  3. Battery sensor and re-connecting to gateway
24 Posts 6 Posters 9.1k Views 4 Watching
  • karl261K karl261
    @tekka The only problem with this extra code is, that in case the node loses its connection, it will drain the battery quite quickly...
    tekkaT
    tekkaT
    tekka
    @karl261 yes, in the example you mentioned, the node won't sleep at all if connection is lost and cannot be re-established. For battery powered nodes I recommend using MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC to prevent the transport state machine from entering the SNP (search new parent) state.
    MySensors 2.0.1 introduces an enhanced sleeping function with a reconnection timeout: https://github.com/mysensors/MySensors/pull/558
    • tekkaT tekka
      great work @tekka
      • karl261K
        karl261K
        karl261
        @tekka Yeah, that's what I actually use. Since I normally don't move my sensors and repeaters, having the parent node static sounds like a good thing to do.
        I look forward to the 2.0.1 release. There seem to be a lot of cool new things inside.
        @tekka, @oitzu, Still, this nrf is driving me nuts. My sensor in the garden has worked just fine for three weeks, and nothing has changed. Now it makes problems. It is still running, because once per day one Temp reading or similar is getting through. Battery is just the same as before.
        Do you have any idea why it could have stopped working? I don't see any reason why the repeater should stop receiving the values. The repeater works fine, it relays all other nodes. And the geometry between repeater and garden sensor has not changed.
        The weather has changed. The T is about 7 degrees less outside...
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          @tekka I'm using the latest snapshot on one of my battery sensors and can see if it can't connect, it doesn't sleep and the debug shows a rapid number of connection attempts. I'd like to know if the sensor will eventually sleep if it cannot successfully connect, and what the default timeout is?
          tekkaT 1 Reply Last reply
          • Mark SwiftM Mark Swift
            tekkaT
            tekkaT
            tekka
            @Mark-Swift Please post your sketch & full debug log. Thanks
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              @tekka I don't think there's an issue.
              I'm simply asking what the logic is behind the reconnection logic on sleeping sensors, how long is the timeout for example (I'm conscious of battery drain for nodes having issues connecting).
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @Mark-Swift No, this sounds like an issue - a rapid number of connection attempts is unusual, that's why I'm interested in your sketch/debug log.
                To answer your questions: In the latest dev version the node will try to reconnect with a 10sec timeout (if sleeping time > 10sec, this can be changed via MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) before sleeping - if time is left.
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  wrote on last edited by Mark Swift
                  @tekka it's been a while but I never resolved this... If I test by changing the parent node ID to a fake one, it just tried to connect forever, thus draining the battery...
                  Sketch:
                    REVISION HISTORY
                    Created by Mark Swift
                    V1.2 - Added sleep time to force daily update
                    V1.3 - Deactivate pullup on setup and added old_value logic
                    V1.4 - Added daily wakeup to sleep
                    V1.5 - Code cleanup
                  //*** EXTERNAL LIBRARIES **********************************
                  #include <Vcc.h>
                  //*** MYSENSORS *******************************************
                  // Enable debug prints
                  // Lower serial speed if using 1Mhz clock
                  // #define MY_BAUD_RATE 9600
                  #define MY_NODE_ID 4
                  #define MY_PARENT_NODE_ID 1 // AUTO
                  // #define MY_RADIO_RFM69
                  // Override RF24L01 channel number
                  // #define MY_RF24_CHANNEL 125
                  // Override RF24L01 module PA level
                  // #define MY_RF24_PA_LEVEL RF24_PA_LOW
                  // Override RF24L01 datarate
                  // #define MY_RF24_DATARATE RF24_250KBPS
                  // *** SKETCH CONFIG **************************************
                  #define SKETCH_NAME "Door Sensor"
                  #define SKETCH_MAJOR_VER "1"
                  #define SKETCH_MINOR_VER "5"
                  // Define the sensor child IDs
                  #define CHILD_ID1 1 // Switch
                  #define CHILD_ID2 2 // Battery voltage
                  #define CHILD_ID3 3 // Battery percent
                  // Define the message formats
                  MyMessage msg(CHILD_ID1, V_TRIPPED);
                  MyMessage msg2(CHILD_ID2, V_CUSTOM);
                  MyMessage msg3(CHILD_ID3, V_CUSTOM);
                  // *** SENSORS CONFIG *************************************
                  // Digital I/O pin for button or reed switch
                  #define PRIMARY_BUTTON_PIN 3
                  // Debounce using a small sleep
                  #define DEBOUNCE_SLEEP 5
                  // Sleep timer in milliseconds
                  #define SLEEP_IN_MS 86400000
                  // Store the old value for comparison
                  int old_value = -1;
                  // Minimum expected vcc level, in volts (2xAA alkaline)
                  const float vcc_min = 2.0 * 0.9;
                  // Maximum expected vcc level, in volts (2xAA alkaline)
                  const float vcc_max = 2.0 * 1.5;
                  // Measured vcc by multimeter divided by reported vcc
                  const float vcc_correction = 2.88 / 2.82;
                  Vcc vcc(vcc_correction);
                  // *** BEGIN **********************************************
                    // Setup the contact sensor
                    // Activate or deactivate the internal pull-up - high if using internal resistor or low if using external
                    digitalWrite(PRIMARY_BUTTON_PIN, LOW);
                    // Register all sensors to the gateway
                    present(CHILD_ID1, S_DOOR);
                    present(CHILD_ID2, S_CUSTOM);
                    present(CHILD_ID3, S_CUSTOM);
                    // Debouce using sleep
                    sleep(DEBOUNCE_SLEEP);
                    int value = digitalRead(PRIMARY_BUTTON_PIN);
                    // If value has changed send the updated value
