  2. Announcements
  • M marceloaqno
    @pete1450 Could you send the debug log with the connection errors?
    P
    P
    pete1450
    @marceloaqno
    Ran as root and made sure I didn't have mysgw already running:
    rm -r MySensors/
    cd MySensors/
    ./configure --my-controller-ip-address=192.168.1.136 --my-port=5003 --my-rf24-irq-pin=15
    make
    root@raspberrypi:~/downloads/MySensors# ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: failed to connect
    mysgw: Eth: connect
    • b0rmannB
      b0rmannB
      b0rmann
      every few days mysgw randomly dies :(
      Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:READ,5-5-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
      Jan 19 06:40:01 pi mysgw[17960]: Sending message on topic: mysensors/out/1/5/255/3/0/21
      Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:READ,0-5-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
      Jan 19 06:40:01 pi mysgw[17960]: TSF:MSG:BC
      Jan 19 06:40:01 pi systemd[1]: mysgw.service: main process exited, code=killed, status=11/SEGV
      Jan 19 06:40:01 pi systemd[1]: Unit mysgw.service entered failed state.
      • P pete1450
        @marceloaqno
        rm -r MySensors/
        cd MySensors/
        make
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: Eth: connect
        marceloaqno
        Code Contributor
        @pete1450 If you use the --my-controller-ip-address= option, the gateway will act as a client and attempt to conect to the supplied ip and port. If you want the gateway to open port 5003, omit this option.
        P 1 Reply Last reply
        • AndurilA
          AndurilA
          Anduril
          @marceloaqno what is the correct configure option to make this gatway connect to an ethernet gateway and let a serial-only-controller connect to it. I suppose to use the pty option, but didn't got this working. As said above, socat and nodered are no option.
          • M marceloaqno
            P
            P
            pete1450
            wrote on last edited by pete1450
            #326
            @marceloaqno Well that fixed the connection issue. Now I'm just back to square one where pressing start doesn't do anything. Why do I not need to specify my controllers ip? That is the ip for my veralite. Whats the use case for that option.
            • b0rmannB b0rmann
              marceloaqno
              Code Contributor
              @b0rmann Could you provide the following information?
              • Your RPi model and which linux distribution you are using.
              • gcc version
              • The version and options you used to build the gateway (./configure --option)
              • The number of nodes on your network that sends messages to the gateway.
              • The broker you are using for MQTT and its version
              • AndurilA Anduril
                marceloaqno
                Code Contributor
                @Anduril Sorry, the gateway does not support what you're trying to do.
                • P pete1450
                  marceloaqno
                  Code Contributor
                  @pete1450
                  I can't help you with this, I've never used the Vera controller. You need to search in the Vera settings where you set this option. If Vera supports being a server and opening a port for the gateway to connect, then you use the --my-controller-ip-address option.
                    Michael Curtis
                    Does anyone know if the Raspberry implementation have a UserPassword option for ./configure MQTT
                    • M Michael Curtis
                      Michael Curtis
                      @Michael-Curtis Nevermind, I fixed it.... you ned to add :
                      --my-mqtt-password=<PASS>   MQTT password
                      Under "cat"
                      And for the actual options under "opt do"
                      --my-mqtt-user=*)
                          CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
                      --my-mqtt-password=*)
                          CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
                      then just add those option flags to the ./configure and run make
                      • Roberto Mo CaR
                        Roberto Mo CaR
                        Roberto Mo Ca
                        what means "5VReg -> 3.3V" in raspberry? can connect directly to 3.3V or if requied connecto to 5V with regulator to obtain 3.3v?
                          macvictor
                          Hi :) Does anybody know how to use MY_SIGNING_NODE_WHITELISTING in gateway raspbery pi? Where I must create/edit white list with my nodes?
                          • OliverDogO
                            OliverDogO
                            OliverDog
                            first sorry about the basics question but I think many people have the same questions and can't find the answers:
                            After connecting the radio (including IRQ on 15pin) and the info LEDs to the GPIO, how to config it?
                            1. Do I need to configure all the info on the same command, or can I send the command "./configure --" many times for different configs?
                            2. Do I need to configure it as a MQTT gateway?
                            3. Where did the 127.0.0.1 IP come from?
                            4. Does MQTT use internet connection?
                            5. Why do you talk about Serial Gateway here, once we have a specific type for it? this type is about using GPIO only, isn't it? That is confusing!!!
                            • OliverDogO
                              OliverDogO
                              OliverDog
                              trying to config on a Home Assistant Rpi.
                              Sorry again for the newbie questions...!!!
                              • Erik TammingaE
                                Erik TammingaE
                                Erik Tamminga
                                Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
                                If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
                                I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
                                Regards,
                                Erik
                                • Roberto Mo CaR Roberto Mo Ca
                                  marceloaqno
                                  Code Contributor
                                  S 1 Reply Last reply
                                  • M macvictor
                                    marceloaqno
                                    Code Contributor
                                    wrote on last edited by marceloaqno
                                    #338
                                    @macvictor For the MY_SIGNING_NODE_WHITELISTING, you can uncomment and edit it in MyConfig.h or add it to the examples/mysgw.cpp.
                                    • OliverDogO OliverDog
                                      marceloaqno
                                      Code Contributor
                                      @OliverDog
                                      You execute ./configure once with all your options to set your gateway.
                                      You need to decide what type of gateway you want to build: ethernet, serial or mqtt:
                                      https://www.mysensors.org/build/select_gateway
                                      Take a look at the link and let me know if you still have any questions.
                                      • OliverDogO
                                        OliverDogO
                                        OliverDog
                                        thaks @marceloaqno but I was wondering there was a new type of gateway named Raspberry Gateway, were we could connect the radio directly on the GPIO and config it locally, without internet, because of that I also would like to know if MQTT uses internet connection.
                                        I actually use a serial gateway connected to Pi USG and it works without internet...
                                        I just want to have only one device...
                                          marceloaqno
                                          Code Contributor
                                          @OliverDog You can configure the RPi to be any of the 3 types: ethernet, serial or mqtt, with the nrf24 attached to it.
                                          OliverDogO 1 Reply Last reply
