  3. Node only works for a few days
22 Posts 10 Posters 7.2k Views 7 Watching
  • Geert MassaG Geert Massa
    it looks like the node lost connection to the gateway.
    Had the same issue.
    Had to add a repeater between the node and gateway.
    Hopefully someone else knows a better solution.
    raptorjrR
    raptorjrR
    raptorjr
    @Geert-Massa
    Thank you for looking.
    I hope not a repeater is needed. They are only 2-3 meters apart. And that don't explain why it works for a few days after a restart.
    I have capacitors on both node and gateway, so that should not be a problem either.
    tekkaT 1 Reply Last reply
    • b0rmannB
      b0rmannB
      b0rmann
      ...same problem :(
      • wallyllamaW
        wallyllamaW
        wallyllama
        My wild guess would be a memory leak in the code. Turning on debug uses more memory so it takes less time to fail.
        • F
          F
          Fabien
          First switch your gateway to 2.1.0 stable.
          I think sensors.begin must be in setup not in loop.
          And I think you have perhaps TX problem on gateway side (after reading logs).
          Retry with 2.1.0 on both sides, compile node sketch with sensors.begin in setup, turn on log on node and gw.
          When you have failure, try to reboot only gateway and wait until node try to find parent. Make the same test but this time reboot only node.
          raptorjrR 1 Reply Last reply
          • raptorjrR raptorjr
            @Geert-Massa
            tekkaT
            tekkaT
            tekka
            @raptorjr Looking at your logs
            GW log, line 578
            mysgw: TSF:MSG:READ,1-1-0,s=171,c=5,t=42,pt=7,l=13,sg=0:30713023823872.00000000
            mysgw: !TSF:MSG:LEN,12!=20
            I assume a power/bad cable issue and/or a EMP interference caused by a switching relay.
            • F Fabien
              raptorjrR
              raptorjrR
              raptorjr
              Will try this first. To me it feels that if it was something wrong with the hardware in some way it would happen right away, not only after a few days.
              But I'll start with this before I consider to buy new hardware.
                Before buying new hw it's better to do some cross tests to pin point where the problem is.
                • FotoFieberF
                  FotoFieberF
                  FotoFieber
                  I had a similar problem with the control of a heating mixer and three dallas sensors. I solved the problem with:
                  • replacement of the relays with solid state relays
                  • moved conttroller more in distance of the high voltage parts
                  I also added a watchdog and a reboot mechanism in case of sensor problems.
                  Maybe this sketch can give you an inspiration: (work in progress, MYS-Part not tested in depth)
                  //#define MY_DEBUG      // in Mysensors
                  #define EN_DEBUG      // in this sketch
                  //#define NO_MYS      // ohne Mysensors Unterstützung?
                  //#define SIMULATION
                  #define NO_AC_DETECT  // ohne AC sensor
                  #define NO_RTC
                  // RTC nur zusammen mit Mysensors
                  #ifdef NO_MYS
                  #ifndef NO_RTC
                  #define NO_RTC
                  #ifdef SIMULATION
                  // für Simulation ohne Sensoren
                  #define SIMULATE_VOR  35
                  #define SIMULATE_RUE  30
                  #define SIMULATE_ZU   65
                  #ifdef SIMULATE_VOR
                  #warning Achtung! Keine Echtentemperaturmessungen -> Simulation
                  #ifdef SIMULATE_RUE
                  #ifdef SIMULATE_ZU
                  #define START_TARGET_TEMP 40
                  #define EEPROM_TARGET_TEMP 900            // Save Porisiton. It is above the Mysensors range of lib 2.1
                  #define EEPROM_POWERSTATE  902            // Save Porisiton. It is above the Mysensors range of lib 2.1
                  #define MAX_TEMP 50
                  #define VORLAUF 0
                  #define RUECKLAUF 1
                  #define ZULAUF 2
                  #define PUMPE 0
                  #define MISCHER_ZU  1
                  #define MISCHER_AUF 2
                  #define POWERLED 7                        // 8. LED
                  #define TEMPDOWNLED 5                     // 6. Led
                  #define TEMPUPLED 6                       // 7. Led
                  #ifndef NO_AC_DETECT
                  #define BUDERUSLED 4                      // 5. Led
                  #define RETRY_TIMEOUT_PUMP 2*60*1000UL     // alle 2 Minuten testen, ob Vorlauf nicht besser (5 Sekunden pumpen)
                  #define REGULATION_TIMEOUT_PUMP 30*1000UL  // 30 Sekunden warten nach neuer Einstellung
                  #define PROBE_TIMEOUT_PUMP 5*1000UL        // 5 Sekunden Pumpe für Test einschalten, wenn Zulauf zu kalt
                  #define BUDERUS_PIN 3                     // Buderus Powererkennung Pumpe auf PIN 3
                  #ifndef SIMULATION
                  #define MISCHER_RESET_TIME 120*1000UL      // 2 Minuten bis Nullstellung
                  #define MISCHER_RESET_TIME 10*1000UL      // 10 Sekunden bis Nullstellung nei Simulation
