  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T Tag
    @marceloaqno
    Sure here it is,
    nRF24L01 | OrangePi  | OrangePi
             | phyPin    | GPIO
    _________|_______________________
    VCC      | 3V3-PWR   | 3V3-PWR
    GND      | GND       | GND
    CSN      | 24        | 13
    CE       | 22        | 2
    MOSI     | 19        | 15
    SCK      | 23        | 14
    MISO     | 21        | 16
    Radio seems to be recognised, still need to test data transfer...
    marceloaqno
    Code Contributor
    wrote on last edited by marceloaqno
    #77
    I created the draft for the official article: https://www.mysensors.org/build/orange
    mfalkviddM T R 3 Replies Last reply
    • M marceloaqno
      @marceloaqno and everyone else involved in this effort: great work! I love when people come together to solve a problem.
      jirmJ 1 Reply Last reply
        jirmJ
        jirmJ
        jirm
        wrote on last edited by jirm
        #79
        @marceloaqno
        @mfalkvidd @Tag @pansen @Reza @mihai.aldea @hausinger
        Wooow woow woow !!!
        Only few days "off" and the problem to make work Mysensors on OPI are solved.
        So many many thanks to all people here that have been involved to make that OPI good little boards can work with Mysensors.
        This is the proof that when good people join can reach the most difficult achievements and all humanity can benefit.
        Awesome work !
        Regards
        • M marceloaqno
          Tag
          wrote on last edited by Tag
          #80
          @marceloaqno
          Great work!!! the GPIO part most probably needs some additions for OPI zero on the topic of the spidev1.0 driver and the GPIO pins, send it to you once i got everything documented.
          Really many thanks for your hard work here!!
          • R
            R
            Reza
            • M marceloaqno
              R
              R
              Reza
              @marceloaqno
              thank you. but i have error:
              root@OrangePI:~# ls /sys/class/gpio/export
              ls: cannot access /sys/class/gpio/export: No such file or directory
              root@OrangePI:~# modprobe gpio-sunxi
              in class folder i dont have gpio folder (i use a orangepi one with ubuntu os )
              i
              • R Reza
                @marceloaqno
                i
                Tag
                @Reza
                You need to create the files after each boot.
                After the modprobe, Issue this command:
                sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                This will get you the files.
                R 2 Replies Last reply
                • R
                  R
                  Reza
                  root@OrangePI:~# git clone https://github.com/marceloaqno/MySensors.git orangepi               Cloning into 'orangepi'...
                  remote: Counting objects: 13858, done.
                  remote: Compressing objects: 100% (50/50), done.
                  remote: Total 13858 (delta 17), reused 0 (delta 0), pack-reused 13808
                  Receiving objects: 100% (13858/13858), 9.68 MiB | 79.00 KiB/s, done.
                  Resolving deltas: 100% (8304/8304), done.
                  Checking connectivity... done.
                  root@OrangePI:~# cd orangepi/
                  root@OrangePI:~/orangepi# git pull origin spidev
                  From https://github.com/marceloaqno/MySensors
                   * branch            spidev     -> FETCH_HEAD
                  Updating 570b607..63e1a81
                  Fast-forward
                   Makefile                                          |  16 +++
                   MyConfig.h                                        |   4 +
                   MySensors.h                                       |   2 +-
                   configure                                         |  79 ++++++++++---
                   core/MyHwLinuxGeneric.cpp                         |  17 +++
                   core/MyHwLinuxGeneric.h                           |  12 +-
                   core/MyHwRPi.cpp                                  |   1 +
                   core/MyHwRPi.h                                    |  28 -----
                   core/MyMainLinux.cpp                              |  30 ++---
                   drivers/{RPi => BCM}/SPI.cpp                      |  10 +-
                   drivers/{RPi => BCM}/SPI.h                        | 116 ++++++++++++-------
                   drivers/{RPi => BCM}/Wire.cpp                     |   0
                   drivers/{RPi => BCM}/Wire.h                       |   1 +
                   drivers/Linux/Arduino.h                           |  22 +++-
                   drivers/Linux/GPIO.cpp                            | 119 ++++++++++++++++++++
                   drivers/Linux/GPIO.h                              |  47 ++++++++
                   drivers/Linux/Stream.h                            |   1 +
                   drivers/Linux/compatibility.cpp                   |  11 +-
                   drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} | 144 +++++-------------------
                   drivers/Linux/interrupt.h                         |  45 ++++++++
                   drivers/RF24/RF24.cpp                             |   4 +-
                   drivers/RF24/RF24.h                               |   2 +-
                   drivers/RPi/RPi.cpp                               |  59 ++++++++++
                   drivers/RPi/RPi.h                                 |  22 ++++
                   drivers/RPi/piHiPri.c                             |  49 --------
                   drivers/RPi/rpi_util.h                            |  76 -------------
                   drivers/RPi/wiring.cpp                            |  72 ++++++++++++
                   drivers/RPi/wiring.h                              |  24 ++++
                   drivers/SPIDEV/SPI.cpp                            | 223 +++++++++++++++++++++++++++++++++++++
                   drivers/SPIDEV/SPI.h                              | 178 +++++++++++++++++++++++++++++
                   30 files changed, 1054 insertions(+), 360 deletions(-)
                   rename drivers/{RPi => BCM}/SPI.cpp (100%)
                   rename drivers/{RPi => BCM}/SPI.h (62%)
                   rename drivers/{RPi => BCM}/Wire.cpp (100%)
                   rename drivers/{RPi => BCM}/Wire.h (99%)
                   create mode 100644 drivers/Linux/GPIO.cpp
                   create mode 100644 drivers/Linux/GPIO.h
                   rename drivers/{RPi/rpi_util.cpp => Linux/interrupt.cpp} (63%)
                   create mode 100644 drivers/Linux/interrupt.h
                   create mode 100644 drivers/RPi/RPi.cpp
                   create mode 100644 drivers/RPi/RPi.h
                   delete mode 100644 drivers/RPi/piHiPri.c
                   delete mode 100644 drivers/RPi/rpi_util.h
                   create mode 100644 drivers/RPi/wiring.cpp
                   create mode 100644 drivers/RPi/wiring.h
                   create mode 100644 drivers/SPIDEV/SPI.cpp
                   create mode 100644 drivers/SPIDEV/SPI.h
                  root@OrangePI:~/orangepi# ./configure
                  [OK] Finished.