                    if (value != old_value) {
                      send(msg.set(value == HIGH ? 0 : 1));
                      old_value = value;
                    // Read battery voltage
                    float battery_voltage = vcc.Read_Volts();
                    // Calculate battery percentage
                    float battery_percent = vcc.Read_Perc(vcc_min, vcc_max);
                  #ifdef MY_DEBUG
                    Serial.print("Battery = ");
                    Serial.print(battery_voltage);
                    Serial.println(" Volts");
                    Serial.print(battery_percent);
                    Serial.println("%");
                    // Send battery readings
                    send(msg2.set(battery_voltage, 2));
                    send(msg3.set(battery_percent, 1));
                    sendBatteryLevel(battery_percent);
                    // Sleep until either interupt change or timer reaches zero
                    smartSleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_IN_MS);
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    Debug:
                    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                    4 TSM:INIT
                    6 TSF:WUR:MS=0
                    14 TSM:INIT:TSP OK
                    16 TSM:INIT:STATID=4
                    18 TSF:SID:OK,ID=4
                    20 TSM:FPAR
                    22 TSM:FPAR:STATP=1
                    24 TSM:ID
                    24 TSM:ID:OK
                    26 TSM:UPL
                    63 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    2072 TSM:UPL
                    2109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    4118 TSM:UPL
                    4155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    6164 TSM:UPL
                    6201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    8210 !TSM:UPL:FAIL
                    8212 TSM:FPAR
                    8212 TSM:FPAR:STATP=1
                    8214 TSM:ID
                    8216 TSM:ID:OK
                    8218 TSM:UPL
                    8255 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    10264 TSM:UPL
                    10301 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    12310 TSM:UPL
                    12347 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    14356 TSM:UPL
                    14393 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    16402 !TSM:UPL:FAIL
                    16404 TSM:FPAR
                    16404 TSM:FPAR:STATP=1
                    16408 TSM:ID
                    16410 TSM:ID:OK
                    16410 TSM:UPL
                    16449 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    18458 TSM:UPL
                    18495 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    20504 TSM:UPL
                    20541 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    22550 TSM:UPL
                    22587 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    24596 !TSM:UPL:FAIL
                    24598 TSM:FPAR
                    24598 TSM:FPAR:STATP=1
                    24602 TSM:ID
                    24604 TSM:ID:OK
                    24604 TSM:UPL
                    24643 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    26652 TSM:UPL
                    26689 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    28698 TSM:UPL
                    28735 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    30744 TSM:UPL
                    30781 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    32790 !TSM:UPL:FAIL
                    32792 TSM:FPAR
                    32792 TSM:FPAR:STATP=1
                    32796 TSM:ID
                    32798 TSM:ID:OK
                    32798 TSM:UPL
                    32837 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    34846 TSM:UPL
                    34883 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    36892 TSM:UPL
                    36929 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    38938 TSM:UPL
                    38975 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    40984 !TSM:UPL:FAIL
                    40986 TSM:FPAR
                    40986 TSM:FPAR:STATP=1
                    40990 TSM:ID
                    40992 TSM:ID:OK
                    40992 TSM:UPL
                    41031 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    43040 TSM:UPL
                    43077 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    45086 TSM:UPL
                    45123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    47132 TSM:UPL
                    47169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    49178 !TSM:UPL:FAIL
                    49180 TSM:FPAR
                    49180 TSM:FPAR:STATP=1
                    49184 TSM:ID
                    49186 TSM:ID:OK
                    49186 TSM:UPL
                    49225 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    51234 TSM:UPL
                    51271 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    53280 TSM:UPL
                    53317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    55326 TSM:UPL
                    55363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    57372 !TSM:UPL:FAIL
                    57374 TSM:FPAR
                    57374 TSM:FPAR:STATP=1
                    57378 TSM:ID
                    57380 TSM:ID:OK
                    57380 TSM:UPL
                    57419 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    59428 TSM:UPL
                    59465 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    61474 TSM:UPL
                    61511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    63520 TSM:UPL
                    63557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    65566 !TSM:UPL:FAIL
                    65568 TSM:FPAR
                    65568 TSM:FPAR:STATP=1
                    65572 TSM:ID
                    65574 TSM:ID:OK
                    65574 TSM:UPL
                    65613 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    67624 TSM:UPL
                    67661 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    69672 TSM:UPL
                    69709 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    71720 TSM:UPL
                    71757 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    73768 !TSM:UPL:FAIL
                    73771 TSM:FPAR
                    73771 TSM:FPAR:STATP=1
                    73775 TSM:ID
                    73777 TSM:ID:OK
                    73777 TSM:UPL
                    73816 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    75825 TSM:UPL