                  #ifdef EN_DEBUG
                  #define DEBUG_PRINT(x) Serial.print (x)
                  #ifdef EN_DEBUG
                  #define DEBUG_PRINTLN(x)  Serial.println (x)
                  #ifndef NO_MYS
                  // Radio Configuration
                  #define MY_TRANSPORT_WAIT_READY_MS (10000ul)
                  #define MY_RADIO_RFM69
                  #define MY_RFM69_FREQUENCY RF69_868MHZ
                  #define MY_RFM69_NETWORKID 13
                  #define MY_RFM69_ENABLE_ENCRYPTION
                  #define MY_NODE_ID 168
                  //#define MY_IS_RFM69HW
                  #include <Arduino.h>
                  #include <avr/wdt.h>
                  #include <EEPROM.h>
                  #include <MemoryFree.h>
                  #ifndef NO_MYS
                  #define MIN_REPORT_INTERVAL  5 * 60 * 1000L   // mindestens alle 5 Minuten melden
                  #include <Time.h>        //http://www.arduino.cc/playground/Code/Time
                  #include <Timezone.h>    //https://github.com/JChristensen/Timezone
                  #include <TimeLib.h>
                  //Central European Time (Frankfurt, Paris)
                  TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 120};     //Central European Summer Time
                  TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, 60};       //Central European Standard Time
                  Timezone CE(CEST, CET);
                  bool timeReceived = false;
                  unsigned long lastUpdate = 0, lastRequest = 0;
                  #ifndef NO_RTC
                  #include <DS3232RTC.h>  // A  DS3231/DS3232 library
                  #define MAX_LEDS 8
                  byte lastButtonState = 0;
                  #define RELAY_ON HIGH
                  #define RELAY_OFF LOW
                  #define RELAY_1  A0         // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                  #define NUMBER_OF_RELAYS 4  // Total number of attached relays
                  boolean ledState[MAX_LEDS] = { false, false, false, false, false, false, false, false };
                  boolean relState[NUMBER_OF_RELAYS] = { false, false, false, false };
                  #include <TM1638.h>
                  #include <OneWire.h>
                  #define ONE_WIRE_BUS 6 // Pin where dallase sensor is connected
                  #define TEMPERATURE_PRECISION 9
                  #define MAX_ATTACHED_DS18B20 3
                  //28B404080000804A
                  DeviceAddress Probe01 = { 0x28, 0xB4, 0x04, 0x08, 0x00, 0x00, 0x80, 0x4A };
                  //28C606080000803F
                  DeviceAddress Probe02 = { 0x28, 0xC6, 0x06, 0x08, 0x00, 0x00, 0x80, 0x3F };
                  //28750808000080C3
                  DeviceAddress Probe03 = { 0x28, 0x75, 0x08, 0x08, 0x00, 0x00, 0x80, 0xC3 };
                  int numSensors = 0;
                  int lastTemperature[MAX_ATTACHED_DS18B20] = { -100, -100, -100 };
                  int16_t conversionTime;
                  unsigned long previousTempMillis = -1;
                  static unsigned long nowms = millis();    // update at start of loop()
                  // define LCD module
                  TM1638 ledModule(8, 9, 7);
                  int displayInfo = -1;
                  unsigned long previousDisplayMillis = 0;
                  int targetTemp = START_TARGET_TEMP;
                  #ifdef SIMULATION
                  bool powerOn = true;
                  bool powerOnBuderus = true;
                  bool powerOn = false;
                  bool powerOnBuderus = false;
                  bool resetMischer = true; // mischer zuerst in Nullstellung
                  bool testStateBuderus = false;
                  unsigned long lastResetBuderus = -1;
                  #ifndef NO_MYS
                  // Initialize messages
                  MyMessage msgTemp(0, V_TEMP);
                  MyMessage msgStatus(0, V_STATUS);
                  MyMessage msgTargetTemp(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS, V_HVAC_SETPOINT_HEAT);
                  MyMessage msgPower(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 1, V_STATUS);
                  MyMessage msgPowerBuderus(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 2, V_STATUS);
                  MyMessage msgDebug(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 3, V_TEXT);
                  // the setup function runs once when you press reset or power the board
                    DEBUG_PRINTLN(F("Starte setup"));
                    wdt_enable(WDTO_8S);
                  #ifndef NO_RTC
                    // the function to get the time from the RTC
                    setSyncProvider(RTC.get);
                  #ifndef NO_MYS
                    // Request latest time from controller at startup
                    requestTime();
                    // Zieltemperatur aus EERPOM lesem:
                    targetTemp = EEPROM.read(EEPROM_TARGET_TEMP);
                    if ((targetTemp < 30) || (targetTemp > MAX_TEMP)) {
                      EEPROM.write(EEPROM_TARGET_TEMP, targetTemp);
                    int state = EEPROM.read(EEPROM_POWERSTATE);
                    if (state == 0) {
                      powerOn = false;
