  3. Battery sensor and re-connecting to gateway
24 Posts 6 Posters 9.1k Views 4 Watching
  • karl261K karl261
    Ok, thanks a lot. It is clear now. I will add some code and try. Later in 2.0.1 I can just remove this code...
    Question: the six failed transmissions: do they need to be consecutive? Or does it just count to six over time?
    tekkaT
    tekkaT
    tekka
    @karl261 consecutive
    • karl261K
      karl261K
      karl261
      Another question:
      Woudn't it be better to do something like this
      while(!isTransportOK()){
         wait(5000); // transport is not operational, allow the transport layer to fix this
      sleep(SLEEP_TIME);  // transport is OK, node can sleep
      or doesn't this bring anything?
      • karl261K
        karl261K
        karl261
        Wow, This is so cool. This probably solves all my problems from the past year.
        It just happened: I had a node connected to the gateway and brought it far away. It lost the connection to the gateway. I switched on a repeater node halfway. The node reconnected to the gateway via the repeater node.
        I can't believe it!
        • karl261K
          karl261K
          karl261
          @tekka The only problem with this extra code is, that in case the node loses its connection, it will drain the battery quite quickly...
          tekkaT 1 Reply Last reply
          • karl261K karl261
            tekkaT
            tekkaT
            tekka
            @karl261 yes, in the example you mentioned, the node won't sleep at all if connection is lost and cannot be re-established. For battery powered nodes I recommend using MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC to prevent the transport state machine from entering the SNP (search new parent) state.
            MySensors 2.0.1 introduces an enhanced sleeping function with a reconnection timeout: https://github.com/mysensors/MySensors/pull/558
            • tekkaT tekka
              great work @tekka
              • karl261K
                karl261K
                karl261
                @tekka Yeah, that's what I actually use. Since I normally don't move my sensors and repeaters, having the parent node static sounds like a good thing to do.
                I look forward to the 2.0.1 release. There seem to be a lot of cool new things inside.
                @tekka, @oitzu, Still, this nrf is driving me nuts. My sensor in the garden has worked just fine for three weeks, and nothing has changed. Now it makes problems. It is still running, because once per day one Temp reading or similar is getting through. Battery is just the same as before.
                Do you have any idea why it could have stopped working? I don't see any reason why the repeater should stop receiving the values. The repeater works fine, it relays all other nodes. And the geometry between repeater and garden sensor has not changed.
                The weather has changed. The T is about 7 degrees less outside...
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  @tekka I'm using the latest snapshot on one of my battery sensors and can see if it can't connect, it doesn't sleep and the debug shows a rapid number of connection attempts. I'd like to know if the sensor will eventually sleep if it cannot successfully connect, and what the default timeout is?
                  • Mark SwiftM Mark Swift
                    tekkaT
                    tekkaT
                    tekka
                    @Mark-Swift Please post your sketch & full debug log. Thanks
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      @tekka I don't think there's an issue.
                      I'm simply asking what the logic is behind the reconnection logic on sleeping sensors, how long is the timeout for example (I'm conscious of battery drain for nodes having issues connecting).
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        @Mark-Swift No, this sounds like an issue - a rapid number of connection attempts is unusual, that's why I'm interested in your sketch/debug log.
                        To answer your questions: In the latest dev version the node will try to reconnect with a 10sec timeout (if sleeping time > 10sec, this can be changed via MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) before sleeping - if time is left.
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          wrote on last edited by Mark Swift
                          @tekka it's been a while but I never resolved this... If I test by changing the parent node ID to a fake one, it just tried to connect forever, thus draining the battery...
                          Sketch:
                            REVISION HISTORY
                            Created by Mark Swift
                            V1.2 - Added sleep time to force daily update
                            V1.3 - Deactivate pullup on setup and added old_value logic
                            V1.4 - Added daily wakeup to sleep
                            V1.5 - Code cleanup
                          //*** EXTERNAL LIBRARIES **********************************
                          #include <Vcc.h>
                          //*** MYSENSORS *******************************************
                          // Enable debug prints
                          // Lower serial speed if using 1Mhz clock
                          // #define MY_BAUD_RATE 9600
                          #define MY_NODE_ID 4
                          #define MY_PARENT_NODE_ID 1 // AUTO
                          // #define MY_RADIO_RFM69
                          // Override RF24L01 channel number
                          // #define MY_RF24_CHANNEL 125
                          // Override RF24L01 module PA level
                          // #define MY_RF24_PA_LEVEL RF24_PA_LOW
                          // Override RF24L01 datarate
                          // #define MY_RF24_DATARATE RF24_250KBPS
                          // *** SKETCH CONFIG **************************************
                          #define SKETCH_NAME "Door Sensor"
                          #define SKETCH_MAJOR_VER "1"
                          #define SKETCH_MINOR_VER "5"
                          // Define the sensor child IDs
                          #define CHILD_ID1 1 // Switch
                          #define CHILD_ID2 2 // Battery voltage
                          #define CHILD_ID3 3 // Battery percent
                          // Define the message formats
                          MyMessage msg(CHILD_ID1, V_TRIPPED);
                          MyMessage msg2(CHILD_ID2, V_CUSTOM);
                          MyMessage msg3(CHILD_ID3, V_CUSTOM);
                          // *** SENSORS CONFIG *************************************
                          // Digital I/O pin for button or reed switch
                          #define PRIMARY_BUTTON_PIN 3
                          // Debounce using a small sleep
                          #define DEBOUNCE_SLEEP 5
                          // Sleep timer in milliseconds
                          #define SLEEP_IN_MS 86400000
                          // Store the old value for comparison
                          int old_value = -1;
                          // Minimum expected vcc level, in volts (2xAA alkaline)
                          const float vcc_min = 2.0 * 0.9;
                          // Maximum expected vcc level, in volts (2xAA alkaline)
                          const float vcc_max = 2.0 * 1.5;
                          // Measured vcc by multimeter divided by reported vcc
                          const float vcc_correction = 2.88 / 2.82;
                          Vcc vcc(vcc_correction);
                          // *** BEGIN **********************************************
                            // Setup the contact sensor
                            // Activate or deactivate the internal pull-up - high if using internal resistor or low if using external
                            digitalWrite(PRIMARY_BUTTON_PIN, LOW);
