  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • M marceloaqno
    I created the draft for the official article: https://www.mysensors.org/build/orange
    @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
    jirmJ 1 Reply Last reply
      jirmJ
      jirmJ
      jirm
      wrote on last edited by jirm
      #79
      @marceloaqno
      @mfalkvidd @Tag @pansen @Reza @mihai.aldea @hausinger
      Wooow woow woow !!!
      Only few days "off" and the problem to make work Mysensors on OPI are solved.
      So many many thanks to all people here that have been involved to make that OPI good little boards can work with Mysensors.
      This is the proof that when good people join can reach the most difficult achievements and all humanity can benefit.
      Awesome work !
      Regards
      • M marceloaqno
        Tag
        wrote on last edited by Tag
        #80
        @marceloaqno
        Great work!!! the GPIO part most probably needs some additions for OPI zero on the topic of the spidev1.0 driver and the GPIO pins, send it to you once i got everything documented.
        Really many thanks for your hard work here!!
        • R
          R
          Reza
          • M marceloaqno
            R
            R
            Reza
            @marceloaqno
            thank you. but i have error:
            root@OrangePI:~# ls /sys/class/gpio/export
            ls: cannot access /sys/class/gpio/export: No such file or directory
            root@OrangePI:~# modprobe gpio-sunxi
            in class folder i dont have gpio folder (i use a orangepi one with ubuntu os )
            i
            • R Reza
              @marceloaqno
              i
              Tag
              @Reza
              You need to create the files after each boot.
              After the modprobe, Issue this command:
              sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
              This will get you the files.
              R 2 Replies Last reply
              • R
                R
                Reza
                root@OrangePI:~# git clone https://github.com/marceloaqno/MySensors.git orangepi               Cloning into 'orangepi'...
                remote: Counting objects: 13858, done.
                remote: Compressing objects: 100% (50/50), done.
                remote: Total 13858 (delta 17), reused 0 (delta 0), pack-reused 13808
                Receiving objects: 100% (13858/13858), 9.68 MiB | 79.00 KiB/s, done.
                Resolving deltas: 100% (8304/8304), done.
                Checking connectivity... done.
                root@OrangePI:~# cd orangepi/
                root@OrangePI:~/orangepi# git pull origin spidev
                From https://github.com/marceloaqno/MySensors
                 * branch            spidev     -> FETCH_HEAD
                Updating 570b607..63e1a81
                Fast-forward
                 Makefile                                          |  16 +++
                 MyConfig.h                                        |   4 +
                 MySensors.h                                       |   2 +-
                 configure                                         |  79 ++++++++++---
                 core/MyHwLinuxGeneric.cpp                         |  17 +++
                 core/MyHwLinuxGeneric.h                           |  12 +-
                 core/MyHwRPi.cpp                                  |   1 +
                 core/MyHwRPi.h                                    |  28 -----
                 core/MyMainLinux.cpp                              |  30 ++---
                 drivers/{RPi => BCM}/SPI.cpp                      |  10 +-
                 drivers/{RPi => BCM}/SPI.h                        | 116 ++++++++++++-------
                 drivers/{RPi => BCM}/Wire.cpp                     |   0
                 drivers/{RPi => BCM}/Wire.h                       |   1 +
                 drivers/Linux/Arduino.h                           |  22 +++-
                 drivers/Linux/GPIO.cpp                            | 119 ++++++++++++++++++++
                 drivers/Linux/GPIO.h                              |  47 ++++++++
                 drivers/Linux/Stream.h                            |   1 +
                 drivers/Linux/compatibility.cpp                   |  11 +-
                 drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} | 144 +++++-------------------
                 drivers/Linux/interrupt.h                         |  45 ++++++++
                 drivers/RF24/RF24.cpp                             |   4 +-
                 drivers/RF24/RF24.h                               |   2 +-
                 drivers/RPi/RPi.cpp                               |  59 ++++++++++
                 drivers/RPi/RPi.h                                 |  22 ++++
                 drivers/RPi/piHiPri.c                             |  49 --------
                 drivers/RPi/rpi_util.h                            |  76 -------------
                 drivers/RPi/wiring.cpp                            |  72 ++++++++++++
                 drivers/RPi/wiring.h                              |  24 ++++
                 drivers/SPIDEV/SPI.cpp                            | 223 +++++++++++++++++++++++++++++++++++++
                 drivers/SPIDEV/SPI.h                              | 178 +++++++++++++++++++++++++++++
                 30 files changed, 1054 insertions(+), 360 deletions(-)
                 rename drivers/{RPi => BCM}/SPI.cpp (100%)
                 rename drivers/{RPi => BCM}/SPI.h (62%)
                 rename drivers/{RPi => BCM}/Wire.cpp (100%)
                 rename drivers/{RPi => BCM}/Wire.h (99%)
                 create mode 100644 drivers/Linux/GPIO.cpp
                 create mode 100644 drivers/Linux/GPIO.h
                 rename drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} (63%)
                 create mode 100644 drivers/Linux/interrupt.h
