  3. Home Assistant
  4. Struggling with configure.yaml
21 Posts 2 Posters 11.5k Views 2 Watching
  • el tigroE Offline
    el tigroE Offline
    el tigro
    Hi all. Bordering on suicidal, please help.
    Pi 3 with all in one (raspian lite - mosquitto - home assistant) installed
    NodeMCU 1.09 wireless GW with nrf2401+ radio.
    arduino nano clone mysensors relay. v2 node
    Node talks to GW ok
    GW talks to node ok
    GW talks to mosquitto ok
    mosquitto talk to GW ok
    Home assistant boots up with :8123 ok
    getting HA to find sensors, configure configure.yaml...... NOT OK
    because of this, no GW to HA communication.
    How I managed the above, I really have no idea. I am one of the mugs that believed the arduino hype. "No coding experience required, cut and paste, simple"..... What a load of tripe. lol. I now know a little bit about alot of areas but now and again I just hit a wall. I cannot get my head around how to configure the configure.jaml file. Every time I try it crashes the browser socket.
    A simple working example and I will be away and learn from there. I feel like a dumb blonde on this but I swear, if you guys don't help me out, I am putting the wife in the garden shed for the rest of the winter.
    Thanks in advance.
    el tigroE 1 Reply Last reply
    • el tigroE el tigro
      Node talks to GW ok
      GW talks to node ok
      Thanks in advance.
      el tigroE Offline
      el tigroE Offline
      el tigro
      @el-tigro
      Ok. How would I configure the example from HA to my setup?? many thanks.
      mysensors:
      gateways:
      - device: '/dev/ttyUSB0'
      persistence_file: 'path/mysensors.json'
      baud_rate: 38400
      - device: '/dev/ttyACM0'
      persistence_file: 'path/mysensors2.json'
      baud_rate: 115200
      - device: '192.168.1.18'
      persistence_file: 'path/mysensors3.json'
      tcp_port: 5003
      - device: mqtt
      persistence_file: 'path/mysensors4.json'
      topic_in_prefix: 'mygateway1-out'
      topic_out_prefix: 'mygateway1-in'
      debug: true
      optimistic: false
      persistence: true
      retain: true
      version: 2.0
        @el-tigro
        mysensors:
        gateways:
        baud_rate: 38400
        baud_rate: 115200
        tcp_port: 5003
        - device: mqtt
        debug: true
        optimistic: false
        persistence: true
        retain: true
        version: 2.0
        el tigroE Offline
        el tigroE Offline
        el tigro
        @el-tigro
        I assume the above example is instructions for 4 devices, 1 being mqtt broker.
        what is - device: '/dev/ttyUSB0' and how does it identify the device? It looks like a path to a destination file, where? what is it?
        how many of the 4 sets of instructions are relavent to my setup and which if any can i drop? Mqtt to stay
        how do I identify, what do i need to identify / present for my wireless gateway and node?
        thanks again.
          @el-tigro
          thanks again.
          martinhjelmareM Offline
          martinhjelmare
          @el-tigro
          Hi!
          Since you only have one mqtt arduino gateway you only need one device entry in your mysensors home assistant config. Keep the one called mqtt. This will set up home assistant to try to use a mqtt client to interface with the mysensors component which handles the mysensors - home assistant logic.
          Make sure you read how to configure the topic prefixes in the gateway and note those and then use those when you configure the mqtt device in the mysensors home assistant config. Otherwise the gateway cannot talk to home assistant. There's a good tutorial on the mqtt client gateway in the forum here.
          https://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway
          You also need to set up the mqtt component in home assistant. Here you will configure the mqtt client to connect to the correct mqtt broker address. You can read more about the mqtt component in the home assistant docs.
          https://home-assistant.io/components/mqtt/
          This is basically what you need for mysensors config.
          mysensors:
            gateways:
              - device: mqtt
            debug: true
            optimistic: false
            persistence: true
            retain: true
            version: 2.0
          Of course you have to replace path for the persistence file with a real path to a folder that exists and that home assistant can write to. The config directory is usually good. You don't need to create the actual persistence file. It will be created when the first sensors are added.
