  3. Vera
  4. Issue with temperature units
23 Posts 9 Posters 11.8k Views 2 Watching
    @jocke4u
    Are you saying adding debug prints makes it work?
    jocke4uJ 1 Reply Last reply
      @jocke4u
      jocke4uJ
      jocke4uJ
      jocke4u
      @hek
      Yes for some strange reason :)
      However I used %s and not %d in the debug but have now used %d as below
      } else if (type == I_CONFIG) {
          // Pick up configuration from controller (currently only metric/imperial)
          // and store it in eeprom if changed
          isMetric = msg.getByte() == 'M' ;
          debug(PSTR("isMetric=%d\n"), isMetric);
          debug(PSTR("cc.isMetric=%d\n"), cc.isMetric);
          if (cc.isMetric != isMetric) {
              cc.isMetric = isMetric;
              debug(PSTR("Updating EEPROM\n"));
              eeprom_write_byte((uint8_t*)EEPROM_CONTROLLER_CONFIG_ADDRESS, isMetric);
              //eeprom_write_block((const void*)&cc, (uint8_t*)EEPROM_CONTROLLER_CONFIG_ADDRESS, sizeof(ControllerConfig));
      Gives the output
      sensor started, id 2
      send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
      send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      read: 0-0-2 s=255,c=3,t=6,pt=0,l=2:M
      isMetric=0
      cc.isMetric=1
      Updating EEPROM
      isMetric=0
      cc.isMetric=0
      So it seems that "metric" flag is not unpacked correctly, or?
      • YveauxY
        @jocke4u said:
        l=2:M
        I find it strange that length is reported as 2 while only a single character seems to be sent. The protocol version 1.4 is correctly reported as length 3.
        hekH 1 Reply Last reply
        • YveauxY Yveaux
          @jocke4u said:
          l=2:M
          @Yveaux
          uint8_t MyMessage::getByte() const {
          	if (miGetPayloadType() == P_BYTE) {
          		return data[0];
          	} else if (miGetPayloadType() == P_STRING) {
          		return atoi(data);
          		return 0;
          Payload type will be P_STRING when controller sends the data. Yes, why does it get size 2?!
            @Yveaux
            		return data[0];
            		return atoi(data);
            		return 0;
            wrote on last edited by hek
            Hmm.. we should probably not use atoi in case of String. Payload type should not matter in the getByte.
              Yep, this is a bug.
              I've also found that the newline character is included and transmitted on all outgoing messages from gateway! So payload length 2 was correct, and wrong ;)
              How is it possible no one has seen this before (me included)?
              • jocke4uJ
                jocke4uJ
                jocke4u
                Sounds good anyway....one bug less :)
                I just setup a sensor with DHT22/AM2302 and get the same results here.
                  Fix checked in. I'm creating a more comprehensive release note in the 1.4 thread.
                    Yep, this is a bug.
                    At least I saw it ;-)
                    I personally tend to read over all the details in the serial api... This time I noticed.
                    Be glad you nailed it!
                    • jocke4uJ
                      jocke4uJ
                      jocke4u
                      Thanks @hek and @Yveaux I can confirm it's working on both Dallas sensor and DHT22.
                      Great support!!
                      • NuubiN
                        NuubiN
                        Nuubi
                        Hmmm... how can one override this statement to be METRIC?
                        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?TemperatureSensors.getTempCByIndex(CHILD_ID_TEMPERATURE_FIRST+i):TemperatureSensors.getTempFByIndex(CHILD_ID_TEMPERATURE_FIRST+i)) * 10.)) / 10.;
                        • H
                          H
                          hexenmeister
                          hello,
                          I must confess I have not read this thread completely. Too much for my bad english)
                          We try MySensors support for FHEM (www.fhem.de) to impementieren. I noticed that when the I_CONFIG message is answered correctly with 'M' for metric, then the sensor sends in Imperial. Is not surprising, everything is interpreted as a string from Gateway, but also byte checked. My solution proposal: In MySensors.cpp:
                          (isMetric = msg.getString()[0] == 'M' ; instead of isMetric = msg.getByte() == 'M' ;)
                          				//isMetric = msg.getByte() == 'M' ;
                          			} else if (type == I_CHILDREN) {
                          Best regards,
                          Alexander
                            Welcome @hexenmeister!
                            What version of MySensors library did you download? The current version in gihub/master already has getString()[0].
                            • H
                              H
                              hexenmeister
                              Thanks for the quick reply.
                              I've downloaded the source here: https://github.com/mysensors/CodeBender/blob/master/MySensor.cpp
                              Since it is still old.
                              Now I see that https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp would be better.
                                Oh.. you downloaded from codebender. That explains it.
                                Unfortunately it's still a bit too messy to update the public libraries over there (have to contact the codebender-people every time). Nowadays we keep a copy among in the MySensors-account which gets copied if you clone one of the examples.
                                Github always contains the latest.
                                • H
                                  H
                                  hexenmeister
                                  My mistake. Was unfortunately cost few hours time for the search. For that I have won something overview in MySensors Code :)