                            // Register all sensors to the gateway
                            present(CHILD_ID1, S_DOOR);
                            present(CHILD_ID2, S_CUSTOM);
                            present(CHILD_ID3, S_CUSTOM);
                            // Debouce using sleep
                            sleep(DEBOUNCE_SLEEP);
                            int value = digitalRead(PRIMARY_BUTTON_PIN);
                            // If value has changed send the updated value
                            if (value != old_value) {
                              send(msg.set(value == HIGH ? 0 : 1));
                              old_value = value;
                            // Read battery voltage
                            float battery_voltage = vcc.Read_Volts();
                            // Calculate battery percentage
                            float battery_percent = vcc.Read_Perc(vcc_min, vcc_max);
                          #ifdef MY_DEBUG
                            Serial.print("Battery = ");
                            Serial.print(battery_voltage);
                            Serial.println(" Volts");
                            Serial.print(battery_percent);
                            Serial.println("%");
                            // Send battery readings
                            send(msg2.set(battery_voltage, 2));
                            send(msg3.set(battery_percent, 1));
                            sendBatteryLevel(battery_percent);
                            // Sleep until either interupt change or timer reaches zero
                            smartSleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_IN_MS);
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            Debug:
                            0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                            4 TSM:INIT
                            6 TSF:WUR:MS=0
                            14 TSM:INIT:TSP OK
                            16 TSM:INIT:STATID=4
                            18 TSF:SID:OK,ID=4
                            20 TSM:FPAR
                            22 TSM:FPAR:STATP=1
                            24 TSM:ID
                            24 TSM:ID:OK
                            26 TSM:UPL
                            63 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            2072 TSM:UPL
                            2109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            4118 TSM:UPL
                            4155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            6164 TSM:UPL
                            6201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            8210 !TSM:UPL:FAIL
                            8212 TSM:FPAR
                            8212 TSM:FPAR:STATP=1
                            8214 TSM:ID
                            8216 TSM:ID:OK
                            8218 TSM:UPL
                            8255 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            10264 TSM:UPL
                            10301 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            12310 TSM:UPL
                            12347 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            14356 TSM:UPL
                            14393 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            16402 !TSM:UPL:FAIL
                            16404 TSM:FPAR
                            16404 TSM:FPAR:STATP=1
                            16408 TSM:ID
                            16410 TSM:ID:OK
                            16410 TSM:UPL
                            16449 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            18458 TSM:UPL
                            18495 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            20504 TSM:UPL
                            20541 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            22550 TSM:UPL
                            22587 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            24596 !TSM:UPL:FAIL
                            24598 TSM:FPAR
                            24598 TSM:FPAR:STATP=1
                            24602 TSM:ID
                            24604 TSM:ID:OK
                            24604 TSM:UPL
                            24643 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            26652 TSM:UPL
                            26689 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            28698 TSM:UPL
                            28735 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            30744 TSM:UPL
                            30781 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            32790 !TSM:UPL:FAIL
                            32792 TSM:FPAR
                            32792 TSM:FPAR:STATP=1
                            32796 TSM:ID
                            32798 TSM:ID:OK
                            32798 TSM:UPL
                            32837 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            34846 TSM:UPL
                            34883 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            36892 TSM:UPL
                            36929 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            38938 TSM:UPL
                            38975 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            40984 !TSM:UPL:FAIL
                            40986 TSM:FPAR
                            40986 TSM:FPAR:STATP=1
                            40990 TSM:ID
                            40992 TSM:ID:OK
                            40992 TSM:UPL
                            41031 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            43040 TSM:UPL
                            43077 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            45086 TSM:UPL
                            45123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            47132 TSM:UPL
                            47169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            49178 !TSM:UPL:FAIL
                            49180 TSM:FPAR
                            49180 TSM:FPAR:STATP=1
                            49184 TSM:ID
                            49186 TSM:ID:OK
                            49186 TSM:UPL
                            49225 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            51234 TSM:UPL
                            51271 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            53280 TSM:UPL
                            53317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            55326 TSM:UPL
                            55363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            57372 !TSM:UPL:FAIL
                            57374 TSM:FPAR
                            57374 TSM:FPAR:STATP=1
                            57378 TSM:ID
                            57380 TSM:ID:OK
                            57380 TSM:UPL
                            57419 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            59428 TSM:UPL
                            59465 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            61474 TSM:UPL
                            61511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            63520 TSM:UPL
                            63557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            65566 !TSM:UPL:FAIL
                            65568 TSM:FPAR
                            65568 TSM:FPAR:STATP=1
                            65572 TSM:ID
                            65574 TSM:ID:OK
                            65574 TSM:UPL
                            65613 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            67624 TSM:UPL
                            67661 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            69672 TSM:UPL
                            69709 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            71720 TSM:UPL
