  3. Could use a bid help to get started
24 Posts 3 Posters 7.5k Views 2 Watching
  • R
    R
    Rene046
    Hi there,
    Today i started with MySensor,
    I installed Domoticz on an arduino.
    I made MySensor gateway that runs on Domoticz Gateway Version: 2.1.0
    then i took a nano and installed a DHT11 took a sample code and i can read in serial monitor the temperature.
    I i am trying by using many sample codes for sending the dht11 data to domoticz
    but almost with all sample codes i get messages
    about :
    exit status 1
    no matching function for call to 'DHT::DHT()'
    or that the code is not for the nano.
    Is there one simple working sample so i can test if i can sent a bid of data into domoticz.
    im getting crazy because simple code can be written into my nano but stuff related to my sensor ... i get all kinds of problems..
    Sorry for my bad english im a Dutch guy.
    Kind Regards Rene.
    p.s. i hope once to get a weather station running with more sensors, but would be glad to get 1 thing working
    • R Rene046
      Hi there,
      about :
      exit status 1
      Kind Regards Rene.
      sundberg84S
      sundberg84S
      @Rene046 - Hi and welcome!
      no matching function for call to 'DHT::DHT()' means you are missing the DHT library. You need to install it from here: https://github.com/mysensors/MySensorsArduinoExamples
      • R
        R
        Rene046
        Thx for you fast answer,
        i installed you links library, seems i had to overwrite because i already had those,during compiling i get....
        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Rene\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Rene\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10801 -build-path H:\WINDOW~1\Temp\arduino_build_113476 -warnings=default -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino
        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Rene\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Rene\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10801 -build-path H:\WINDOW~1\Temp\arduino_build_113476 -warnings=default -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino
        Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
        Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
        Detecting libraries used...
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0" "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library" "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library" "H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library\DHT.cpp" -o "nul"
        Generating function prototypes...
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library" "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp" -o "H:\WINDOW~1\Temp\arduino_build_113476\preproc\ctags_target_for_gcc_minus_e.cpp"
        "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "H:\WINDOW~1\Temp\arduino_build_113476\preproc\ctags_target_for_gcc_minus_e.cpp"
        Compiling sketch...
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0" "-IH:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library" "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp" -o "H:\WINDOW~1\Temp\arduino_build_113476\sketch\DHT22-1.ino.cpp.o"
        DHT22-1:73: error: no matching function for call to 'DHT::DHT()'
        DHT dht;
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino:73:5: note: candidates are:
        In file included from H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino:44:0:
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
        DHT(uint8_t pin, uint8_t type, uint8_t count=6);
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library/DHT.h:40:4: note: candidate expects 3 arguments, 0 provided
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(const DHT&)
        class DHT {
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: candidate expects 1 argument, 0 provided
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library/DHT.h:38:7: note: constexpr DHT::DHT(DHT&&)
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino: In function 'void setup()':
        DHT22-1:91: error: 'class DHT' has no member named 'setup'
        DHT22-1:92: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
        DHT22-1:97: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
        H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino: In function 'void loop()':
        DHT22-1:104: error: 'class DHT' has no member named 'readSensor'
        dht.readSensor(true);
        DHT22-1:107: error: 'class DHT' has no member named 'getTemperature'
        DHT22-1:114: error: 'class DHT' has no member named 'toFahrenheit'
        DHT22-1:131: error: 'class DHT' has no member named 'getHumidity'
        Multiple libraries were found for "DHT.h"
        Used: H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library
        Not used: H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT-sensor-library-master
        Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
        Using library MySensors-2.0.0 at version 2.0.0 in folder: H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\MySensors-2.0.0
        Using library DHT_sensor_library at version 1.2.3 in folder: H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT_sensor_library
        exit status 1
        • R
          R
          Rene046
          this is the sketch :
          • The MySensors Arduino library handles the wireless radio link and protocol
          • between your home built sensors/actuators and HA controller of choice.
          • The sensors forms a self healing radio network with optional repeaters. Each
          • repeater and gateway builds a routing tables in EEPROM which keeps track of the
          • network topology allowing messages to be routed to nodes.
          • Created by Henrik Ekblad henrik.ekblad@mysensors.org
          • Copyright (C) 2013-2015 Sensnology AB
          • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
          • Documentation: http://www.mysensors.org
          • Support Forum: http://forum.mysensors.org
          • This program is free software; you can redistribute it and/or
          • modify it under the terms of the GNU General Public License
          • version 2 as published by the Free Software Foundation.
          • REVISION HISTORY
          • Version 1.0: Henrik EKblad
          • Version 1.1 - 2016-07-20: Converted to MySensors v2.0 and added various improvements - Torben Woltjen (mozzbozz)
          • DESCRIPTION
          • This sketch provides an example of how to implement a humidity/temperature
          • sensor using a DHT11/DHT-22.
