  3. Interrupt and sleep
Interrupt and sleep
26 Posts 7 Posters 13.0k Views 6 Watching
  • J
    J
    JoergP
    That's bad - if you like you can send me your source and I can try to compile it on my environment.
    I use the watchdog in general - in the past I had the issue that some nodes stopped working without any reason - watchdog helped to solve this
      Look at my first post, that's the code. It's a draft so it's not really cleaned up
      • J JoergP
        I checked the used versions - as I already wrote the used arduino-IDE is 1.6.8. But due to the case that I used 1.8.0 before and downgraded the board definition by "Board manager" the board definition is 1.6.11 (if you down/upgrade by BoardManager you can find the files in dir "C:\Users...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11"
        I added my own definitions to board.txt (because I use 2AA Battery node -> https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node)
        here my quick and dirty source - have to clean up if it works as expected:
        // based on 2AA Battery Node
        // ATMEGA328P (@ internal OSC 1MHz)
        // device ID = 0x07D5 (2005d )
        // 0  - Input 0 -> S_DOOR / V_TRIPPED
        // 1  - Input 1 -> S_DOOR / V_TRIPPED
        // 2  - temperature (HTU)
        // 3  - humidity (HTU)
        // includes
        #include "Adafruit_HTU21DF.h"
        #include <Vcc.h>
        #include <avr/wdt.h>
        // MySensors
        // MySensor
        #define SN "AA - Windows / Temperature"
        #define SV "1.1"
        #define ms_input_0      0
        #define ms_input_1      1
        #define ms_temperature  2
        #define ms_humidity     3
        // used PINs
        #define PIN_INPUT_0     2
        #define PIN_INPUT_1     3
        // Sleep
        #define SLEEP_TIME 300000   // ms => 5 min
        #define VALUE_MIN_COUNT 12  // send min every 12th measurement one value (once per hour)
        // Vcc
        #define VCC_MIN 1.9
        #define VCC_MAX 3.3
        #define BATTERY_COUNT 288   // 288 * 5 min = 1 day
        // global vars
        MyMessage msg(0,0);
        Adafruit_HTU21DF htu = Adafruit_HTU21DF();
        boolean htu_available = false;
        float htu_temperature = 1000;
        float htu_humidity = 1000;
        int batteryCnt = 0;
        int temperatureCnt = 0;
        int humidityCnt = 0;;
        Vcc vcc;
        // setup
          // PINs
          pinMode(PIN_INPUT_0, INPUT_PULLUP);
          pinMode(PIN_INPUT_1, INPUT_PULLUP);
          // HTU21
          if (htu.begin())
            htu_available = true;
        // presentation
          sendSketchInfo(SN, SV);
          // Send sensor information
          present(ms_input_0, S_DOOR);
          present(ms_input_1, S_DOOR);
          if(htu_available) {
            present(ms_temperature, S_TEMP);
            present(ms_humidity, S_HUM);
        // loop
          // enable watchdog
          wdt_enable(WDTO_8S);
          // inputs
          sendInput0();
          sendInput1();
          // check battery
          if(batteryCnt == 0)
            sendBatteryReport();
          batteryCnt++;
          if(batteryCnt > BATTERY_COUNT)
            batteryCnt = 0;
          // temperature
          if(htu_available) {
            sendTemperature();
            sendHumidity();
          // sleep
          delay(500);
          wdt_disable();
          sleep(digitalPinToInterrupt(PIN_INPUT_0), CHANGE, digitalPinToInterrupt(PIN_INPUT_1), CHANGE, SLEEP_TIME);
        // helper functions
        float rfloat(float val, unsigned int num) {
          if(num) {
            float f = 10.0 * num;
            return round(val*f)/f;
            return round(val);
        void sendTemperature() {
          wdt_reset();
          float tmp = htu.readTemperature();
          if(tmp < 900){ // check errors
            tmp = rfloat(tmp, 1);
            if((tmp != htu_temperature) || (temperatureCnt >= VALUE_MIN_COUNT)){
              htu_temperature = tmp;
              send(msg.setSensor(ms_temperature).setType(V_TEMP).set(htu_temperature,1));
              temperatureCnt = 0;
              temperatureCnt++;
        void sendHumidity() {
          wdt_reset();
          float tmp = htu.readHumidity();
            tmp = rfloat(tmp, 0);
            if((tmp != htu_humidity) || (humidityCnt >= VALUE_MIN_COUNT)){
              htu_humidity = tmp;
              send(msg.setSensor(ms_humidity).setType(V_HUM).set(htu_humidity,0));
              humidityCnt = 0;
              humidityCnt++;
        void sendBatteryReport() {
          wdt_reset();
          delay(500);
          float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
          int batteryPcnt = static_cast<int>(p);
        void sendInput0() {
          wdt_reset();
          if(digitalRead(PIN_INPUT_0) == HIGH)
            send(msg.setSensor(ms_input_0).setType(V_TRIPPED).set(0));
            send(msg.setSensor(ms_input_0).setType(V_TRIPPED).set(1));
        void sendInput1() {
          wdt_reset();
          if(digitalRead(PIN_INPUT_1) == HIGH)
            send(msg.setSensor(ms_input_1).setType(V_TRIPPED).set(0));
            send(msg.setSensor(ms_input_1).setType(V_TRIPPED).set(1));
        EfflonE
        EfflonE
        Efflon
        @JoergP ans others, I have tried versions 1.6.8 and the board definitions 1.6.11 and interrupt seems to work but in the case of using a PIR the sensor somehow seems to be triggered when going out of sleep due to time...
