  3. Node only works for a few days
22 Posts 10 Posters 7.2k Views 7 Watching
  • raptorjrR raptorjr
    @Geert-Massa
    Thank you for looking.
    I hope not a repeater is needed. They are only 2-3 meters apart. And that don't explain why it works for a few days after a restart.
    I have capacitors on both node and gateway, so that should not be a problem either.
    tekkaT
    tekkaT
    tekka
    @raptorjr Looking at your logs
    GW log, line 578
    mysgw: TSF:MSG:READ,1-1-0,s=171,c=5,t=42,pt=7,l=13,sg=0:30713023823872.00000000
    mysgw: !TSF:MSG:LEN,12!=20
    I assume a power/bad cable issue and/or a EMP interference caused by a switching relay.
    • F Fabien
      First switch your gateway to 2.1.0 stable.
      I think sensors.begin must be in setup not in loop.
      And I think you have perhaps TX problem on gateway side (after reading logs).
      Retry with 2.1.0 on both sides, compile node sketch with sensors.begin in setup, turn on log on node and gw.
      When you have failure, try to reboot only gateway and wait until node try to find parent. Make the same test but this time reboot only node.
      raptorjrR
      raptorjrR
      raptorjr
      Will try this first. To me it feels that if it was something wrong with the hardware in some way it would happen right away, not only after a few days.
      But I'll start with this before I consider to buy new hardware.
        Before buying new hw it's better to do some cross tests to pin point where the problem is.
        • FotoFieberF
          FotoFieberF
          FotoFieber
          I had a similar problem with the control of a heating mixer and three dallas sensors. I solved the problem with:
          • replacement of the relays with solid state relays
          • moved conttroller more in distance of the high voltage parts
          I also added a watchdog and a reboot mechanism in case of sensor problems.
          Maybe this sketch can give you an inspiration: (work in progress, MYS-Part not tested in depth)
          //#define MY_DEBUG      // in Mysensors
          #define EN_DEBUG      // in this sketch
          //#define NO_MYS      // ohne Mysensors Unterstützung?
          //#define SIMULATION
          #define NO_AC_DETECT  // ohne AC sensor
          #define NO_RTC
          // RTC nur zusammen mit Mysensors
          #ifdef NO_MYS
          #ifndef NO_RTC
          #define NO_RTC
          #ifdef SIMULATION
          // für Simulation ohne Sensoren
          #define SIMULATE_VOR  35
          #define SIMULATE_RUE  30
          #define SIMULATE_ZU   65
          #ifdef SIMULATE_VOR
          #warning Achtung! Keine Echtentemperaturmessungen -> Simulation
          #ifdef SIMULATE_RUE
          #ifdef SIMULATE_ZU
          #define START_TARGET_TEMP 40
          #define EEPROM_TARGET_TEMP 900            // Save Porisiton. It is above the Mysensors range of lib 2.1
          #define EEPROM_POWERSTATE  902            // Save Porisiton. It is above the Mysensors range of lib 2.1
          #define MAX_TEMP 50
          #define VORLAUF 0
          #define RUECKLAUF 1
          #define ZULAUF 2
          #define PUMPE 0
          #define MISCHER_ZU  1
          #define MISCHER_AUF 2
          #define POWERLED 7                        // 8. LED
          #define TEMPDOWNLED 5                     // 6. Led
          #define TEMPUPLED 6                       // 7. Led
          #ifndef NO_AC_DETECT
          #define BUDERUSLED 4                      // 5. Led
          #define RETRY_TIMEOUT_PUMP 2*60*1000UL     // alle 2 Minuten testen, ob Vorlauf nicht besser (5 Sekunden pumpen)
          #define REGULATION_TIMEOUT_PUMP 30*1000UL  // 30 Sekunden warten nach neuer Einstellung
          #define PROBE_TIMEOUT_PUMP 5*1000UL        // 5 Sekunden Pumpe für Test einschalten, wenn Zulauf zu kalt
          #define BUDERUS_PIN 3                     // Buderus Powererkennung Pumpe auf PIN 3
          #ifndef SIMULATION
          #define MISCHER_RESET_TIME 120*1000UL      // 2 Minuten bis Nullstellung
          #define MISCHER_RESET_TIME 10*1000UL      // 10 Sekunden bis Nullstellung nei Simulation
          #ifdef EN_DEBUG
          #define DEBUG_PRINT(x) Serial.print (x)
          #ifdef EN_DEBUG
          #define DEBUG_PRINTLN(x)  Serial.println (x)
          #ifndef NO_MYS
          // Radio Configuration
          #define MY_TRANSPORT_WAIT_READY_MS (10000ul)
          #define MY_RADIO_RFM69
          #define MY_RFM69_FREQUENCY RF69_868MHZ
          #define MY_RFM69_NETWORKID 13
          #define MY_RFM69_ENABLE_ENCRYPTION
          #define MY_NODE_ID 168
