  3. Interrupt and sleep
Interrupt and sleep
26 Posts 7 Posters 12.9k Views 6 Watching
  • elysionE elysion
    From your description it sounds like your problem is pretty much exactly same as mine was when I started that thread. I have not experienced any crashes. The issue is just that the board does not wake up on CHANGE. Have you tried using LOW instead of CHANGE for sleep? There were comments in the aforementioned thread that this might be an issue with a certain version of Arduino and boards file. Have not yet had time to investigate tough.
    @elysion
    I have updated IDE to latest version and I got a change: now it takes a variable time between 30 sec to 2 minutes for the motion sensor to restore to "0" .
    If I set it to LOW it just skips the sleep as I see continuously errors from reading from the DHT11 sensor until I trigger the motion sensor. Changing it to HIGH or CHANGE I get the same result. Now it's late, so maybe tomorrow I'll try downgrading IDE and boards to 1.6.8 as suggested in another thread.
      Downgraded to 1.6.8 IDE and boards but no change, also tried to compile it in Visual Studio but behavior is the same. Maybe the Mega has some issues that other boards don't have?
      Here is log
      5079 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
      5107 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
      5112 MCO:SLP:TPD
      5113 MCO:SLP:WUP=1
      5118 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
      5149 TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.9
      T: 20.94
      5156 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
      5160 MCO:SLP:TPD
      5163 MCO:SLP:WUP=-1
      5168 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
      5196 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
      5200 MCO:SLP:TPD
      5202 MCO:SLP:WUP=-1
      5208 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
      5238 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:20.0
      H: 20.00
      5244 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
      5250 MCO:SLP:TPD
      5252 MCO:SLP:WUP=-1
      5256 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
      5284 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
      5289 MCO:SLP:TPD
      5291 MCO:SLP:WUP=1
      5298 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
      5326 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
      5331 MCO:SLP:TPD
      As you can see when motion is triggered (the "1" on 5th line) it takes a while for it to go back to "0" and each message is 10 seconds from the previous like it is ignoring the interrupt.
      I'm running out of options besides buying a few Pro Mini and start building a definitive sensor
        Here is log
        5112 MCO:SLP:TPD
        5113 MCO:SLP:WUP=1
        T: 20.94
        5160 MCO:SLP:TPD
        5163 MCO:SLP:WUP=-1
        5200 MCO:SLP:TPD
        5202 MCO:SLP:WUP=-1
        H: 20.00
        5250 MCO:SLP:TPD
        5252 MCO:SLP:WUP=-1
        5289 MCO:SLP:TPD
        5291 MCO:SLP:WUP=1
        5331 MCO:SLP:TPD
        sundberg84S
        sundberg84S
        @gohan - any change if you try to change the trigger delay on the motion sensor?
          No, I tried to move it around but it doesn't change the behavior in this case.
          • J
            J
            JoergP
            ahhhhhhhhhhhh - I created a door/window sensor some weeks ago - but I couldn't make it run to fire an interrupt on pin change (INT0 and INT1 are used to connect external magnetic sensors) - today I decided to work on this issue again and found this topic at the forum - so I downgraded my arduino IDE by downloading v1.6.8 from arduino.cc today - compiled my code again - falshed it - and voilà - it works
            That is really frustrating by wasting that many hours of time only by inconsistancy with compiler/board definitions.
