  2. Feature Requests
  3. Add variables for voltage, current, frequency, power factor sector and support for 3-phase systems to S-POWER Type
Scheduled Pinned Locked Moved Feature Requests
1 Posts 1 Posters 1.1k Views 1 Watching
  • RedguyR
    RedguyR
    Redguy
    I an currently implementing a My Sensors imlementation that reads measurements from a Schneider PM9C Energy monitoring device through Modbus and feeds those measurements into the MySensors network.. This is quite a nice device to use but a lot of measurement have not been implemented in the sensor types provided in the MySensors library.
    The S-POWER type (type 13), meant to be used for this kind of devices only supports the V_WATT, V_KWH, V_VAR, V_VA, V_POWER_FACTOR variables. I can add the measured Voltages and Currents by using the S_MULTIMETER type, but still. I think many power meters out there support a lot more then just the pure power readings.
    The PM9C for instance provides me with :
    • Current measurements for each Phase and the Neutral line
    • Voltage measurement between the 3 Phases and for each Phase against Neutral
    • Frequency
    • Total and per Phase Active power
    • Total and per Phase Reactive power
    • Total Apparent power
    • Power factor
    • Power factor sector
    • Power demand
    • Maximum power demand
    • Operating time counter
    • Active and Reactive total energy counter
    Sure i can use custom values for this, but it would mean defining 3 devices types for this one powermeter.
    I suggest adding the existing V_VOLTAGE, V_CURRENT variables to the S-POWERMETER type, and add new variable types for V_FREQUENCY, V_POWER_FACTOR_SECTOR, V_POWER_DEMAND