                            71757 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            73768 !TSM:UPL:FAIL
                            73771 TSM:FPAR
                            73771 TSM:FPAR:STATP=1
                            73775 TSM:ID
                            73777 TSM:ID:OK
                            73777 TSM:UPL
                            73816 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            75825 TSM:UPL
                            75862 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            77871 TSM:UPL
                            77907 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            79917 TSM:UPL
                            79953 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            81963 !TSM:UPL:FAIL
                            81965 TSM:FPAR
                            81965 TSM:FPAR:STATP=1
                            81969 TSM:ID
                            81971 TSM:ID:OK
                            81971 TSM:UPL
                            82010 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            84019 TSM:UPL
                            84056 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            86065 TSM:UPL
                            86102 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            88111 TSM:UPL
                            88147 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            90157 !TSM:UPL:FAIL
                            90159 TSM:FPAR
                            90159 TSM:FPAR:STATP=1
                            90163 TSM:ID
                            90165 TSM:ID:OK
                            90165 TSM:UPL
                            90204 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            92213 TSM:UPL
                            92250 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            94259 TSM:UPL
                            94296 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            96305 TSM:UPL
                            96342 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            98351 !TSM:UPL:FAIL
                            98353 TSM:FPAR
                            98353 TSM:FPAR:STATP=1
                            98357 TSM:ID
                            98359 TSM:ID:OK
                            98359 TSM:UPL
                            98398 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            100407 TSM:UPL
                            100444 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            102453 TSM:UPL
                            102490 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            104499 TSM:UPL
                            104536 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            106545 !TSM:UPL:FAIL
                            106547 TSM:FPAR
                            106549 TSM:FPAR:STATP=1
                            106551 TSM:ID
                            106553 TSM:ID:OK
                            106555 TSM:UPL
                            106592 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            108601 TSM:UPL
                            108638 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            110647 TSM:UPL
                            110684 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            112693 TSM:UPL
                            112730 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            114739 !TSM:UPL:FAIL
                            114741 TSM:FPAR
                            114743 TSM:FPAR:STATP=1
                            114745 TSM:ID
                            114747 TSM:ID:OK
                            114749 TSM:UPL
                            114786 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            116795 TSM:UPL
                            116832 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            118841 TSM:UPL
                            118878 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            120887 TSM:UPL
                            120924 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            122933 !TSM:UPL:FAIL
                            122935 TSM:FPAR
                            122937 TSM:FPAR:STATP=1
                            122939 TSM:ID
                            122941 TSM:ID:OK
                            122943 TSM:UPL
                            122980 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            124989 TSM:UPL
                            125026 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            127035 TSM:UPL
                            127072 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            129081 TSM:UPL
                            129118 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            131127 !TSM:UPL:FAIL
                            131129 TSM:FPAR
                            131131 TSM:FPAR:STATP=1
                            131133 TSM:ID
                            131135 TSM:ID:OK
                            131137 TSM:UPL
                            131174 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            133183 TSM:UPL
                            133220 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            135229 TSM:UPL
                            135266 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            137275 TSM:UPL
                            137312 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            139321 !TSM:UPL:FAIL
                            139323 TSM:FPAR
                            139325 TSM:FPAR:STATP=1
                            139327 TSM:ID
                            139329 TSM:ID:OK
                            139331 TSM:UPL
                            139368 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            141377 TSM:UPL
                            141414 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            143423 TSM:UPL
                            143460 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            145469 TSM:UPL
                            145506 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            147515 !TSM:UPL:FAIL
                            147517 TSM:FPAR
                            147519 TSM:FPAR:STATP=1
                            147521 TSM:ID
                            147523 TSM:ID:OK
                            147525 TSM:UPL
                            147562 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            149571 TSM:UPL
                            149608 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            151617 TSM:UPL
                            151654 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            153663 TSM:UPL
                            153700 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            155709 !TSM:UPL:FAIL
                            155711 TSM:FPAR
                            155713 TSM:FPAR:STATP=1
                            155715 TSM:ID
                            155717 TSM:ID:OK
                            155719 TSM:UPL
                            155756 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            157765 TSM:UPL
                            157802 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            159811 TSM:UPL
                            159848 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            161857 TSM:UPL
                            161894 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            163903 !TSM:UPL:FAIL
                            163905 TSM:FPAR
                            163907 TSM:FPAR:STATP=1
                            163909 TSM:ID
                            163911 TSM:ID:OK
                            163913 TSM:UPL
                            163950 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            165959 TSM:UPL