                  root@OrangePI:~/orangepi# make
                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                  g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                  g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                  g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                  g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                  g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                  g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                  g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                  g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                  g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                  drivers/Linux/interrupt.cpp: In function ‘void* interruptHandler(void*)’:
                  drivers/Linux/interrupt.cpp:107:26: warning: ignoring return value of ‘ssize_t read(int, void*, size_t)’, declared with attribute warn_unused_result [-Wunused-result]
                     (void)read (fd, &c, 1) ;
                  g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                  g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                  g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_SPIDEV -DLINUX_ARCH_ORANGEPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                  In file included from ./MySensors.h:294:0,
                                   from examples_linux/mysgw.cpp:74:
                  ./drivers/RF24/RF24.cpp:39:11: error: Not supported on this platform.
                    hwDigitalWrite(MY_RF24_CS_PIN, level);
                  ./drivers/RF24/RF24.cpp:44:11: error: Not supported on this platform.
                    hwDigitalWrite(MY_RF24_CE_PIN, level);
                  ./drivers/RF24/RF24.cpp:388:11: error: Not supported on this platform.
                    hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                  ./drivers/RF24/RF24.cpp:389:11: error: Not supported on this platform.
                    hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                  ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                   LOCAL void RF24_csn(const bool level)
                  ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                   LOCAL void RF24_ce(const bool level)
                  ./drivers/RF24/RF24.cpp: In function ‘uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)’:
                  ./drivers/RF24/RF24.cpp:56:11: error: ‘LOW’ was not declared in this scope
                    RF24_csn(LOW);
                  ./drivers/RF24/RF24.cpp:99:11: error: ‘HIGH’ was not declared in this scope
                    RF24_csn(HIGH);
                  ./drivers/RF24/RF24.cpp: In function ‘void RF24_startListening()’:
                  ./drivers/RF24/RF24.cpp:235:10: error: ‘HIGH’ was not declared in this scope
                    RF24_ce(HIGH);
                  ./drivers/RF24/RF24.cpp: In function ‘void RF24_stopListening()’:
                  ./drivers/RF24/RF24.cpp:241:10: error: ‘LOW’ was not declared in this scope
                    RF24_ce(LOW);
                  ./drivers/RF24/RF24.cpp: In function ‘void RF24_powerDown()’:
                  ./drivers/RF24/RF24.cpp:251:10: error: ‘LOW’ was not declared in this scope
                    RF24_ce(LOW);
                  ./drivers/RF24/RF24.cpp: In function ‘bool RF24_sendMessage(uint8_t, const void*, uint8_t)’:
                  ./drivers/RF24/RF24.cpp:269:10: error: ‘HIGH’ was not declared in this scope
                    RF24_ce(HIGH);
                  ./drivers/RF24/RF24.cpp:276:10: error: ‘LOW’ was not declared in this scope
                    RF24_ce(LOW);
                  ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                  ./drivers/RF24/RF24.cpp:395:10: error: ‘LOW’ was not declared in this scope
                    RF24_ce(LOW);
                  ./drivers/RF24/RF24.cpp:396:11: error: ‘HIGH’ was not declared in this scope
                    RF24_csn(HIGH);
                  Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                  root@OrangePI:~/orangepi#```
                  • T Tag
                    @Reza
                    R
                    R
                    Reza
                    @Tag
                    root@OrangePI:~/orangepi# sudo for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                    -bash: syntax error near unexpected token `do'
                    root@OrangePI:~/orangepi# ```
                    • T Tag
                      @Reza
                      R
                      R
                      Reza
                      orangepi one have 40 pins
                      • R Reza
                        marceloaqno
                        Code Contributor
                        @Reza Is there /sys/class/gpio/export file on your OPi?
