  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T Tag
    @Reza
    You need to create the files after each boot.
    After the modprobe, Issue this command:
    sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
    This will get you the files.
    R
    R
    Reza
    orangepi one have 40 pins
    • R Reza
      marceloaqno
      Code Contributor
      @Reza Is there /sys/class/gpio/export file on your OPi?
      R 2 Replies Last reply
      • M marceloaqno
        R
        R
        Reza
        @marceloaqno
        no i have not folder "gpio" in my orangepi
          mihai.aldea
          @marceloaqno It still doesn't work on my OPi Zero :confused:
          root@opi-zero-1:~/orangepi# bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: !TSM:INIT:TSP FAIL
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:PDT
          mysgw: Received SIGINT
          I do have the /sys/class/gpio/export and I ran for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
          For the record, here's my OS:
          BOARD=orangepizero
          BOARD_NAME="Orange Pi Zero"
          VERSION=5.24
          LINUXFAMILY=sun8i
          BRANCH=default
          ARCH=arm
          PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
          NAME="Debian GNU/Linux"
          VERSION_ID="8"
          VERSION="8 (jessie)"
          ID=debian
          HOME_URL="http://www.debian.org/"
          SUPPORT_URL="http://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          • M mihai.aldea
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:FAIL:PDT
            BOARD=orangepizero
            VERSION=5.24
            LINUXFAMILY=sun8i
            BRANCH=default
            ARCH=arm
            VERSION_ID="8"
            ID=debian
            marceloaqno
            Code Contributor
            @mihai.aldea The gateway does the exporting when needed, you don't need to run:
            Could you send the output of this command?
            ls -lah /dev/spidev*
            • M marceloaqno
              Tag
              wrote on last edited by Tag
              #91
              @marceloaqno
              Still issues here:
              root@orangepizero:~/orangepi/bin# ll /dev/spi*
              crw------- 1 root root 153, 0 Jan  9 22:51 /dev/spidev0.0
              crw------- 1 root root 153, 1 Jan  9 22:51 /dev/spidev1.0
              Then:
              ./configure --spi-spidev-device=/dev/spidev1.0
              added to examples_linux/mysgw.cpp
              #define MY_RF24_CE_PIN 2
              #define MY_RF24_CS_PIN 13
              end enabled radio debugging:
              output:
              root@orangepizero:~/orangepi/bin# ./mysgw -d
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: RF24:write register, reg=0, value=14
              mysgw: RF24:write register, reg=3, value=3
              mysgw: RF24:write register, reg=4, value=95
              mysgw: RF24:write register, reg=5, value=76
              mysgw: RF24:write register, reg=6, value=39
              mysgw: RF24:write register, reg=16, value=115
              mysgw: RF24:write register, reg=29, value=6
              mysgw: RF24:read register, reg=6, value=39
              mysgw: RF24:read register, reg=5, value=76
              mysgw: RF24:write register, reg=2, value=2
              mysgw: RF24:write register, reg=1, value=0
              mysgw: RF24:write register, reg=28, value=3
              mysgw: RF24:flushRX
              mysgw: RF24:flushTX
              mysgw: RF24:write register, reg=7, value=112
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: RF24:write register, reg=2, value=3
              mysgw: RF24:write register, reg=1, value=1
              mysgw: RF24:STRT LIS
              mysgw: RF24:write register, reg=0, value=15
              mysgw: RF24:write register, reg=10, value=0
              mysgw: MCO:REG:NOT NEEDED
              mysgw: RF24:read register, reg=23, value=17
              Illegal instruction
              Almost there?
              • M marceloaqno
                R
                R
                Reza
                wrote on last edited by Reza
                #92
                @marceloaqno
                in "orangepi one"(ubuntu os) there is not gpio folder in sys/class. but i think after run "modprobe gpio-sunxi" built a folder that name is "gpio_sw" and in this folder there are this files: normal_led,pa3,pa6,pa8 and 9,10,13,14,15,21 ,...
                M T 2 Replies Last reply
                • R Reza
                  @marceloaqno
                  mihai.aldea
                  @Reza Is it too complicated to switch to Debian?
                  R 1 Reply Last reply
                  • M mihai.aldea
                    R
                    R
                    Reza
                    you told me i change my os ? to armbian ?
                    • R Reza
                      @marceloaqno
                      Tag
                      #95
                      @Reza
                      More info on armbian.com
                      I use the debian jessie, works like a charm!
                        mihai.aldea
                        @Reza I wouldn't even dream of not using Armbian on OrangePi and NanoPi. Compared to Raspbian it's years ahead in terms of optimization and tidyness. Armbian is the reason I'm avoiding RPi when possible. So go ahead and install a proper OS for your OPi. Not sure if Xenial or Debian, maybe we should wait for @marceloaqno to respond to my comment with the running OS.
                        • T Tag
                          @Reza
                          R
                          R
                          Reza
                          @Tag
                          i worked with armbiam before. but my question is with armbian my problem is resolve ?
                            mihai.aldea
                            That I can not say.