                            165996 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            168005 TSM:UPL
                            168042 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            170051 TSM:UPL
                            170088 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            172097 !TSM:UPL:FAIL
                            172099 TSM:FPAR
                            172101 TSM:FPAR:STATP=1
                            172103 TSM:ID
                            172105 TSM:ID:OK
                            172107 TSM:UPL
                            172144 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            174153 TSM:UPL
                            174190 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            176199 TSM:UPL
                            176236 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            178245 TSM:UPL
                            178282 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            180291 !TSM:UPL:FAIL
                            180293 TSM:FPAR
                            180295 TSM:FPAR:STATP=1
                            180297 TSM:ID
                            180299 TSM:ID:OK
                            180301 TSM:UPL
                            180338 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            182347 TSM:UPL
                            182384 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            184393 TSM:UPL
                            184430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            186439 TSM:UPL
                            186476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            188485 !TSM:UPL:FAIL
                            188487 TSM:FPAR
                            188489 TSM:FPAR:STATP=1
                            188491 TSM:ID
                            188493 TSM:ID:OK
                            188495 TSM:UPL
                            188532 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            190541 TSM:UPL
                            190578 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            192587 TSM:UPL
                            192624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            194633 TSM:UPL
                            194670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            196679 !TSM:UPL:FAIL
                            196681 TSM:FPAR
                            196683 TSM:FPAR:STATP=1
                            196685 TSM:ID
                            196687 TSM:ID:OK
                            196689 TSM:UPL
                            196726 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            198735 TSM:UPL
                            198772 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            200781 TSM:UPL
                            200818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            202827 TSM:UPL
                            202864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            204873 !TSM:UPL:FAIL
                            204875 TSM:FPAR
                            204877 TSM:FPAR:STATP=1
                            204879 TSM:ID
                            204881 TSM:ID:OK
                            204883 TSM:UPL
                            204920 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            206931 TSM:UPL
                            206968 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            208979 TSM:UPL
                            209016 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            211027 TSM:UPL
                            211064 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            213075 !TSM:UPL:FAIL
                            213078 TSM:FPAR
                            213080 TSM:FPAR:STATP=1
                            213082 TSM:ID
                            213084 TSM:ID:OK
                            213086 TSM:UPL
                            213123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            215132 TSM:UPL
                            215169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            217178 TSM:UPL
                            217214 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            219224 TSM:UPL
                            219260 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            221270 !TSM:UPL:FAIL
                            221272 TSM:FPAR
                            221274 TSM:FPAR:STATP=1
                            221276 TSM:ID
                            221278 TSM:ID:OK
                            221280 TSM:UPL
                            221317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            223326 TSM:UPL
                            223363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            225372 TSM:UPL
                            225409 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            225689 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                            225695 TSF:MSG:BC
                            226275 TSF:MSG:READ,0-3-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                            226281 TSF:MSG:BC
                            227418 TSM:UPL
                            227454 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            229464 !TSM:UPL:FAIL
                            229466 TSM:FPAR
                            229468 TSM:FPAR:STATP=1
                            229470 TSM:ID
                            229472 TSM:ID:OK
                            229474 TSM:UPL
                            229511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            231520 TSM:UPL
                            231557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            233566 TSM:UPL
                            233603 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            235612 TSM:UPL
                            235649 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            237658 !TSM:UPL:FAIL
                            237660 TSM:FPAR
                            237662 TSM:FPAR:STATP=1
                            237664 TSM:ID
                            237666 TSM:ID:OK
                            237668 TSM:UPL
                            237705 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            239714 TSM:UPL
                            239751 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            241760 TSM:UPL
                            241797 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            243806 TSM:UPL
                            243843 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            245852 !TSM:UPL:FAIL
                            245854 TSM:FPAR
                            245856 TSM:FPAR:STATP=1
                            245858 TSM:ID
                            245860 TSM:ID:OK
                            245862 TSM:UPL
                            245899 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            247908 TSM:UPL
                            247945 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            249954 TSM:UPL
                            249991 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            252000 TSM:UPL
                            252037 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            254046 !TSM:UPL:FAIL
                            254048 TSM:FPAR
                            254050 TSM:FPAR:STATP=1
                            254052 TSM:ID
                            254054 TSM:ID:OK
                            254056 TSM:UPL
                            254093 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            256102 TSM:UPL
                            256139 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            258148 TSM:UPL
                            258185 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            260194 TSM:UPL