                    75862 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    77871 TSM:UPL
                    77907 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    79917 TSM:UPL
                    79953 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    81963 !TSM:UPL:FAIL
                    81965 TSM:FPAR
                    81965 TSM:FPAR:STATP=1
                    81969 TSM:ID
                    81971 TSM:ID:OK
                    81971 TSM:UPL
                    82010 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    84019 TSM:UPL
                    84056 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    86065 TSM:UPL
                    86102 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    88111 TSM:UPL
                    88147 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    90157 !TSM:UPL:FAIL
                    90159 TSM:FPAR
                    90159 TSM:FPAR:STATP=1
                    90163 TSM:ID
                    90165 TSM:ID:OK
                    90165 TSM:UPL
                    90204 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    92213 TSM:UPL
                    92250 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    94259 TSM:UPL
                    94296 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    96305 TSM:UPL
                    96342 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    98351 !TSM:UPL:FAIL
                    98353 TSM:FPAR
                    98353 TSM:FPAR:STATP=1
                    98357 TSM:ID
                    98359 TSM:ID:OK
                    98359 TSM:UPL
                    98398 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    100407 TSM:UPL
                    100444 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    102453 TSM:UPL
                    102490 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    104499 TSM:UPL
                    104536 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    106545 !TSM:UPL:FAIL
                    106547 TSM:FPAR
                    106549 TSM:FPAR:STATP=1
                    106551 TSM:ID
                    106553 TSM:ID:OK
                    106555 TSM:UPL
                    106592 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    108601 TSM:UPL
                    108638 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    110647 TSM:UPL
                    110684 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    112693 TSM:UPL
                    112730 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    114739 !TSM:UPL:FAIL
                    114741 TSM:FPAR
                    114743 TSM:FPAR:STATP=1
                    114745 TSM:ID
                    114747 TSM:ID:OK
                    114749 TSM:UPL
                    114786 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    116795 TSM:UPL
                    116832 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    118841 TSM:UPL
                    118878 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    120887 TSM:UPL
                    120924 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    122933 !TSM:UPL:FAIL
                    122935 TSM:FPAR
                    122937 TSM:FPAR:STATP=1
                    122939 TSM:ID
                    122941 TSM:ID:OK
                    122943 TSM:UPL
                    122980 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    124989 TSM:UPL
                    125026 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    127035 TSM:UPL
                    127072 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    129081 TSM:UPL
                    129118 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    131127 !TSM:UPL:FAIL
                    131129 TSM:FPAR
                    131131 TSM:FPAR:STATP=1
                    131133 TSM:ID
                    131135 TSM:ID:OK
                    131137 TSM:UPL
                    131174 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    133183 TSM:UPL
                    133220 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    135229 TSM:UPL
                    135266 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    137275 TSM:UPL
                    137312 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    139321 !TSM:UPL:FAIL
                    139323 TSM:FPAR
                    139325 TSM:FPAR:STATP=1
                    139327 TSM:ID
                    139329 TSM:ID:OK
                    139331 TSM:UPL
                    139368 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    141377 TSM:UPL
                    141414 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    143423 TSM:UPL
                    143460 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    145469 TSM:UPL
                    145506 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    147515 !TSM:UPL:FAIL
                    147517 TSM:FPAR
                    147519 TSM:FPAR:STATP=1
                    147521 TSM:ID
                    147523 TSM:ID:OK
                    147525 TSM:UPL
                    147562 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    149571 TSM:UPL
                    149608 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    151617 TSM:UPL
                    151654 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    153663 TSM:UPL
                    153700 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    155709 !TSM:UPL:FAIL
                    155711 TSM:FPAR
                    155713 TSM:FPAR:STATP=1
                    155715 TSM:ID
                    155717 TSM:ID:OK
                    155719 TSM:UPL
                    155756 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    157765 TSM:UPL
                    157802 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    159811 TSM:UPL
                    159848 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    161857 TSM:UPL
                    161894 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    163903 !TSM:UPL:FAIL
                    163905 TSM:FPAR
                    163907 TSM:FPAR:STATP=1
                    163909 TSM:ID
                    163911 TSM:ID:OK
                    163913 TSM:UPL
                    163950 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    165959 TSM:UPL
                    165996 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    168005 TSM:UPL
                    168042 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    170051 TSM:UPL
                    170088 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    172097 !TSM:UPL:FAIL