          //#define MY_IS_RFM69HW
          #include <Arduino.h>
          #include <avr/wdt.h>
          #include <EEPROM.h>
          #include <MemoryFree.h>
          #ifndef NO_MYS
          #define MIN_REPORT_INTERVAL  5 * 60 * 1000L   // mindestens alle 5 Minuten melden
          #include <Time.h>        //http://www.arduino.cc/playground/Code/Time
          #include <Timezone.h>    //https://github.com/JChristensen/Timezone
          #include <TimeLib.h>
          //Central European Time (Frankfurt, Paris)
          TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 120};     //Central European Summer Time
          TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, 60};       //Central European Standard Time
          Timezone CE(CEST, CET);
          bool timeReceived = false;
          unsigned long lastUpdate = 0, lastRequest = 0;
          #ifndef NO_RTC
          #include <DS3232RTC.h>  // A  DS3231/DS3232 library
          #define MAX_LEDS 8
          byte lastButtonState = 0;
          #define RELAY_ON HIGH
          #define RELAY_OFF LOW
          #define RELAY_1  A0         // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          #define NUMBER_OF_RELAYS 4  // Total number of attached relays
          boolean ledState[MAX_LEDS] = { false, false, false, false, false, false, false, false };
          boolean relState[NUMBER_OF_RELAYS] = { false, false, false, false };
          #include <TM1638.h>
          #include <OneWire.h>
          #define ONE_WIRE_BUS 6 // Pin where dallase sensor is connected
          #define TEMPERATURE_PRECISION 9
          #define MAX_ATTACHED_DS18B20 3
          //28B404080000804A
          DeviceAddress Probe01 = { 0x28, 0xB4, 0x04, 0x08, 0x00, 0x00, 0x80, 0x4A };
          //28C606080000803F
          DeviceAddress Probe02 = { 0x28, 0xC6, 0x06, 0x08, 0x00, 0x00, 0x80, 0x3F };
          //28750808000080C3
          DeviceAddress Probe03 = { 0x28, 0x75, 0x08, 0x08, 0x00, 0x00, 0x80, 0xC3 };
          int numSensors = 0;
          int lastTemperature[MAX_ATTACHED_DS18B20] = { -100, -100, -100 };
          int16_t conversionTime;
          unsigned long previousTempMillis = -1;
          static unsigned long nowms = millis();    // update at start of loop()
          // define LCD module
          TM1638 ledModule(8, 9, 7);
          int displayInfo = -1;
          unsigned long previousDisplayMillis = 0;
          int targetTemp = START_TARGET_TEMP;
          #ifdef SIMULATION
          bool powerOn = true;
          bool powerOnBuderus = true;
          bool powerOn = false;
          bool powerOnBuderus = false;
          bool resetMischer = true; // mischer zuerst in Nullstellung
          bool testStateBuderus = false;
          unsigned long lastResetBuderus = -1;
          #ifndef NO_MYS
          // Initialize messages
          MyMessage msgTemp(0, V_TEMP);
          MyMessage msgStatus(0, V_STATUS);
          MyMessage msgTargetTemp(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS, V_HVAC_SETPOINT_HEAT);
          MyMessage msgPower(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 1, V_STATUS);
          MyMessage msgPowerBuderus(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 2, V_STATUS);
          MyMessage msgDebug(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 3, V_TEXT);
          // the setup function runs once when you press reset or power the board
            DEBUG_PRINTLN(F("Starte setup"));
            wdt_enable(WDTO_8S);
          #ifndef NO_RTC
            // the function to get the time from the RTC
            setSyncProvider(RTC.get);
          #ifndef NO_MYS
            // Request latest time from controller at startup
            requestTime();
            // Zieltemperatur aus EERPOM lesem:
            targetTemp = EEPROM.read(EEPROM_TARGET_TEMP);
            if ((targetTemp < 30) || (targetTemp > MAX_TEMP)) {
              EEPROM.write(EEPROM_TARGET_TEMP, targetTemp);
            int state = EEPROM.read(EEPROM_POWERSTATE);
            if (state == 0) {
              powerOn = false;
            else powerOn = true;
            // Buderuserkennung auf PIN3
            attachInterrupt(digitalPinToInterrupt(BUDERUS_PIN), buderusSet, CHANGE);
            lastResetBuderus = millis();
          #ifndef NO_MYS
            send(msgPowerBuderus.set(powerOnBuderus));
            // Relayausgänge initialisiern
            for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
              pinMode(pin, OUTPUT);
              digitalWrite(pin, RELAY_OFF);
            // Dallas Temperatursensoren
