  3. Vera
  4. Issue with temperature units
23 Posts 9 Posters 11.8k Views 2 Watching
    @Yveaux
    uint8_t MyMessage::getByte() const {
    	if (miGetPayloadType() == P_BYTE) {
    		return data[0];
    	} else if (miGetPayloadType() == P_STRING) {
    		return atoi(data);
    		return 0;
    Payload type will be P_STRING when controller sends the data. Yes, why does it get size 2?!
    wrote on last edited by hek
    Hmm.. we should probably not use atoi in case of String. Payload type should not matter in the getByte.
    hekH 1 Reply Last reply
      Yep, this is a bug.
      I've also found that the newline character is included and transmitted on all outgoing messages from gateway! So payload length 2 was correct, and wrong ;)
      How is it possible no one has seen this before (me included)?
      • jocke4uJ
        jocke4uJ
        jocke4u
        Sounds good anyway....one bug less :)
        I just setup a sensor with DHT22/AM2302 and get the same results here.
          Fix checked in. I'm creating a more comprehensive release note in the 1.4 thread.
            Yep, this is a bug.
            At least I saw it ;-)
            I personally tend to read over all the details in the serial api... This time I noticed.
            Be glad you nailed it!
            • jocke4uJ
              jocke4uJ
              jocke4u
              Thanks @hek and @Yveaux I can confirm it's working on both Dallas sensor and DHT22.
              Great support!!
              • NuubiN
                NuubiN
                Nuubi
                Hmmm... how can one override this statement to be METRIC?
                float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?TemperatureSensors.getTempCByIndex(CHILD_ID_TEMPERATURE_FIRST+i):TemperatureSensors.getTempFByIndex(CHILD_ID_TEMPERATURE_FIRST+i)) * 10.)) / 10.;
                • H
                  H
                  hexenmeister
                  hello,
                  I must confess I have not read this thread completely. Too much for my bad english)
                  We try MySensors support for FHEM (www.fhem.de) to impementieren. I noticed that when the I_CONFIG message is answered correctly with 'M' for metric, then the sensor sends in Imperial. Is not surprising, everything is interpreted as a string from Gateway, but also byte checked. My solution proposal: In MySensors.cpp:
                  (isMetric = msg.getString()[0] == 'M' ; instead of isMetric = msg.getByte() == 'M' ;)
                  			} else if (type == I_CONFIG) {
                  				// Pick up configuration from controller (currently only metric/imperial)
                  				// and store it in eeprom if changed
                  				//isMetric = msg.getByte() == 'M' ;
                  				if (cc.isMetric != isMetric) {
                  					cc.isMetric = isMetric;
                  					eeprom_write_byte((uint8_t*)EEPROM_CONTROLLER_CONFIG_ADDRESS, isMetric);
                  					//eeprom_write_block((const void*)&cc, (uint8_t*)EEPROM_CONTROLLER_CONFIG_ADDRESS, sizeof(ControllerConfig));
                  			} else if (type == I_CHILDREN) {
                  Best regards,
                  Alexander
                    Welcome @hexenmeister!
                    What version of MySensors library did you download? The current version in gihub/master already has getString()[0].
                    • H
                      H
                      hexenmeister
                      Thanks for the quick reply.
                      I've downloaded the source here: https://github.com/mysensors/CodeBender/blob/master/MySensor.cpp
                      Since it is still old.
                      Now I see that https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp would be better.
                        Oh.. you downloaded from codebender. That explains it.
                        Unfortunately it's still a bit too messy to update the public libraries over there (have to contact the codebender-people every time). Nowadays we keep a copy among in the MySensors-account which gets copied if you clone one of the examples.
                        Github always contains the latest.
                        • H
                          H
                          hexenmeister
                          My mistake. Was unfortunately cost few hours time for the search. For that I have won something overview in MySensors Code :)
