  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 677.3k Views 99 Watching
  • AndrewZA AndrewZ
    Hello everyone
    I'm slowly migrating to OH2, my small MySensors network generally works fine but I see some weird behavior with the binding configuration in Paper UI.
    So far it looks like "Disable network sanity check" is reversed - I'm sliding it to the left which means for me 'not disabled', i.e. 'enabled', but in the log I see "Checker thread disabled".
    2017-01-11 16:50:38.405 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
    2017-01-11 16:50:38.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.1.0
    2017-01-11 16:50:38.503 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2017-01-11 16:50:38.511 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.0
    2017-01-11 16:50:38.512 [DEBUG] [col.serial.MySensorsSerialConnection] - Good,Gateway is up and running! (Ver:2.1.0)
    2017-01-11 16:50:38.514 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
    2017-01-11 16:50:38.515 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
    2017-01-11 16:50:48.516 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
    Is that ok?
    TimO
    @AndrewZ Don't worry about that message, the debug log looks good. The warning is confusing and we need to change that. :-)
    AndrewZA 1 Reply Last reply
    • T TimO
      AndrewZA
      AndrewZA
      AndrewZ
      @TimO Thanks, will keep it off in the GUI.
      • Duncan PullenD
        Duncan PullenD
        Duncan Pullen
        Hi @TimO
        I've logged a job to include documentation about non-native OpenHAB 2.0 bindings in the official OH2 docs.
        ThomDeitrich is looking to know why it's not yet in the official distro. Can provide some info?
        https://github.com/openhab/openhab-docs/issues/188
        • Duncan PullenD Duncan Pullen
          Hi @TimO
          TimO
          Hey @Duncan-Pullen !
          The main reason is: I'm waiting for suggestions / approval from the OH2 developers. :)
          The MySensors binding has grown big and a review takes some time.
            @TimO, thank you for all the effort you've put into this!
            • FusedHe3F
              FusedHe3F
              FusedHe3
              wrote on last edited by FusedHe3
              #355
              Hi everyone,
              @TimO, thanks for everything you did here!
              I just made the 2.0 version (code in comments of respective post) of petewill's Simple Scene Controller and discovered that a Scene Controller is not yet implemented in the OpenHAB binding. Is there a possibility that it will be implemented in the future?
              For now, is it possible to get this working with CustomSensor or Text?
              • FusedHe3F FusedHe3
                Hi everyone,
                TimO
                Hi @FusedHe3 !
                My first thought was: that's easy, lets add this! But after a second thought ...
                I see one problem with S_SCENE_CONTROLLER: how do I map this in OpenHAB?
                In MySensors there is V_SCENE_ON and V_SCENE_OFF. The message contains the corresponding scene number.
                In OpenHAB I've: Number, Switch, Selection ...
                0_1484735515591_upload-dac7eae9-cec0-4cbd-95ec-a0428268441c
                In OpenHAB I may choose between Scene A, Scene B and so on, but I can't select between ON and OFF. Is Scene A switched off, when I select Scene B?
                I'm using scenes with a switch in OpenHAB. Something like "Christmas decoration ON". In OpenHAB I'm using a group for that gChristmasDecoration or a rule: switch light on, shutter to 33%, ..
                My approach in implementing a (hardware) scene controller would be a mapping of those switches. So I would define a switch / child for every button (scene) on the controller.
                I'm open for ideas on how to map V_SCENE_CONTROLLER in OpenHAB, so if you or someone else have and idea, shout it out. :D
                FusedHe3F 1 Reply Last reply
                • T
                  TimO
                  Ah, by the way, I forgot to mention: SmartSleep is supported since last week.
                  0_1484736645455_upload-d9d8432b-4892-4c07-876a-3abd4def86a0
                  • T TimO
                    Hi @FusedHe3 !
                    FusedHe3F
                    FusedHe3F
                    FusedHe3
                    @TimO Thanks for the quick reply!