            sensors.begin();
            DEBUG_PRINT(F("Dallas Sensoren "));
            DEBUG_PRINTLN(numSensors);
            DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
            for (int i = 0; i < numSensors; i++)
              wdt_reset();
              // Search the wire for address
              if (sensors.getAddress(tempDeviceAddress, i))
                DEBUG_PRINT(F("Found device "));
          #ifdef EN_DEBUG
                Serial.print(i, DEC);
                DEBUG_PRINT(F(" with address: "));
                printAddress(tempDeviceAddress);
                DEBUG_PRINTLN();
                DEBUG_PRINT(F("Setting resolution to "));
          #ifdef EN_DEBUG
                Serial.println(TEMPERATURE_PRECISION, DEC);
                // set the resolution to 12 bit (Each Dallas/Maxim device is capable of several different resolutions)
                sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
                DEBUG_PRINT(F("Resolution actually set to: "));
          #ifdef EN_DEBUG
                Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
                DEBUG_PRINTLN();
                DEBUG_PRINT(F("Found ghost device at "));
          #ifdef EN_DEBUG
                DEBUG_PRINT(F(" but could not detect address. Check power and cabling"));
            wdt_reset();
            conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
          // the loop function runs over and over again forever
            nowms = millis();
          #ifndef NO_MYS
            // If no time has been received yet, request it every 10 second from controller
            // When time has been received, request update every hour
            if ((!timeReceived && (nowms - lastRequest) > (10UL * 1000UL))
                || (timeReceived && (nowms - lastRequest) > (60UL * 1000UL * 60UL))) {
              // Request time from controller.
              DEBUG_PRINTLN("requesting time");
              requestTime();
              lastRequest = nowms;
            wdt_reset();
            readAC();
            readTemp();
            readButtons();
            updateDisp();
            // Temperaturen senden
          #ifndef NO_MYS
            sendTemp();
            // Kontroller
            control();
            // Loop 2x pro Sekunde ist aureichend
            unsigned long loopTime = millis() - nowms;
            if (loopTime < 450) {
          #ifdef NO_MYS
              delay (500 - loopTime);
              wait (500 - loopTime);
          // end loop
          // Steuerung
          void control()
            wdt_reset();
            static unsigned long lastPumpTest = 0;
            static unsigned long lastRegulation = -REGULATION_TIMEOUT_PUMP;
            static unsigned long resetStart = 0;                     // wann wurde die Rücksetzung des Mischers gestartet
            static bool lastPower = powerOn;
            static float moveSeconds = 0.0;                 // Zeiten für Stellmotor Mischer
            // controllerState
            // 0 initialized
            // 1 Pumpe für kurzen test aktiviert, warten auf Timeout für Deaktivierung
            // 2 in der Regelung, warten auf Timeout für Deaktivierung
            // 3 in Ausganglage fahren
            static int controllerState = 0;
            // Emergency
            if  (lastTemperature[VORLAUF] > MAX_TEMP) {
              if (resetStart == 0) {
                if (relState[PUMPE]) {
                  DEBUG_PRINT(F("Zu heiss. Emergency Mischer schliessen"));
                  DEBUG_PRINTLN(lastTemperature[VORLAUF]);
                closeMischer();
                return;
            // Temperatur noch nicht gelesen;
            if (lastTemperature[VORLAUF] == -100) return;
            // Fehler mit den Sensoren
            if ((lastTemperature[VORLAUF] < 0) ||
                (lastTemperature[VORLAUF] > 100) ||
                (lastTemperature[RUECKLAUF] < 0) ||
                (lastTemperature[RUECKLAUF] > 100) ||
                (lastTemperature[ZULAUF] < 0) ||
                (lastTemperature[ZULAUF] > 100)) {
              relState[PUMPE] = false;
              updateRelays();
              ledState[PUMPE] = relState[PUMPE];
              // Test
              //powerOn = false;
          #ifndef NO_MYS
              //send(msgPower.set(powerOn));
              DEBUG_PRINTLN(F("Fehler mit den Sensoren, Temperaturen unter 0 oder über 100. Poweroff!"));
              return;
            if (resetMischer) {
              DEBUG_PRINTLN(F("Mischer initialisieren"));
              closeMischer();
              resetStart = millis();