          PS
          The other devices in the example config you posted are examples of other types of gateways that can be used together with home assistant. There's the serial gateway and the ethernet gateway. The ethernet gateway takes an ip address and a port number and the serial gateway takes a path to the serial port that the gateway is connected to, this is usually under /dev/ on a Linux host. You can also set the baud rate on the home assistant side for the communication over the serial connection.
          • el tigroE Offline
            el tigroE Offline
            el tigro
            Firstly, thanks for replying, you are at present, my only contact with hope. Hey..come back don't run away. lol.
            Once I get one working node, I can start to disect how it's done and apply (hopefully) to the next node, that's my funked up way of doing things. I am getting confused now, my gateway is an ESP8266 (NodeMCU) and my nodes are arduino.
            My brain fart is understanding the device identification system, terms and syntax so to speak.
            • device: '/dev/ttyUSB0'
            it means nothing to me other than a pointer, to something. That something, makes somebody's config work based on their setup. In the terms/syntax used above, I have no idea what I have, where to point to and what i need to tell it to do or tell it to do.
            No info, i can find, point's towards (or am I blinded) my wireless gateway and connecting to HA.
            I feel like I am trying to make a cake, I know I have all the ingredients right, everything is weighed out correct, I followed all the recipe-ish, but still it remains gooey. I do it over and over and still the same result, gunky mess, no cake. Then I realise I farted at the little 1 liner about turning the oven on and missed it.
            any help or pointers appreciated.
            • el tigroE Offline
              el tigroE Offline
              el tigro
              wow, your message grew as I was writing, I will try what you suggested now, thanks
              • martinhjelmareM Offline
                martinhjelmare
                Sorry I shouldn't have said arduino gateway. It's a nodeMCU as you said or ESP.
                You only need to make sure that the gateway can talk to home assistant, since you say that everything else works. And you want to use mqtt for this connection, right? So don't bother with the serial gateway path, /dev/... . That's only for a serial gateway. You want to use a mqtt client gateway. Follow what I wrote above and read the corresponding doc and forum pages I linked.
                • el tigroE Offline
                  el tigroE Offline
                  el tigro
                  wrote on last edited by el tigro
                  Some progress, probably me not understanding.
                  firstly, my humble apologes if I come across as thick. 2 weeks ago I was playing with arduino IDE and NRF24 libraries. To me Linux was a nerd code, way above me and cmd prompt was chinese.
                  is my persistence part right? It is the same path I take to configure.yaml
                  mysensors:
                    gateways:
                      - device: mqtt
                        persistence_file: 'home/homeassistance/.homeassistance/mysensors4.json'
                    debug: true
                    optimistic: false
                    persistence: true
                    retain: true
                    version: 2.0
                  I left the pub/sub part as is, content can come later.... I assume.
                  Good and bad results.
                  Home assistant socket :8123 stays up (crashed every time for me) but shows errors.
                  Invalid config
                  The following components and platforms could not be set up:
                      mysensors
                      mqtt
                  Please check your config
                  Is my syntax correct?
                  I have been looking at the work you put in and your result, some folk deserve a drink. Do you have paypal details?
                    martinhjelmare
                    To really be able to check the formatting of the config, you should post your config within codeblock markdown here in the forum. That's three back-tics, newline, code, newline, three back-tics. Then you'll get a black box with the code/config like I posted above, and formatting will be retained. Indentation is very important for yaml syntax.
                    Other than that it seems you have a non standard spelling of "homeassistant" in the path for the persistence file. My guess is that is a typo, at least for the hidden directory that start with a period.
                    But the most important part is that you don't say that you've configured the mqtt component. Did you do that? You should have a separate entry in the config with
                    mqtt:
                    and under that the broker ip etc.
