  3. CAN bus transport implementation for MYS
35 Posts 12 Posters 16.8k Views 16 Watching
  • N
    N
    napo7
    wrote on last edited by napo7
    I agree with @kimot : the RS485 bus is not designed to have many masters on the same bus.
    So, when you want to use RS485, you have 2 choices :
    • The master polls the slaves to ask them if they have something to say (you give them the "right" to talk)
    • Each device tries to talk when needed, with the risk of collision, and the message could not be correctly transmitted.
    Using a MCP2551 driver (without a MCP2515 controller) allows to use the benefits of CAN bus : If 2 masters talk at the same time, one of them will "see" that one of the bit he tried to push on the bus has been overwritten by another one, and will have to try again a few times later. This is not collision avoidance, but collision detection.
    Of course, since we use only a CAN driver and not a controller, we must do the checks via software (listen to what is being heard as we're talking).
    I have some arduinos laying around, and some MCP2551. I must do some tests.
      in case, this is also an interesting note about CAN, for 3.3v transceivers, http://www.ti.com/lit/an/slla337/slla337.pdf
      esp32 has a CAN controller, so it will just need the transceiver i think (I'm waiting their lib release). geek sidenote :)
      Keep the good work, I also think CAN bus is very reliable compared to halfduplex rs485.
      • N
        N
        napo7
        Yes, this device is interresting.
        None the less, we're thinking of using only a CAN driver without controller, in a kind of RS485 bus...
        This way, we make an hybride bus : simplicity of RS485, with multi-master possibilities of CAN thanks to the way his driver works !
        So, having a CAN controller on ESP32 is ( from my point of view) not-so-much usefull.
        • H hausinger
          @kimot
          thank you for your answers in this case.
          You think, the SN65HVD230 is better than the max485? Can I use the SN65HVD230 with mysensors and Transport class rs485 without changes in the code? If yes, how do I do with the "DE-Pin" ?
          I don't know, why you are using 3 Bus Systems at your home? Why not 1 Stable Bus?
          I want a stable bus for several things in my new home. PIR, Standard button Switch, Contacts (Window, Smoke), Dimmers, RGB Dimmers, Temperaturesensors, Relays should be my nodes. The Problem in this case is, that I want to use my nodes even when the bus have Errors.
          So if you seperate the communication from sensors to Gateway (with your self made library, as you wrote here) and the Gateway communication with the Controller with the mysensors libs, that would be excactly what I'm locking for.
          My idea besides of that is, that nodes can work without the bus. For examble the push button Switch can Switch the light, even when the bus is down. With mysensors this is not possible, because nodes have to register to the Gateway. Mysensors should be a "add on" for the nodes in my home, to control all on one place - openhab.
          I also want to have a stable bus, because it would be very bad, when i press a push button and nothing happens (=is dark in the room), because the bus is busy. Sure it doesn't matter if a temp sensor can't transmit it's value to the Controller. But for Switch / PIR it is very important.
          N
          N
          napo7
          The only way to handle this kind of problem, is to make device with INPUT and OUTPUT at the same time !
          You would then have to think of an intelligent way of handling what happens when the INPUT see events :
          Do you have to transmit it to the gateway, wait for a reply, and then fall back to a "fail" mode if the gateway doesn't reply after a delay ?
          Do you prefer handling the event simply by turning ON/OFF the output, and just inform the gateway of what happening ? this way, even if the bus is down, your device will continue to work... but you're loosing the benefits of having an intelligent controller/gateway that can make decisions...
          H 1 Reply Last reply
          • P
            P
            pjr
            @kimot Would it be hard to write CANbus version of the transport class based on rs485 implementation? Is there some extra things you need to handle on top of "basic serial communication"?
            N 1 Reply Last reply
            • N napo7
              H
              H
              hausinger
              @napo7
              Hi @napo7
              Yes, i would prefer handling it direct on the nodes. Not only ON/OFF, also dimmer (1 short press on the push button - Light on (last value) + turn on power supply of the lamps (Relais=1), 1 short press on the push button - light off + turn power supply off of the lamps (Relais=0), 1 Long press on the bush putton - dimming). The Gateway (and Controller) should be able to do the same Thing, if the bus is ok. But if it fials, i could use it localy and so i'm not in a dark room.
              • P pjr
                N
                N
                napo7
                @pjr
                If we want to use CAN drivers instead of RS485 drivers, we don't have to add anything to the code.
                We will benefit of CAN drivers capabilities, but we still have to write some code to handle collisions.
                If we want to use a CAN CONTROLLER, yes, there is more to do :we must setup the CAN controller each time the board start-up : this is needed to tell the CAN controller on which kind of message we must listen to, what is our ID (CAN controller do all the filtering job...), etc...
                • P
                  P
                  pjr
                  wrote on last edited by pjr
                  @napo7 and if we use CAN CONTROLLER it does all the needed collision avoiding, detection and "resending" and it dont need to be written in the transport class? Only the initalization of the CAN CONTROLLER needs to be added?
                  Is there much difference in communication reliability if we use CAN DRIVER vs. RS485 DRIVER currently without modifying the rs485 transport class?
                  • N
                    N
                    napo7
                    Yes, the CAN controller handles all this stuff (collision detection and resending...)
                    So, yes, only CAN initialization has to be added.
                    In facts, NO, without adding code, there will be no difference between between the two drivers. I haven't looked at the class, but if we use a CAN driver, the goal is to use its advantages to "allow" collisions and handle them better.
