  2. Announcements
  • R
    R
    Reza
    wrote on last edited by Reza
    #267
    • eyesoftE eyesoft
      @Mihai
      you can attach analogue sensor to ESP2866 with espeasy firmware ... more info here : http://www.letscontrolit.com/wiki/index.php/ESPEasy ... i'm using one ESP8266-12E and i have good results and Uptime: 74209 minutes (usb powered).
      i'm using IRQ on NRF24L01 connected to my Rpi, but i don't have many sensor with nrf+arduino (only 2) and i had no problems ... i don't if IRQ improve the reliability and i never play with irq fron nrf on arduino.
      regarding retain=true have a look here : http://www.hivemq.com/blog/mqtt-essentials-part-8-retained-messages
      for more reliability on mqtt i think you can use qos=1 ( The broker/client will deliver the message at least once, with confirmation required.), but all depends on your set-up .. not all messages need special attention.
      Mihai
      @eyesoft
      As far as I understand, MySensors relay on PubSubClient for MQTT and it does not allow to publish messages with QOS=1 or 2, only 0.
      Retain is different that QOS, it offers the possibility to recover the state for a device that loose connection for a while (e.g. after a restart). I find it very usefull. For example I have to restart the controller. When come back I got all states to their real values if retain=true. Otherwise they goes to the default, usually 0.
      I have now 6 nodes, each with several sensors and relays.
      • R
        R
        Reza
        please help :(
        every time after reboot i have to run this code
        sudo ./bin/mysgw -d
        so built a virtual usb but after reboot ....
        how put this code in startup ? :( please help thank you
        • R Reza
          please help :(
          sudo ./bin/mysgw -d
          marceloaqno
          Code Contributor
          @Reza
          From the Building a Raspberry Pi Gateway article:
          If you wish to install:
          sudo make install
          The last command will provide instructions for your system on how to start the gateway on every boot.
          R 2 Replies Last reply
          • M marceloaqno
            @Reza
            sudo make install
            R
            R
            Reza
            @marceloaqno
            i do it but after reboot serial lost again :(
            just with command work again
            sudo ./bin/mysgw -d
            • M marceloaqno
              @Reza
              sudo make install
              R
              R
              Reza
              @marceloaqno
              i'm sorry
              after sudo make install i must run this lines:
              sorry thank you
              • R
                R
                Reza
                @marceloaqno can you build a rs485 gateway on raspberry pi ?
                • eyesoftE
                  eyesoftE
                  eyesoft
                  @Mihai yes you are right
                  • Shantanu MhapankarS
                    Shantanu MhapankarS
                    Shantanu Mhapankar
                    This data that I get when I run ./mysgw --d , where is it stored and how can I get it to push it on cloud? Please help.
                    • Shantanu MhapankarS Shantanu Mhapankar
                      Tag
                      @Shantanu-Mhapankar
                      Data is not stored... to store the data and do something usefull with it (or not) you need a controller. I use mycontroller, and from this software you can "push" data to an external server.
                      I use my controller, but i am sure that other controller software also has this feature.
                        Shantanu MhapankarS
                        Shantanu Mhapankar
                        @Tag , The controller must be using something to get the data right? How can we do it directly without using the controller?
                        • P
                          P
                          pete1450
                          @hek It looks like development is the default branch in the repository. I was following the build instructions and couldn't figure out why I kept getting "connection refused". Just typing up a troubleshooting post when I saw my log said 2.2.0-beta. Sure enough when I grabbed master(2.1.0) instead it ran fine. Should probably add a checkout in the instructions.
                          • P pete1450
                            #279
                            @pete1450 could you clarify which instructions should be updated?
                            The instructions at https://www.mysensors.org/about/arduino recommend using the Arduino IDE Board manager, which will get the latest stable version.
                            Edit: Now I see. The link in the first post in this thread. It doesn't mention the master branch because up until Dec 25th the development branch was required. But now that 2.1 has been released the instructions should indeed use the stable version. I've updated the instructions. Thanks for noticing!
                              Tag
                              wrote on last edited by Tag
                              #280
                              @Shantanu-Mhapankar
                              This is also new for me since i do not send data into any cloud... but i can imagine that you can use MQTT. (see https://www.mysensors.org/build/mqtt_gateway for more details) is important that the receiving side supports MQTT. in this case google is your friend ;)
                              if you do a ./configure --help you will find you can build the mysensors gateway with MQTT support
                              ./configure --help
                                  --my-gateway=[ethernet|serial|mqtt]
                                                              Gateway type, set to none to disable gateway feature. [ethernet]
                                  --my-node-id=<ID>           Disable gateway feature and run as a node with given id.
                                                              Controller or MQTT broker ip.
                              • LaMB95L
                                LaMB95L
                                LaMB95
                                ran sudo ./bin/mysgw -d
                                I keep getting mysgw: accept: Bad File Descriptor.
                                Any possible cause ?
                                  This thread contains comments for the article "Building a Raspberry Pi Gateway" posted on MySensors.org.
                                  marceltrapmanM
                                  marceltrapmanM
                                  marceltrapman
                                  I am trying to get the raspi ethernet gateway running but on both my pi 3 (also running openHAB) and the pi B (pretty basic install).
                                  Unfortunately I get the same error on both.
                                  Any ideas what could be going on here?
                                  I am running the latest gateway and the latest raspbian.
                                  mysgw: Starting gateway...
                                  mysgw: Protocol version - 2.1.0
                                  mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:INIT:TSP OK
                                  mysgw: TSM:INIT:GW MODE
                                  mysgw: MCO:REG:NOT NEEDED
                                  mysgw: failed to connect
                                  mysgw: Eth: connect
                                  mysgw: Eth: connect
                                  Fulltime Servoy Developer
                                  LaMB95L M 2 Replies Last reply
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: Eth: connect
                                    mysgw: Eth: connect
                                    LaMB95L
                                    LaMB95L
                                    LaMB95
                                    @marceltrapman
                                    I am using a Rasp Pi 3 as well.
                                    I can't even proceed further in the tutorial cause of this error cause nothing works after it.
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: Eth: connect
                                      mysgw: Eth: connect
                                      marceloaqno
                                      Code Contributor
                                      @marceltrapman @LaMB95
                                      Could you post the complete ./configure command used to configure the gateway?
                                      marceltrapmanM LaMB95L 2 Replies Last reply
                                      • M marceloaqno
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        @marceloaqno Sure, forgot it :)
                                        sudo ./configure \
                                            --my-gateway=ethernet \
                                            --my-controller-ip-address=192.168.1.xx \
                                            --my-port=5003 \
                                            --my-transport=nrf24
                                          sudo ./configure \
                                              --my-port=5003 \
                                          marceloaqno
                                          Code Contributor
                                          @marceltrapman Are you sure it's not a problem with your controller?
                                          Have you tried connecting to your controller using telnet?
                                          telnet 192.168.1.x 5003
                                          marceltrapmanM 2 Replies Last reply