                            260231 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            262240 !TSM:UPL:FAIL
                            262242 TSM:FPAR
                            262244 TSM:FPAR:STATP=1
                            262246 TSM:ID
                            262248 TSM:ID:OK
                            262250 TSM:UPL
                            262287 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            264296 TSM:UPL
                            264333 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            266342 TSM:UPL
                            266379 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            268388 TSM:UPL
                            268425 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            270434 !TSM:UPL:FAIL
                            270436 TSM:FPAR
                            270438 TSM:FPAR:STATP=1
                            270440 TSM:ID
                            270442 TSM:ID:OK
                            270444 TSM:UPL
                            270481 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            272490 TSM:UPL
                            272527 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            274536 TSM:UPL
                            274573 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            276582 TSM:UPL
                            276619 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            278628 !TSM:UPL:FAIL
                            278630 TSM:FPAR
                            278632 TSM:FPAR:STATP=1
                            278634 TSM:ID
                            278636 TSM:ID:OK
                            278638 TSM:UPL
                            278675 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            280684 TSM:UPL
                            280721 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            282730 TSM:UPL
                            282767 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            284776 TSM:UPL
                            284813 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            286822 !TSM:UPL:FAIL
                            286824 TSM:FPAR
                            286826 TSM:FPAR:STATP=1
                            286828 TSM:ID
                            286830 TSM:ID:OK
                            286832 TSM:UPL
                            286869 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            288878 TSM:UPL
                            288915 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            290924 TSM:UPL
                            290961 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            292970 TSM:UPL
                            293007 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            295016 !TSM:UPL:FAIL
                            295018 TSM:FPAR
                            295020 TSM:FPAR:STATP=1
                            295022 TSM:ID
                            295024 TSM:ID:OK
                            295026 TSM:UPL
                            295063 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            297072 TSM:UPL
                            297109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            299118 TSM:UPL
                            299155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            301164 TSM:UPL
                            301201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            303210 !TSM:UPL:FAIL
                            303212 TSM:FPAR
                            303214 TSM:FPAR:STATP=1
                            303216 TSM:ID
                            303218 TSM:ID:OK
                            303220 TSM:UPL
                            303257 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            305266 TSM:UPL
                            305303 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            307312 TSM:UPL
                            307349 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            309358 TSM:UPL
                            309395 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            311404 !TSM:UPL:FAIL
                            311406 TSM:FPAR
                            311408 TSM:FPAR:STATP=1
                            311410 TSM:ID
                            311412 TSM:ID:OK
                            311414 TSM:UPL
                            311451 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            313460 TSM:UPL
                            313497 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            315506 TSM:UPL
                            315543 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            317552 TSM:UPL
                            317589 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            319598 !TSM:UPL:FAIL
                            319600 TSM:FPAR
                            319602 TSM:FPAR:STATP=1
                            319604 TSM:ID
                            319606 TSM:ID:OK
                            319608 TSM:UPL
                            319645 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            321654 TSM:UPL
                            321691 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            323700 TSM:UPL
                            323737 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            325746 TSM:UPL
                            325783 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            327792 !TSM:UPL:FAIL
                            327794 TSM:FPAR
                            327796 TSM:FPAR:STATP=1
                            327798 TSM:ID
                            327800 TSM:ID:OK
                            327802 TSM:UPL
                            327839 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            329848 TSM:UPL
                            329885 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            331894 TSM:UPL
                            331931 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            333940 TSM:UPL
                            333977 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            335986 !TSM:UPL:FAIL
                            335988 TSM:FPAR
                            335990 TSM:FPAR:STATP=1
                            335992 TSM:ID
                            335994 TSM:ID:OK
                            335996 TSM:UPL
                            336033 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            338042 TSM:UPL
                            338079 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            340088 TSM:UPL
                            340125 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            342134 TSM:UPL
                            342171 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            344180 !TSM:UPL:FAIL
                            344182 TSM:FPAR
                            344184 TSM:FPAR:STATP=1
                            344186 TSM:ID
                            344188 TSM:ID:OK
                            344190 TSM:UPL
                            344227 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            346238 TSM:UPL
                            346275 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            348286 TSM:UPL
                            348323 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            350334 TSM:UPL
                            350371 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            352382 !TSM:UPL:FAIL
                            352385 TSM:FPAR
                            352387 TSM:FPAR:STATP=1
                            352389 TSM:ID
                            352391 TSM:ID:OK
                            352393 TSM:UPL
                            352430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            354439 TSM:UPL
