  3. Battery sensor and re-connecting to gateway
24 Posts 6 Posters 9.1k Views 4 Watching
  • karl261K
    karl261K
    karl261
    Wow, This is so cool. This probably solves all my problems from the past year.
    It just happened: I had a node connected to the gateway and brought it far away. It lost the connection to the gateway. I switched on a repeater node halfway. The node reconnected to the gateway via the repeater node.
    I can't believe it!
    • karl261K
      karl261K
      karl261
      @tekka The only problem with this extra code is, that in case the node loses its connection, it will drain the battery quite quickly...
      tekkaT 1 Reply Last reply
      • karl261K karl261
        tekkaT
        tekkaT
        tekka
        @karl261 yes, in the example you mentioned, the node won't sleep at all if connection is lost and cannot be re-established. For battery powered nodes I recommend using MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC to prevent the transport state machine from entering the SNP (search new parent) state.
        MySensors 2.0.1 introduces an enhanced sleeping function with a reconnection timeout: https://github.com/mysensors/MySensors/pull/558
        • tekkaT tekka
          great work @tekka
          • karl261K
            karl261K
            karl261
            @tekka Yeah, that's what I actually use. Since I normally don't move my sensors and repeaters, having the parent node static sounds like a good thing to do.
            I look forward to the 2.0.1 release. There seem to be a lot of cool new things inside.
            @tekka, @oitzu, Still, this nrf is driving me nuts. My sensor in the garden has worked just fine for three weeks, and nothing has changed. Now it makes problems. It is still running, because once per day one Temp reading or similar is getting through. Battery is just the same as before.
            Do you have any idea why it could have stopped working? I don't see any reason why the repeater should stop receiving the values. The repeater works fine, it relays all other nodes. And the geometry between repeater and garden sensor has not changed.
            The weather has changed. The T is about 7 degrees less outside...
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              @tekka I'm using the latest snapshot on one of my battery sensors and can see if it can't connect, it doesn't sleep and the debug shows a rapid number of connection attempts. I'd like to know if the sensor will eventually sleep if it cannot successfully connect, and what the default timeout is?
              • Mark SwiftM Mark Swift
                tekkaT
                tekkaT
                tekka
                @Mark-Swift Please post your sketch & full debug log. Thanks
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  @tekka I don't think there's an issue.
                  I'm simply asking what the logic is behind the reconnection logic on sleeping sensors, how long is the timeout for example (I'm conscious of battery drain for nodes having issues connecting).
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    @Mark-Swift No, this sounds like an issue - a rapid number of connection attempts is unusual, that's why I'm interested in your sketch/debug log.
                    To answer your questions: In the latest dev version the node will try to reconnect with a 10sec timeout (if sleeping time > 10sec, this can be changed via MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) before sleeping - if time is left.
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      wrote on last edited by Mark Swift
                      @tekka it's been a while but I never resolved this... If I test by changing the parent node ID to a fake one, it just tried to connect forever, thus draining the battery...
                      Sketch:
                        REVISION HISTORY
                        Created by Mark Swift
                        V1.2 - Added sleep time to force daily update
                        V1.3 - Deactivate pullup on setup and added old_value logic
                        V1.4 - Added daily wakeup to sleep
                        V1.5 - Code cleanup
                      //*** EXTERNAL LIBRARIES **********************************
                      #include <Vcc.h>
                      //*** MYSENSORS *******************************************
                      // Enable debug prints
                      // Lower serial speed if using 1Mhz clock
                      // #define MY_BAUD_RATE 9600
                      #define MY_NODE_ID 4
                      #define MY_PARENT_NODE_ID 1 // AUTO
                      // #define MY_RADIO_RFM69
                      // Override RF24L01 channel number
                      // #define MY_RF24_CHANNEL 125
                      // Override RF24L01 module PA level
                      // #define MY_RF24_PA_LEVEL RF24_PA_LOW
                      // Override RF24L01 datarate
                      // #define MY_RF24_DATARATE RF24_250KBPS
                      // *** SKETCH CONFIG **************************************
                      #define SKETCH_NAME "Door Sensor"
                      #define SKETCH_MAJOR_VER "1"
                      #define SKETCH_MINOR_VER "5"
                      // Define the sensor child IDs
                      #define CHILD_ID1 1 // Switch
                      #define CHILD_ID2 2 // Battery voltage
                      #define CHILD_ID3 3 // Battery percent
                      // Define the message formats
                      MyMessage msg(CHILD_ID1, V_TRIPPED);
                      MyMessage msg2(CHILD_ID2, V_CUSTOM);
                      MyMessage msg3(CHILD_ID3, V_CUSTOM);
                      // *** SENSORS CONFIG *************************************
                      // Digital I/O pin for button or reed switch
                      #define PRIMARY_BUTTON_PIN 3
                      // Debounce using a small sleep
                      #define DEBOUNCE_SLEEP 5
                      // Sleep timer in milliseconds
                      #define SLEEP_IN_MS 86400000
                      // Store the old value for comparison
                      int old_value = -1;
                      // Minimum expected vcc level, in volts (2xAA alkaline)
                      const float vcc_min = 2.0 * 0.9;
                      // Maximum expected vcc level, in volts (2xAA alkaline)
                      const float vcc_max = 2.0 * 1.5;
                      // Measured vcc by multimeter divided by reported vcc
                      const float vcc_correction = 2.88 / 2.82;
                      Vcc vcc(vcc_correction);
                      // *** BEGIN **********************************************
                        // Setup the contact sensor
                        // Activate or deactivate the internal pull-up - high if using internal resistor or low if using external
                        digitalWrite(PRIMARY_BUTTON_PIN, LOW);
                        // Register all sensors to the gateway
                        present(CHILD_ID1, S_DOOR);
                        present(CHILD_ID2, S_CUSTOM);
                        present(CHILD_ID3, S_CUSTOM);
                        // Debouce using sleep
                        sleep(DEBOUNCE_SLEEP);