                 create mode 100644 drivers/RPi/RPi.cpp
                 create mode 100644 drivers/RPi/RPi.h
                 delete mode 100644 drivers/RPi/piHiPri.c
                 delete mode 100644 drivers/RPi/rpi_util.h
                 create mode 100644 drivers/RPi/wiring.cpp
                 create mode 100644 drivers/RPi/wiring.h
                 create mode 100644 drivers/SPIDEV/SPI.cpp
                 create mode 100644 drivers/SPIDEV/SPI.h
                root@OrangePI:~/orangepi# ./configure
                [OK] Finished.
                root@OrangePI:~/orangepi# make
                gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
                drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
                   (void)read (fd, &c, 1) ;
                g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                In file included from ./MySensors.h:294:0,
                                 from examples_linux/mysgw.cpp:74:
                ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
                  hwDigitalWrite(MY_RF24_CS_PIN, level);
                ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
                  hwDigitalWrite(MY_RF24_CE_PIN, level);
                ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
                  hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
                  hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                 LOCAL void RF24_csn(const bool level)
                ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                 LOCAL void RF24_ce(const bool level)
                ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
                ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
                  RF24_csn(LOW);
                ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
                  RF24_csn(HIGH);
                ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
                ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
                  RF24_ce(HIGH);
                ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
                ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
                  RF24_ce(LOW);
                ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
                ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
                  RF24_ce(LOW);
                ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
                ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
                  RF24_ce(HIGH);
                ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
                  RF24_ce(LOW);
                ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
                  RF24_ce(LOW);
                ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
                  RF24_csn(HIGH);
                Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                root@OrangePI:~/orangepi#```
                • T Tag
                  @Reza
                  R
                  R
                  Reza
                  @Tag
                  root@OrangePI:~/orangepi# sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                  -bash: syntax error near unexpected token `do'
                  root@OrangePI:~/orangepi# ```
                  • T Tag
                    @Reza
                    R
                    R
                    Reza
                    orangepi one have 40 pins
                    • R Reza
                      marceloaqno
                      Code Contributor
                      @Reza Is there /sys/class/gpio/export file on your OPi?
                      • M marceloaqno
                        R
                        R
                        Reza
                        @marceloaqno
                        no i have not folder "gpio" in my orangepi
                          mihai.aldea
                          @marceloaqno It still doesn't work on my OPi Zero :confused:
                          root@opi-zero-1:~/orangepi# bin/mysgw -d
                          mysgw: Starting gateway...
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: !TSM:INIT:TSP FAIL
                          mysgw: TSM:FAIL:CNT=1
                          mysgw: TSM:FAIL:PDT
                          mysgw: Received SIGINT
                          I do have the /sys/class/gpio/export and I ran for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                          For the record, here's my OS:
                          BOARD=orangepizero
                          BOARD_NAME="Orange Pi Zero"
                          VERSION=5.24
                          LINUXFAMILY=sun8i
                          BRANCH=default
                          ARCH=arm
                          PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
                          NAME="Debian GNU/Linux"
                          VERSION_ID="8"
                          VERSION="8 (jessie)"
                          ID=debian
                          HOME_URL="http://www.debian.org/"
                          SUPPORT_URL="http://www.debian.org/support"
                          BUG_REPORT_URL="https://bugs.debian.org/"
                          • M mihai.aldea
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:FAIL:PDT
                            BOARD=orangepizero
                            VERSION=5.24
                            LINUXFAMILY=sun8i
                            BRANCH=default
                            ARCH=arm
                            VERSION_ID="8"
                            ID=debian
                            marceloaqno
                            Code Contributor
                            @mihai.aldea The gateway does the exporting when needed, you don't need to run:
                            Could you send the output of this command?