              resetMischer = false;
              return;
            if (resetStart > 0) {
              if ((millis() - resetStart) > MISCHER_RESET_TIME) {
                DEBUG_PRINTLN(F("Mischer fertig initialisiert"));
                relState[MISCHER_ZU] = false;
                updateRelays();
                ledState[MISCHER_ZU] = relState[MISCHER_ZU];
                resetStart = 0;
              return;
            // wenn ausser Betrieb -> verlassen;
            if (powerOn == false) {
              if (lastPower == false) return;
              DEBUG_PRINTLN("Go to power off state");
          #ifndef NO_MYS
              lastPower = false;
              relState[MISCHER_AUF] = false;
              updateRelays();
              ledState[MISCHER_AUF] = relState[MISCHER_AUF];
              EEPROM.write(EEPROM_POWERSTATE, 0);
              return;
            //DEBUG_PRINTLN("a");
            lastPower = true;
            switch (controllerState) {
              case  0:  // Initialisiert
                if (lastTemperature[ZULAUF] < 30) {
                  if ((millis() - lastPumpTest) > RETRY_TIMEOUT_PUMP) {
                    controllerState = 1;
                    lastPumpTest = millis();
                    DEBUG_PRINTLN(F("Zulauf zu kalt. Schalte Pumpe für 5 Sekunden ein."));
                    relState[PUMPE] = true;
                    updateRelays();
                  return;
                //DEBUG_PRINTLN("x");
                updateRelays();
                // nicht regulieren, wenn schon genau genug
                if (abs(lastTemperature[VORLAUF] - targetTemp) <= 1) {
                  // DEBUG_PRINTLN("diff zu klein, keine Steuerung notwendig");
                  return;
                if ((millis() - lastRegulation) > REGULATION_TIMEOUT_PUMP) {
                  controllerState = 2;
                  lastRegulation = millis();
                  int diffZualaufRuecklauf = lastTemperature[ZULAUF] - lastTemperature[RUECKLAUF];
                  float actPercent = (float)(lastTemperature[VORLAUF] - lastTemperature[RUECKLAUF]) * 100.0 / (float)diffZualaufRuecklauf;
                  float shoulPercent = (float)(targetTemp - lastTemperature[RUECKLAUF]) * 100.0 / (float)diffZualaufRuecklauf;
                  // 120 Sekunden für ganzen Weg
                  moveSeconds = (float)MISCHER_RESET_TIME / 1000.0 / 100.0 * abs(shoulPercent - actPercent);
                  DEBUG_PRINT(F("Berechnete Sekunden fuer Mischerumstellung "));
                  DEBUG_PRINTLN(moveSeconds);
                  if (moveSeconds > 8)
                    moveSeconds = 8;
                  if (targetTemp > lastTemperature[VORLAUF]) {
                    DEBUG_PRINTLN(F("Mischer auf"));
                    relState[MISCHER_AUF] = true;
                    updateRelays();
                    DEBUG_PRINTLN(F("Mischer zu"));
                    relState[MISCHER_ZU] = true;
                    updateRelays();
                  return;
                return;
              case  1: // in Testmodus bei zu wenig  Temp im Zulauf
                if ((millis() - lastPumpTest) > PROBE_TIMEOUT_PUMP) {
                  updateRelays();
                  DEBUG_PRINTLN(F("Pumpe ausgeschaltet"));
                return;
              case  2: // in der Regelung
                if ((millis() - lastRegulation) > moveSeconds * 1000.0) {
                  DEBUG_PRINTLN("Mischer zu.");
                  updateRelays();
                return;
              default:
                DEBUG_PRINT(F("ERROR, unknown state :"));
                DEBUG_PRINTLN(controllerState);
                return;
          // function to print a device address
          void printAddress(DeviceAddress deviceAddress)
            for (uint8_t i = 0; i < 8; i++)
              if (deviceAddress[i] < 16) DEBUG_PRINT("0");
          #ifdef EN_DEBUG
              Serial.print(deviceAddress[i], HEX);
          void updateRelays() {
            static boolean relayStateReported[8] = { false, false, false, false, false, false, false, false };
          #ifndef NO_MYS
            static unsigned long previousStateMillis[NUMBER_OF_RELAYS] = { 0, 0, 0, 0 };
            for (int i = 0; i < NUMBER_OF_RELAYS; i++) {
              if (relState[i]) {
                digitalWrite(RELAY_1 + i, RELAY_ON);
                digitalWrite(RELAY_1 + i, RELAY_OFF);
          #ifndef NO_MYS
              bool bSend = false;
              if (previousStateMillis[i] == 0) {                               // noch nie gesendet
                bSend = true;