                        int value = digitalRead(PRIMARY_BUTTON_PIN);
                        // If value has changed send the updated value
                        if (value != old_value) {
                          send(msg.set(value == HIGH ? 0 : 1));
                          old_value = value;
                        // Read battery voltage
                        float battery_voltage = vcc.Read_Volts();
                        // Calculate battery percentage
                        float battery_percent = vcc.Read_Perc(vcc_min, vcc_max);
                      #ifdef MY_DEBUG
                        Serial.print("Battery = ");
                        Serial.print(battery_voltage);
                        Serial.println(" Volts");
                        Serial.print(battery_percent);
                        Serial.println("%");
                        // Send battery readings
                        send(msg2.set(battery_voltage, 2));
                        send(msg3.set(battery_percent, 1));
                        sendBatteryLevel(battery_percent);
                        // Sleep until either interupt change or timer reaches zero
                        smartSleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_IN_MS);
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        Debug:
                        0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                        4 TSM:INIT
                        6 TSF:WUR:MS=0
                        14 TSM:INIT:TSP OK
                        16 TSM:INIT:STATID=4
                        18 TSF:SID:OK,ID=4
                        20 TSM:FPAR
                        22 TSM:FPAR:STATP=1
                        24 TSM:ID
                        24 TSM:ID:OK
                        26 TSM:UPL
                        63 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        2072 TSM:UPL
                        2109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        4118 TSM:UPL
                        4155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        6164 TSM:UPL
                        6201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        8210 !TSM:UPL:FAIL
                        8212 TSM:FPAR
                        8212 TSM:FPAR:STATP=1
                        8214 TSM:ID
                        8216 TSM:ID:OK
                        8218 TSM:UPL
                        8255 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        10264 TSM:UPL
                        10301 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        12310 TSM:UPL
                        12347 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        14356 TSM:UPL
                        14393 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        16402 !TSM:UPL:FAIL
                        16404 TSM:FPAR
                        16404 TSM:FPAR:STATP=1
                        16408 TSM:ID
                        16410 TSM:ID:OK
                        16410 TSM:UPL
                        16449 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        18458 TSM:UPL
                        18495 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        20504 TSM:UPL
                        20541 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        22550 TSM:UPL
                        22587 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        24596 !TSM:UPL:FAIL
                        24598 TSM:FPAR
                        24598 TSM:FPAR:STATP=1
                        24602 TSM:ID
                        24604 TSM:ID:OK
                        24604 TSM:UPL
                        24643 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        26652 TSM:UPL
                        26689 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        28698 TSM:UPL
                        28735 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        30744 TSM:UPL
                        30781 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        32790 !TSM:UPL:FAIL
                        32792 TSM:FPAR
                        32792 TSM:FPAR:STATP=1
                        32796 TSM:ID
                        32798 TSM:ID:OK
                        32798 TSM:UPL
                        32837 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        34846 TSM:UPL
                        34883 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        36892 TSM:UPL
                        36929 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        38938 TSM:UPL
                        38975 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        40984 !TSM:UPL:FAIL
                        40986 TSM:FPAR
                        40986 TSM:FPAR:STATP=1
                        40990 TSM:ID
                        40992 TSM:ID:OK
                        40992 TSM:UPL
                        41031 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        43040 TSM:UPL
                        43077 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        45086 TSM:UPL
                        45123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        47132 TSM:UPL
                        47169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        49178 !TSM:UPL:FAIL
                        49180 TSM:FPAR
                        49180 TSM:FPAR:STATP=1
                        49184 TSM:ID
                        49186 TSM:ID:OK
                        49186 TSM:UPL
                        49225 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        51234 TSM:UPL
                        51271 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        53280 TSM:UPL
                        53317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        55326 TSM:UPL
                        55363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        57372 !TSM:UPL:FAIL
                        57374 TSM:FPAR
                        57374 TSM:FPAR:STATP=1
                        57378 TSM:ID
                        57380 TSM:ID:OK
                        57380 TSM:UPL
                        57419 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        59428 TSM:UPL
                        59465 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        61474 TSM:UPL
                        61511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        63520 TSM:UPL
                        63557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        65566 !TSM:UPL:FAIL
                        65568 TSM:FPAR
                        65568 TSM:FPAR:STATP=1
                        65572 TSM:ID
                        65574 TSM:ID:OK
                        65574 TSM:UPL
                        65613 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        67624 TSM:UPL
                        67661 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        69672 TSM:UPL
                        69709 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        71720 TSM:UPL
                        71757 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        73768 !TSM:UPL:FAIL
                        73771 TSM:FPAR
                        73771 TSM:FPAR:STATP=1
                        73775 TSM:ID
                        73777 TSM:ID:OK
                        73777 TSM:UPL