                    172099 TSM:FPAR
                    172101 TSM:FPAR:STATP=1
                    172103 TSM:ID
                    172105 TSM:ID:OK
                    172107 TSM:UPL
                    172144 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    174153 TSM:UPL
                    174190 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    176199 TSM:UPL
                    176236 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    178245 TSM:UPL
                    178282 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    180291 !TSM:UPL:FAIL
                    180293 TSM:FPAR
                    180295 TSM:FPAR:STATP=1
                    180297 TSM:ID
                    180299 TSM:ID:OK
                    180301 TSM:UPL
                    180338 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    182347 TSM:UPL
                    182384 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    184393 TSM:UPL
                    184430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    186439 TSM:UPL
                    186476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    188485 !TSM:UPL:FAIL
                    188487 TSM:FPAR
                    188489 TSM:FPAR:STATP=1
                    188491 TSM:ID
                    188493 TSM:ID:OK
                    188495 TSM:UPL
                    188532 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    190541 TSM:UPL
                    190578 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    192587 TSM:UPL
                    192624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    194633 TSM:UPL
                    194670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    196679 !TSM:UPL:FAIL
                    196681 TSM:FPAR
                    196683 TSM:FPAR:STATP=1
                    196685 TSM:ID
                    196687 TSM:ID:OK
                    196689 TSM:UPL
                    196726 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    198735 TSM:UPL
                    198772 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    200781 TSM:UPL
                    200818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    202827 TSM:UPL
                    202864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    204873 !TSM:UPL:FAIL
                    204875 TSM:FPAR
                    204877 TSM:FPAR:STATP=1
                    204879 TSM:ID
                    204881 TSM:ID:OK
                    204883 TSM:UPL
                    204920 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    206931 TSM:UPL
                    206968 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    208979 TSM:UPL
                    209016 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    211027 TSM:UPL
                    211064 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    213075 !TSM:UPL:FAIL
                    213078 TSM:FPAR
                    213080 TSM:FPAR:STATP=1
                    213082 TSM:ID
                    213084 TSM:ID:OK
                    213086 TSM:UPL
                    213123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    215132 TSM:UPL
                    215169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    217178 TSM:UPL
                    217214 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    219224 TSM:UPL
                    219260 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    221270 !TSM:UPL:FAIL
                    221272 TSM:FPAR
                    221274 TSM:FPAR:STATP=1
                    221276 TSM:ID
                    221278 TSM:ID:OK
                    221280 TSM:UPL
                    221317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    223326 TSM:UPL
                    223363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    225372 TSM:UPL
                    225409 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    225689 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                    225695 TSF:MSG:BC
                    226275 TSF:MSG:READ,0-3-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                    226281 TSF:MSG:BC
                    227418 TSM:UPL
                    227454 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    229464 !TSM:UPL:FAIL
                    229466 TSM:FPAR
                    229468 TSM:FPAR:STATP=1
                    229470 TSM:ID
                    229472 TSM:ID:OK
                    229474 TSM:UPL
                    229511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    231520 TSM:UPL
                    231557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    233566 TSM:UPL
                    233603 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    235612 TSM:UPL
                    235649 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    237658 !TSM:UPL:FAIL
                    237660 TSM:FPAR
                    237662 TSM:FPAR:STATP=1
                    237664 TSM:ID
                    237666 TSM:ID:OK
                    237668 TSM:UPL
                    237705 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    239714 TSM:UPL
                    239751 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    241760 TSM:UPL
                    241797 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    243806 TSM:UPL
                    243843 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    245852 !TSM:UPL:FAIL
                    245854 TSM:FPAR
                    245856 TSM:FPAR:STATP=1
                    245858 TSM:ID
                    245860 TSM:ID:OK
                    245862 TSM:UPL
                    245899 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    247908 TSM:UPL
                    247945 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    249954 TSM:UPL
                    249991 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    252000 TSM:UPL
                    252037 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    254046 !TSM:UPL:FAIL
                    254048 TSM:FPAR
                    254050 TSM:FPAR:STATP=1
                    254052 TSM:ID
                    254054 TSM:ID:OK
                    254056 TSM:UPL
                    254093 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    256102 TSM:UPL
                    256139 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    258148 TSM:UPL
                    258185 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    260194 TSM:UPL
                    260231 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    262240 !TSM:UPL:FAIL
                    262242 TSM:FPAR