              else if (relayStateReported[i] != relState[i] ) { // Änderungen melden
                bSend = true;
              else if ((millis() - previousStateMillis[i]) > MIN_REPORT_INTERVAL) {
                bSend = true;
              if (bSend) {
                // TODO: Check if we want to look at the return value of send
                send(msgStatus.setSensor(i + MAX_ATTACHED_DS18B20).set(relState[i] ? 1 : 0));
                previousStateMillis[i] = millis();
                relayStateReported[i] = relState[i];
          void updateDisp() {
            static char s[8];
            static unsigned long previousDisplayMillis = 0;
            // update display?
            if ((millis() - previousDisplayMillis) > 1000) {
              previousDisplayMillis = millis();
              displayInfo++;
          #ifdef NO_MYS
              if (displayInfo > 4) displayInfo = 0;
              if (displayInfo > 5) displayInfo = 0;
              ledModule.clearDisplay();
              // sind die Temperaturen schon gelesen worden? Wenn nicht, abbrechen.
              if (lastTemperature[0] == -100) return;
              for (byte i = 0; i <= 7; i++) {
                if (ledState[i])
                  ledModule.setLED(1, i);
                  ledModule.setLED(0, i);
              // 0 Vorlauf, 1 Rücklauf, 2 Zulauf, 3 Sollwert
              switch (displayInfo) {
                case 0: // Vorlauf
                  sprintf(s, "Vor %2i",  lastTemperature[VORLAUF]);
                case 1: // Rücklauf
                  sprintf(s, "Rue %2i",  lastTemperature[RUECKLAUF]);
                case 2: // Zulauf
                  sprintf(s, "Zu %2i",  lastTemperature[ZULAUF]);
                case 3: // Zielwert
                  sprintf(s, "Soll %2i",  targetTemp);
                case 4: // Power
                  if (powerOn) {
                    sprintf(s, "PowerOn");
                  else {
                    sprintf(s, "PowerOff");
          #ifndef NO_MYS
                case 5: //clock
                  TimeChangeRule *tcr;
                  time_t utc = millis();
                  time_t t = CE.toLocal(utc, &tcr);
                  unsigned long dispTime = hour(t) * 100 * 100 + minute(t) * 100 + second(t);
                  if (hour(t) < 10) {
                    sprintf(s, "U 0%lu",  dispTime);
                    sprintf(s, "U %lu",  dispTime);
              ledModule.setDisplayToString(s);
          void closeMischer() {
            updateRelays();
          #ifndef NO_MYS
          void before()
            sendSketchInfo("Mischer Node", "1.1");
            DEBUG_PRINT(F("Numsensors "));
            for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
              present(i, S_TEMP);
            for (int sensor = MAX_ATTACHED_DS18B20, pin = RELAY_1; sensor < (MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS); sensor++, pin++) {
              present(sensor, S_BINARY);
            // Thermopunkt
            present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS, S_HVAC);
            // Power
            present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 1, S_HEATER);
            // AC Buderuus
            present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 2, S_BINATY);
            // Power
            present(MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 3, S_INFO);
            // Initialltemperatur mitteilen
            send(msgTargetTemp.set(targetTemp));
          void receive(const MyMessage & message)
            DEBUG_PRINT(F("Meldung an Sensor "));
            DEBUG_PRINT(message.sensor);
            DEBUG_PRINT(F(" mit type "));
            DEBUG_PRINTLN(message.type);
              int i = message.sensor - MAX_ATTACHED_DS18B20;
              if ((i >= 0) && (i < NUMBER_OF_RELAYS)) {
                DEBUG_PRINT(F("Schaltbefehl für Relay "));
                DEBUG_PRINT(i);
                DEBUG_PRINT(F(" auf "));
                DEBUG_PRINTLN(message.getBool());
                relState[i] = message.getBool();
                ledState[i] = relState[i];
              else if (i == MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS + 1) {
                powerOn = message.getBool();
                if (powerOn)
                  EEPROM.write(EEPROM_POWERSTATE, 1);
                  ledState[POWERLED] = false;
                  DEBUG_PRINTLN(F("Befehl für PowerOff"));
                else {
                  ledState[POWERLED] = true;
                  DEBUG_PRINTLN(F("Befehl für PowerOn"));
              updateRelays();
            else if (message.type == V_HVAC_SETPOINT_HEAT) {