                        73816 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        75825 TSM:UPL
                        75862 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        77871 TSM:UPL
                        77907 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        79917 TSM:UPL
                        79953 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        81963 !TSM:UPL:FAIL
                        81965 TSM:FPAR
                        81965 TSM:FPAR:STATP=1
                        81969 TSM:ID
                        81971 TSM:ID:OK
                        81971 TSM:UPL
                        82010 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        84019 TSM:UPL
                        84056 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        86065 TSM:UPL
                        86102 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        88111 TSM:UPL
                        88147 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        90157 !TSM:UPL:FAIL
                        90159 TSM:FPAR
                        90159 TSM:FPAR:STATP=1
                        90163 TSM:ID
                        90165 TSM:ID:OK
                        90165 TSM:UPL
                        90204 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        92213 TSM:UPL
                        92250 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        94259 TSM:UPL
                        94296 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        96305 TSM:UPL
                        96342 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        98351 !TSM:UPL:FAIL
                        98353 TSM:FPAR
                        98353 TSM:FPAR:STATP=1
                        98357 TSM:ID
                        98359 TSM:ID:OK
                        98359 TSM:UPL
                        98398 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        100407 TSM:UPL
                        100444 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        102453 TSM:UPL
                        102490 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        104499 TSM:UPL
                        104536 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        106545 !TSM:UPL:FAIL
                        106547 TSM:FPAR
                        106549 TSM:FPAR:STATP=1
                        106551 TSM:ID
                        106553 TSM:ID:OK
                        106555 TSM:UPL
                        106592 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        108601 TSM:UPL
                        108638 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        110647 TSM:UPL
                        110684 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        112693 TSM:UPL
                        112730 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        114739 !TSM:UPL:FAIL
                        114741 TSM:FPAR
                        114743 TSM:FPAR:STATP=1
                        114745 TSM:ID
                        114747 TSM:ID:OK
                        114749 TSM:UPL
                        114786 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        116795 TSM:UPL
                        116832 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        118841 TSM:UPL
                        118878 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        120887 TSM:UPL
                        120924 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        122933 !TSM:UPL:FAIL
                        122935 TSM:FPAR
                        122937 TSM:FPAR:STATP=1
                        122939 TSM:ID
                        122941 TSM:ID:OK
                        122943 TSM:UPL
                        122980 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        124989 TSM:UPL
                        125026 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        127035 TSM:UPL
                        127072 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        129081 TSM:UPL
                        129118 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        131127 !TSM:UPL:FAIL
                        131129 TSM:FPAR
                        131131 TSM:FPAR:STATP=1
                        131133 TSM:ID
                        131135 TSM:ID:OK
                        131137 TSM:UPL
                        131174 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        133183 TSM:UPL
                        133220 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        135229 TSM:UPL
                        135266 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        137275 TSM:UPL
                        137312 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        139321 !TSM:UPL:FAIL
                        139323 TSM:FPAR
                        139325 TSM:FPAR:STATP=1
                        139327 TSM:ID
                        139329 TSM:ID:OK
                        139331 TSM:UPL
                        139368 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        141377 TSM:UPL
                        141414 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        143423 TSM:UPL
                        143460 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        145469 TSM:UPL
                        145506 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        147515 !TSM:UPL:FAIL
                        147517 TSM:FPAR
                        147519 TSM:FPAR:STATP=1
                        147521 TSM:ID
                        147523 TSM:ID:OK
                        147525 TSM:UPL
                        147562 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        149571 TSM:UPL
                        149608 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        151617 TSM:UPL
                        151654 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        153663 TSM:UPL
                        153700 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        155709 !TSM:UPL:FAIL
                        155711 TSM:FPAR
                        155713 TSM:FPAR:STATP=1
                        155715 TSM:ID
                        155717 TSM:ID:OK
                        155719 TSM:UPL
                        155756 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        157765 TSM:UPL
                        157802 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        159811 TSM:UPL
                        159848 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        161857 TSM:UPL
                        161894 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        163903 !TSM:UPL:FAIL
                        163905 TSM:FPAR
                        163907 TSM:FPAR:STATP=1
                        163909 TSM:ID
                        163911 TSM:ID:OK
                        163913 TSM:UPL
                        163950 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        165959 TSM:UPL
                        165996 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        168005 TSM:UPL
                        168042 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        170051 TSM:UPL
