp:77:0:
                      • M mihai.aldea
                        Here it is
                        [OK] Finished.
                        marceloaqno
                        Code Contributor
                        wrote on last edited by marceloaqno
                        #66
                        @mihai.aldea I think you're not in the right branch, could you start from scratch like this:
                        rm -rf marceloaqno-spidev
                        git clone https://github.com/marceloaqno/MySensors marceloaqno-spidev
                        cd marceloaqno-spidev
                        git checkout spidev
                        ./configure
                        make
                        • M marceloaqno
                          R
                          R
                          Reza
                          @marceloaqno
                          i have not any folder "gpio" in class folder .
                          what am i do ? :(
                          can you create a new topic with all steps after full fix on orange pi ?
                          thank you. i follow this topic
                            mihai.aldea
                            #68
                            @marceloaqno You were right, I wasn't using the correct branch. Your instructions though did not work for me
                            root@opi-pc-1:~# git clone https://github.com/marceloaqno/MySensors/tree/spidev marceloaqno-spidev
                            Cloning into 'marceloaqno-spidev'...
                            fatal: repository 'https://github.com/marceloaqno/MySensors/tree/spidev/' not found
                            Anyway, I found another way:
                            git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                            cd marceloaqno-spidev/
                            git pull origin spidev
                            ./configure
                            make
                            This time it compiled successfuly, but when I fired up mysgw all I got was:
                            mysgw: Starting gateway...
                            with no other output.
                            Just to be sure we're on the same note, what is the wiring schematic I should use? When I first started to tinker with RF24 on OPi I found at least two wiring schematics.
                            For reference here's the gpio readall on my OPi PC:
                             +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
                             | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
                             |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
                             |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
                             |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
                             |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 0 | ALT4 | TxD3     | 15  | 13  |
                             |     |     |       0v |      |   |  9 || 10 | 0 | ALT4 | RxD3     | 16  | 14  |
                             |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
                             |   0 |   2 |     TxD2 | ALT5 | 1 | 13 || 14 |   |      | 0v       |     |     |
                             |   3 |   3 |     CTS2 | ALT5 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                             |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
                             |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
                             |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | ALT5 | RTS2     | 6   | 2   |
                             |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
                             |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
                             |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
                             |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
                             |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT5 | RTS1     | 26  | 200 |
                             |   9 |  23 |  GPIO.23 |  OUT | 0 | 33 || 34 |   |      | 0v       |     |     |
                             |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT5 | CTS1     | 27  | 201 |
                             |  20 |  25 |  GPIO.25 | ALT3 | 0 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                             |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
                             +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
                            • M mihai.aldea
                              ./configure
                              make
                              Tag
                              #69
                              @mihai.aldea
                              Just a question the command "gpio readall" does that does show the actual status of the system, or is it just a fixed table that is printed on screen....
                              Look at mine:
                              root@orangepizero:~# gpio readall
                               |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
                               |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
                               |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
                               |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
                               |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
                               |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
                               |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
                               |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
                              It is the same... and shows 40 pins while the OPI Zero only has 26.......
                              There are some small differences between our tables in the naming column... so i guess it really reads the status / names of the pins.. Anyhow still strange that 40 pins are shown instead of 26 for the zero..
                              • pansenP
                                pansenP
                                pansen
                                @marceloaqno: are you planning to create a pull request? also, like @Reza suggested i think it would be smart to gather all information somehwhere, unfortunately mysensors does not seem to have a wiki. can we write an article somehow? i could take care of that.
                                Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                                • pansenP pansen
                                  marceloaqno
                                  Code Contributor
                                  #71
                                  @mihai.aldea sorry about the github link mistake.
                                  @pansen Yes, I will.
                                  Is the orientation of the pins correct in the image?
                                  • M marceloaqno
                                    Tag
                                    @marceloaqno
                                    Nope pinout is reversed!,
                                    The link below shows the correct one!
                                    https://oshlab.com/orange-pi-zero-pinout/
                                    • T Tag
                                      @marceloaqno
                                      marceloaqno
                                      Code Contributor
                                      #73
                                      @Tag Oops, did I get it right this time (I reuploaded the image)?
                                      • T
                                        Tag
                                        @marceloaqno
                                        Build the RF24 lib, without erros on the OPI Zero. and am now able to start the tools and radio seems to be recognised!. (was a faulty breadboard wire.... :( )
                                        Used the follwing to for the radio:
                                        RF24 radio(2,0);
                                        Output from gettingstarted:
                                        root@orangepizero:~/rf24libs/RF24/examples_linux# ./gettingstarted
                                        STATUS           = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                                        RX_ADDR_P0-1     = 0x0000000000 0xff00000000
                                        RX_ADDR_P2-5     = 0xff 0xff 0xff 0xff
                                        TX_ADDR          = 0xffffffffff
                                        RX_PW_P0-6       = 0xff 0xff 0xff 0xff 0xff 0xff
                                        EN_AA            = 0xff
                                        EN_RXADDR        = 0xff
                                        RF_CH            = 0xbc
                                        RF_SETUP         = 0xff
                                        CONFIG           = 0xff
                                        DYNPD/FEATURE    = 0xff 0xff
                                        Data Rate        = 1MBPS
                                        Model            = nRF24L01
                                        PA Power         = PA_MAX
                                        • T Tag
                                          @marceloaqno
                                          RF24 radio(2,0);
                                          EN_AA            = 0xff
                                          EN_RXADDR        = 0xff
                                          RF_CH            = 0xbc
                                          RF_SETUP         = 0xff
                                          CONFIG           = 0xff
                                          Data Rate        = 1MBPS
                                          Model            = nRF24L01
                                          PA Power         = PA_MAX
                                          marceloaqno
                                          Code Contributor
                                          #75
                                          @Tag Could you fill this table with your current setup?
                                          nRF24L01 | OrangePi  | OrangePi
                                                   | phyPin    | GPIO
                                          _________|_______________________
                                          VCC      | 3V3-PWR   | 3V3-PWR
                                          GND      | GND       | GND
                                          CSN      |           |
                                          CE       |           |
                                          MOSI     | 19        | 15
                                          SCK      | 23        | 14
                                          MISO     | 21        | 16