                    262244 TSM:FPAR:STATP=1
                    262246 TSM:ID
                    262248 TSM:ID:OK
                    262250 TSM:UPL
                    262287 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    264296 TSM:UPL
                    264333 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    266342 TSM:UPL
                    266379 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    268388 TSM:UPL
                    268425 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    270434 !TSM:UPL:FAIL
                    270436 TSM:FPAR
                    270438 TSM:FPAR:STATP=1
                    270440 TSM:ID
                    270442 TSM:ID:OK
                    270444 TSM:UPL
                    270481 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    272490 TSM:UPL
                    272527 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    274536 TSM:UPL
                    274573 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    276582 TSM:UPL
                    276619 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    278628 !TSM:UPL:FAIL
                    278630 TSM:FPAR
                    278632 TSM:FPAR:STATP=1
                    278634 TSM:ID
                    278636 TSM:ID:OK
                    278638 TSM:UPL
                    278675 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    280684 TSM:UPL
                    280721 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    282730 TSM:UPL
                    282767 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    284776 TSM:UPL
                    284813 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    286822 !TSM:UPL:FAIL
                    286824 TSM:FPAR
                    286826 TSM:FPAR:STATP=1
                    286828 TSM:ID
                    286830 TSM:ID:OK
                    286832 TSM:UPL
                    286869 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    288878 TSM:UPL
                    288915 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    290924 TSM:UPL
                    290961 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    292970 TSM:UPL
                    293007 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    295016 !TSM:UPL:FAIL
                    295018 TSM:FPAR
                    295020 TSM:FPAR:STATP=1
                    295022 TSM:ID
                    295024 TSM:ID:OK
                    295026 TSM:UPL
                    295063 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    297072 TSM:UPL
                    297109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    299118 TSM:UPL
                    299155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    301164 TSM:UPL
                    301201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    303210 !TSM:UPL:FAIL
                    303212 TSM:FPAR
                    303214 TSM:FPAR:STATP=1
                    303216 TSM:ID
                    303218 TSM:ID:OK
                    303220 TSM:UPL
                    303257 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    305266 TSM:UPL
                    305303 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    307312 TSM:UPL
                    307349 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    309358 TSM:UPL
                    309395 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    311404 !TSM:UPL:FAIL
                    311406 TSM:FPAR
                    311408 TSM:FPAR:STATP=1
                    311410 TSM:ID
                    311412 TSM:ID:OK
                    311414 TSM:UPL
                    311451 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    313460 TSM:UPL
                    313497 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    315506 TSM:UPL
                    315543 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    317552 TSM:UPL
                    317589 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    319598 !TSM:UPL:FAIL
                    319600 TSM:FPAR
                    319602 TSM:FPAR:STATP=1
                    319604 TSM:ID
                    319606 TSM:ID:OK
                    319608 TSM:UPL
                    319645 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    321654 TSM:UPL
                    321691 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    323700 TSM:UPL
                    323737 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    325746 TSM:UPL
                    325783 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    327792 !TSM:UPL:FAIL
                    327794 TSM:FPAR
                    327796 TSM:FPAR:STATP=1
                    327798 TSM:ID
                    327800 TSM:ID:OK
                    327802 TSM:UPL
                    327839 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    329848 TSM:UPL
                    329885 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    331894 TSM:UPL
                    331931 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    333940 TSM:UPL
                    333977 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    335986 !TSM:UPL:FAIL
                    335988 TSM:FPAR
                    335990 TSM:FPAR:STATP=1
                    335992 TSM:ID
                    335994 TSM:ID:OK
                    335996 TSM:UPL
                    336033 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    338042 TSM:UPL
                    338079 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    340088 TSM:UPL
                    340125 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    342134 TSM:UPL
                    342171 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    344180 !TSM:UPL:FAIL
                    344182 TSM:FPAR
                    344184 TSM:FPAR:STATP=1
                    344186 TSM:ID
                    344188 TSM:ID:OK
                    344190 TSM:UPL
                    344227 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    346238 TSM:UPL
                    346275 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    348286 TSM:UPL
                    348323 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    350334 TSM:UPL
                    350371 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    352382 !TSM:UPL:FAIL
                    352385 TSM:FPAR
                    352387 TSM:FPAR:STATP=1
                    352389 TSM:ID
                    352391 TSM:ID:OK
                    352393 TSM:UPL
                    352430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    354439 TSM:UPL