            Is there any need to update to newer arduino-IDE - otherwise I would recommend to general stick to one version ...
            gohanG 1 Reply Last reply
            • J JoergP
              wrote on last edited by gohan
              @JoergP
              Would you mind posting board version you are using and also your code? Did some test but I couldn't figure out anything on my mega so probably there is also something about that kind of board, so I didn't spend too much time on it and wait for the other minis I ordered
              • J
                J
                JoergP
                I checked the used versions - as I already wrote the used arduino-IDE is 1.6.8. But due to the case that I used 1.8.0 before and downgraded the board definition by "Board manager" the board definition is 1.6.11 (if you down/upgrade by BoardManager you can find the files in dir "C:\Users...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11"
                I added my own definitions to board.txt (because I use 2AA Battery node -> https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node)
                here my quick and dirty source - have to clean up if it works as expected:
                // based on 2AA Battery Node
                // ATMEGA328P (@ internal OSC 1MHz)
                // device ID = 0x07D5 (2005d )
                // 0  - Input 0 -> S_DOOR / V_TRIPPED
                // 1  - Input 1 -> S_DOOR / V_TRIPPED
                // 2  - temperature (HTU)
                // 3  - humidity (HTU)
                // includes
                #include "Adafruit_HTU21DF.h"
                #include <Vcc.h>
                #include <avr/wdt.h>
                // MySensors
                // MySensor
                #define SN "AA - Windows / Temperature"
                #define SV "1.1"
                #define ms_input_0      0
                #define ms_input_1      1
                #define ms_temperature  2
                #define ms_humidity     3
                // used PINs
                #define PIN_INPUT_0     2
                #define PIN_INPUT_1     3
                // Sleep
                #define SLEEP_TIME 300000   // ms => 5 min
                #define VALUE_MIN_COUNT 12  // send min every 12th measurement one value (once per hour)
                // Vcc
                #define VCC_MIN 1.9
                #define VCC_MAX 3.3
                #define BATTERY_COUNT 288   // 288 * 5 min = 1 day
                // global vars
                MyMessage msg(0,0);
                Adafruit_HTU21DF htu = Adafruit_HTU21DF();
                boolean htu_available = false;
                float htu_temperature = 1000;
                float htu_humidity = 1000;
                int batteryCnt = 0;
                int temperatureCnt = 0;
                int humidityCnt = 0;;
                Vcc vcc;
                // setup
                  // PINs
                  pinMode(PIN_INPUT_0, INPUT_PULLUP);
                  pinMode(PIN_INPUT_1, INPUT_PULLUP);
                  // HTU21
                  if (htu.begin())
                    htu_available = true;
                // presentation
                  sendSketchInfo(SN, SV);
                  // Send sensor information
                  present(ms_input_0, S_DOOR);
                  present(ms_input_1, S_DOOR);
                  if(htu_available) {
                    present(ms_temperature, S_TEMP);
                    present(ms_humidity, S_HUM);
                // loop
                  // enable watchdog
                  wdt_enable(WDTO_8S);
                  // inputs
                  sendInput0();
                  sendInput1();
                  // check battery
                  if(batteryCnt == 0)
                    sendBatteryReport();
                  batteryCnt++;
                  if(batteryCnt > BATTERY_COUNT)
                    batteryCnt = 0;
                  // temperature
                  if(htu_available) {
                    sendTemperature();
                    sendHumidity();
                  // sleep
                  delay(500);
                  wdt_disable();
                  sleep(digitalPinToInterrupt(PIN_INPUT_0), CHANGE, digitalPinToInterrupt(PIN_INPUT_1), CHANGE, SLEEP_TIME);
                // helper functions
                float rfloat(float val, unsigned int num) {
                  if(num) {
                    float f = 10.0 * num;
                    return round(val*f)/f;
                    return round(val);
                void sendTemperature() {
                  wdt_reset();
                  float tmp = htu.readTemperature();
                  if(tmp < 900){ // check errors
                    tmp = rfloat(tmp, 1);
                    if((tmp != htu_temperature) || (temperatureCnt >= VALUE_MIN_COUNT)){
                      htu_temperature = tmp;
                      send(msg.setSensor(ms_temperature).setType(V_TEMP).set(htu_temperature,1));
                      temperatureCnt = 0;
                      temperatureCnt++;
                void sendHumidity() {
                  wdt_reset();
                  float tmp = htu.readHumidity();
                    tmp = rfloat(tmp, 0);
                    if((tmp != htu_humidity) || (humidityCnt >= VALUE_MIN_COUNT)){
                      htu_humidity = tmp;
                      send(msg.setSensor(ms_humidity).setType(V_HUM).set(htu_humidity,0));
                      humidityCnt = 0;
                      humidityCnt++;
                void sendBatteryReport() {
                  wdt_reset();
                  delay(500);
                  float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
                  int batteryPcnt = static_cast<int>(p);
                void sendInput0() {
                  wdt_reset();
                  if(digitalRead(PIN_INPUT_0) == HIGH)
                    send(msg.setSensor(ms_input_0).setType(V_TRIPPED).set(0));
                    send(msg.setSensor(ms_input_0).setType(V_TRIPPED).set(1));
                void sendInput1() {
                  wdt_reset();
                  if(digitalRead(PIN_INPUT_1) == HIGH)
                    send(msg.setSensor(ms_input_1).setType(V_TRIPPED).set(0));
                    send(msg.setSensor(ms_input_1).setType(V_TRIPPED).set(1));
                EfflonE 1 Reply Last reply
                  What does this do?