              if (message.sensor == (MAX_ATTACHED_DS18B20 + NUMBER_OF_RELAYS)) {
                targetTemp = message.getInt();
                DEBUG_PRINT(F("Zieltemp gesetzt auf "));
                DEBUG_PRINTLN(targetTemp);
                if (targetTemp > MAX_TEMP) targetTemp = START_TARGET_TEMP;
                if (targetTemp < 20) targetTemp = 20;
            // Ok, set incoming time
            DEBUG_PRINT(F("Time value received: "));
            DEBUG_PRINTLN(controllerTime);
          #ifndef NO_RTC
            RTC.set(controllerTime);
              setTime(controllerTime);
            timeReceived = true;
          void sendTemp() {
            static int lastSentTemperature[MAX_ATTACHED_DS18B20] = { -100, -100, -100 };
            static unsigned long previousTempMillis[MAX_ATTACHED_DS18B20] = { 0, 0, 0 };
            for (int i = 0; i < MAX_ATTACHED_DS18B20 ; i++) {
              if (lastTemperature[i] != -100) {
                bool bSend = false;
                if (previousTempMillis[i] == 0) {                               // noch nie gesendet
                  bSend = true;
                else if (abs(lastSentTemperature[i] - lastTemperature[i]) >= 2) { // Differenz von >= zwei Grad werden gemeldet
                  bSend = true;
                else if ((millis() - previousTempMillis[i]) > MIN_REPORT_INTERVAL) {
                  bSend = true;
                if (bSend) {
                  send(msgTemp.setSensor(i).set(lastTemperature[i], 1));
                  previousTempMillis[i] = millis();
                  lastSentTemperature[i] = lastTemperature[i];
          void buderusSet() {
            testStateBuderus = true;
          void reboot() {
            wdt_enable(WDTO_30MS);
            while (1) {};
          void readButtons() {
            byte buttons = ledModule.getButtons();
            if (lastButtonState != buttons) {
              lastButtonState = buttons;
              if (buttons > 0) {
                  if ((buttons >> i) & 1) {
                    ledState[i] = !ledState[i];
                    if (i < NUMBER_OF_RELAYS) relState[i] = ledState[i];
                    updateRelays();
                    if (ledState[i])
                    if (i == POWERLED) {
                      powerOn = ledState[i];
          #ifndef NO_MYS
                      if (powerOn)
                    if (i == TEMPDOWNLED) {
                      targetTemp--;
                      if (targetTemp < 30) targetTemp = 30;
                    if (i == TEMPUPLED) {
                      targetTemp++;
                      if (targetTemp > MAX_TEMP) targetTemp = MAX_TEMP;
                    DEBUG_PRINT(F("ButtonState changed "));
                    DEBUG_PRINTLN(i);
          void readTemp() {
            static float temp;
            static int tempi;
            static unsigned long lastReadTemp1 = -1;
            static unsigned long lastReadTemp2 = -1;
            static unsigned long lastReadTemp3 = -1;
            if (previousTempMillis == -1) {
              // Dallas
              previousTempMillis = nowms;
            if ((millis() - previousTempMillis) >= conversionTime) {
              temp = sensors.getTempC(Probe01);
              if (temp != DEVICE_DISCONNECTED_C) {
                tempi = (int)(temp + 0.5);
                lastTemperature[VORLAUF] = tempi;
                lastReadTemp1 = nowms;
                temp = sensors.getTempC(Probe02);
                lastTemperature[RUECKLAUF] = tempi;
                lastReadTemp2 = nowms;
                temp = sensors.getTempC(Probe03);
                lastTemperature[ZULAUF] = tempi;
                lastReadTemp3 = nowms;
              if (nowms > 60000) {    // ersta nach einer minute prüfen
                unsigned long compare = nowms - 60000; // vor 1 Minute
                if ((lastReadTemp1 < compare) || (lastReadTemp2 < compare) || (lastReadTemp3 < compare)) {
                  DEBUG_PRINTLN(F("Zu lange keine Temeratur -> reset"));
                  lastReadTemp1 = -1;
                  lastReadTemp2 = -1;
                  lastReadTemp3 = -1;
                  ledModule.setDisplayToString(F("ERR Reb"));
                  delay(1000);
                  reboot();
          #ifdef SIMULATE_VOR
            lastTemperature[VORLAUF] = SIMULATE_VOR;
          #ifdef SIMULATE_RUE
            lastTemperature[RUECKLAUF] = SIMULATE_RUE;
          #ifdef SIMULATE_ZU
            lastTemperature[ZULAUF] = SIMULATE_ZU;
          void readAC() {
            if ((millis() - lastResetBuderus) > 100) // bei 50 HZ sind das 25 Durchgänge...