                    Thanks for the virtual beer! :smile: This is my hobby and it's super fun. You learn a lot. The great feedback you get from the community is reward enough for me.
                    PS there are many that helped build the mysensors component in home assistant, and it's based on two super communities.
                    • el tigroE Offline
                      el tigroE Offline
                      el tigro
                      • el tigroE Offline
                        el tigroE Offline
                        el tigro
                          el tigroE Offline
                          el tigroE Offline
                          el tigro
                          @el-tigro said:
                           mysensors:
                             gateways:
                               - device: mqtt
                                 persistence_file: 'home/homeassistant/.homeassistant/mysensors4.json'
                             debug: true
                             optimistic: false
                             persistence: true
                             retain: true
                             version: 2.0
                          Good morning from blighty. I retained your format and indentations, I think. Sorry for typo's, it was 1am and a few southern comforts. The hidden .homeassistant folder, was part of install and is where my config file lives, is that not good.
                          You are exposing my dumb ass here lol, i thought we just configured the '-device :mqtt'.
                          This is from HA website for mysensors but all I can see to configure is the boker IP. I tried it along with the previous code.... same error.
                          Where I come from, it's rude not to accept a drink between men and I don't mean a virtual drink. Your service and assistance is invaluable to me and the least I could do is slide you a bottle of Southern Comfort. So stop being humble, stop being rude and email me an paypal addy.
                           mqtt:
                             broker: IP_ADDRESS_BROKER
                             port: 1883
                             client_id: home-assistant-1
                             keepalive: 60
                             username: USERNAME
                             password: PASSWORD
                             certificate: /home/paulus/dev/addtrustexternalcaroot.crt
                             protocol: 3.1
                             birth_message:
                               topic: 'hass/status'
                               payload: 'online'
                               qos: 1
                               retain: true
                             will_message:
                               payload: 'offline'
                               qos: 1
                               retain: true
                          looked for a path to certificate...... no idea there. Tried leaving in and without
                          my mosquitto mqtt has no username or pw at the moment. Tried leaving in and without.
                          Once again I am at your mercy lol
                            martinhjelmare
                            You are missing a leading slash for the path to the persistence file, ie before home.
                            Try a minimal config for the mqtt component:
                            mqtt:
                            Of course, replace IP_ADDRESS_BROKER with your real mqtt broker ip address.
                            Sorry I don't wish to be rude, but I don't want to accept any money. If you want to donate, mysensors.org has a donate with paypal button. This will help keep the site hosting alive etc and support the community.
                              mqtt:
                              el tigroE Offline
                              el tigroE Offline
                              el tigro
                              mysensors:
                                gateways:
                                  - device: mqtt
                                    persistence_file: '/home/homeassistant/.homeassistant/mysensors4.json'
                                debug: true
                                optimistic: false
                                persistence: true
                                retain: true
                                version: 2.0
                              mqtt:
                                broker: 192.168.1.115
                              is giving the same
                              Invalid config
                                  mysensors
                                  mqtt
                              To clarify in my head, everything that is connected to HA needs a block in config with minimum set of data but can be finely tuned with further commands if need be.
                              If this is the case, how is the gateway identified in the first block of code.
                              To make sure I am not mis-reading debug, this is my arduino nano node
                              Starting repeater (RNNRA-, 2.0.0)
                              TSM:INIT
                              TSM:RADIO:OK
                              TSP:ASSIGNID:OK (ID=1)
                              TSM:FPAR
                              TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                              TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              TSP:MSG:PAR OK (ID=0, dist=1)
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:CHKID:OK (ID=1)
                              TSM:UPL
                              TSP:PING:SEND (dest=0)
                              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                              TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              TSP:MSG:PONG RECV (hops=1)
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                              TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                              TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Relay+button
                              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                              TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                              Request registration...