                    354476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    356485 TSM:UPL
                    356521 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    358531 TSM:UPL
                    358567 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    360577 !TSM:UPL:FAIL
                    360579 TSM:FPAR
                    360581 TSM:FPAR:STATP=1
                    360583 TSM:ID
                    360585 TSM:ID:OK
                    360587 TSM:UPL
                    360624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    362633 TSM:UPL
                    362670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    364679 TSM:UPL
                    364716 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    366725 TSM:UPL
                    366761 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    368771 !TSM:UPL:FAIL
                    368773 TSM:FPAR
                    368775 TSM:FPAR:STATP=1
                    368777 TSM:ID
                    368779 TSM:ID:OK
                    368781 TSM:UPL
                    368818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    370827 TSM:UPL
                    370864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    372873 TSM:UPL
                    372910 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    374919 TSM:UPL
                    374956 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    376965 !TSM:UPL:FAIL
                    376967 TSM:FPAR
                    376969 TSM:FPAR:STATP=1
                    376971 TSM:ID
                    376973 TSM:ID:OK
                    376975 TSM:UPL
                    377012 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                    379021 TSM:UPL
                    379058 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                    381067 TSM:UPL
                    381104 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                    383113 TSM:UPL
                    383150 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                    385159 !TSM:UPL:FAIL
                    385161 TSM:FPAR
                    385163 TSM:FPAR:STATP=1
                    385165 TSM:ID
                    385167 TSM:ID:OK
                    385169 TSM:UPL
                    385206 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                    387215 TSM:UPL
                    387252 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                    389261 TSM:UPL
                    389298 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                    391307 TSM:UPL
                    391344 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                    393353 !TSM:UPL:FAIL
                    393355 TSM:FPAR
                    393357 TSM:FPAR:STATP=1
                    393359 TSM:ID
                    393361 TSM:ID:OK
                    393363 TSM:UPL
                    393400 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    395409 TSM:UPL
                    395446 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    397455 TSM:UPL
                    397492 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                    399501 TSM:UPL
                    399538 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                    401547 !TSM:UPL:FAIL
                    401549 TSM:FPAR
                    401551 TSM:FPAR:STATP=1
                    401553 TSM:ID
                    401555 TSM:ID:OK
                    401557 TSM:UPL
                    401594 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                    403603 TSM:UPL
                    403640 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                    405649 TSM:UPL
                    405686 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                    407695 TSM:UPL
                    407732 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                    409741 !TSM:UPL:FAIL
                    409743 TSM:FPAR
                    409745 TSM:FPAR:STATP=1
                    409747 TSM:ID
                    409749 TSM:ID:OK
                    409751 TSM:UPL
                    409788 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                      Debug:
                      4 TSM:INIT
                      6 TSF:WUR:MS=0
                      14 TSM:INIT:TSP OK
                      18 TSF:SID:OK,ID=4
                      20 TSM:FPAR
                      22 TSM:FPAR:STATP=1
                      24 TSM:ID
                      24 TSM:ID:OK
                      26 TSM:UPL
                      2072 TSM:UPL
                      4118 TSM:UPL
                      6164 TSM:UPL
                      8210 !TSM:UPL:FAIL
                      8212 TSM:FPAR
                      8214 TSM:ID
                      8216 TSM:ID:OK
                      8218 TSM:UPL
                      10264 TSM:UPL
                      12310 TSM:UPL
                      14356 TSM:UPL
                      16402 !TSM:UPL:FAIL
                      16404 TSM:FPAR
                      16408 TSM:ID
                      16410 TSM:ID:OK
                      16410 TSM:UPL
                      18458 TSM:UPL
                      20504 TSM:UPL
                      22550 TSM:UPL
                      24596 !TSM:UPL:FAIL
                      24598 TSM:FPAR
                      24602 TSM:ID
                      24604 TSM:ID:OK
                      24604 TSM:UPL
                      26652 TSM:UPL
                      28698 TSM:UPL
                      30744 TSM:UPL
                      32790 !TSM:UPL:FAIL
                      32792 TSM:FPAR
                      32796 TSM:ID
                      32798 TSM:ID:OK
                      32798 TSM:UPL
                      34846 TSM:UPL
                      36892 TSM:UPL
                      38938 TSM:UPL
                      40984 !TSM:UPL:FAIL
                      40986 TSM:FPAR
                      40990 TSM:ID
                      40992 TSM:ID:OK
                      40992 TSM:UPL
                      43040 TSM:UPL
                      45086 TSM:UPL
                      47132 TSM:UPL
                      49178 !TSM:UPL:FAIL
                      49180 TSM:FPAR
                      49184 TSM:ID
                      49186 TSM:ID:OK
                      49186 TSM:UPL
                      51234 TSM:UPL
                      53280 TSM:UPL
                      55326 TSM:UPL
                      57372 !TSM:UPL:FAIL
                      57374 TSM:FPAR
                      57378 TSM:ID
                      57380 TSM:ID:OK
                      57380 TSM:UPL
                      59428 TSM:UPL