              noInterrupts();
              if (testStateBuderus != powerOnBuderus ) {
                powerOnBuderus = testStateBuderus;
                interrupts();
                ledState[BUDERUSLED] = powerOnBuderus;
          #ifndef NO_MYS
              lastResetBuderus = nowms;
            } else
              interrupts();
          raptorjrR 1 Reply Last reply
          • FotoFieberF FotoFieber
            #define NO_RTC
            #ifdef NO_MYS
            #ifndef NO_RTC
            #define NO_RTC
            #ifdef SIMULATION
            #ifdef SIMULATE_VOR
            #ifdef SIMULATE_RUE
            #ifdef SIMULATE_ZU
            #define MAX_TEMP 50
            #define VORLAUF 0
            #define RUECKLAUF 1
            #define ZULAUF 2
            #define PUMPE 0
            #ifndef SIMULATION
            #ifdef EN_DEBUG
            #ifdef EN_DEBUG
            #ifndef NO_MYS
            #include <EEPROM.h>
            #ifndef NO_MYS
            #ifndef NO_RTC
            #define MAX_LEDS 8
            #include <TM1638.h>
            //28B404080000804A
            //28C606080000803F
            //28750808000080C3
            int numSensors = 0;
            #ifdef SIMULATION
            #ifndef NO_MYS
            #ifndef NO_RTC
            #ifndef NO_MYS
              requestTime();
              if (state == 0) {
                powerOn = false;
            #ifndef NO_MYS
              sensors.begin();
                wdt_reset();
            #ifdef EN_DEBUG
                  DEBUG_PRINTLN();
            #ifdef EN_DEBUG
            #ifdef EN_DEBUG
                  DEBUG_PRINTLN();
            #ifdef EN_DEBUG
              wdt_reset();
              nowms = millis();
            #ifndef NO_MYS
                requestTime();
              wdt_reset();
              readAC();
              readTemp();
              readButtons();
              updateDisp();
            #ifndef NO_MYS
              sendTemp();
              // Kontroller
              control();
            #ifdef NO_MYS
            // end loop
            // Steuerung
            void control()
              wdt_reset();
              // controllerState
              // 0 initialized
              // Emergency
                  closeMischer();
                  return;
                updateRelays();
                // Test
                //powerOn = false;
            #ifndef NO_MYS
                return;
              if (resetMischer) {
                closeMischer();
                return;
                  updateRelays();
                  resetStart = 0;
                return;
            #ifndef NO_MYS
                lastPower = false;
                updateRelays();
                return;
              lastPower = true;
                      updateRelays();
                    return;
                  updateRelays();
                    return;
                      moveSeconds = 8;
                      updateRelays();
                      updateRelays();
                    return;
                  return;
                    updateRelays();
                  return;
                    updateRelays();
                  return;
                default:
                  return;
            #ifdef EN_DEBUG
            #ifndef NO_MYS
                if (relState[i]) {
            #ifndef NO_MYS
                bool bSend = false;
                  bSend = true;
                  bSend = true;
                  bSend = true;
                if (bSend) {
            void updateDisp() {
              static char s[8];
              // update display?