                    else powerOn = true;
                    // Buderuserkennung auf PIN3
                    attachInterrupt(digitalPinToInterrupt(BUDERUS_PIN), buderusSet, CHANGE);
                    lastResetBuderus = millis();
                  #ifndef NO_MYS
                    send(msgPowerBuderus.set(powerOnBuderus));
                    // Relayausgänge initialisiern
                    for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                      pinMode(pin, OUTPUT);
                      digitalWrite(pin, RELAY_OFF);
                    // Dallas Temperatursensoren
                    sensors.begin();
                    DEBUG_PRINT(F("Dallas Sensoren "));
                    DEBUG_PRINTLN(numSensors);
                    DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
                    for (int i = 0; i < numSensors; i++)
                      wdt_reset();
                      // Search the wire for address
                      if (sensors.getAddress(tempDeviceAddress, i))
                        DEBUG_PRINT(F("Found device "));
                  #ifdef EN_DEBUG
                        Serial.print(i, DEC);
                        DEBUG_PRINT(F(" with address: "));
                        printAddress(tempDeviceAddress);
                        DEBUG_PRINTLN();
                        DEBUG_PRINT(F("Setting resolution to "));
                  #ifdef EN_DEBUG
                        Serial.println(TEMPERATURE_PRECISION, DEC);
                        // set the resolution to 12 bit (Each Dallas/Maxim device is capable of several different resolutions)
                        sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
                        DEBUG_PRINT(F("Resolution actually set to: "));
                  #ifdef EN_DEBUG
                        Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
                        DEBUG_PRINTLN();
                        DEBUG_PRINT(F("Found ghost device at "));
                  #ifdef EN_DEBUG
                        DEBUG_PRINT(F(" but could not detect address. Check power and cabling"));
                    wdt_reset();
                    conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
                  // the loop function runs over and over again forever
                    nowms = millis();
                  #ifndef NO_MYS
                    // If no time has been received yet, request it every 10 second from controller
                    // When time has been received, request update every hour
                    if ((!timeReceived && (nowms - lastRequest) > (10UL * 1000UL))
                        || (timeReceived && (nowms - lastRequest) > (60UL * 1000UL * 60UL))) {
                      // Request time from controller.
                      DEBUG_PRINTLN("requesting time");
                      requestTime();
                      lastRequest = nowms;
                    wdt_reset();
                    readAC();
                    readTemp();
                    readButtons();
                    updateDisp();
                    // Temperaturen senden
                  #ifndef NO_MYS
                    sendTemp();
                    // Kontroller
                    control();
                    // Loop 2x pro Sekunde ist aureichend
                    unsigned long loopTime = millis() - nowms;
                    if (loopTime < 450) {
                  #ifdef NO_MYS
                      delay (500 - loopTime);
                      wait (500 - loopTime);
                  // end loop
                  // Steuerung
                  void control()
                    wdt_reset();
                    static unsigned long lastPumpTest = 0;
                    static unsigned long lastRegulation = -REGULATION_TIMEOUT_PUMP;
                    static unsigned long resetStart = 0;                     // wann wurde die Rücksetzung des Mischers gestartet
                    static bool lastPower = powerOn;
                    static float moveSeconds = 0.0;                 // Zeiten für Stellmotor Mischer
                    // controllerState
                    // 0 initialized
                    // 1 Pumpe für kurzen test aktiviert, warten auf Timeout für Deaktivierung
                    // 2 in der Regelung, warten auf Timeout für Deaktivierung
                    // 3 in Ausganglage fahren
                    static int controllerState = 0;
                    // Emergency
                    if  (lastTemperature[VORLAUF] > MAX_TEMP) {
                      if (resetStart == 0) {
                        if (relState[PUMPE]) {
                          DEBUG_PRINT(F("Zu heiss. Emergency Mischer schliessen"));
                          DEBUG_PRINTLN(lastTemperature[VORLAUF]);
                        closeMischer();
                        return;
                    // Temperatur noch nicht gelesen;
                    if (lastTemperature[VORLAUF] == -100) return;
                    // Fehler mit den Sensoren
                    if ((lastTemperature[VORLAUF] < 0) ||
                        (lastTemperature[VORLAUF] > 100) ||
                        (lastTemperature[RUECKLAUF] < 0) ||
                        (lastTemperature[RUECKLAUF] > 100) ||
                        (lastTemperature[ZULAUF] < 0) ||
