  3. Sending sensor data from raspberry via NRF24L01+ to arduino
33 Posts 4 Posters 10.8k Views 3 Watching
  • H
    H
    hugo_pn
    wrote on last edited by hugo_pn
    Hi all,
    @LaMB95
    I'll have to get back to you later on that.
    @gohan
    The software says it's installed. Is there a way to uninstall and install again?
    gohanG 1 Reply Last reply
    • H hugo_pn
      Hi all,
      @LaMB95
      @gohan
      @hugo_pn
      from library manager you can install, remove, update the libraries. You can try to remove from the Arduino IDE and try to copy the library manually where you have all the libraries
      • H
        H
        hugo_pn
        Hi all,
        Sorry for the delay, my IDE is 1.6.5 going to try and update.
        Thanks in advance.
        cheers
        • H
          H
          hugo_pn
          Got it working, IDE updated and everything working.
          My temperature already getting values.
          Going to try and attached another DS18B20 as shown in the example.
          Don´t really know what is going to show up.
            Just change the node ID and you shouldn't have any problem
            LaMB95L 1 Reply Last reply
              LaMB95L
              LaMB95L
              LaMB95
              @gohan
              I am facing an issue while sending data from an Arduino pro mini 5V to an arduino UNO. Receiving a lot of garbage from the Pro mini.
              Any idea why ?
              • LaMB95L LaMB95
                @gohan
                Any idea why ?
                @LaMB95
                do you have a log to take a look? Just to understand what is the garbage you are talking about.
                What NRF24 library are you using? I'm using the one from Maniacbug
                  @LaMB95
                  LaMB95L
                  LaMB95L
                  LaMB95
                  Code in Pro Mini:
                  #include <HardwareSerial.h>
                  #include <nRF24L01.h>
                  #include <RF24.h>
                  RF24 radio(9, 10);
                  const byte rxAddr[6] = "00001";
                    while (!Serial);
                    Serial.begin(9600);
                    radio.begin();
                    radio.openReadingPipe(1, rxAddr);
                    radio.startListening();
                    if (radio.available())
                      char text[32] = {0};
                      radio.read(&text, sizeof(text));
                      Serial.println(text);
                  Code in Uno:
                  #include <RF24.h>
                  RF24 radio(9, 10);
                  void setup(void)
                    radio.begin();
                    //Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
                    radio.setRetries(15, 15);
                    radio.openWritingPipe(rxAddr);
                    radio.stopListening();
                  void loop(void)
                    const char text[] = "Hello World";
                    radio.write(&text, sizeof(text));
                    delay(1500);
                  I have set the processor to 3.3V 8MHz.
                  I have connected the Pro mini to the computer via a CP2102 breakout board.
                    I haven't tried the Mini yet, I am waiting for it to be delivered so I can't help you much, but my best shot could be something with serial speed somewhere or something related.
                    Have you tried to use a 16x2 LCD to show data instead of the serial console? I do it sometimes when I don't want to take bring computer with me if I only need to show a few values.
                      LaMB95L
                      LaMB95L
                      LaMB95
                      @gohan Well I was gonna use the received text to test the communication itself. The whole point I got a pro mini was to connect it as a serial gateway to the RPi3 and see it on Domoticz as we discussed earlier.
                      • H
                        H
                        hugo_pn
                        #25
                        @ LaMB95 Sorry can't really help you out there.
                        Just to give a feedback on my two temperature sensors.
                        Got them working fine. Two separate graphics, only had to connect the sensor to the wright spots.
                        Thanks for the help.
                        • LaMB95L LaMB95
                          @LaMB95 if I read between the lines in your posts, it sounds as if you have a Pro Mini 5V 16MHz but you tell the Arduino IDE to program it as if it was running at 8MHz. That means all timings will be off. The code expects to run at 8MHz but is run at 16MHz so everything is twice as fast.
                            LaMB95L
                            LaMB95L
                            LaMB95
                            @mfalkvidd
                            Well, I do believe that is the underlying issue here. But the NRF modules can't handle VCC more than 3.3V so I took a 3.3V connection from my breakout board (CP2012) and supplied to the NRF module (Vcc pin only).
                            Could this be causing the issue?
                            • LaMB95L LaMB95
                              @mfalkvidd
                              @LaMB95 no. At 16MHz you are running the Atmega out of spec, so it could behave in lots of strange ways, but often it works without problems.
                              Set the Arduino IDE to 5V/16MHz and flash your sketch. Power it with 3.3V and you'll probably see that everything works.
                                LaMB95L
                                LaMB95L
                                LaMB95
                                @mfalkvidd I m sorry but Whats flashing a sketch ?
                                • LaMB95L LaMB95
                                  @LaMB95 sorry. The Arduino IDE calls it "Upload"
                                    LaMB95L
                                    LaMB95L
                                    LaMB95
                                    @mfalkvidd Ah thanks ! Also when you mean power it with 3.3V do you mean just the nrf module or the entire Pro mini board ?
                                    • LaMB95L LaMB95
                                      @LaMB95 the best would be to power the 5V Pro Mini with 5V and the nrf with 3.3V and connect GND from both power sources together.
                                      • H
                                        H
                                        hugo_pn
                                        #33