        J 1 Reply Last reply
        • EfflonE Efflon
          J
          J
          JoergP
          @Efflon I'm not sure what exactly you mean - do you refer to my code? In that case this is a quick and dirty try - I'll send at every pin change and at timeout the input values ...
          EfflonE 1 Reply Last reply
            My mega goes to sleep for the time specified, but it doesn't wake up when pir is triggered
            • J JoergP
              EfflonE
              EfflonE
              Efflon
              wrote on last edited by Efflon
              #22
              @JoergP Sorry, what I meant was regarding the versions you were using to get your sensor to work. I've been fighting to get interrupts to work for a day and your suggestion helped.
              Now it's just that going out of sleep triggers the PIR, then it goes for sleep and wakes up immediately and then finally goes to sleep ... gahh
              Tripped: 0
              13207 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
              13213 MCO:SLP:TPD
              13217 MCO:SLP:WUP=-1
              interrupt: -1
              Tripped: 0
              Tripped: 1
              Tripped: 1
              Tripped: 1
              Tripped: 1
              interrupt: -1
              Tripped: 1
              Tripped: 0
              Tripped: 0
              Tripped: 0
              Tripped: 0
              14024 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
              14032 MCO:SLP:TPD
              14034 MCO:SLP:WUP=1
              interrupt: 1
              Tripped: 0
              Tripped: 0
              Tripped: 0
              Tripped: 0
              Tripped: 0
              14440 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
              14446 MCO:SLP:TPD```
              • J
                J
                JoergP
                hmmmm .... I'm not so familiar with the arduino build process - I guess that Interrupt Request registers are not reset correctly, but never did that manual with Arduino
                I use following board setting
                AAnode1.name=AA sensor node (1MHz int)
                AAnode1.upload.tool=avrdude
                AAnode1.upload.protocol=arduino
                AAnode1.upload.maximum_size=32256
                AAnode1.upload.speed=9600
                AAnode1.bootloader.tool=avrdude
                AAnode1.bootloader.low_fuses=0x62
                AAnode1.bootloader.high_fuses=0xde
                AAnode1.bootloader.extended_fuses=0x07
                AAnode1.bootloader.path=optiboot_v50
                AAnode1.bootloader.unlock_bits=0x3F
                AAnode1.bootloader.lock_bits=0x2F
                AAnode1.build.mcu=atmega328p
                AAnode1.build.f_cpu=1000000L
                AAnode1.build.core=arduino
                AAnode1.build.variant=standard
                AAnode1.build.board=AVR_AANODE_1MHz
                I guess the xxx.build.xxx settings are of interest - do you use the same or do you have different?
                • J JoergP
                  EfflonE
                  EfflonE
                  Efflon
                  @JoergP Don't know. I just select "mini pro" from within Arduino IDE.
                  I'll create a new trouble shooting topic with my problem since this is going out of topic.
                  • G
                    G
                    giovaFr
                    wrote on last edited by giovaFr
                    #25
                    my 2 cents :
                    Why are you doing a sleep into setup method?
                    why not using wait method instead?
                    I understand that you'd like switch in sleep mode after a loop, but this doesnt sounds natural to do this during "initializing" step.
                    if you remove sleep from setup, do you still have your issues?
                    moreover, i've read somewhere that smartsleep methode gives messages time to be sent before sleeping (i'm not absolutly sure about this, i cannot find anymore the place where i've read that).
                    bool smartSleep(uint8_t interrupt, uint8_t mode, unsigned long ms=0)
                    @params:
                    • interrupt: Pin that should trigger the wakeup
                    • mode: RISING, FALLING, CHANGE
                    • ms: Number of milliseconds to sleep or 0 to sleep forever
                    @return: True if wake up was triggered by pin change and false means timer woke it up.
                    at last : you can wait for an aknownledge, it'll be slower but you'll be sure that message is sent before going to the next line of code...
                    i did not test it yet, but it would be something like this :
                    bool ack = true;
                    send(myMsg.set(avalue), ack );
                    if(!wait(2000,V_TEMP , mymsg.getType());)
                         Serial.println("timeout after 2 secs");
                    gohanG 1 Reply Last reply
                    • G giovaFr
                      my 2 cents :
                      @params:
                      bool ack = true;
                      @giovaFr
                      if you are referring to
                      that was straight from the example of the DHT11 sensor.
                      12.5k
