  2. Announcements
  3. 💬 Light Level Sensor - BH1750
15 Posts 9 Posters 6.9k Views 7 Watching
  • H Offline
    H Offline
    wrote on last edited by hek
    This thread contains comments for the article "Light Level Sensor - BH1750" posted on MySensors.org.
    • K Offline
      K Offline
      ksga
      • ร Offline
        ร Offline
        รอเรือ
        Using a Arduino Pro Mini with BURNED FUSES, set to 1MHz I've built a low power battery sensor using the BH1750FVI. When using the statement "lightSensor.begin();" as in the example above, the BH1750FVI is set to continuous reading, hence will not sleep. Including the radio the measuread DC current when sleep() is 140μA and my 2 AA batteries will not last for more than maybe 1,5 years. However if I change that statement to "lightSensor.begin(BH1750_ONE_TIME_HIGH_RES_MODE);", the BH1750FVI device is automatically set to Power Down after measurement. I end up using about 6μA while sleeping which is a great improvement.My batteries will die due to old age and that's nice for the environment and to my wallet!
        • ร Offline
          ร Offline
          รอเรือ
          Ohh... I forgot to mention that I unsoldered the power regulator on the BH1750FVI and bridged Volt In with Volt Out. By doing that I hope that the BH1750FVI will work on lower voltages than specified. Time will tell.
          • ร Offline
            ร Offline
            รอเรือ
            Another important note... If doing it the way I suggested below, You will need to reconfigure the BH1750FVI before every reading. Something like this will do:
            lightSensor.configure(BH1750_ONE_TIME_HIGH_RES_MODE);
            delay(500); // Allow some time
            Cheers!
            • riochickenR Offline
              riochickenR Offline
              riochicken
              Is there a way to combine this sketch and sensor with the Atmospheric Pressure since they both use the same A4 and A5 connections on the Arduino...
              • riochickenR riochicken
                @riochicken yes. They both use the i2c bus, which supports multiple devices.
                  riochickenR Offline
                  riochicken
                  @mfalkvidd : Cool! So just combine the sketches and go?!?!?!!?!
                    @riochicken yup. You're welcome :)
                    • meanmrgreenM Offline
                      meanmrgreen
                      • C Offline
                        C Offline
                        checkup
                        The BH1750FVI IC can handle 4.5V max and the normal operating voltage is 2.4V-3.6V.
                        So it should be ok to desolder the voltage regulator and drive this thing from the 2xAlkaline or 3xNIMH
                        • Dennis van der WolfD Offline
                          Dennis van der Wolf
                          I have connected my BH1750 to an Arduino nano as indicated above. After that i uploaded the sketch. I defined a node id 16 and child id 1. Nothing is happend. When i read the log it's says child id 255
                          debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:BC
                          19:55:26debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:READ 16-16-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                          19:55:25debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;!TSP:MSG:SEND 0-0-16-16 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                          19:55:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:GWL OK
                          19:55:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                          19:55:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;255;3;0;9;TSP:MSG:FPAR REQ (sender=16)
                          I don't know what i did wrong. Anyone an idea?
                          • C Offline
                            C Offline
                            checkup
                            try to flash the "clear eeprom" sketch from the mysensors library and try again with your sketch.
                            Dennis van der WolfD 1 Reply Last reply
                            • C checkup
                              Dennis van der Wolf
                              @checkup Hi, i have done that a few times now. Unfortunately, with the same result.
                              • K Offline
                                K Offline
                                kiesel
                                What's the expected value range for this sensor in the evening with some lights on? It's not dark here atm but I am getting ca 10 lux only. Any ideas?
                                12.1k