                        (lastTemperature[ZULAUF] > 100)) {
                      relState[PUMPE] = false;
                      updateRelays();
                      ledState[PUMPE] = relState[PUMPE];
                      // Test
                      //powerOn = false;
                  #ifndef NO_MYS
                      //send(msgPower.set(powerOn));
                      DEBUG_PRINTLN(F("Fehler mit den Sensoren, Temperaturen unter 0 oder über 100. Poweroff!"));
                      return;
                    if (resetMischer) {
                      DEBUG_PRINTLN(F("Mischer initialisieren"));
                      closeMischer();
                      resetStart = millis();
                      resetMischer = false;
                      return;
                    if (resetStart > 0) {
                      if ((millis() - resetStart) > MISCHER_RESET_TIME) {
                        DEBUG_PRINTLN(F("Mischer fertig initialisiert"));
                        relState[MISCHER_ZU] = false;
                        updateRelays();
                        ledState[MISCHER_ZU] = relState[MISCHER_ZU];
                        resetStart = 0;
                      return;
                    // wenn ausser Betrieb -> verlassen;
                    if (powerOn == false) {
                      if (lastPower == false) return;
                      DEBUG_PRINTLN("Go to power off state");
                  #ifndef NO_MYS
                      lastPower = false;
                      relState[MISCHER_AUF] = false;
                      updateRelays();
                      ledState[MISCHER_AUF] = relState[MISCHER_AUF];
                      EEPROM.write(EEPROM_POWERSTATE, 0);
                      return;
                    //DEBUG_PRINTLN("a");
                    lastPower = true;
                    switch (controllerState) {
                      case  0:  // Initialisiert
                        if (lastTemperature[ZULAUF] < 30) {
                          if ((millis() - lastPumpTest) > RETRY_TIMEOUT_PUMP) {
                            controllerState = 1;
                            lastPumpTest = millis();
                            DEBUG_PRINTLN(F("Zulauf zu kalt. Schalte Pumpe für 5 Sekunden ein."));
                            relState[PUMPE] = true;
                            updateRelays();
                          return;
                        //DEBUG_PRINTLN("x");
                        updateRelays();
                        // nicht regulieren, wenn schon genau genug
                        if (abs(lastTemperature[VORLAUF] - targetTemp) <= 1) {
                          // DEBUG_PRINTLN("diff zu klein, keine Steuerung notwendig");
                          return;
                        if ((millis() - lastRegulation) > REGULATION_TIMEOUT_PUMP) {
                          controllerState = 2;
                          lastRegulation = millis();
                          int diffZualaufRuecklauf = lastTemperature[ZULAUF] - lastTemperature[RUECKLAUF];
                          float actPercent = (float)(lastTemperature[VORLAUF] - lastTemperature[RUECKLAUF]) * 100.0 / (float)diffZualaufRuecklauf;
                          float shoulPercent = (float)(targetTemp - lastTemperature[RUECKLAUF]) * 100.0 / (float)diffZualaufRuecklauf;
                          // 120 Sekunden für ganzen Weg
                          moveSeconds = (float)MISCHER_RESET_TIME / 1000.0 / 100.0 * abs(shoulPercent - actPercent);
                          DEBUG_PRINT(F("Berechnete Sekunden fuer Mischerumstellung "));
                          DEBUG_PRINTLN(moveSeconds);
                          if (moveSeconds > 8)
                            moveSeconds = 8;
                          if (targetTemp > lastTemperature[VORLAUF]) {
                            DEBUG_PRINTLN(F("Mischer auf"));
                            relState[MISCHER_AUF] = true;
                            updateRelays();
                            DEBUG_PRINTLN(F("Mischer zu"));
                            relState[MISCHER_ZU] = true;
                            updateRelays();
                          return;
                        return;
                      case  1: // in Testmodus bei zu wenig  Temp im Zulauf
                        if ((millis() - lastPumpTest) > PROBE_TIMEOUT_PUMP) {
                          updateRelays();
                          DEBUG_PRINTLN(F("Pumpe ausgeschaltet"));
                        return;
                      case  2: // in der Regelung
                        if ((millis() - lastRegulation) > moveSeconds * 1000.0) {
                          DEBUG_PRINTLN("Mischer zu.");
                          updateRelays();
                        return;
                      default:
                        DEBUG_PRINT(F("ERROR, unknown state :"));
                        DEBUG_PRINTLN(controllerState);
                        return;
                  // function to print a device address
                  void printAddress(DeviceAddress deviceAddress)
                    for (uint8_t i = 0; i < 8; i++)
                      if (deviceAddress[i] < 16) DEBUG_PRINT("0");
                  #ifdef EN_DEBUG
                      Serial.print(deviceAddress[i], HEX);
                  void updateRelays() {