                            ls -lah /dev/spidev*
                            • M marceloaqno
                              Tag
                              #91
                              @marceloaqno
                              Still issues here:
                              root@orangepizero:~/orangepi/bin# ll /dev/spi*
                              crw------- 1 root root 153, 0 Jan  9 22:51 /dev/spidev0.0
                              crw------- 1 root root 153, 1 Jan  9 22:51 /dev/spidev1.0
                              Then:
                              ./configure --spi-spidev-device=/dev/spidev1.0
                              added to examples_linux/mysgw.cpp
                              #define MY_RF24_CE_PIN 2
                              #define MY_RF24_CS_PIN 13
                              end enabled radio debugging:
                              output:
                              root@orangepizero:~/orangepi/bin# ./mysgw -d
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: RF24:write register, reg=0, value=14
                              mysgw: RF24:write register, reg=3, value=3
                              mysgw: RF24:write register, reg=4, value=95
                              mysgw: RF24:write register, reg=5, value=76
                              mysgw: RF24:write register, reg=6, value=39
                              mysgw: RF24:write register, reg=16, value=115
                              mysgw: RF24:write register, reg=29, value=6
                              mysgw: RF24:read register, reg=6, value=39
                              mysgw: RF24:read register, reg=5, value=76
                              mysgw: RF24:write register, reg=2, value=2
                              mysgw: RF24:write register, reg=1, value=0
                              mysgw: RF24:write register, reg=28, value=3
                              mysgw: RF24:flushRX
                              mysgw: RF24:flushTX
                              mysgw: RF24:write register, reg=7, value=112
                              mysgw: TSM:INIT:TSP OK
                              mysgw: TSM:INIT:GW MODE
                              mysgw: RF24:write register, reg=2, value=3
                              mysgw: RF24:write register, reg=1, value=1
                              mysgw: RF24:STRT LIS
                              mysgw: RF24:write register, reg=0, value=15
                              mysgw: RF24:write register, reg=10, value=0
                              mysgw: MCO:REG:NOT NEEDED
                              mysgw: RF24:read register, reg=23, value=17
                              Illegal instruction
                              Almost there?
                              • M marceloaqno
                                R
                                R
                                Reza
                                wrote on last edited by Reza
                                #92
                                @marceloaqno
                                in "orangepi one"(ubuntu os) there is not gpio folder in sys/class. but i think after run "modprobe gpio-sunxi" built a folder that name is "gpio_sw" and in this folder there are this files: normal_led,pa3,pa6,pa8 and 9,10,13,14,15,21 ,...
                                M T 2 Replies Last reply
                                • R Reza
                                  @marceloaqno
                                  mihai.aldea
                                  @Reza Is it too complicated to switch to Debian?
                                  R 1 Reply Last reply
                                  • M mihai.aldea
                                    R
                                    R
                                    Reza
                                    you told me i change my os ? to armbian ?
                                    • R Reza
                                      @marceloaqno
                                      Tag
                                      #95
                                      @Reza
                                      More info on armbian.com
                                      I use the debian jessie, works like a charm!
                                        mihai.aldea
                                        @Reza I wouldn't even dream of not using Armbian on OrangePi and NanoPi. Compared to Raspbian it's years ahead in terms of optimization and tidyness. Armbian is the reason I'm avoiding RPi when possible. So go ahead and install a proper OS for your OPi. Not sure if Xenial or Debian, maybe we should wait for @marceloaqno to respond to my comment with the running OS.
                                        • T Tag
                                          @Reza
                                          R
                                          R
                                          Reza
                                          @Tag
                                          i worked with armbiam before. but my question is with armbian my problem is resolve ?