                            • T Tag
                              @Reza
                              R
                              R
                              Reza
                              ok i change my os and test again. thank you
                                mihai.aldea
                                I confirm it's not working on the OPi PC where TMRh20 works.
                                S 1 Reply Last reply
                                • M marceloaqno
                                  @Tag Oops, did I get it right this time (I reuploaded the image)?
                                  Tag
                                  Got it spot on!! looks great!
                                  • R
                                    R
                                    Reza
                                    i have problem with compile source domoticz(i must use source domoticz for my changes) in armbian, so i have to use ubuntu.
                                    @marceloaqno can you help me to run mysensors gateway in orangepi one (ubuntu os).thank you
                                    • T
                                      Tag
                                      #103
                                      Hi All,
                                      I put together the steps to get MySensors running on the OrangePi Zero:
                                      Take note of the SPI part, 1 typo and you will not see /dev/spidev1.0
                                      • Download and Install the ARMbian(debian) OS image
                                        https://www.armbian.com/orange-pi-zero/
                                      • Install sunxi-tools:
                                        These tools are required to make changes in the boot area of the system
                                      sudo apt-get update
                                      sudo apt-get install sunxi-tools
                                      • How to add /dev/spidev1.0 (which is required since /dev/spidev0.0 is used for the onboard NAND flash)
                                      cd /boot
                                      bin2fex /boot/script.bin /root/myscript.txt
                                      Now edit /root/myscript.bin and add/change the following so it looks exactly like the part below:
                                      [spi0]
                                      spi_used = 1
                                      spi_cs_bitmap = 1
                                      spi_mosi = port:PC00<3><default><default><default>
                                      spi_miso = port:PC01<3><default><default><default>
                                      spi_sclk = port:PC02<3><default><default><default>
                                      spi_cs0 = port:PC03<3><1><default><default>
                                      [spi1]
                                      spi_used = 1
                                      spi_cs_bitmap = 1
                                      spi_cs0 = port:PA13<2><1><default><default>
                                      spi_sclk = port:PA14<2><default><default><default>
                                      spi_mosi = port:PA15<2><default><default><default>
                                      spi_miso = port:PA16<2><default><default><default>
                                      [spi_devices]
                                      spi_dev_num = 2
                                      [spi_board0]
                                      modalias = "spidev"
                                      max_speed_hz = 33000000
                                      bus_num = 0
                                      chip_select = 0
                                      mode = 0
                                      full_duplex = 1
                                      manual_cs = 0
                                      [spi_board1]
                                      modalias = "spidev"
                                      bus_num = 1
                                      chip_select = 0
                                      mode = 0
                                      full_duplex = 1
                                      manual_cs = 0
                                      • Then recompile the script file:
                                      fex2bin /root/myscript.txt /boot/script.bin
                                      Reboot the system
                                      reboot
                                      2 device files should exist now:
                                      root@orangepizero:~# ls -l /dev/spi*
                                      crw------- 1 root root 153, 0 Jan 11 16:31 /dev/spidev0.0
                                      crw------- 1 root root 153, 1 Jan 11 16:31 /dev/spidev1.0
                                      Load the gpio module
                                      modprobe gpio-sunxi
                                      To load the module gpio-sunxi automagically load at boot time, add gpio-sunxi to /etc/modules
                                      echo gpio-sunxi >> /etc/modules
                                      • Now it is time to install the GW.
                                      cd /root
                                      git clone https://github.com/marceloaqno/MySensors.git orangepi
                                      cd orangepi/
                                      git pull origin spidev
                                      make
                                      Working like a charm!
                                      If you tested "/bin/mysgw -d" and all works as expected, make the installation permanent:
                                      make install
                                      Additional
                                      If you want to read data into a controller using a device file (i.e Mycontroller) use the build string below
                                       ./configure --spi-spidev-device=/dev/spidev1.0  --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                                      Hope this helps!! have fun!!
                                      • T Tag
                                        Hi All,
                                        sudo apt-get update
                                        cd /boot
                                        [spi0]
                                        spi_used = 1
                                        spi_cs_bitmap = 1
                                        [spi1]
                                        spi_used = 1
                                        spi_cs_bitmap = 1
                                        [spi_devices]
                                        spi_dev_num = 2
                                        [spi_board0]
                                        modalias = "spidev"
                                        bus_num = 0
                                        chip_select = 0
                                        mode = 0
                                        full_duplex = 1
                                        manual_cs = 0
                                        [spi_board1]
                                        modalias = "spidev"
                                        bus_num = 1
                                        chip_select = 0
                                        mode = 0
                                        full_duplex = 1
                                        manual_cs = 0
                                        Reboot the system
                                        reboot
                                        modprobe gpio-sunxi
                                        cd /root
                                        cd orangepi/
                                        make
                                        make install
                                        Additional
                                        marceloaqno
                                        Code Contributor
                                        @Tag great! Thanks for the detailed explanation :clap:
                                        I will add to the instructions page
                                        • pansenP
                                          pansenP
                                          pansen
                                          out of curiousity: this all relates to 3.x kernel in armbian right? which has proprietary stuff in there?
                                          i read somewhere that mainline 4.10 SPI is "work in progress"
                                          Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