                    static boolean relayStateReported[8] = { false, false, false, false, false, false, false, false };
                  #ifndef NO_MYS
                    static unsigned long previousStateMillis[NUMBER_OF_RELAYS] = { 0, 0, 0, 0 };
                    for (int i = 0; i < NUMBER_OF_RELAYS; i++) {
                      if (relState[i]) {
                        digitalWrite(RELAY_1 + i, RELAY_ON);
                        digitalWrite(RELAY_1 + i, RELAY_OFF);
                  #ifndef NO_MYS
                      bool bSend = false;
                      if (previousStateMillis[i] == 0) {                               // noch nie gesendet
                        bSend = true;
                      else if (relayStateReported[i] != relState[i] ) { // Änderungen melden
                        bSend = true;
                      else if ((millis() - previousStateMillis[i]) > MIN_REPORT_INTERVAL) {
                        bSend = true;
                      if (bSend) {
                        // TODO: Check if we want to look at the return value of send
                        send(msgStatus.setSensor(i + MAX_ATTACHED_DS18B20).set(relState[i] ? 1 : 0));
                        previousStateMillis[i] = millis();
                        relayStateReported[i] = relState[i];
                  void updateDisp() {
                    static char s[8];
                    static unsigned long previousDisplayMillis = 0;
                    // update display?
                    if ((millis() - previousDisplayMillis) > 1000) {
                      previousDisplayMillis = millis();
                      displayInfo++;
                  #ifdef NO_MYS
                      if (displayInfo > 4) displayInfo = 0;
                      if (displayInfo > 5) displayInfo = 0;
                      ledModule.clearDisplay();
                      // sind die Temperaturen schon gelesen worden? Wenn nicht, abbrechen.
                      if (lastTemperature[0] == -100) return;
                      for (byte i = 0; i <= 7; i++) {
                        if (ledState[i])
                          ledModule.setLED(1, i);
                          ledModule.setLED(0, i);
                      // 0 Vorlauf, 1 Rücklauf, 2 Zulauf, 3 Sollwert
                      switch (displayInfo) {
                        case 0: // Vorlauf
                          sprintf(s, "Vor %2i",  lastTemperature[VORLAUF]);
                        case 1: // Rücklauf
                          sprintf(s, "Rue %2i",  lastTemperature[RUECKLAUF]);
                        case 2: // Zulauf
                          sprintf(s, "Zu %2i",  lastTemperature[ZULAUF]);
                        case 3: // Zielwert
                          sprintf(s, "Soll %2i",  targetTemp);
                        case 4: // Power
                          if (powerOn) {
                            sprintf(s, "PowerOn");
                          else {
                            sprintf(s, "PowerOff");
                  #ifndef NO_MYS
                        case 5: //clock
                          TimeChangeRule *tcr;
                          time_t utc = millis();
                          time_t t = CE.toLocal(utc, &tcr);
                          unsigned long dispTime = hour(t) * 100 * 100 + minute(t) * 100 + second(t);
                          if (hour(t) < 10) {
                            sprintf(s, "U 0%lu",  dispTime);
                            sprintf(s, "U %lu",  dispTime);
                      ledModule.setDisplayToString(s);
                  void closeMischer() {
                    updateRelays();
                  #ifndef NO_MYS
                  void before()
                    sendSketchInfo("Mischer Node", "1.1");
                    DEBUG_PRINT(F("Numsensors "));
                    for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                      present(i, S_TEMP);
                    for (int sensor = MAX_ATTACHED_DS18B20, pin = RELAY_1; sensor < (MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS); sensor++, pin++) {
                      present(sensor, S_BINARY);
                    // Thermopunkt
                    present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS, S_HVAC);
                    // Power
                    present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 1, S_HEATER);
                    // AC Buderuus
                    present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 2, S_BINATY);
                    // Power
                    present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 3, S_INFO);
                    // Initialltemperatur mitteilen
                    send(msgTargetTemp.set(targetTemp));
                  void receive(const MyMessage & message)
                    DEBUG_PRINT(F("Meldung an Sensor "));
                    DEBUG_PRINT(message.sensor);
                    DEBUG_PRINT(F(" mit type "));
                    DEBUG_PRINTLN(message.type);
                      int i = message.sensor - MAX_ATTACHED_DS18B20;
                      if ((i >= 0) && (i < NUMBER_OF_RELAYS)) {
                        DEBUG_PRINT(F("Schaltbefehl für Relay "));
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" auf "));
                        DEBUG_PRINTLN(message.getBool());