                        170088 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        172097 !TSM:UPL:FAIL
                        172099 TSM:FPAR
                        172101 TSM:FPAR:STATP=1
                        172103 TSM:ID
                        172105 TSM:ID:OK
                        172107 TSM:UPL
                        172144 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        174153 TSM:UPL
                        174190 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        176199 TSM:UPL
                        176236 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        178245 TSM:UPL
                        178282 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        180291 !TSM:UPL:FAIL
                        180293 TSM:FPAR
                        180295 TSM:FPAR:STATP=1
                        180297 TSM:ID
                        180299 TSM:ID:OK
                        180301 TSM:UPL
                        180338 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        182347 TSM:UPL
                        182384 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        184393 TSM:UPL
                        184430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        186439 TSM:UPL
                        186476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        188485 !TSM:UPL:FAIL
                        188487 TSM:FPAR
                        188489 TSM:FPAR:STATP=1
                        188491 TSM:ID
                        188493 TSM:ID:OK
                        188495 TSM:UPL
                        188532 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        190541 TSM:UPL
                        190578 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        192587 TSM:UPL
                        192624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        194633 TSM:UPL
                        194670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        196679 !TSM:UPL:FAIL
                        196681 TSM:FPAR
                        196683 TSM:FPAR:STATP=1
                        196685 TSM:ID
                        196687 TSM:ID:OK
                        196689 TSM:UPL
                        196726 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        198735 TSM:UPL
                        198772 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        200781 TSM:UPL
                        200818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        202827 TSM:UPL
                        202864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        204873 !TSM:UPL:FAIL
                        204875 TSM:FPAR
                        204877 TSM:FPAR:STATP=1
                        204879 TSM:ID
                        204881 TSM:ID:OK
                        204883 TSM:UPL
                        204920 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        206931 TSM:UPL
                        206968 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        208979 TSM:UPL
                        209016 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        211027 TSM:UPL
                        211064 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        213075 !TSM:UPL:FAIL
                        213078 TSM:FPAR
                        213080 TSM:FPAR:STATP=1
                        213082 TSM:ID
                        213084 TSM:ID:OK
                        213086 TSM:UPL
                        213123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        215132 TSM:UPL
                        215169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        217178 TSM:UPL
                        217214 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        219224 TSM:UPL
                        219260 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        221270 !TSM:UPL:FAIL
                        221272 TSM:FPAR
                        221274 TSM:FPAR:STATP=1
                        221276 TSM:ID
                        221278 TSM:ID:OK
                        221280 TSM:UPL
                        221317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        223326 TSM:UPL
                        223363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        225372 TSM:UPL
                        225409 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        225689 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                        225695 TSF:MSG:BC
                        226275 TSF:MSG:READ,0-3-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                        226281 TSF:MSG:BC
                        227418 TSM:UPL
                        227454 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        229464 !TSM:UPL:FAIL
                        229466 TSM:FPAR
                        229468 TSM:FPAR:STATP=1
                        229470 TSM:ID
                        229472 TSM:ID:OK
                        229474 TSM:UPL
                        229511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        231520 TSM:UPL
                        231557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        233566 TSM:UPL
                        233603 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        235612 TSM:UPL
                        235649 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        237658 !TSM:UPL:FAIL
                        237660 TSM:FPAR
                        237662 TSM:FPAR:STATP=1
                        237664 TSM:ID
                        237666 TSM:ID:OK
                        237668 TSM:UPL
                        237705 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        239714 TSM:UPL
                        239751 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        241760 TSM:UPL
                        241797 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        243806 TSM:UPL
                        243843 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        245852 !TSM:UPL:FAIL
                        245854 TSM:FPAR
                        245856 TSM:FPAR:STATP=1
                        245858 TSM:ID
                        245860 TSM:ID:OK
                        245862 TSM:UPL
                        245899 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        247908 TSM:UPL
                        247945 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        249954 TSM:UPL
                        249991 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        252000 TSM:UPL
                        252037 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        254046 !TSM:UPL:FAIL
                        254048 TSM:FPAR
                        254050 TSM:FPAR:STATP=1
                        254052 TSM:ID
                        254054 TSM:ID:OK
                        254056 TSM:UPL
                        254093 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        256102 TSM:UPL
                        256139 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        258148 TSM:UPL
                        258185 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        260194 TSM:UPL
                        260231 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        262240 !TSM:UPL:FAIL