                      61474 TSM:UPL
                      63520 TSM:UPL
                      65566 !TSM:UPL:FAIL
                      65568 TSM:FPAR
                      65572 TSM:ID
                      65574 TSM:ID:OK
                      65574 TSM:UPL
                      67624 TSM:UPL
                      69672 TSM:UPL
                      71720 TSM:UPL
                      73768 !TSM:UPL:FAIL
                      73771 TSM:FPAR
                      73775 TSM:ID
                      73777 TSM:ID:OK
                      73777 TSM:UPL
                      75825 TSM:UPL
                      77871 TSM:UPL
                      79917 TSM:UPL
                      81963 !TSM:UPL:FAIL
                      81965 TSM:FPAR
                      81969 TSM:ID
                      81971 TSM:ID:OK
                      81971 TSM:UPL
                      84019 TSM:UPL
                      86065 TSM:UPL
                      88111 TSM:UPL
                      90157 !TSM:UPL:FAIL
                      90159 TSM:FPAR
                      90163 TSM:ID
                      90165 TSM:ID:OK
                      90165 TSM:UPL
                      92213 TSM:UPL
                      94259 TSM:UPL
                      96305 TSM:UPL
                      98351 !TSM:UPL:FAIL
                      98353 TSM:FPAR
                      98357 TSM:ID
                      98359 TSM:ID:OK
                      98359 TSM:UPL
                      100407 TSM:UPL
                      102453 TSM:UPL
                      104499 TSM:UPL
                      106547 TSM:FPAR
                      106551 TSM:ID
                      106553 TSM:ID:OK
                      106555 TSM:UPL
                      108601 TSM:UPL
                      110647 TSM:UPL
                      112693 TSM:UPL
                      114741 TSM:FPAR
                      114745 TSM:ID
                      114747 TSM:ID:OK
                      114749 TSM:UPL
                      116795 TSM:UPL
                      118841 TSM:UPL
                      120887 TSM:UPL
                      122935 TSM:FPAR
                      122939 TSM:ID
                      122941 TSM:ID:OK
                      122943 TSM:UPL
                      124989 TSM:UPL
                      127035 TSM:UPL
                      129081 TSM:UPL
                      131129 TSM:FPAR
                      131133 TSM:ID
                      131135 TSM:ID:OK
                      131137 TSM:UPL
                      133183 TSM:UPL
                      135229 TSM:UPL
                      137275 TSM:UPL
                      139323 TSM:FPAR
                      139327 TSM:ID
                      139329 TSM:ID:OK
                      139331 TSM:UPL
                      141377 TSM:UPL
                      143423 TSM:UPL
                      145469 TSM:UPL
                      147517 TSM:FPAR
                      147521 TSM:ID
                      147523 TSM:ID:OK
                      147525 TSM:UPL
                      149571 TSM:UPL
                      151617 TSM:UPL
                      153663 TSM:UPL
                      155711 TSM:FPAR
                      155715 TSM:ID
                      155717 TSM:ID:OK
                      155719 TSM:UPL
                      157765 TSM:UPL
                      159811 TSM:UPL
                      161857 TSM:UPL
                      163905 TSM:FPAR
                      163909 TSM:ID
                      163911 TSM:ID:OK
                      163913 TSM:UPL
                      165959 TSM:UPL
                      168005 TSM:UPL
                      170051 TSM:UPL
                      172099 TSM:FPAR
                      172103 TSM:ID
                      172105 TSM:ID:OK
                      172107 TSM:UPL
                      174153 TSM:UPL
                      176199 TSM:UPL
                      178245 TSM:UPL
                      180293 TSM:FPAR
                      180297 TSM:ID
                      180299 TSM:ID:OK
                      180301 TSM:UPL
                      182347 TSM:UPL
                      184393 TSM:UPL
                      186439 TSM:UPL
                      188487 TSM:FPAR
                      188491 TSM:ID
                      188493 TSM:ID:OK
                      188495 TSM:UPL
                      190541 TSM:UPL
                      192587 TSM:UPL
                      194633 TSM:UPL
                      196681 TSM:FPAR
                      196685 TSM:ID
                      196687 TSM:ID:OK
                      196689 TSM:UPL
                      198735 TSM:UPL
                      200781 TSM:UPL
                      202827 TSM:UPL
                      204875 TSM:FPAR
                      204879 TSM:ID
                      204881 TSM:ID:OK
                      204883 TSM:UPL
                      206931 TSM:UPL
                      208979 TSM:UPL
                      211027 TSM:UPL
                      213078 TSM:FPAR
                      213082 TSM:ID
                      213084 TSM:ID:OK
                      213086 TSM:UPL
                      215132 TSM:UPL
                      217178 TSM:UPL
                      219224 TSM:UPL
                      221272 TSM:FPAR
                      221276 TSM:ID
                      221278 TSM:ID:OK
                      221280 TSM:UPL
                      223326 TSM:UPL
                      225372 TSM:UPL
                      225695 TSF:MSG:BC
                      226281 TSF:MSG:BC
                      227418 TSM:UPL
                      229466 TSM:FPAR
                      229470 TSM:ID
                      229472 TSM:ID:OK
                      229474 TSM:UPL
                      231520 TSM:UPL
                      233566 TSM:UPL
                      235612 TSM:UPL
                      237660 TSM:FPAR
                      237664 TSM:ID
                      237666 TSM:ID:OK
                      237668 TSM:UPL
                      239714 TSM:UPL
                      241760 TSM:UPL
                      243806 TSM:UPL
                      245854 TSM:FPAR
                      245858 TSM:ID
                      245860 TSM:ID:OK
                      245862 TSM:UPL
                      247908 TSM:UPL
                      249954 TSM:UPL
                      252000 TSM:UPL
                      254048 TSM:FPAR
                      254052 TSM:ID
                      254054 TSM:ID:OK
                      254056 TSM:UPL
                      256102 TSM:UPL
                      258148 TSM:UPL
                      260194 TSM:UPL
                      262242 TSM:FPAR
                      262246 TSM:ID
                      262248 TSM:ID:OK
                      262250 TSM:UPL
