  2. Announcements
  • Shantanu MhapankarS
    Shantanu MhapankarS
    Shantanu Mhapankar
    This data that I get when I run ./mysgw --d , where is it stored and how can I get it to push it on cloud? Please help.
    • Shantanu MhapankarS Shantanu Mhapankar
      Tag
      @Shantanu-Mhapankar
      Data is not stored... to store the data and do something usefull with it (or not) you need a controller. I use mycontroller, and from this software you can "push" data to an external server.
      I use my controller, but i am sure that other controller software also has this feature.
        Shantanu MhapankarS
        Shantanu Mhapankar
        @Tag , The controller must be using something to get the data right? How can we do it directly without using the controller?
        • P
          P
          pete1450
          @hek It looks like development is the default branch in the repository. I was following the build instructions and couldn't figure out why I kept getting "connection refused". Just typing up a troubleshooting post when I saw my log said 2.2.0-beta. Sure enough when I grabbed master(2.1.0) instead it ran fine. Should probably add a checkout in the instructions.
          • P pete1450
            #279
            @pete1450 could you clarify which instructions should be updated?
            The instructions at https://www.mysensors.org/about/arduino recommend using the Arduino IDE Board manager, which will get the latest stable version.
            Edit: Now I see. The link in the first post in this thread. It doesn't mention the master branch because up until Dec 25th the development branch was required. But now that 2.1 has been released the instructions should indeed use the stable version. I've updated the instructions. Thanks for noticing!
              Tag
              wrote on last edited by Tag
              #280
              @Shantanu-Mhapankar
              This is also new for me since i do not send data into any cloud... but i can imagine that you can use MQTT. (see https://www.mysensors.org/build/mqtt_gateway for more details) is important that the receiving side supports MQTT. in this case google is your friend ;)
              if you do a ./configure --help you will find you can build the mysensors gateway with MQTT support
              ./configure --help
                  --my-gateway=[ethernet|serial|mqtt]
                                              Gateway type, set to none to disable gateway feature. [ethernet]
                  --my-node-id=<ID>           Disable gateway feature and run as a node with given id.
                                              Controller or MQTT broker ip.
              • LaMB95L
                LaMB95L
                LaMB95
                ran sudo ./bin/mysgw -d
                I keep getting mysgw: accept: Bad File Descriptor.
                Any possible cause ?
                  This thread contains comments for the article "Building a Raspberry Pi Gateway" posted on MySensors.org.
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  I am trying to get the raspi ethernet gateway running but on both my pi 3 (also running openHAB) and the pi B (pretty basic install).
                  Unfortunately I get the same error on both.
                  Any ideas what could be going on here?
                  I am running the latest gateway and the latest raspbian.
                  mysgw: Starting gateway...
                  mysgw: Protocol version - 2.1.0
                  mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:INIT:TSP OK
                  mysgw: TSM:INIT:GW MODE
                  mysgw: MCO:REG:NOT NEEDED
                  mysgw: failed to connect
                  mysgw: Eth: connect
                  mysgw: Eth: connect
                  Fulltime Servoy Developer
                  LaMB95L M 2 Replies Last reply
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: Eth: connect
                    mysgw: Eth: connect
                    LaMB95L
                    LaMB95L
                    LaMB95
                    @marceltrapman
                    I am using a Rasp Pi 3 as well.
                    I can't even proceed further in the tutorial cause of this error cause nothing works after it.
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: Eth: connect
                      mysgw: Eth: connect
                      marceloaqno
                      Code Contributor
                      @marceltrapman @LaMB95
                      Could you post the complete ./configure command used to configure the gateway?
                      marceltrapmanM LaMB95L 2 Replies Last reply
                      • M marceloaqno
                        marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        @marceloaqno Sure, forgot it :)
                        sudo ./configure \
                            --my-gateway=ethernet \
                            --my-controller-ip-address=192.168.1.xx \
                            --my-port=5003 \
                            --my-transport=nrf24
                          sudo ./configure \
                              --my-port=5003 \
                          marceloaqno
                          Code Contributor
                          @marceltrapman Are you sure it's not a problem with your controller?
                          Have you tried connecting to your controller using telnet?
                          telnet 192.168.1.x 5003
                          marceltrapmanM 2 Replies Last reply
                          • M marceloaqno
                            LaMB95L
                            LaMB95L
                            LaMB95
                            wrote on last edited by LaMB95
                            #287
                            Is this what you meant?
                            • M marceloaqno
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              @marceloaqno not sure no.
                              So, I downloaded telnet on the same raspi that I want to use as the gateway and the issue seems to be that port 5003 is not available.
                              Funny but how do I solve this.
                              It can't be an issue with the firewall because it allows all traffic on the internal network.
                              • M marceloaqno
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                @marceloaqno and the same from the controller to the gateway gives the same error on that port :(
                                  marceloaqno
                                  Code Contributor
                                  @Reza Yes, you can use rs485 in the RPi.
                                  ./configure --my-transport=rs485 --my-rs485-serial-port=<YOUR_SERIAL_PORT>
                                  For more options, run:
                                  ./configure -h
                                  R 1 Reply Last reply
                                  • LaMB95L LaMB95
                                    marceloaqno
                                    Code Contributor
                                    @LaMB95 No, I meant the options you used when you ran ./configure
                                    LaMB95L 1 Reply Last reply
                                    • tianaT tiana
                                      Is it possible to use the second ISP on my raspberypi 3 to connect NRF24L01+ and what will be the wiring diagram, also what have to change in mygsw library
                                      marceloaqno
                                      Code Contributor
                                      @tiana
                                      "The Broadcom SoC has three independant SPI interfaces, however only one of these is brought out to the GPIO connector, and that one SPI interface has 2 Chip enable lines."
                                      More info here: https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=22608
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        wrote on last edited by marceltrapman
                                        #293
                                        @marceloaqno from the docs I assume it is the gateway that has to open up port 5003 but I guess it does not because it can't connect to the ethernet (for some reason) or am I wrong?
                                        marceltrapmanM M 2 Replies Last reply
                                        • M marceloaqno
                                          ./configure -h
                                          R
                                          R
                                          Reza
                                          @marceloaqno
                                          i means that without arduino and usb port, similar to raspberry gateway ( raspberry +nrf24)
                                          i means connect rs485 module to GPIO raspberry pi :) with domoticz