                        262242 TSM:FPAR
                        262244 TSM:FPAR:STATP=1
                        262246 TSM:ID
                        262248 TSM:ID:OK
                        262250 TSM:UPL
                        262287 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        264296 TSM:UPL
                        264333 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        266342 TSM:UPL
                        266379 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        268388 TSM:UPL
                        268425 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        270434 !TSM:UPL:FAIL
                        270436 TSM:FPAR
                        270438 TSM:FPAR:STATP=1
                        270440 TSM:ID
                        270442 TSM:ID:OK
                        270444 TSM:UPL
                        270481 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        272490 TSM:UPL
                        272527 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        274536 TSM:UPL
                        274573 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        276582 TSM:UPL
                        276619 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        278628 !TSM:UPL:FAIL
                        278630 TSM:FPAR
                        278632 TSM:FPAR:STATP=1
                        278634 TSM:ID
                        278636 TSM:ID:OK
                        278638 TSM:UPL
                        278675 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        280684 TSM:UPL
                        280721 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        282730 TSM:UPL
                        282767 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        284776 TSM:UPL
                        284813 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        286822 !TSM:UPL:FAIL
                        286824 TSM:FPAR
                        286826 TSM:FPAR:STATP=1
                        286828 TSM:ID
                        286830 TSM:ID:OK
                        286832 TSM:UPL
                        286869 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        288878 TSM:UPL
                        288915 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        290924 TSM:UPL
                        290961 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        292970 TSM:UPL
                        293007 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        295016 !TSM:UPL:FAIL
                        295018 TSM:FPAR
                        295020 TSM:FPAR:STATP=1
                        295022 TSM:ID
                        295024 TSM:ID:OK
                        295026 TSM:UPL
                        295063 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        297072 TSM:UPL
                        297109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        299118 TSM:UPL
                        299155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        301164 TSM:UPL
                        301201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        303210 !TSM:UPL:FAIL
                        303212 TSM:FPAR
                        303214 TSM:FPAR:STATP=1
                        303216 TSM:ID
                        303218 TSM:ID:OK
                        303220 TSM:UPL
                        303257 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        305266 TSM:UPL
                        305303 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        307312 TSM:UPL
                        307349 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        309358 TSM:UPL
                        309395 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        311404 !TSM:UPL:FAIL
                        311406 TSM:FPAR
                        311408 TSM:FPAR:STATP=1
                        311410 TSM:ID
                        311412 TSM:ID:OK
                        311414 TSM:UPL
                        311451 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        313460 TSM:UPL
                        313497 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        315506 TSM:UPL
                        315543 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        317552 TSM:UPL
                        317589 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        319598 !TSM:UPL:FAIL
                        319600 TSM:FPAR
                        319602 TSM:FPAR:STATP=1
                        319604 TSM:ID
                        319606 TSM:ID:OK
                        319608 TSM:UPL
                        319645 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        321654 TSM:UPL
                        321691 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        323700 TSM:UPL
                        323737 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        325746 TSM:UPL
                        325783 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        327792 !TSM:UPL:FAIL
                        327794 TSM:FPAR
                        327796 TSM:FPAR:STATP=1
                        327798 TSM:ID
                        327800 TSM:ID:OK
                        327802 TSM:UPL
                        327839 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        329848 TSM:UPL
                        329885 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        331894 TSM:UPL
                        331931 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        333940 TSM:UPL
                        333977 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        335986 !TSM:UPL:FAIL
                        335988 TSM:FPAR
                        335990 TSM:FPAR:STATP=1
                        335992 TSM:ID
                        335994 TSM:ID:OK
                        335996 TSM:UPL
                        336033 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        338042 TSM:UPL
                        338079 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        340088 TSM:UPL
                        340125 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        342134 TSM:UPL
                        342171 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        344180 !TSM:UPL:FAIL
                        344182 TSM:FPAR
                        344184 TSM:FPAR:STATP=1
                        344186 TSM:ID
                        344188 TSM:ID:OK
                        344190 TSM:UPL
                        344227 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        346238 TSM:UPL
                        346275 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        348286 TSM:UPL
                        348323 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        350334 TSM:UPL
                        350371 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        352382 !TSM:UPL:FAIL
                        352385 TSM:FPAR
                        352387 TSM:FPAR:STATP=1
                        352389 TSM:ID
                        352391 TSM:ID:OK
                        352393 TSM:UPL
                        352430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        354439 TSM:UPL
