  3. Sensebender Micro - Problem accessing accelerometer via SDA and SCL pins
10 Posts 3 Posters 3.0k Views 1 Watching
  • J Offline
    J Offline
    jwoods
    Has anyone had any issues using the SDA and SCL pins on the Sensebender Micro.
    I have a sketch running on an Arduino Pro Mini ( 3.3v 8 Hz) that accesses a Sparkfun accelerometer via the SDA and SCL pins using a Sparkfun library. I’m able to upload this same sketch to the Sensebender Micro but when I run the sketch the accelerometer fails to initialize.
    This same sketch runs perfectly on a Nano v3 and the Pro Mini. I’m trying to get the sketch working on the Sensebender Micro so that I can take advantage of the Micro’s low power consumption since I’m planning to run the Micro on AA batteries.
    Thoughts?
    • J jwoods
      Thoughts?
      @jwoods this is just a wild guess, but maybe you need to add pullups to the signal lines? https://learn.sparkfun.com/tutorials/i2c/i2c-at-the-hardware-level
      • tbowmoT Offline
        tbowmoT Offline
        tbowmo
        @mfalkvidd
        There is two 4k7 pullups on the sensebender micro, as i2c is used for the onboard sensor.
        @jwoods
        One thought, can you use the onboard Si7021, while the accelerometer is attached to the sensebender? Also, which chip is used for the accelerometer? (Sparkfun has 3-4 different versions with different chipset onboard)
        J 1 Reply Last reply
        • tbowmoT tbowmo
          @mfalkvidd
          @jwoods
          J Offline
          J Offline
          jwoods
          @tbowmo - Thanks for the response. I'm using the mma8452q accelerometer. I'll have to pull some code together to see if I can get a reading from the si7021 while the accelerometer is attached.
          • tbowmoT Offline
            tbowmoT Offline
            tbowmo
            @jwoods
            You could just use the default sensebender micro sketch :)
            just a thought, is there pullups on sda/scl on the Sparkfun board? If so, they are in parallel with the pullups on the sensebender, and when in parallel, the total resistance will be lower, and create a stronger pullup, which might mess up things.
            • tbowmoT tbowmo
              @jwoods
              J Offline
              J Offline
              jwoods
              @tbowmo I’ve complied and uploaded the default sensebender micro sketch. The sketch hangs on the following line of code humiditySensor.begin(); -- actually hangs on Wire.endTransmission(); inside the begin procedure from the SI7021 library.
              For my original sketch that accesses the accelerometer… that code also hangs when I call the a readRegister function that is also trying to execute Wire.endTransmission() function.
              Could I have inadvertently damaged the sensebender and or the I2C circuitry?
              • tbowmoT Offline
                tbowmoT Offline
                tbowmo
                It hangs without the accelerometer connected? Could sound like hw problems.
                Do you have a scope so you coukd2check sda /scl lines?
                • tbowmoT tbowmo
                  J Offline
                  J Offline
                  jwoods
                  @tbowmo Correct. Hangs with and without accelerometer connected. No scope, only multimeter.
                  • J jwoods
                    J Offline
                    J Offline
                    jwoods
                    @tbowmo - Just to close the loop on this one. A few weeks ago I had ordered a few additional Micro's.... they arrived today, uploaded my sketch and got good readings from the accelerometer. Must have been a problem with hw and or I2C circuitry. Thanks again for your assistance.
                    tbowmoT 1 Reply Last reply
                    • J jwoods
                      tbowmoT Offline
                      tbowmoT Offline
                      tbowmo
                      @jwoods
                      Thanks for the feedback :) problem could be either the atmega or the Si7021 chip on board the micro.. But hard to figure out without access to a scope..
                      (Btw. you have checked the board for solder bridges etc, right?)
                      11.8k
                      113.2k