                    I do think the ON/OFF switch for every scene would be the most logical solution. In that way it's fully compatibel with the MySensors Scene Controller and you can have multiple scenes active at the same time.
                    • AndrewZA
                      AndrewZA
                      AndrewZ
                      Just updated my OH2 installation from snapshot to RC/beta and immediately got an error with the binding:
                      [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "Gateway startup complete.") on reading from connection, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                      But then the usual:
                      What could be a problem? Do I need to perform some cleanup on my system? What exactly needs to be deleted?
                      • T TimO
                        Hey @Nicklas-Starkel !
                        I hope it will work out for you! :-)
                        It is not yet part of OH2 and downloadable within OH2 because my pull request is still open. A OH2 developer needs to look at it. :-)
                        K
                        K
                        krejcarek
                        I ran into trouble today by apt-get updating Openhab.
                        I am over redefining the Distro for Snapshot... I have 2.0.0-SNAPSHOT, Build #743 up and running.
                        my bundle list looks following:
                        204 | Active | 80 | 3.12.0.OH | nrjavaserial
                        205 | Installed | 80 | 2.0.0.201611221149 | MySensors Binding
                        Still getting these errors:
                        "03:17:10.911 [ERROR] [org.openhab.binding.mysensors ] - FrameworkEvent ERROR - org.openhab.binding.mysensors
                        org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [205]
                        Unresolved requirement: Require-Bundle: org.openhab.io.transport.serial"
                        Any idea for next step?
                        • K krejcarek
                          TimO
                          @krejcarek please upgrade the binding to the most recent version. :-)
                          AndrewZA K 2 Replies Last reply
                          • T TimO
                            AndrewZA
                            AndrewZA
                            AndrewZ
                            @TimO what about my error? I'm on the latest version already.
                            • AndrewZA AndrewZ
                              TimO
                              @AndrewZ Sorry! Is it working despite the error? I need to test with RC1 myself. The error looks like it could be ignored. From time to time messages get corrupted, due to connection issues and the parser stumbles about that. But it should continue to work just fine. I suppose this is the case here, but I'll check!
                              • T TimO
                                AndrewZA
                                AndrewZA
                                AndrewZ
                                @TimO yes, it is working, but please check this one and 2nd (Network Sanity Checker thread disabled). Thank you!
                                • jogantJ
                                  jogantJ
                                  jogant
                                  I had the same error messages on first boot of OH. After finishing upgrade procedure and restarting OH once again error message is gone. New version of the binding is working well. No hickups at the moment.
                                  • ben999B
                                    ben999B
                                    ben999
                                    wrote on last edited by ben999
                                    #366
                                    Hi Guys
                                    I am currently playing with a fairly fresh install of openhab2 (last weekend)
                                    I have played with the auto-discovery function in PaperUI
                                    Wow that's amazing :)
                                    But i am having trouble when it comes to sitemap file : sitemap function is not included within PaperUI (as far as i know) and i need this file to configure properly my iOS app
                                    So i have to go back to the old fashionned way and edit thing, item and map files with a text editor (which is fine)
                                    Two questions from here:
                                    • please prove me wrong in the way that i can discover things and configure items within paperUI and still create a valid sitemap file usable by my iOS devices
                                    • if above not possible, is there a way to "flush" openhab things and items database as i am getting warnings about things that don't exist anymore (things previously discovered by paperUI but deleted since)
                                      Thanks a lot for reading
                                    • H
                                      H
                                      hillmanr
                                      I must be missing something. I have the same error as well. Is there a link to the latest binding. The one on the instructions page is dated 20161122 and a second one refereed to in this topic above dated 20161222. Which binding should I be using
                                      • T TimO
                                        K
                                        K
                                        krejcarek
                                        @TimO, Thanks for the quick response. Probably was some stupid mistake with copying.jar file. Got mine now on 2.0.0.201701181308, and works like charm.
                                        Hoping to have mysensors soon as official binding to avoid the need of workarounds and thus prone to mistakes.
                                        • H hillmanr
                                          TimO
                                          @hillmanr please try this link: Download