                    Tests so far are just as the same as before even with the changes you suggested, so I believe I'll just wait for the other new arduinos and use the mega for other purposes
                    • J
                      J
                      JoergP
                      That's bad - if you like you can send me your source and I can try to compile it on my environment.
                      I use the watchdog in general - in the past I had the issue that some nodes stopped working without any reason - watchdog helped to solve this
                        Look at my first post, that's the code. It's a draft so it's not really cleaned up
                        • J JoergP
                          // includes
                          #include <Vcc.h>
                          // MySensors
                          // MySensor
                          #define SV "1.1"
                          // used PINs
                          // Sleep
                          // Vcc
                          #define VCC_MIN 1.9
                          #define VCC_MAX 3.3
                          // global vars
                          MyMessage msg(0,0);
                          int batteryCnt = 0;
                          Vcc vcc;
                          // setup
                            // PINs
                            // HTU21
                            if (htu.begin())
                          // presentation
                            if(htu_available) {
                          // loop
                            // enable watchdog
                            // inputs
                            sendInput0();
                            sendInput1();
                            // check battery
                            if(batteryCnt == 0)
                            batteryCnt++;
                              batteryCnt = 0;
                            // temperature
                            if(htu_available) {
                              sendTemperature();
                              sendHumidity();
                            // sleep
                            delay(500);
                            wdt_disable();
                          // helper functions
                            if(num) {
                              return round(val);
                            wdt_reset();
                                temperatureCnt = 0;
                                temperatureCnt++;
                            wdt_reset();
                                htu_humidity = tmp;
                                humidityCnt = 0;
                                humidityCnt++;
                            wdt_reset();
                            delay(500);
                          void sendInput0() {
                            wdt_reset();
                          void sendInput1() {
                            wdt_reset();
                          EfflonE
                          EfflonE
                          Efflon
                          @JoergP ans others, I have tried versions 1.6.8 and the board definitions 1.6.11 and interrupt seems to work but in the case of using a PIR the sensor somehow seems to be triggered when going out of sleep due to time...
                          J 1 Reply Last reply
                          • EfflonE Efflon
                            J
                            J
                            JoergP
                            @Efflon I'm not sure what exactly you mean - do you refer to my code? In that case this is a quick and dirty try - I'll send at every pin change and at timeout the input values ...
                              My mega goes to sleep for the time specified, but it doesn't wake up when pir is triggered
                              • J JoergP
                                EfflonE
                                EfflonE
                                Efflon
                                wrote on last edited by Efflon
                                #22
                                @JoergP Sorry, what I meant was regarding the versions you were using to get your sensor to work. I've been fighting to get interrupts to work for a day and your suggestion helped.
