  3. Is my project possible with MySensors?
14 Posts 7 Posters 5.0k Views 4 Watching
  • pansenP
    pansenP
    pansen
    wrote on last edited by pansen
    I think it is possible. However, in your special case I would rather implement something from the scratch since you do not really need MySensors here (except maybe for signing messages and the WebGUI but you said no controller so..).
    There are nrf24 libraries floating around in the web, probably also some signing functionality I would suppose.
    For sending messages to your network, I'd just put another arduino to the RPi and use the serial port.
    So answering your questions:
    • Implement yourself, for MySensors I don't know
    • See above. MySensors has some signing capabilties afaik
    • Datasheet p24 describes the "received power detector (RPD)" which in the end is a register that can be read out.
    Hope that helps
    Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
    F 1 Reply Last reply
    • P
      P
      pjr
      @frazzle said:
      Now my questions:
      • Can send and receive messages without a controller? How would I go about that?
      • How secure is the NRF24 connection? To be clear, I don't mind anybody reading what's being sent, but I don't want someone sending commands to my stations and thus triggering the relays (it's very unlikely, but you never know :wink: )
      • Is there a way to report signal strength between the gateway and the wireless station?
      • Any other tips you can give me?
      Thanks for reading
      1. Yes you can. Take a look at serial api documentation. You need to implement "controller" software by yourself.
      2. Use signing. You can find more information from here
      3. Not really. nRF24 library support only check if signal => -64dBm or not.. see this
      4. It might be easier to use arduino as gw. See ACK functionality from documentation for resending the lost packages.
      • P pjr
        @frazzle said:
        Now my questions:
        Thanks for reading
        sundberg84S
        sundberg84S
        @pjr what comes to my mind might be hard is using batteries to run nodes with relays. The nodes needs to be awake all the time not to miss any message on/off for the relay and that consumes power.
        • pansenP pansen
          Hope that helps
          F
          F
          frazzle
          Thanks for the answers!
          @pansen said in Is my project possible with MySensors?:
          Hope that helps
          At the moment I don't really want to start something from scratch.
          @pjr said in Is my project possible with MySensors?:
          1. Thanks, I'll have a look at that. Any other information about "writing your own controller"?
          2. Well that feature isn't that important, so guess I'm fine dropping it.
          3. Why would arduino be better as a gateway?
          @sundberg84 said in Is my project possible with MySensors?:
          Power consumption shouldn't be an issue as I'll use a big 12v battery and the wireless nodes are only used for short periods (propably not longer than 5 hours)
          pansenP 1 Reply Last reply
          • F frazzle
            Hope that helps
            pansenP
            pansenP
            pansen
            @frazzle said in Is my project possible with MySensors?:
            If you connect the nrf24 via SPI it will be emulated as an ethernet gateway, and I assume it is more complicated than using a serial gateway (i.e. Arduino) which you directly send commands to, via ttyUSBx. No experience in that though, maybe it is worth to dig a bit more.
              Using an Arduino as gateway is much easier than compiling the gateway in the rpi especially for troubleshooting if you are not expert
              • tbowmoT
                tbowmoT
                tbowmo
                @frazzle
                If it's essential for your project to read out RSSI, then I suggest to use rfm69(h)w for radio, as they have an RSSI register that you can read.
                For the security, if you implement signing it will add a bit of latency in the loop, as the nodes has to exchange nonces before sending the actual data.
                RFM69 has a hardware encryption engine, so it can encrypt things on the fly (this is not the same as signing though, and can be subjectable to record / playback of transmissions)
                If you want to go with a "no hazzle" hardware solution with an external gateway, there is also the sensebender gateway.
                • tbowmoT tbowmo
                  @frazzle
                  F
                  F
                  frazzle
                  @tbowmo said in Is my project possible with MySensors?:
                  @frazzle
                  It would be more of a gimmick than really needed (signal strength within 50m and line of sight should be no issue I think). But it's nice to know that the RFM69 offers that.
                  Any information/statistics on how much signing affects RDT?
                  Encryption is definitely not needed, but preventing replay attacks is. Doesn't need to be the most sophisticated thing in the world, but it should offer a reasonable amount of protection.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @frazzle
                    Not using signing actively myself (yet), so can't help with any numbers there.. Someone else has to kick in with their experience..
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      Message exchange with and without signing would look something like this:
                      Scenario: No one require signing:
                      Sending from node to GW:
                      node->gw (message)
                      Sending from GW to node:
                      gw->node (message)
                      Scenario: GW does not require signed messages, node does:
                      node->gw (message)
                      gw->node (nonce request)
                      node->gw (nonce)
                      gw->node (signed message)
                      Scenario: GW require signed messages, node does as well:
                      node->gw (nonce request)
                      gw->node (nonce)
                      node->gw (signed message)
                      node->gw (nonce)
                      So, not counting calculation latencies, from a pure transmission point of view, a signed messages takes three times longer than a non signed message does due to handshaking.
                      • P
                        P
                        pjr
                        @Anticimex
                        Have you measured or know someone who has or can you estimate how much the communication takes time with one "relay on" command for example?
                        1ms, 10ms or 100ms?
                        AnticimexA 1 Reply Last reply
                        • P pjr
                          @Anticimex
                          1ms, 10ms or 100ms?
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @pjr
                          No. It depend on your HW and what frequency you execute with. So it will be quite specific to the setup, and that vary a lot between users.
                          • F
                            F
                            frazzle
                            I'm rethinking my network layout right now and I was thinking if I could use an ESP8266 in AP mdoe (running a websocket server like: https://github.com/Links2004/arduinoWebSockets) as a serial gateway?
                            The description of the example code on the "Building a serial gateway" page says:
                            So could I just use Serial.write() to push my commands the esp8266 received from my smartphone on the websocket connection to serial, which will then be sent out to the nodes via radio?
                            In the other direction I would need to read data from the serial and push it to the smartphone via the websocket connection.
                            I was also thinking to just connect my phone to the gateway via usb and then make an app that sends commands to the gateway over serial, but a wireless connection would be so much nicer.
                            I'm probably gonna order some nrf24 module and some more arduinos on the weekend so I can tinker a bit with them as I'm new to radio stuff.