                              TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                              TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                              Node registration=1
                              Init complete, id=1, parent=0, distance=1, registration=1
                              Sending initial value
                              TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                              Requesting initial value from controller
                              This is My gateway
                              0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.1.0
                              0;255;3;0;9;TSF:LRT:OK
                              0;255;3;0;9;TSM:INIT
                              0;255;3;0;9;TSF:WUR:MS=0
                              scandone
                              no BTHub5-C2FC found, reconnect after 1s
                              0;255;3;0;9;TSM:INIT:TSP OK
                              0;255;3;0;9;TSM:INIT:GW MODE
                              reconnect
                              f 0, 0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0
                              scandone
                              f -180, ....scandone
                              reconnect
                              f r0, ....scandone
                              reconnect
                              f 0, .....scandone
                              state: 0 -> 2 (b0)
                              state: 2 -> 3 (0)
                              state: 3 -> 5 (10)
                              add 0
                              aid 1
                              cnt
                              .0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSF:MSG:BC
                              0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
                              0;255;3;0;9;TSF:PNG:SEND,TO=0
                              0;255;3;0;9;TSF:CKU:OK
                              0;255;3;0;9;TSF:MSG:GWL OK
                              connected with BTHub5-C2FC, channel 6
                              dhcp client start...
                              0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                              ..ip:192.168.1.117,mask:255.255.255.0,gw:192.168.1.254
                              .IP: 192.168.1.117
                              0;255;3;0;9;MCO:BGN:STP
                              IP: 192.168.1.117
                              0;255;3;0;9;MQTT connected
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
                              0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
                              0;255;3;0;9;Sending message on topic: mygateway1-out/1/255/0/0/18
                              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              0;255;3;0;9;Sending message on topic: mygateway1-out/1/255/3/0/6
                              And here is broker
                              login as: pi
                              pi@192.168.1.115's password:
                              The programs included with the Debian GNU/Linux system are free software;
                              the exact distribution terms for each program are described in the
                              individual files in /usr/share/doc/*/copyright.
                              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                              permitted by applicable law.
                              Last login: Thu Jan 19 22:04:56 2017
                              pi@raspberrypi:~ $ mosquitto -v
                              1484863517: mosquitto version 1.3.4 (build date 2014-08-22 06:10:51+0000) starting
                              1484863517: Using default config.
                              1484863517: Opening ipv4 listen socket on port 1883.
                              1484863517: Opening ipv6 listen socket on port 1883.
                              1484863518: New connection from 192.168.1.117 on port 1883.
                              1484863518: New client connected from 192.168.1.117 as mysensors-1 (c1, k15).
                              1484863518: Sending CONNACK to mysensors-1 (0)
                              1484863518: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/0/255/0/0/18', ... (5 bytes))
                              1484863518: Received SUBSCRIBE from mysensors-1
                              1484863518:     mygateway1-in/+/+/+/+/+ (QoS 0)
                              1484863518: mysensors-1 0 mygateway1-in/+/+/+/+/+
                              1484863518: Sending SUBACK to mysensors-1
                              1484863518: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863519: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863520: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863520: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863522: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863522: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863524: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863524: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863526: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863526: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863528: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863528: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863530: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863530: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863532: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
                              1484863532: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
                              1484863534: Received PINGREQ from mysensors-1
                              1484863534: Sending PINGRESP to mysensors-1
                              It won't matter that my broker and HA are on the smae pi will it.
                              Your a rare breed fella, don't let the wifey know ya refusing $$ lol. Will make a donation.... if ya sort me out.
                              • el tigroE Offline
                                el tigroE Offline
                                el tigro
                                Should my gate gateway sketch have presentation details in it, coz it doesn't. I removed comments to reduce size.