                            354476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            356485 TSM:UPL
                            356521 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            358531 TSM:UPL
                            358567 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            360577 !TSM:UPL:FAIL
                            360579 TSM:FPAR
                            360581 TSM:FPAR:STATP=1
                            360583 TSM:ID
                            360585 TSM:ID:OK
                            360587 TSM:UPL
                            360624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            362633 TSM:UPL
                            362670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            364679 TSM:UPL
                            364716 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            366725 TSM:UPL
                            366761 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            368771 !TSM:UPL:FAIL
                            368773 TSM:FPAR
                            368775 TSM:FPAR:STATP=1
                            368777 TSM:ID
                            368779 TSM:ID:OK
                            368781 TSM:UPL
                            368818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            370827 TSM:UPL
                            370864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            372873 TSM:UPL
                            372910 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            374919 TSM:UPL
                            374956 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            376965 !TSM:UPL:FAIL
                            376967 TSM:FPAR
                            376969 TSM:FPAR:STATP=1
                            376971 TSM:ID
                            376973 TSM:ID:OK
                            376975 TSM:UPL
                            377012 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                            379021 TSM:UPL
                            379058 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                            381067 TSM:UPL
                            381104 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                            383113 TSM:UPL
                            383150 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                            385159 !TSM:UPL:FAIL
                            385161 TSM:FPAR
                            385163 TSM:FPAR:STATP=1
                            385165 TSM:ID
                            385167 TSM:ID:OK
                            385169 TSM:UPL
                            385206 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                            387215 TSM:UPL
                            387252 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                            389261 TSM:UPL
                            389298 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                            391307 TSM:UPL
                            391344 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                            393353 !TSM:UPL:FAIL
                            393355 TSM:FPAR
                            393357 TSM:FPAR:STATP=1
                            393359 TSM:ID
                            393361 TSM:ID:OK
                            393363 TSM:UPL
                            393400 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                            395409 TSM:UPL
                            395446 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                            397455 TSM:UPL
                            397492 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                            399501 TSM:UPL
                            399538 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                            401547 !TSM:UPL:FAIL
                            401549 TSM:FPAR
                            401551 TSM:FPAR:STATP=1
                            401553 TSM:ID
                            401555 TSM:ID:OK
                            401557 TSM:UPL
                            401594 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                            403603 TSM:UPL
                            403640 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                            405649 TSM:UPL
                            405686 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                            407695 TSM:UPL
                            407732 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                            409741 !TSM:UPL:FAIL
                            409743 TSM:FPAR
                            409745 TSM:FPAR:STATP=1
                            409747 TSM:ID
                            409749 TSM:ID:OK
                            409751 TSM:UPL
                            409788 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                              Debug:
                              4 TSM:INIT
                              6 TSF:WUR:MS=0
                              14 TSM:INIT:TSP OK
                              18 TSF:SID:OK,ID=4
                              20 TSM:FPAR
                              22 TSM:FPAR:STATP=1
                              24 TSM:ID
                              24 TSM:ID:OK
                              26 TSM:UPL
                              2072 TSM:UPL
                              4118 TSM:UPL
                              6164 TSM:UPL
                              8210 !TSM:UPL:FAIL
                              8212 TSM:FPAR
                              8214 TSM:ID
                              8216 TSM:ID:OK
                              8218 TSM:UPL
                              10264 TSM:UPL
                              12310 TSM:UPL
                              14356 TSM:UPL
                              16402 !TSM:UPL:FAIL
                              16404 TSM:FPAR
                              16408 TSM:ID
                              16410 TSM:ID:OK
                              16410 TSM:UPL
                              18458 TSM:UPL
                              20504 TSM:UPL
                              22550 TSM:UPL
                              24596 !TSM:UPL:FAIL
                              24598 TSM:FPAR
                              24602 TSM:ID
                              24604 TSM:ID:OK
                              24604 TSM:UPL
                              26652 TSM:UPL
                              28698 TSM:UPL
                              30744 TSM:UPL
                              32790 !TSM:UPL:FAIL
                              32792 TSM:FPAR
                              32796 TSM:ID
                              32798 TSM:ID:OK
                              32798 TSM:UPL
                              34846 TSM:UPL
                              36892 TSM:UPL
                              38938 TSM:UPL
                              40984 !TSM:UPL:FAIL
                              40986 TSM:FPAR
                              40990 TSM:ID
                              40992 TSM:ID:OK
                              40992 TSM:UPL
                              43040 TSM:UPL
                              45086 TSM:UPL
                              47132 TSM:UPL
                              49178 !TSM:UPL:FAIL
                              49180 TSM:FPAR
                              49184 TSM:ID
                              49186 TSM:ID:OK
                              49186 TSM:UPL
                              51234 TSM:UPL
                              53280 TSM:UPL
                              55326 TSM:UPL
                              57372 !TSM:UPL:FAIL
                              57374 TSM:FPAR
                              57378 TSM:ID
                              57380 TSM:ID:OK
                              57380 TSM:UPL