                    • G
                      G
                      gonzalonal
                      Hi everyone. Have there been any developments regarding CAN Bus Controller integration to MySensors Library?
                      K 1 Reply Last reply
                      • G gonzalonal
                        K
                        K
                        kimot
                        wrote on last edited by kimot
                        @gonzalonal
                        Yes I am.
                        But I have got a lot of other works, so It's going slowly.
                        The problem is, that CAN can transfer only 29 bits ID ( 3 bytes + 5 bits ) and max. 8 bytes of data.
                        MySensors message has got max. 32 bytes ( 7 bytes header and 25 bytes of data ).
                        I must either send MySensors message like 3 packets of CAN messages or limit properties of MySensors protocol.
                        Now I am working on second variant.
                        I am able code to one CAN message:
                        6 bits - destination
                        6 bis - sender
                        (gateway, broadcast, 62 nodes - it is enough for me for one bus. I plane three buses and gateway can " translate " or "expand" nodes ID from and to controller )
                        1 bit - RACK
                        1 bit - IS ACK
                        3 bits - command
                        6 bits - type ( MY sensors has 56 types max. now )
                        6 bits - sensor id ( only 64 sensors per node ... )
                        3 bits - payload type ( int, uint, long .... )
                        The sum of these is not 29, but 32 so I am using a little "hacking" data length field in CAN frame to obtain additional 3 bits.
                        For data I have got 8 bytes.
                        It is enough for conventional data types from char to floating point.
                        Only text messages are limited to 8 bytes. But for us, old boys, who remember old DOS file names, it is enough.
                        In this time, I am able send and receive packets in that format between nodes and now I am working on transfer RS485 library to CAN library.
                        The problem is, that RS485 library sends destination address, node id, length of message and then MySensors message, witch "surprisingly" contain again destination and sender bytes. A little bit redundant for me.
                        So I must remove some fields from MySensors message, put it to CAN ID and send only payload in CAN data fields.
                        When I receive CAN message, I must again assemble correct MySensors message format and put it to MySensors system.
                        But unfortunately only documentation is library code itself :o(
                        I try a "stress test" like here:
                        https://forum.mysensors.org/topic/5051/rs485-stress-test
                        I send 10 000 messages from two nodes to "gateway" ( 22kbps ).
                        Result - zero messages lost.
                        But it is expectable with CAN.
                        • P
                          P
                          pjr
                          @kimot what hw you are using? MCP2515 + MCP2551?
                          • P pjr
                            K
                            K
                            kimot
                            @pjr
                            This module.
                            http://www.ebay.com/itm/Arduino-MCP2515-CAN-Bus-Module-TJA1050-Receiver-SPI-Module-/311520457612?hash=item488810f38c:g:g8MAAOSwu4BVzbWC
                              A Former User
                              I'm really interested in the solution you are working on (can bus with mysensors). I would like as much as possible to avoid a wireless network but I still would like to use the "mysensors" libraries and protocol. As this project as a lot of users it's a warranty of longevity.
                              @kimot : your trials seems great, did you have the change of getting further?
                              • ? A Former User
                                K
                                K
                                kimot
                                @gasuter
                                I think I am able sending data from node to gateway (GW) and through it to controller.
                                There is limited data space in CAN message, so I must avoid sending long strings and send all as possible like integers, longs, floats etc. It is not problem when sending from node to GW, because in the message header is field, which describes type of payload and according GW code, I assume, it can translate it to strings for controller correctly.
                                But problem is, when GW receives data from controller. Payload is always string and I must convert it to int, long, float and sometimes short string for sending it through CAN bus to the node. But from serial protocol GW can not recognize, what type of this payload is. I think I need to built some translation table for each serial protocol TYPE to variable type.
                                But maybe each controller sends different type of data for the same sensor value (0, 1 x "on", "off" ).
                                Or better something "smart" like "when there is a dot and not letter in string, it is float", "if there are only numbers, it is int or long" ....
                                • wallyllamaW
                                  wallyllamaW
                                  wallyllama
                                  Sorry to hijack a bit, but j1708 looks like it can do bit level collision detection with a max485, it means controlling the DE line. More work than CANBus?
                                  • wallyllamaW wallyllama
                                    K
                                    K
                                    kimot
                                    #23
                                    @wallyllama
                                    I look at j1708 spec. and I think, that this protocol was born long before CAN.
                                    It uses MAX485 bus drivers that way, that CAN bus drivers can works at higher speeds and better now.
                                    And I must say, I can see better multimaster implementation for RS485 bus than j1708 ( clever addressing, bus arbitration, CRC instead of simple SUM etc. ) And there is AVR libraries so you do not start from scratch. For J1708 I can not find any.
                                      A friend of mine who works a lot with can bus told me that j1939 supports multi pack when bigger payloads are needed
                                        K
                                        K
                                        kimot
                                        #25
                                        @gohan
                                        Thanks for your message.
                                        All CAN controllers can send max 8 bytes of data, so longer messages must be divided to multiple packets. J1939 works this way too. That is what I do not want. With heavy traffic especially GW must again assemble packets to complete message, but packet of one message will not come one by one. Packets will be coming mixed from different nodes and GW must assemble them in memory to complete message from each node. So you for example has 30 messages in different state of completion. Some of them has received 1 packet and waiting for 2nd , some has 2nd and waiting for 3rd. ....
                                        I am concerned that it does not work for ATmega328, and must be used processor with more RAM.
                                        D 1 Reply Last reply
                                          I understand your concerns, but can bus is made more for industrial purposes. Maybe you need to find a more powerful replacement for the ATmega328
