  3. Template sketch for flexible use with many different sensor types
7 Posts 4 Posters 2.6k Views 4 Watching
  • Dave MyersD Offline
    Dave MyersD Offline
    Dave Myers
    I've created a companion Arduino sketch / library to go along with the MySensors library. The companion library is designed with flexibility and inheritance to allow easy configuration of attached sensors and actuators. I.e. just tell the library you want to add a gpio output, an analog input, a PWM output, ... and the library handles all the necessary code. This makes the base Arduino sketch much simpler and allows for easier configuration and programming of modules with different and varying features.
    I'm midway through development and have some more features to add, but I wanted to solicit some feedback to see if there were general ideas or concepts that I am missing. Note: I'm not a professional programmer and am learning some of this as I go!
    The software is specifically designed for (and only tested with) the Home Assistant controller - though I hope other controller software is compatible.
    Github here: https://github.com/brahmafear/MySensors_Node. Best starting point is the Arduino sketch listed in the examples folder.
    Cheers.
    Dave MyersD 2 Replies Last reply
    • Dave MyersD Dave Myers
      Cheers.
      Dave MyersD Offline
      Dave MyersD Offline
      Dave Myers
      @Dave-Myers said:
      Oops - forgot to add: for MySensors 2.x only.
        Cheers.
        Dave MyersD Offline
        Dave MyersD Offline
        Dave Myers
        @Dave-Myers
        Example of a full Arduino sketch with 4 sensors/actuators using this library:
        #include "MySensors_Node.h"
        MySensors_Node node("Sample", "0.01");
          MySensors_Node_Sensor_Gpio_Out nsgo( 11, "Simple LED 1", 5, true );
          node.add_sensor( &nsgo );
          node.add_sensor(  new MySensors_Node_Sensor_Gpio_In( 13, "Simple Motion", 2, true, INPUT_PULLUP, 500 ) );
          node.add_sensor(  new MySensors_Node_Sensor_Analog_In( 14, "Analog In", A0, true, 1024, 10000 ) );
          node.add_sensor(  new MySensors_Node_Sensor_Pwm( 15, "PWM LED", 6, true, true, 255 ) );
          node.present();
        void receive( const MyMessage &msg ) {
          node.receive( msg );
          node.setup();
          node.loop();
        fernando alvarez buyllaF 1 Reply Last reply
          @Dave-Myers
            node.present();
            node.setup();
            node.loop();
          fernando alvarez buyllaF Offline
          @Dave-Myers this is asoweme will try in this days but sound amazing thanks for sharing.
          • hekH Offline
            hekH Offline
            wrote on last edited by hek
            Looks great @Dave-Myers!
            This is an very nice start of the "Helper Classes" I was thinking of back in the old architecture document.
            Dave MyersD 1 Reply Last reply
              Dave MyersD Offline
              Dave MyersD Offline
              Dave Myers
              @hek
              Nice. Hadn't seen that doc before. Please let me know if there are any changes you suggest.
              • wesW Offline
                wesW Offline
                wes
                Have a look at https://github.com/mysensors/NodeManager/
                (I think this only became available since the last reply in this thread).
                Blog: https://www.wes.id.au/
                Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                Gateway & Controller: Raspberry Pi 3 + Home Assistant