                        relState[i] = message.getBool();
                        ledState[i] = relState[i];
                      else if (i == MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 1) {
                        powerOn = message.getBool();
                        if (powerOn)
                          EEPROM.write(EEPROM_POWERSTATE, 1);
                          ledState[POWERLED] = false;
                          DEBUG_PRINTLN(F("Befehl für PowerOff"));
                        else {
                          ledState[POWERLED] = true;
                          DEBUG_PRINTLN(F("Befehl für PowerOn"));
                      updateRelays();
                    else if (message.type == V_HVAC_SETPOINT_HEAT) {
                      if (message.sensor == (MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS)) {
                        targetTemp = message.getInt();
                        DEBUG_PRINT(F("Zieltemp gesetzt auf "));
                        DEBUG_PRINTLN(targetTemp);
                        if (targetTemp > MAX_TEMP) targetTemp = START_TARGET_TEMP;
                        if (targetTemp < 20) targetTemp = 20;
                    // Ok, set incoming time
                    DEBUG_PRINT(F("Time value received: "));
                    DEBUG_PRINTLN(controllerTime);
                  #ifndef NO_RTC
                    RTC.set(controllerTime);
                      setTime(controllerTime);
                    timeReceived = true;
                  void sendTemp() {
                    static int lastSentTemperature[MAX_ATTACHED_DS18B20] = { -100, -100, -100 };
                    static unsigned long previousTempMillis[MAX_ATTACHED_DS18B20] = { 0, 0, 0 };
                    for (int i = 0; i < MAX_ATTACHED_DS18B20 ; i++) {
                      if (lastTemperature[i] != -100) {
                        bool bSend = false;
                        if (previousTempMillis[i] == 0) {                               // noch nie gesendet
                          bSend = true;
                        else if (abs(lastSentTemperature[i] - lastTemperature[i]) >= 2) { // Differenz von >= zwei Grad werden gemeldet
                          bSend = true;
                        else if ((millis() - previousTempMillis[i]) > MIN_REPORT_INTERVAL) {
                          bSend = true;
                        if (bSend) {
                          send(msgTemp.setSensor(i).set(lastTemperature[i], 1));
                          previousTempMillis[i] = millis();
                          lastSentTemperature[i] = lastTemperature[i];
                  void buderusSet() {
                    testStateBuderus = true;
                  void reboot() {
                    wdt_enable(WDTO_30MS);
                    while (1) {};
                  void readButtons() {
                    byte buttons = ledModule.getButtons();
                    if (lastButtonState != buttons) {
                      lastButtonState = buttons;
                      if (buttons > 0) {
                          if ((buttons >> i) & 1) {
                            ledState[i] = !ledState[i];
                            if (i < NUMBER_OF_RELAYS) relState[i] = ledState[i];
                            updateRelays();
                            if (ledState[i])
                            if (i == POWERLED) {
                              powerOn = ledState[i];
                  #ifndef NO_MYS
                              if (powerOn)
                            if (i == TEMPDOWNLED) {
                              targetTemp--;
                              if (targetTemp < 30) targetTemp = 30;
                            if (i == TEMPUPLED) {
                              targetTemp++;
                              if (targetTemp > MAX_TEMP) targetTemp = MAX_TEMP;
                            DEBUG_PRINT(F("ButtonState changed "));
                            DEBUG_PRINTLN(i);
                  void readTemp() {
                    static float temp;
                    static int tempi;
                    static unsigned long lastReadTemp1 = -1;
                    static unsigned long lastReadTemp2 = -1;
                    static unsigned long lastReadTemp3 = -1;
                    if (previousTempMillis == -1) {
                      // Dallas
                      previousTempMillis = nowms;
                    if ((millis() - previousTempMillis) >= conversionTime) {
                      temp = sensors.getTempC(Probe01);
                      if (temp != DEVICE_DISCONNECTED_C) {
                        tempi = (int)(temp + 0.5);
                        lastTemperature[VORLAUF] = tempi;
                        lastReadTemp1 = nowms;
                        temp = sensors.getTempC(Probe02);
                        lastTemperature[RUECKLAUF] = tempi;
                        lastReadTemp2 = nowms;
                        temp = sensors.getTempC(Probe03);
                        lastTemperature[ZULAUF] = tempi;
                        lastReadTemp3 = nowms;
                      if (nowms > 60000) {    // ersta nach einer minute prüfen
                        unsigned long compare = nowms - 60000; // vor 1 Minute
                        if ((lastReadTemp1 < compare) || (lastReadTemp2 < compare) || (lastReadTemp3 < compare)) {
