  2. Announcements
  3. 💬 Light Level Sensor - BH1750
15 Posts 9 Posters 7.2k Views 7 Watching
  • ร
    ร
    รอเรือ
    Ohh... I forgot to mention that I unsoldered the power regulator on the BH1750FVI and bridged Volt In with Volt Out. By doing that I hope that the BH1750FVI will work on lower voltages than specified. Time will tell.
    • ร
      ร
      รอเรือ
      Another important note... If doing it the way I suggested below, You will need to reconfigure the BH1750FVI before every reading. Something like this will do:
      lightSensor.configure(BH1750_ONE_TIME_HIGH_RES_MODE);
      delay(500); // Allow some time
      Cheers!
      • riochickenR
        riochickenR
        riochicken
        Is there a way to combine this sketch and sensor with the Atmospheric Pressure since they both use the same A4 and A5 connections on the Arduino...
        • riochickenR riochicken
          @riochicken yes. They both use the i2c bus, which supports multiple devices.
          • riochickenR
            riochickenR
            riochicken
            @mfalkvidd : Cool! So just combine the sketches and go?!?!?!!?!
              @riochicken yup. You're welcome :)
              • meanmrgreenM
                meanmrgreenM
                meanmrgreen
                • checkupC
                  checkupC
                  checkup
                  The BH1750FVI IC can handle 4.5V max and the normal operating voltage is 2.4V-3.6V.
                  So it should be ok to desolder the voltage regulator and drive this thing from the 2xAlkaline or 3xNIMH
                  • Dennis van der WolfD
                    Dennis van der Wolf
                    I have connected my BH1750 to an Arduino nano as indicated above. After that i uploaded the sketch. I defined a node id 16 and child id 1. Nothing is happend. When i read the log it's says child id 255
                    debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:BC
                    19:55:26debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:READ 16-16-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    19:55:25debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;!TSP:MSG:SEND 0-0-16-16 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                    19:55:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:GWL OK
                    19:55:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                    19:55:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:FPAR REQ (sender=16)
                    I don't know what i did wrong. Anyone an idea?
                    • checkupC
                      checkupC
                      checkup
                      try to flash the "clear eeprom" sketch from the mysensors library and try again with your sketch.
                      Dennis van der WolfD 1 Reply Last reply
                      • checkupC checkup
                        Dennis van der Wolf
                        @checkup Hi, i have done that a few times now. Unfortunately, with the same result.
                        • K
                          K
                          kiesel
                          What's the expected value range for this sensor in the evening with some lights on? It's not dark here atm but I am getting ca 10 lux only. Any ideas?