                                Now it's just that going out of sleep triggers the PIR, then it goes for sleep and wakes up immediately and then finally goes to sleep ... gahh
                                Tripped: 0
                                13207 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
                                13213 MCO:SLP:TPD
                                13217 MCO:SLP:WUP=-1
                                interrupt: -1
                                Tripped: 0
                                Tripped: 1
                                Tripped: 1
                                Tripped: 1
                                Tripped: 1
                                interrupt: -1
                                Tripped: 1
                                Tripped: 0
                                Tripped: 0
                                Tripped: 0
                                Tripped: 0
                                14024 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
                                14032 MCO:SLP:TPD
                                14034 MCO:SLP:WUP=1
                                interrupt: 1
                                Tripped: 0
                                Tripped: 0
                                Tripped: 0
                                Tripped: 0
                                Tripped: 0
                                14440 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
                                14446 MCO:SLP:TPD```
                                • J
                                  J
                                  JoergP
                                  hmmmm .... I'm not so familiar with the arduino build process - I guess that Interrupt Request registers are not reset correctly, but never did that manual with Arduino
                                  I use following board setting
                                  AAnode1.name=AA sensor node (1MHz int)
                                  AAnode1.upload.tool=avrdude
                                  AAnode1.upload.protocol=arduino
                                  AAnode1.upload.maximum_size=32256
                                  AAnode1.upload.speed=9600
                                  AAnode1.bootloader.tool=avrdude
                                  AAnode1.bootloader.low_fuses=0x62
                                  AAnode1.bootloader.high_fuses=0xde
                                  AAnode1.bootloader.extended_fuses=0x07
                                  AAnode1.bootloader.path=optiboot_v50
                                  AAnode1.bootloader.unlock_bits=0x3F
                                  AAnode1.bootloader.lock_bits=0x2F
                                  AAnode1.build.mcu=atmega328p
                                  AAnode1.build.f_cpu=1000000L
                                  AAnode1.build.core=arduino
                                  AAnode1.build.variant=standard
                                  AAnode1.build.board=AVR_AANODE_1MHz
                                  I guess the xxx.build.xxx settings are of interest - do you use the same or do you have different?
                                  • J JoergP
                                    EfflonE
                                    EfflonE
                                    Efflon
                                    @JoergP Don't know. I just select "mini pro" from within Arduino IDE.
                                    I'll create a new trouble shooting topic with my problem since this is going out of topic.
                                    • G
                                      G
                                      giovaFr
                                      wrote on last edited by giovaFr
                                      #25
                                      my 2 cents :
                                      Why are you doing a sleep into setup method?
                                      why not using wait method instead?
                                      I understand that you'd like switch in sleep mode after a loop, but this doesnt sounds natural to do this during "initializing" step.
                                      if you remove sleep from setup, do you still have your issues?
                                      moreover, i've read somewhere that smartsleep methode gives messages time to be sent before sleeping (i'm not absolutly sure about this, i cannot find anymore the place where i've read that).
                                      bool smartSleep(uint8_t interrupt, uint8_t mode, unsigned long ms=0)
                                      @params:
                                      • interrupt: Pin that should trigger the wakeup
                                      • mode: RISING, FALLING, CHANGE
                                      • ms: Number of milliseconds to sleep or 0 to sleep forever
                                      @return: True if wake up was triggered by pin change and false means timer woke it up.
                                      at last : you can wait for an aknownledge, it'll be slower but you'll be sure that message is sent before going to the next line of code...
                                      i did not test it yet, but it would be something like this :
                                      bool ack = true;
                                      send(myMsg.set(avalue), ack );
                                      if(!wait(2000,V_TEMP , mymsg.getType());)
                                           Serial.println("timeout after 2 secs");
                                      • G giovaFr
                                        my 2 cents :
                                        @params:
                                        bool ack = true;
                                        @giovaFr
                                        if you are referring to
                                        that was straight from the example of the DHT11 sensor.