                        354476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        356485 TSM:UPL
                        356521 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        358531 TSM:UPL
                        358567 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        360577 !TSM:UPL:FAIL
                        360579 TSM:FPAR
                        360581 TSM:FPAR:STATP=1
                        360583 TSM:ID
                        360585 TSM:ID:OK
                        360587 TSM:UPL
                        360624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        362633 TSM:UPL
                        362670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        364679 TSM:UPL
                        364716 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        366725 TSM:UPL
                        366761 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        368771 !TSM:UPL:FAIL
                        368773 TSM:FPAR
                        368775 TSM:FPAR:STATP=1
                        368777 TSM:ID
                        368779 TSM:ID:OK
                        368781 TSM:UPL
                        368818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        370827 TSM:UPL
                        370864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        372873 TSM:UPL
                        372910 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        374919 TSM:UPL
                        374956 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        376965 !TSM:UPL:FAIL
                        376967 TSM:FPAR
                        376969 TSM:FPAR:STATP=1
                        376971 TSM:ID
                        376973 TSM:ID:OK
                        376975 TSM:UPL
                        377012 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                        379021 TSM:UPL
                        379058 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
                        381067 TSM:UPL
                        381104 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
                        383113 TSM:UPL
                        383150 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
                        385159 !TSM:UPL:FAIL
                        385161 TSM:FPAR
                        385163 TSM:FPAR:STATP=1
                        385165 TSM:ID
                        385167 TSM:ID:OK
                        385169 TSM:UPL
                        385206 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
                        387215 TSM:UPL
                        387252 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
                        389261 TSM:UPL
                        389298 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
                        391307 TSM:UPL
                        391344 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
                        393353 !TSM:UPL:FAIL
                        393355 TSM:FPAR
                        393357 TSM:FPAR:STATP=1
                        393359 TSM:ID
                        393361 TSM:ID:OK
                        393363 TSM:UPL
                        393400 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                        395409 TSM:UPL
                        395446 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                        397455 TSM:UPL
                        397492 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                        399501 TSM:UPL
                        399538 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                        401547 !TSM:UPL:FAIL
                        401549 TSM:FPAR
                        401551 TSM:FPAR:STATP=1
                        401553 TSM:ID
                        401555 TSM:ID:OK
                        401557 TSM:UPL
                        401594 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
                        403603 TSM:UPL
                        403640 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
                        405649 TSM:UPL
                        405686 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
                        407695 TSM:UPL
                        407732 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
                        409741 !TSM:UPL:FAIL
                        409743 TSM:FPAR
                        409745 TSM:FPAR:STATP=1
                        409747 TSM:ID
                        409749 TSM:ID:OK
                        409751 TSM:UPL
                        409788 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
                          Debug:
                          4 TSM:INIT
                          6 TSF:WUR:MS=0
                          14 TSM:INIT:TSP OK
                          18 TSF:SID:OK,ID=4
                          20 TSM:FPAR
                          22 TSM:FPAR:STATP=1
                          24 TSM:ID
                          24 TSM:ID:OK
                          26 TSM:UPL
                          2072 TSM:UPL
                          4118 TSM:UPL
                          6164 TSM:UPL
                          8210 !TSM:UPL:FAIL
                          8212 TSM:FPAR
                          8214 TSM:ID
                          8216 TSM:ID:OK
                          8218 TSM:UPL
                          10264 TSM:UPL
                          12310 TSM:UPL
                          14356 TSM:UPL
                          16402 !TSM:UPL:FAIL
                          16404 TSM:FPAR
                          16408 TSM:ID
                          16410 TSM:ID:OK
                          16410 TSM:UPL
                          18458 TSM:UPL
                          20504 TSM:UPL
                          22550 TSM:UPL
                          24596 !TSM:UPL:FAIL
                          24598 TSM:FPAR
                          24602 TSM:ID
                          24604 TSM:ID:OK
                          24604 TSM:UPL
                          26652 TSM:UPL
                          28698 TSM:UPL
                          30744 TSM:UPL
                          32790 !TSM:UPL:FAIL
                          32792 TSM:FPAR
                          32796 TSM:ID
                          32798 TSM:ID:OK
                          32798 TSM:UPL
                          34846 TSM:UPL
                          36892 TSM:UPL
                          38938 TSM:UPL
                          40984 !TSM:UPL:FAIL
                          40986 TSM:FPAR
                          40990 TSM:ID
                          40992 TSM:ID:OK
                          40992 TSM:UPL
                          43040 TSM:UPL
                          45086 TSM:UPL
                          47132 TSM:UPL
                          49178 !TSM:UPL:FAIL
                          49180 TSM:FPAR
                          49184 TSM:ID
                          49186 TSM:ID:OK
                          49186 TSM:UPL
                          51234 TSM:UPL
                          53280 TSM:UPL
                          55326 TSM:UPL
                          57372 !TSM:UPL:FAIL
                          57374 TSM:FPAR
                          57378 TSM:ID
                          57380 TSM:ID:OK
                          57380 TSM:UPL