                          DEBUG_PRINTLN(F("Zu lange keine Temeratur -> reset"));
                          lastReadTemp1 = -1;
                          lastReadTemp2 = -1;
                          lastReadTemp3 = -1;
                          ledModule.setDisplayToString(F("ERR Reb"));
                          delay(1000);
                          reboot();
                  #ifdef SIMULATE_VOR
                    lastTemperature[VORLAUF] = SIMULATE_VOR;
                  #ifdef SIMULATE_RUE
                    lastTemperature[RUECKLAUF] = SIMULATE_RUE;
                  #ifdef SIMULATE_ZU
                    lastTemperature[ZULAUF] = SIMULATE_ZU;
                  void readAC() {
                    if ((millis() - lastResetBuderus) > 100) // bei 50 HZ sind das 25 Durchgänge...
                      noInterrupts();
                      if (testStateBuderus != powerOnBuderus ) {
                        powerOnBuderus = testStateBuderus;
                        interrupts();
                        ledState[BUDERUSLED] = powerOnBuderus;
                  #ifndef NO_MYS
                      lastResetBuderus = nowms;
                    } else
                      interrupts();
                  • FotoFieberF FotoFieber
                    #define NO_RTC
                    #ifdef NO_MYS
                    #ifndef NO_RTC
                    #define NO_RTC
                    #ifdef SIMULATION
                    #ifdef SIMULATE_VOR
                    #ifdef SIMULATE_RUE
                    #ifdef SIMULATE_ZU
                    #define MAX_TEMP 50
                    #define VORLAUF 0
                    #define RUECKLAUF 1
                    #define ZULAUF 2
                    #define PUMPE 0
                    #ifndef SIMULATION
                    #ifdef EN_DEBUG
                    #ifdef EN_DEBUG
                    #ifndef NO_MYS
                    #include <EEPROM.h>
                    #ifndef NO_MYS
                    #ifndef NO_RTC
                    #define MAX_LEDS 8
                    #include <TM1638.h>
                    //28B404080000804A
                    //28C606080000803F
                    //28750808000080C3
                    int numSensors = 0;
                    #ifdef SIMULATION
                    #ifndef NO_MYS
                    #ifndef NO_RTC
                    #ifndef NO_MYS
                      requestTime();
                      if (state == 0) {
                        powerOn = false;
                    #ifndef NO_MYS
                      sensors.begin();
                        wdt_reset();
                    #ifdef EN_DEBUG
                          DEBUG_PRINTLN();
                    #ifdef EN_DEBUG
                    #ifdef EN_DEBUG
                          DEBUG_PRINTLN();
                    #ifdef EN_DEBUG
                      wdt_reset();
                      nowms = millis();
                    #ifndef NO_MYS
                        requestTime();
                      wdt_reset();
                      readAC();
                      readTemp();
                      readButtons();
                      updateDisp();
                    #ifndef NO_MYS
                      sendTemp();
                      // Kontroller
                      control();
                    #ifdef NO_MYS
                    // end loop
                    // Steuerung
                    void control()
                      wdt_reset();
                      // controllerState
                      // 0 initialized
                      // Emergency
                          closeMischer();
                          return;
                        updateRelays();
                        // Test
                        //powerOn = false;
                    #ifndef NO_MYS
                        return;
                      if (resetMischer) {
                        closeMischer();
                        return;
                          updateRelays();
                          resetStart = 0;
                        return;
                    #ifndef NO_MYS
                        lastPower = false;
                        updateRelays();
                        return;
                      lastPower = true;
                              updateRelays();
                            return;
                          updateRelays();
                            return;
                              moveSeconds = 8;
                              updateRelays();
                              updateRelays();
                            return;
                          return;
                            updateRelays();
                          return;
                            updateRelays();
                          return;
                        default:
                          return;
                    #ifdef EN_DEBUG
                    #ifndef NO_MYS
                        if (relState[i]) {
                    #ifndef NO_MYS
                        bool bSend = false;
                          bSend = true;
                          bSend = true;
                          bSend = true;
                        if (bSend) {
                    void updateDisp() {
                      static char s[8];
                      // update display?