                      264296 TSM:UPL
                      266342 TSM:UPL
                      268388 TSM:UPL
                      270436 TSM:FPAR
                      270440 TSM:ID
                      270442 TSM:ID:OK
                      270444 TSM:UPL
                      272490 TSM:UPL
                      274536 TSM:UPL
                      276582 TSM:UPL
                      278630 TSM:FPAR
                      278634 TSM:ID
                      278636 TSM:ID:OK
                      278638 TSM:UPL
                      280684 TSM:UPL
                      282730 TSM:UPL
                      284776 TSM:UPL
                      286824 TSM:FPAR
                      286828 TSM:ID
                      286830 TSM:ID:OK
                      286832 TSM:UPL
                      288878 TSM:UPL
                      290924 TSM:UPL
                      292970 TSM:UPL
                      295018 TSM:FPAR
                      295022 TSM:ID
                      295024 TSM:ID:OK
                      295026 TSM:UPL
                      297072 TSM:UPL
                      299118 TSM:UPL
                      301164 TSM:UPL
                      303212 TSM:FPAR
                      303216 TSM:ID
                      303218 TSM:ID:OK
                      303220 TSM:UPL
                      305266 TSM:UPL
                      307312 TSM:UPL
                      309358 TSM:UPL
                      311406 TSM:FPAR
                      311410 TSM:ID
                      311412 TSM:ID:OK
                      311414 TSM:UPL
                      313460 TSM:UPL
                      315506 TSM:UPL
                      317552 TSM:UPL
                      319600 TSM:FPAR
                      319604 TSM:ID
                      319606 TSM:ID:OK
                      319608 TSM:UPL
                      321654 TSM:UPL
                      323700 TSM:UPL
                      325746 TSM:UPL
                      327794 TSM:FPAR
                      327798 TSM:ID
                      327800 TSM:ID:OK
                      327802 TSM:UPL
                      329848 TSM:UPL
                      331894 TSM:UPL
                      333940 TSM:UPL
                      335988 TSM:FPAR
                      335992 TSM:ID
                      335994 TSM:ID:OK
                      335996 TSM:UPL
                      338042 TSM:UPL
                      340088 TSM:UPL
                      342134 TSM:UPL
                      344182 TSM:FPAR
                      344186 TSM:ID
                      344188 TSM:ID:OK
                      344190 TSM:UPL
                      346238 TSM:UPL
                      348286 TSM:UPL
                      350334 TSM:UPL
                      352385 TSM:FPAR
                      352389 TSM:ID
                      352391 TSM:ID:OK
                      352393 TSM:UPL
                      354439 TSM:UPL
                      356485 TSM:UPL
                      358531 TSM:UPL
                      360579 TSM:FPAR
                      360583 TSM:ID
                      360585 TSM:ID:OK
                      360587 TSM:UPL
                      362633 TSM:UPL
                      364679 TSM:UPL
                      366725 TSM:UPL
                      368773 TSM:FPAR
                      368777 TSM:ID
                      368779 TSM:ID:OK
                      368781 TSM:UPL
                      370827 TSM:UPL
                      372873 TSM:UPL
                      374919 TSM:UPL
                      376967 TSM:FPAR
                      376971 TSM:ID
                      376973 TSM:ID:OK
                      376975 TSM:UPL
                      379021 TSM:UPL
                      381067 TSM:UPL
                      383113 TSM:UPL
                      385161 TSM:FPAR
                      385165 TSM:ID
                      385167 TSM:ID:OK
                      385169 TSM:UPL
                      387215 TSM:UPL
                      389261 TSM:UPL
                      391307 TSM:UPL
                      393355 TSM:FPAR
                      393359 TSM:ID
                      393361 TSM:ID:OK
                      393363 TSM:UPL
                      395409 TSM:UPL
                      397455 TSM:UPL
                      399501 TSM:UPL
                      401549 TSM:FPAR
                      401553 TSM:ID
                      401555 TSM:ID:OK
                      401557 TSM:UPL
                      403603 TSM:UPL
                      405649 TSM:UPL
                      407695 TSM:UPL
                      409743 TSM:FPAR
                      409747 TSM:ID
                      409749 TSM:ID:OK
                      409751 TSM:UPL
                      tekkaT
                      tekkaT
                      tekka
                      @Mark-Swift I guess because of MY_PARENT_NODE_IS_STATIC which prevents the use of an alternative parent.
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @tekka I guessed that, I thought however that you'd mentioned it would timeout, and try again later? As it stands it appears it'll keep trying until the battery is dead?
                        If nothing else I just want to clear up the behaviour so I fully understand it.
                        Mark
                          Mark
                          tekkaT
                          tekkaT
                          tekka
                          #22
                          @Mark-Swift it does timeout, but for that you have to set MY_TRANSPORT_WAIT_READY_MS > 0. This ensures, that loop() will be entered after the timeout if the connection could not be established.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @tekka thank you, so if I
                            #define MY_TRANSPORT_WAIT_READY_MS 60000
                            Am I right in thinking that my node will enter the loop after it tries to connect to a parent for 60 seconds and fails? (In my case it'd then sleep until the next interrupt, when I guess it would then try again for 60 seconds...).
                            I really appreciate your help getting my head around this :)
                              tekkaT
                              tekkaT
                              tekka
                              @Mark-Swift Almost :)
                              applies only when the node starts, i.e. before entering loop(). Once you are in loop() and you put the node to sleep
                              #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 10000
                              defines how long the node will try to establish a connection before going to sleep, default is 10s. Please have a look here for additional information.
                              12.5k