                              59428 TSM:UPL
                              61474 TSM:UPL
                              63520 TSM:UPL
                              65566 !TSM:UPL:FAIL
                              65568 TSM:FPAR
                              65572 TSM:ID
                              65574 TSM:ID:OK
                              65574 TSM:UPL
                              67624 TSM:UPL
                              69672 TSM:UPL
                              71720 TSM:UPL
                              73768 !TSM:UPL:FAIL
                              73771 TSM:FPAR
                              73775 TSM:ID
                              73777 TSM:ID:OK
                              73777 TSM:UPL
                              75825 TSM:UPL
                              77871 TSM:UPL
                              79917 TSM:UPL
                              81963 !TSM:UPL:FAIL
                              81965 TSM:FPAR
                              81969 TSM:ID
                              81971 TSM:ID:OK
                              81971 TSM:UPL
                              84019 TSM:UPL
                              86065 TSM:UPL
                              88111 TSM:UPL
                              90157 !TSM:UPL:FAIL
                              90159 TSM:FPAR
                              90163 TSM:ID
                              90165 TSM:ID:OK
                              90165 TSM:UPL
                              92213 TSM:UPL
                              94259 TSM:UPL
                              96305 TSM:UPL
                              98351 !TSM:UPL:FAIL
                              98353 TSM:FPAR
                              98357 TSM:ID
                              98359 TSM:ID:OK
                              98359 TSM:UPL
                              100407 TSM:UPL
                              102453 TSM:UPL
                              104499 TSM:UPL
                              106547 TSM:FPAR
                              106551 TSM:ID
                              106553 TSM:ID:OK
                              106555 TSM:UPL
                              108601 TSM:UPL
                              110647 TSM:UPL
                              112693 TSM:UPL
                              114741 TSM:FPAR
                              114745 TSM:ID
                              114747 TSM:ID:OK
                              114749 TSM:UPL
                              116795 TSM:UPL
                              118841 TSM:UPL
                              120887 TSM:UPL
                              122935 TSM:FPAR
                              122939 TSM:ID
                              122941 TSM:ID:OK
                              122943 TSM:UPL
                              124989 TSM:UPL
                              127035 TSM:UPL
                              129081 TSM:UPL
                              131129 TSM:FPAR
                              131133 TSM:ID
                              131135 TSM:ID:OK
                              131137 TSM:UPL
                              133183 TSM:UPL
                              135229 TSM:UPL
                              137275 TSM:UPL
                              139323 TSM:FPAR
                              139327 TSM:ID
                              139329 TSM:ID:OK
                              139331 TSM:UPL
                              141377 TSM:UPL
                              143423 TSM:UPL
                              145469 TSM:UPL
                              147517 TSM:FPAR
                              147521 TSM:ID
                              147523 TSM:ID:OK
                              147525 TSM:UPL
                              149571 TSM:UPL
                              151617 TSM:UPL
                              153663 TSM:UPL
                              155711 TSM:FPAR
                              155715 TSM:ID
                              155717 TSM:ID:OK
                              155719 TSM:UPL
                              157765 TSM:UPL
                              159811 TSM:UPL
                              161857 TSM:UPL
                              163905 TSM:FPAR
                              163909 TSM:ID
                              163911 TSM:ID:OK
                              163913 TSM:UPL
                              165959 TSM:UPL
                              168005 TSM:UPL
                              170051 TSM:UPL
                              172099 TSM:FPAR
                              172103 TSM:ID
                              172105 TSM:ID:OK
                              172107 TSM:UPL
                              174153 TSM:UPL
                              176199 TSM:UPL
                              178245 TSM:UPL
                              180293 TSM:FPAR
                              180297 TSM:ID
                              180299 TSM:ID:OK
                              180301 TSM:UPL
                              182347 TSM:UPL
                              184393 TSM:UPL
                              186439 TSM:UPL
                              188487 TSM:FPAR
                              188491 TSM:ID
                              188493 TSM:ID:OK
                              188495 TSM:UPL
                              190541 TSM:UPL
                              192587 TSM:UPL
                              194633 TSM:UPL
                              196681 TSM:FPAR
                              196685 TSM:ID
                              196687 TSM:ID:OK
                              196689 TSM:UPL
                              198735 TSM:UPL
                              200781 TSM:UPL
                              202827 TSM:UPL
                              204875 TSM:FPAR
                              204879 TSM:ID
                              204881 TSM:ID:OK
                              204883 TSM:UPL
                              206931 TSM:UPL
                              208979 TSM:UPL
                              211027 TSM:UPL
                              213078 TSM:FPAR
                              213082 TSM:ID
                              213084 TSM:ID:OK
                              213086 TSM:UPL
                              215132 TSM:UPL
                              217178 TSM:UPL
                              219224 TSM:UPL
                              221272 TSM:FPAR
                              221276 TSM:ID
                              221278 TSM:ID:OK
                              221280 TSM:UPL
                              223326 TSM:UPL
                              225372 TSM:UPL
                              225695 TSF:MSG:BC
                              226281 TSF:MSG:BC
                              227418 TSM:UPL
                              229466 TSM:FPAR
                              229470 TSM:ID
                              229472 TSM:ID:OK
                              229474 TSM:UPL
                              231520 TSM:UPL
                              233566 TSM:UPL
                              235612 TSM:UPL
                              237660 TSM:FPAR
                              237664 TSM:ID
                              237666 TSM:ID:OK
                              237668 TSM:UPL
                              239714 TSM:UPL
                              241760 TSM:UPL
                              243806 TSM:UPL
                              245854 TSM:FPAR
                              245858 TSM:ID
                              245860 TSM:ID:OK
                              245862 TSM:UPL
                              247908 TSM:UPL
                              249954 TSM:UPL
                              252000 TSM:UPL
                              254048 TSM:FPAR
                              254052 TSM:ID
                              254054 TSM:ID:OK
                              254056 TSM:UPL
                              256102 TSM:UPL
                              258148 TSM:UPL