                        displayInfo++;
                    #ifdef NO_MYS
                          if (ledState[i])
                          case 0: // Vorlauf
                          case 1: // Rücklauf
                          case 2: // Zulauf
                          case 3: // Zielwert
                          case 4: // Power
                            if (powerOn) {
                            else {
                    #ifndef NO_MYS
                          case 5: //clock
                            if (hour(t) < 10) {
                      updateRelays();
                    #ifndef NO_MYS
                    void before()
                        present(i, S_TEMP);
                      // Thermopunkt
                      // Power
                      // AC Buderuus
                      // Power
                          DEBUG_PRINT(i);
                          if (powerOn)
                          else {
                        updateRelays();
                    #ifndef NO_RTC
                    void sendTemp() {
                          bool bSend = false;
                            bSend = true;
                            bSend = true;
                            bSend = true;
                          if (bSend) {
                    void buderusSet() {
                    void reboot() {
                      while (1) {};
                        if (buttons > 0) {
                              updateRelays();
                              if (ledState[i])
                    #ifndef NO_MYS
                                if (powerOn)
                                targetTemp--;
                                targetTemp++;
                              DEBUG_PRINTLN(i);
                    void readTemp() {
                      static float temp;
                      static int tempi;
                        // Dallas
                            lastReadTemp1 = -1;
                            lastReadTemp2 = -1;
                            lastReadTemp3 = -1;
                            delay(1000);
                            reboot();
                    #ifdef SIMULATE_VOR
                    #ifdef SIMULATE_RUE
                    #ifdef SIMULATE_ZU
                    void readAC() {
                        noInterrupts();
                          interrupts();
                    #ifndef NO_MYS
                      } else
                        interrupts();
                    raptorjrR
                    raptorjrR
                    raptorjr
                    @FotoFieber
                    That was very advanced =) I don't have any high voltage involved. Only have a test setup on a breadboard.
                    I tried to move the sensors.begin to the setup, but then I don't get any temperature readings?
                      Try post your code so we can take a look. Did you cross check the hw yet?
                        raptorjrR
                        raptorjrR
                        raptorjr
                        @gohan
                        It is the same sketch as my second post.
                        Haven't done anything with the hardware yet. Was following Fabiens advice with using 2.1 on both sketch and gateway. And restart gateway with problem. And then test again and restart node when the problem occurs.
                        • Darren McInnesD
                          Darren McInnesD
                          Darren McInnes
                          You may want to check which version of the onewire library you are running. I was having exactly the same issue and fixed it by upgrading the onewire library from 2.7.2 (I think?) To the latest version.
                          It's been a few weeks now with no crashes.
                          • Darren McInnesD Darren McInnes
                            raptorjrR
                            raptorjrR
                            raptorjr
                            In the Arduino IDE version 2.3.2 seems to be the latest. But is there a newer one that I can download and install?
                            Maybe should figure out why I don't get any sensor readings when I have sensors.begin() in the setup. Maybe that is a problem also that I have it in the loop()?
                            • Darren McInnesD
                              Darren McInnesD
                              Darren McInnes
                              Sorry i meant the dallastemperature library!
                              i'm running 3.7.5 now without issues but had problems after a day with 3.7.2
                              my ide version is 1.6.9 and onewire version 2.3.2
                                raptorjrR
                                raptorjrR
                                raptorjr
                                @Darren-McInnes
                                I have 3.7.6 installed. On thing might just be updated libraries. I have been using Visual Studio for development with the plugin from Visual Micro. But then the libraries don't get updated. Had some problems with a update from Visual Micro so I went back to the Arduino IDE.
                                Have been running since Monday now. Although it could take more than a week before any problem, but I'm keeping my fingers crossed.
                                gohanG 1 Reply Last reply
                                  @Darren-McInnes
                                  @raptorjr
                                  I am also using visual studio but libraries and boards get updated through the arduino ide without problems
                                    @raptorjr
                                    raptorjrR
                                    raptorjrR
                                    raptorjr
                                    @gohan
                                    But if you never open the Arduino IDE it can't get updated? Or are you saying that they get updated through Visual Studio?
                                    I hadn't used the IDE for several months. Thought I was a step closer to the problem and that it was bugs in older libraries.
                                      @gohan
                                      @raptorjr
                                      Visual Studio uses libraries from Arduino ide, so the only way to get updates is through the Arduino ide unless you install libraries manually. So it's a good thing to open Arduino ide every now and then if you want updates