                          59428 TSM:UPL
                          61474 TSM:UPL
                          63520 TSM:UPL
                          65566 !TSM:UPL:FAIL
                          65568 TSM:FPAR
                          65572 TSM:ID
                          65574 TSM:ID:OK
                          65574 TSM:UPL
                          67624 TSM:UPL
                          69672 TSM:UPL
                          71720 TSM:UPL
                          73768 !TSM:UPL:FAIL
                          73771 TSM:FPAR
                          73775 TSM:ID
                          73777 TSM:ID:OK
                          73777 TSM:UPL
                          75825 TSM:UPL
                          77871 TSM:UPL
                          79917 TSM:UPL
                          81963 !TSM:UPL:FAIL
                          81965 TSM:FPAR
                          81969 TSM:ID
                          81971 TSM:ID:OK
                          81971 TSM:UPL
                          84019 TSM:UPL
                          86065 TSM:UPL
                          88111 TSM:UPL
                          90157 !TSM:UPL:FAIL
                          90159 TSM:FPAR
                          90163 TSM:ID
                          90165 TSM:ID:OK
                          90165 TSM:UPL
                          92213 TSM:UPL
                          94259 TSM:UPL
                          96305 TSM:UPL
                          98351 !TSM:UPL:FAIL
                          98353 TSM:FPAR
                          98357 TSM:ID
                          98359 TSM:ID:OK
                          98359 TSM:UPL
                          100407 TSM:UPL
                          102453 TSM:UPL
                          104499 TSM:UPL
                          106547 TSM:FPAR
                          106551 TSM:ID
                          106553 TSM:ID:OK
                          106555 TSM:UPL
                          108601 TSM:UPL
                          110647 TSM:UPL
                          112693 TSM:UPL
                          114741 TSM:FPAR
                          114745 TSM:ID
                          114747 TSM:ID:OK
                          114749 TSM:UPL
                          116795 TSM:UPL
                          118841 TSM:UPL
                          120887 TSM:UPL
                          122935 TSM:FPAR
                          122939 TSM:ID
                          122941 TSM:ID:OK
                          122943 TSM:UPL
                          124989 TSM:UPL
                          127035 TSM:UPL
                          129081 TSM:UPL
                          131129 TSM:FPAR
                          131133 TSM:ID
                          131135 TSM:ID:OK
                          131137 TSM:UPL
                          133183 TSM:UPL
                          135229 TSM:UPL
                          137275 TSM:UPL
                          139323 TSM:FPAR
                          139327 TSM:ID
                          139329 TSM:ID:OK
                          139331 TSM:UPL
                          141377 TSM:UPL
                          143423 TSM:UPL
                          145469 TSM:UPL
                          147517 TSM:FPAR
                          147521 TSM:ID
                          147523 TSM:ID:OK
                          147525 TSM:UPL
                          149571 TSM:UPL
                          151617 TSM:UPL
                          153663 TSM:UPL
                          155711 TSM:FPAR
                          155715 TSM:ID
                          155717 TSM:ID:OK
                          155719 TSM:UPL
                          157765 TSM:UPL
                          159811 TSM:UPL
                          161857 TSM:UPL
                          163905 TSM:FPAR
                          163909 TSM:ID
                          163911 TSM:ID:OK
                          163913 TSM:UPL
                          165959 TSM:UPL
                          168005 TSM:UPL
                          170051 TSM:UPL
                          172099 TSM:FPAR
                          172103 TSM:ID
                          172105 TSM:ID:OK
                          172107 TSM:UPL
                          174153 TSM:UPL
                          176199 TSM:UPL
                          178245 TSM:UPL
                          180293 TSM:FPAR
                          180297 TSM:ID
                          180299 TSM:ID:OK
                          180301 TSM:UPL
                          182347 TSM:UPL
                          184393 TSM:UPL
                          186439 TSM:UPL
                          188487 TSM:FPAR
                          188491 TSM:ID
                          188493 TSM:ID:OK
                          188495 TSM:UPL
                          190541 TSM:UPL
                          192587 TSM:UPL
                          194633 TSM:UPL
                          196681 TSM:FPAR
                          196685 TSM:ID
                          196687 TSM:ID:OK
                          196689 TSM:UPL
                          198735 TSM:UPL
                          200781 TSM:UPL
                          202827 TSM:UPL
                          204875 TSM:FPAR
                          204879 TSM:ID
                          204881 TSM:ID:OK
                          204883 TSM:UPL
                          206931 TSM:UPL
                          208979 TSM:UPL
                          211027 TSM:UPL
                          213078 TSM:FPAR
                          213082 TSM:ID
                          213084 TSM:ID:OK
                          213086 TSM:UPL
                          215132 TSM:UPL
                          217178 TSM:UPL
                          219224 TSM:UPL
                          221272 TSM:FPAR
                          221276 TSM:ID
                          221278 TSM:ID:OK
                          221280 TSM:UPL
                          223326 TSM:UPL
                          225372 TSM:UPL
                          225695 TSF:MSG:BC
                          226281 TSF:MSG:BC
                          227418 TSM:UPL
                          229466 TSM:FPAR
                          229470 TSM:ID
                          229472 TSM:ID:OK
                          229474 TSM:UPL
                          231520 TSM:UPL
                          233566 TSM:UPL
                          235612 TSM:UPL
                          237660 TSM:FPAR
                          237664 TSM:ID
                          237666 TSM:ID:OK
                          237668 TSM:UPL
                          239714 TSM:UPL
                          241760 TSM:UPL
                          243806 TSM:UPL
                          245854 TSM:FPAR
                          245858 TSM:ID
                          245860 TSM:ID:OK
                          245862 TSM:UPL
                          247908 TSM:UPL
                          249954 TSM:UPL
                          252000 TSM:UPL
                          254048 TSM:FPAR
                          254052 TSM:ID
                          254054 TSM:ID:OK
                          254056 TSM:UPL
                          256102 TSM:UPL
                          258148 TSM:UPL
                          260194 TSM:UPL
                          262242 TSM:FPAR