                        • M marceloaqno
                          R
                          R
                          Reza
                          @marceloaqno
                          no i have not folder "gpio" in my orangepi
                            mihai.aldea
                            @marceloaqno It still doesn't work on my OPi Zero :confused:
                            root@opi-zero-1:~/orangepi# bin/mysgw -d
                            mysgw: Starting gateway...
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: !TSM:INIT:TSP FAIL
                            mysgw: TSM:FAIL:CNT=1
                            mysgw: TSM:FAIL:PDT
                            mysgw: Received SIGINT
                            I do have the /sys/class/gpio/export and I ran for A in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16; do echo "$A" > /sys/class/gpio/export ; done
                            For the record, here's my OS:
                            BOARD=orangepizero
                            BOARD_NAME="Orange Pi Zero"
                            VERSION=5.24
                            LINUXFAMILY=sun8i
                            BRANCH=default
                            ARCH=arm
                            PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
                            NAME="Debian GNU/Linux"
                            VERSION_ID="8"
                            VERSION="8 (jessie)"
                            ID=debian
                            HOME_URL="http://www.debian.org/"
                            SUPPORT_URL="http://www.debian.org/support"
                            BUG_REPORT_URL="https://bugs.debian.org/"
                            • M mihai.aldea
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:FAIL:PDT
                              BOARD=orangepizero
                              VERSION=5.24
                              LINUXFAMILY=sun8i
                              BRANCH=default
                              ARCH=arm
                              VERSION_ID="8"
                              ID=debian
                              marceloaqno
                              Code Contributor
                              @mihai.aldea The gateway does the exporting when needed, you don't need to run:
                              Could you send the output of this command?
                              ls -lah /dev/spidev*
                              • M marceloaqno
                                Tag
                                #91
                                @marceloaqno
                                Still issues here:
                                root@orangepizero:~/orangepi/bin# ll /dev/spi*
                                crw------- 1 root root 153, 0 Jan  9 22:51 /dev/spidev0.0
                                crw------- 1 root root 153, 1 Jan  9 22:51 /dev/spidev1.0
                                Then:
                                ./configure --spi-spidev-device=/dev/spidev1.0
                                added to examples_linux/mysgw.cpp
                                #define MY_RF24_CE_PIN 2
                                #define MY_RF24_CS_PIN 13
                                end enabled radio debugging:
                                output:
                                root@orangepizero:~/orangepi/bin# ./mysgw -d
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: RF24:write register, reg=0, value=14
                                mysgw: RF24:write register, reg=3, value=3
                                mysgw: RF24:write register, reg=4, value=95
                                mysgw: RF24:write register, reg=5, value=76
                                mysgw: RF24:write register, reg=6, value=39
                                mysgw: RF24:write register, reg=16, value=115
                                mysgw: RF24:write register, reg=29, value=6
                                mysgw: RF24:read register, reg=6, value=39
                                mysgw: RF24:read register, reg=5, value=76
                                mysgw: RF24:write register, reg=2, value=2
                                mysgw: RF24:write register, reg=1, value=0
                                mysgw: RF24:write register, reg=28, value=3
                                mysgw: RF24:flushRX
                                mysgw: RF24:flushTX
                                mysgw: RF24:write register, reg=7, value=112
                                mysgw: TSM:INIT:TSP OK
                                mysgw: TSM:INIT:GW MODE
                                mysgw: RF24:write register, reg=2, value=3
                                mysgw: RF24:write register, reg=1, value=1
                                mysgw: RF24:STRT LIS
                                mysgw: RF24:write register, reg=0, value=15
                                mysgw: RF24:write register, reg=10, value=0
                                mysgw: MCO:REG:NOT NEEDED
                                mysgw: RF24:read register, reg=23, value=17
                                Illegal instruction
                                Almost there?
                                • M marceloaqno
                                  R
                                  R
                                  Reza
                                  wrote on last edited by Reza
                                  #92
                                  @marceloaqno
                                  in "orangepi one"(ubuntu os) there is not gpio folder in sys/class. but i think after run "modprobe gpio-sunxi" built a folder that name is "gpio_sw" and in this folder there are this files: normal_led,pa3,pa6,pa8 and 9,10,13,14,15,21 ,...
                                  M T 2 Replies Last reply
                                  • R Reza
                                    @marceloaqno
                                    mihai.aldea
                                    @Reza Is it too complicated to switch to Debian?
                                    R 1 Reply Last reply
                                    • M mihai.aldea
                                      R
                                      R
                                      Reza
                                      you told me i change my os ? to armbian ?
                                      • R Reza
                                        @marceloaqno
                                        Tag
                                        #95
                                        @Reza
                                        More info on armbian.com
                                        I use the debian jessie, works like a charm!
                                          mihai.aldea
                                          @Reza I wouldn't even dream of not using Armbian on OrangePi and NanoPi. Compared to Raspbian it's years ahead in terms of optimization and tidyness. Armbian is the reason I'm avoiding RPi when possible. So go ahead and install a proper OS for your OPi. Not sure if Xenial or Debian, maybe we should wait for @marceloaqno to respond to my comment with the running OS.
