Sending sensor data from raspberry via NRF24L01+ to arduino
I have been working on the installation of the libraries.
I have Added them to the Arduino ide software but when I run the gateway serial code it shows that
fatal error: MySensors.h: No such file or directory
compilation terminated.What is causing this?
PS I am using a Macbook -
Just resolved the issue !
Apparently my Arduino Ide wasnt updated to the lastest version which explains why I never found the Library Manager :P
Great that you found the problem @LaMB95, thanks for reporting back. It might help someone else in the future if they have the same problem :)
@mfalkvidd
Thanks !
However I am still facing some issues trying to set up a gateway with the raspberry pi,Do you know who could help me with that ?
@mfalkvidd
Thanks !
I'm having problems exactly the same as @LaMB95
The MySensors library is installed, at least is says so doing as shown in the link @mfalkvidd sent.
This is my error:
DallasTemperatureSensor.ino:36:25: fatal error: MySensors.h: No such file or directory
Compilation terminated.
"Thanks
This is my error:
"Thanks
This is my error:
"Thanks
I am facing an issue while sending data from an Arduino pro mini 5V to an arduino UNO. Receiving a lot of garbage from the Pro mini.
Any idea why ? -
@LaMB95
do you have a log to take a look? Just to understand what is the garbage you are talking about.
What NRF24 library are you using? I'm using the one from Maniacbug@gohan
Code in Pro Mini:#include <HardwareSerial.h> #include <SPI.h> #include <nRF24L01.h> #include <RF24.h> RF24 radio(9, 10); const byte rxAddr[6] = "00001"; void setup() { while (!Serial); Serial.begin(9600); radio.begin(); radio.openReadingPipe(1, rxAddr); radio.startListening(); } void loop() { if (radio.available()) { char text[32] = {0}; radio.read(&text, sizeof(text)); Serial.println(text); } }Code in Uno:
#include <SPI.h> #include <nRF24L01.h> #include <RF24.h> RF24 radio(9, 10); const byte rxAddr[6] = "00001"; void setup(void) { radio.begin(); //Serial.println(F("*** PRESS 'T' to begin transmitting to the other node")); radio.setRetries(15, 15); radio.openWritingPipe(rxAddr); radio.stopListening(); } void loop(void) { const char text[] = "Hello World"; radio.write(&text, sizeof(text)); delay(1500); }I have set the processor to 3.3V 8MHz.
I have connected the Pro mini to the computer via a CP2102 breakout board. -
I haven't tried the Mini yet, I am waiting for it to be delivered so I can't help you much, but my best shot could be something with serial speed somewhere or something related.
Have you tried to use a 16x2 LCD to show data instead of the serial console? I do it sometimes when I don't want to take bring computer with me if I only need to show a few values. -