                          262246 TSM:ID
                          262248 TSM:ID:OK
                          262250 TSM:UPL
                          264296 TSM:UPL
                          266342 TSM:UPL
                          268388 TSM:UPL
                          270436 TSM:FPAR
                          270440 TSM:ID
                          270442 TSM:ID:OK
                          270444 TSM:UPL
                          272490 TSM:UPL
                          274536 TSM:UPL
                          276582 TSM:UPL
                          278630 TSM:FPAR
                          278634 TSM:ID
                          278636 TSM:ID:OK
                          278638 TSM:UPL
                          280684 TSM:UPL
                          282730 TSM:UPL
                          284776 TSM:UPL
                          286824 TSM:FPAR
                          286828 TSM:ID
                          286830 TSM:ID:OK
                          286832 TSM:UPL
                          288878 TSM:UPL
                          290924 TSM:UPL
                          292970 TSM:UPL
                          295018 TSM:FPAR
                          295022 TSM:ID
                          295024 TSM:ID:OK
                          295026 TSM:UPL
                          297072 TSM:UPL
                          299118 TSM:UPL
                          301164 TSM:UPL
                          303212 TSM:FPAR
                          303216 TSM:ID
                          303218 TSM:ID:OK
                          303220 TSM:UPL
                          305266 TSM:UPL
                          307312 TSM:UPL
                          309358 TSM:UPL
                          311406 TSM:FPAR
                          311410 TSM:ID
                          311412 TSM:ID:OK
                          311414 TSM:UPL
                          313460 TSM:UPL
                          315506 TSM:UPL
                          317552 TSM:UPL
                          319600 TSM:FPAR
                          319604 TSM:ID
                          319606 TSM:ID:OK
                          319608 TSM:UPL
                          321654 TSM:UPL
                          323700 TSM:UPL
                          325746 TSM:UPL
                          327794 TSM:FPAR
                          327798 TSM:ID
                          327800 TSM:ID:OK
                          327802 TSM:UPL
                          329848 TSM:UPL
                          331894 TSM:UPL
                          333940 TSM:UPL
                          335988 TSM:FPAR
                          335992 TSM:ID
                          335994 TSM:ID:OK
                          335996 TSM:UPL
                          338042 TSM:UPL
                          340088 TSM:UPL
                          342134 TSM:UPL
                          344182 TSM:FPAR
                          344186 TSM:ID
                          344188 TSM:ID:OK
                          344190 TSM:UPL
                          346238 TSM:UPL
                          348286 TSM:UPL
                          350334 TSM:UPL
                          352385 TSM:FPAR
                          352389 TSM:ID
                          352391 TSM:ID:OK
                          352393 TSM:UPL
                          354439 TSM:UPL
                          356485 TSM:UPL
                          358531 TSM:UPL
                          360579 TSM:FPAR
                          360583 TSM:ID
                          360585 TSM:ID:OK
                          360587 TSM:UPL
                          362633 TSM:UPL
                          364679 TSM:UPL
                          366725 TSM:UPL
                          368773 TSM:FPAR
                          368777 TSM:ID
                          368779 TSM:ID:OK
                          368781 TSM:UPL
                          370827 TSM:UPL
                          372873 TSM:UPL
                          374919 TSM:UPL
                          376967 TSM:FPAR
                          376971 TSM:ID
                          376973 TSM:ID:OK
                          376975 TSM:UPL
                          379021 TSM:UPL
                          381067 TSM:UPL
                          383113 TSM:UPL
                          385161 TSM:FPAR
                          385165 TSM:ID
                          385167 TSM:ID:OK
                          385169 TSM:UPL
                          387215 TSM:UPL
                          389261 TSM:UPL
                          391307 TSM:UPL
                          393355 TSM:FPAR
                          393359 TSM:ID
                          393361 TSM:ID:OK
                          393363 TSM:UPL
                          395409 TSM:UPL
                          397455 TSM:UPL
                          399501 TSM:UPL
                          401549 TSM:FPAR
                          401553 TSM:ID
                          401555 TSM:ID:OK
                          401557 TSM:UPL
                          403603 TSM:UPL
                          405649 TSM:UPL
                          407695 TSM:UPL
                          409743 TSM:FPAR
                          409747 TSM:ID
                          409749 TSM:ID:OK
                          409751 TSM:UPL
                          tekkaT
                          tekkaT
                          tekka
                          @Mark-Swift I guess because of MY_PARENT_NODE_IS_STATIC which prevents the use of an alternative parent.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @tekka I guessed that, I thought however that you'd mentioned it would timeout, and try again later? As it stands it appears it'll keep trying until the battery is dead?
                            If nothing else I just want to clear up the behaviour so I fully understand it.
                            Mark
                              Mark
                              tekkaT
                              tekkaT
                              tekka
                              #22
                              @Mark-Swift it does timeout, but for that you have to set MY_TRANSPORT_WAIT_READY_MS > 0. This ensures, that loop() will be entered after the timeout if the connection could not be established.
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @tekka thank you, so if I
                                #define MY_TRANSPORT_WAIT_READY_MS 60000
                                Am I right in thinking that my node will enter the loop after it tries to connect to a parent for 60 seconds and fails? (In my case it'd then sleep until the next interrupt, when I guess it would then try again for 60 seconds...).
                                I really appreciate your help getting my head around this :)
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Mark-Swift Almost :)
                                  applies only when the node starts, i.e. before entering loop(). Once you are in loop() and you put the node to sleep
                                  #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 10000
                                  defines how long the node will try to establish a connection before going to sleep, default is 10s. Please have a look here for additional information.
                                  12.5k