          • For more information, please visit:
          • http://www.mysensors.org/build/humidity
          // Enable debug prints
          //#define MY_RS485
          #define DHT_DATA_PIN 2
          #define SENSOR_TEMP_OFFSET 0
          static const uint64_t UPDATE_INTERVAL = 60000;
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          float lastTemp;
          float lastHum;
          uint8_t nNoUpdatesTemp;
          uint8_t nNoUpdatesHum;
          bool metric = true;
          DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          nNoUpdatesTemp++;
          if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
          nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
          • R
            R
            Rene046
            What i see also often is that Mysensor.h is used in a lot of sketches
            and cant be found by Arduino's ide.
            H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\DHT22-1\DHT22-1.ino:2:22: fatal error: MySensor.h: No such file or directory
            i am afraid i have done something verry wrong that nothing seems to be working here.
            Installed arduino ide many times removed library's many time's but still no sketch with Mysensor works here.
            Please please help
            • R Rene046
              Please please help
              @Rene046 how did you install the MySensors library? Did you use the instructions at https://www.mysensors.org/about/arduino#installing-the-sensor-libraries ?
              Where did you find the dht11 sketch? MySensor.h (without s before the dot) is from MySensors 1.x so it seems there is a mixup between different versions.
              • R
                R
                Rene046
                jes i installed it like in your link.
                Seems my sketch is then from an older version. because it uses Mysensor.h
                I also tried changing it to mysensors.h but then allot of things go wrong while compiling
                Maybe you could point me to a DHT sketch thats up-to-date ? for mysensor version 2.1.1
                i installed.
                Im totally new with mysensor, and now you told me i understand that lots of sketches on internet are old and dont work anymore.
                Where can i find info about changes ?
                i now am trying the sketch of this person
                https://forum.mysensors.org/topic/3774/multiple-dht22-in-one-sensor-for-greenhouse-newbee-question/5
                but he also seems to use old version, i see again mysensor.h instead of mysensors.h
                hope for an answer....
                • R Rene046
                  i installed.
                  @Rene046 many MySensors sketches are included with the MySensors library. You can find them in File->Examples-MySensors in the Arduino IDE
                  However, sketches that require external libraries (such as the temperature example which requires a MySensors fork of the DHT library) can not be included within the library. Therefore, they are available at https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                  • R
                    R
                    Rene046
                    All those samples seems to work and compile perfect,
                    But there is no sample with an DHT sensor temp. and hum included. or do i overlook ?
                    • R Rene046
                      @Rene046 in the MySensorsArduinoExamples zip file is examples/DhtTemperatureAndHumiditySensor and libraries/DHT
                      You'll need both those folders.
                      • R
                        R
                        Rene046
                        should i unzip those inside the mysensor map or arduino ?
                        • R Rene046
                          @Rene046 I am not sure, but try putting DhtTemperatureAndHumiditySensor in the Arduino sketch folder (My Documents\Arduino on my computer) and DHT in the libraries folder (My Documents\Arduino\libraries on my computer)
                          • R
                            R
                            Rene046
                            ok done that, opened the sketch sample for dht.
                            compile and i get :
                            H:\WINDOW~1\Temp\arduino_modified_sketch_660970\DhtTemperatureAndHumiditySensor.ino: In function 'void presentation()':
                            DhtTemperatureAndHumiditySensor:85: error: 'getConfig' was not declared in this scope
                            exit status 1
                            • R Rene046
                              compile and i get :
                              exit status 1
                              @Rene046 There are two DHT folders. Delete the DHT folder that didn't come from the MySensorsArduinoExamples zip file.
                              • R
                                R
                                Rene046
                                ok now im left with this
                                H:\WINDOW~1\Temp\arduino_modified_sketch_225110\DhtTemperatureAndHumiditySensor.ino: In function 'void presentation()':
                                exit status 1
                                • R Rene046
                                  exit status 1
                                  @Rene046 see https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/2
                                  (change getConfig to getControllerConfig)
                                  • R
                                    R
                                    Rene046
                                    thanks it works... i love you ..lol
                                    why do they change basic commands.... this make it hard to use.......
                                    Like this command and why make from mysensor.h mysensors.h.
                                    i also looked inside domoticz and i got data
                                    thank you very very much
                                    • R Rene046
                                      @Rene046 the change from MySensor to MySensors is because the Arduino IDE requires the .h file to have exactly the same name as the library. That was not the case when MySensors was created, but happened some time in 2015 I think. So to comply with Arduino IDE rules, it had to be changed.
                                      The reason for changing getConfig is logged at https://github.com/mysensors/MySensors/issues/736 but I am not sure why and the fix (https://github.com/mysensors/MySensors/pull/737 ) does not explain why either, but seems to be due to a mistake in https://github.com/mysensors/MySensors/commit/92cbd2ac8f49fe2f8cb25726e08aac9ecd597b84
                                      • R
                                        R
                                        Rene046
                                        ok,
                                        At least i can now experiment with other sensors for my weather station project.
                                        i now all electronics are working, i saved this sketch and commented those changes.
                                        Again thank you for getting me started.
                                        • R Rene046
                                          ok,
                                          @Rene046 you're welcome. Great that you got it working.