                              260194 TSM:UPL
                              262242 TSM:FPAR
                              262246 TSM:ID
                              262248 TSM:ID:OK
                              262250 TSM:UPL
                              264296 TSM:UPL
                              266342 TSM:UPL
                              268388 TSM:UPL
                              270436 TSM:FPAR
                              270440 TSM:ID
                              270442 TSM:ID:OK
                              270444 TSM:UPL
                              272490 TSM:UPL
                              274536 TSM:UPL
                              276582 TSM:UPL
                              278630 TSM:FPAR
                              278634 TSM:ID
                              278636 TSM:ID:OK
                              278638 TSM:UPL
                              280684 TSM:UPL
                              282730 TSM:UPL
                              284776 TSM:UPL
                              286824 TSM:FPAR
                              286828 TSM:ID
                              286830 TSM:ID:OK
                              286832 TSM:UPL
                              288878 TSM:UPL
                              290924 TSM:UPL
                              292970 TSM:UPL
                              295018 TSM:FPAR
                              295022 TSM:ID
                              295024 TSM:ID:OK
                              295026 TSM:UPL
                              297072 TSM:UPL
                              299118 TSM:UPL
                              301164 TSM:UPL
                              303212 TSM:FPAR
                              303216 TSM:ID
                              303218 TSM:ID:OK
                              303220 TSM:UPL
                              305266 TSM:UPL
                              307312 TSM:UPL
                              309358 TSM:UPL
                              311406 TSM:FPAR
                              311410 TSM:ID
                              311412 TSM:ID:OK
                              311414 TSM:UPL
                              313460 TSM:UPL
                              315506 TSM:UPL
                              317552 TSM:UPL
                              319600 TSM:FPAR
                              319604 TSM:ID
                              319606 TSM:ID:OK
                              319608 TSM:UPL
                              321654 TSM:UPL
                              323700 TSM:UPL
                              325746 TSM:UPL
                              327794 TSM:FPAR
                              327798 TSM:ID
                              327800 TSM:ID:OK
                              327802 TSM:UPL
                              329848 TSM:UPL
                              331894 TSM:UPL
                              333940 TSM:UPL
                              335988 TSM:FPAR
                              335992 TSM:ID
                              335994 TSM:ID:OK
                              335996 TSM:UPL
                              338042 TSM:UPL
                              340088 TSM:UPL
                              342134 TSM:UPL
                              344182 TSM:FPAR
                              344186 TSM:ID
                              344188 TSM:ID:OK
                              344190 TSM:UPL
                              346238 TSM:UPL
                              348286 TSM:UPL
                              350334 TSM:UPL
                              352385 TSM:FPAR
                              352389 TSM:ID
                              352391 TSM:ID:OK
                              352393 TSM:UPL
                              354439 TSM:UPL
                              356485 TSM:UPL
                              358531 TSM:UPL
                              360579 TSM:FPAR
                              360583 TSM:ID
                              360585 TSM:ID:OK
                              360587 TSM:UPL
                              362633 TSM:UPL
                              364679 TSM:UPL
                              366725 TSM:UPL
                              368773 TSM:FPAR
                              368777 TSM:ID
                              368779 TSM:ID:OK
                              368781 TSM:UPL
                              370827 TSM:UPL
                              372873 TSM:UPL
                              374919 TSM:UPL
                              376967 TSM:FPAR
                              376971 TSM:ID
                              376973 TSM:ID:OK
                              376975 TSM:UPL
                              379021 TSM:UPL
                              381067 TSM:UPL
                              383113 TSM:UPL
                              385161 TSM:FPAR
                              385165 TSM:ID
                              385167 TSM:ID:OK
                              385169 TSM:UPL
                              387215 TSM:UPL
                              389261 TSM:UPL
                              391307 TSM:UPL
                              393355 TSM:FPAR
                              393359 TSM:ID
                              393361 TSM:ID:OK
                              393363 TSM:UPL
                              395409 TSM:UPL
                              397455 TSM:UPL
                              399501 TSM:UPL
                              401549 TSM:FPAR
                              401553 TSM:ID
                              401555 TSM:ID:OK
                              401557 TSM:UPL
                              403603 TSM:UPL
                              405649 TSM:UPL
                              407695 TSM:UPL
                              409743 TSM:FPAR
                              409747 TSM:ID
                              409749 TSM:ID:OK
                              409751 TSM:UPL
                              tekkaT
                              tekkaT
                              tekka
                              @Mark-Swift I guess because of MY_PARENT_NODE_IS_STATIC which prevents the use of an alternative parent.
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @tekka I guessed that, I thought however that you'd mentioned it would timeout, and try again later? As it stands it appears it'll keep trying until the battery is dead?
                                If nothing else I just want to clear up the behaviour so I fully understand it.
                                Mark
                                  Mark
                                  tekkaT
                                  tekkaT
                                  tekka
                                  #22
                                  @Mark-Swift it does timeout, but for that you have to set MY_TRANSPORT_WAIT_READY_MS > 0. This ensures, that loop() will be entered after the timeout if the connection could not be established.
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    @tekka thank you, so if I
                                    #define MY_TRANSPORT_WAIT_READY_MS 60000
                                    Am I right in thinking that my node will enter the loop after it tries to connect to a parent for 60 seconds and fails? (In my case it'd then sleep until the next interrupt, when I guess it would then try again for 60 seconds...).
                                    I really appreciate your help getting my head around this :)
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Mark-Swift Almost :)
                                      applies only when the node starts, i.e. before entering loop(). Once you are in loop() and you put the node to sleep
                                      #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 10000
                                      defines how long the node will try to establish a connection before going to sleep, default is 10s. Please have a look here for additional information.
                                      12.5k