                                 * The ESP8266 MQTT
                                #include <EEPROM.h>
                                #define MY_BAUD_RATE 9600
                                #define MY_GATEWAY_ESP8266
                                #define MY_ESP8266_SSID "BTHub5-C2FC"
                                #define MY_ESP8266_PASSWORD "xxxxxxxxx"
                                 #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway" ///
                                #define MY_CONTROLLER_IP_ADDRESS 192,168,1,115
                                #define MY_PORT 1883
                                // Flash leds on rx/tx/err
                                // Set blinking period
                                // Enable inclusion mode
                                #include <ESP8266WiFi.h>
                                  martinhjelmare
                                  Since your mqtt broker and home assistant is on the same host, you should use localhost or "127.0.0.1" as broker address when setting up the mqtt component in home assistant. Home assistant and mosquitto (MQTT) use different ports so there shouldn't be a conflict.
                                  mqtt:
                                    broker: localhost
                                  The gateway is identified by home assistant via the prefix topics, in the case of the mqtt gateway.
                                  Arduino + ESP sketches and logs look ok.
                                  • el tigroE Offline
                                    el tigroE Offline
                                    el tigro
                                    Same same, no different i'm affraid. It's pissing me off now, more because I don't understand enough to do more for myself. I think this is going to be shelved for a while.
                                    I am talking about the wifi gateway,
                                    I am gonna stick with HA and mysensors but rehash my hardware. I have PI's , Nano's, Yun, Mini's and ESP8266's. What combination / configuration would you recommend for ease of setup.
                                    Gonna try running mosquiito on a seperate Pi to HA first off.
                                      martinhjelmare
                                      Do you get any other errors in the log? It would be interesting to see a log after start of home assistant.
                                      An RPi for controller, a Nano as serial gateway and Pro Minis as sensors, I'd say should be the most easy and "mainstream".
                                      But easy is a relative term. Remember that we're building our own wireless IoT devices and home automation setup. Most people might not call that easy at all. Although I think mysensors lowers the difficulty bar considerably in this context.
                                        el tigroE Offline
                                        el tigroE Offline
                                        el tigro
                                        Hi again.
                                        here is my home-assistant.log
                                        fingers double crossed
                                        pi@raspberrypi:/home/homeassistant/.homeassistant $ less home-assistant.log
                                        17-01-23 19:36:57 homeassistant.components.mqtt: Can't connect to the broker. Please check your settings and the broker itself
                                          File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 262, in setup
                                            birth_message)
                                          File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 351, in __init__
                                            self._mqttc.connect(broker, port, keepalive)
                                          File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 686, in connect
                                            return self.reconnect()
                                          File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 808, in reconnect
                                            sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
                                          File "/usr/lib/python3.4/socket.py", line 509, in create_connection
                                            raise err
                                          File "/usr/lib/python3.4/socket.py", line 500, in create_connection
                                            sock.connect(sa)
                                        ConnectionRefusedError: [Errno 111] Connection refused
                                        17-01-23 19:36:57 homeassistant.bootstrap: component mqtt failed to initialize
                                        17-01-23 19:36:57 homeassistant.bootstrap: Component mqtt failed to setup
                                        17-01-23 19:36:57 homeassistant.components.mysensors: No devices could be setup as gateways, check your configuration
                                        17-01-23 19:36:57 homeassistant.bootstrap: component mysensors failed to initialize
                                            birth_message)
                                            raise err
                                            sock.connect(sa)
                                        • el tigroE Offline
                                          el tigroE Offline
                                          el tigro
                                          OK. we are in, no errors in HA but have this in HA log.
                                          17-01-23 22:19:55 mysensors.mysensors: File does not exist or is not readable: /home/homeassistant/mysensors4.json
                                          17-01-23 22:19:55 mysensors.mysensors: Trying backup file: /home/homeassistant/mysensors4.json.bak
                                          17-01-23 22:19:55 mysensors.mysensors: File does not exist or is not readable: /home/homeassistant/mysensors4.json.bak
                                          17-01-23 22:19:55 mysensors.mysensors: Failed to load sensors from file: /home/homeassistant/mysensors4.json
                                          I have tried a few file path but always the same.
                                          12.1k