                displayInfo++;
            #ifdef NO_MYS
                  if (ledState[i])
                  case 0: // Vorlauf
                  case 1: // Rücklauf
                  case 2: // Zulauf
                  case 3: // Zielwert
                  case 4: // Power
                    if (powerOn) {
                    else {
            #ifndef NO_MYS
                  case 5: //clock
                    if (hour(t) < 10) {
              updateRelays();
            #ifndef NO_MYS
            void before()
                present(i, S_TEMP);
              // Thermopunkt
              // Power
              // AC Buderuus
              // Power
                  DEBUG_PRINT(i);
                  if (powerOn)
                  else {
                updateRelays();
            #ifndef NO_RTC
            void sendTemp() {
                  bool bSend = false;
                    bSend = true;
                    bSend = true;
                    bSend = true;
                  if (bSend) {
            void buderusSet() {
            void reboot() {
              while (1) {};
                if (buttons > 0) {
                      updateRelays();
                      if (ledState[i])
            #ifndef NO_MYS
                        if (powerOn)
                        targetTemp--;
                        targetTemp++;
                      DEBUG_PRINTLN(i);
            void readTemp() {
              static float temp;
              static int tempi;
                // Dallas
                    lastReadTemp1 = -1;
                    lastReadTemp2 = -1;
                    lastReadTemp3 = -1;
                    delay(1000);
                    reboot();
            #ifdef SIMULATE_VOR
            #ifdef SIMULATE_RUE
            #ifdef SIMULATE_ZU
            void readAC() {
                noInterrupts();
                  interrupts();
            #ifndef NO_MYS
              } else
                interrupts();
            raptorjrR
            raptorjrR
            raptorjr
            @FotoFieber
            That was very advanced =) I don't have any high voltage involved. Only have a test setup on a breadboard.
            I tried to move the sensors.begin to the setup, but then I don't get any temperature readings?
              Try post your code so we can take a look. Did you cross check the hw yet?
                raptorjrR
                raptorjrR
                raptorjr
                @gohan
                It is the same sketch as my second post.
                Haven't done anything with the hardware yet. Was following Fabiens advice with using 2.1 on both sketch and gateway. And restart gateway with problem. And then test again and restart node when the problem occurs.
                • Darren McInnesD
                  Darren McInnesD
                  Darren McInnes
                  You may want to check which version of the onewire library you are running. I was having exactly the same issue and fixed it by upgrading the onewire library from 2.7.2 (I think?) To the latest version.
                  It's been a few weeks now with no crashes.
                  • Darren McInnesD Darren McInnes
                    raptorjrR
                    raptorjrR
                    raptorjr
                    In the Arduino IDE version 2.3.2 seems to be the latest. But is there a newer one that I can download and install?
                    Maybe should figure out why I don't get any sensor readings when I have sensors.begin() in the setup. Maybe that is a problem also that I have it in the loop()?
                    • Darren McInnesD
                      Darren McInnesD
                      Darren McInnes
                      Sorry i meant the dallastemperature library!
                      i'm running 3.7.5 now without issues but had problems after a day with 3.7.2
                      my ide version is 1.6.9 and onewire version 2.3.2
                        raptorjrR
                        raptorjrR
                        raptorjr
                        @Darren-McInnes
                        I have 3.7.6 installed. On thing might just be updated libraries. I have been using Visual Studio for development with the plugin from Visual Micro. But then the libraries don't get updated. Had some problems with a update from Visual Micro so I went back to the Arduino IDE.
                        Have been running since Monday now. Although it could take more than a week before any problem, but I'm keeping my fingers crossed.
                        gohanG 1 Reply Last reply
                          @Darren-McInnes
                          @raptorjr
                          I am also using visual studio but libraries and boards get updated through the arduino ide without problems
                            @raptorjr
                            raptorjrR
                            raptorjrR
                            raptorjr
                            @gohan
                            But if you never open the Arduino IDE it can't get updated? Or are you saying that they get updated through Visual Studio?
                            I hadn't used the IDE for several months. Thought I was a step closer to the problem and that it was bugs in older libraries.
                              @gohan
                              @raptorjr
                              Visual Studio uses libraries from Arduino ide, so the only way to get updates is through the Arduino ide unless you install libraries manually. So it's a good thing to open Arduino ide every now and then if you want updates
