  3. CAN bus transport implementation for MYS
35 Posts 12 Posters 16.8k Views 16 Watching
  • N napo7
    @hausinger said:
    My idea besides of that is, that nodes can work without the bus. For examble the push button Switch can Switch the light, even when the bus is down. With mysensors this is not possible, because nodes have to register to the Gateway. Mysensors should be a "add on" for the nodes in my home, to control all on one place - openhab.
    The only way to handle this kind of problem, is to make device with INPUT and OUTPUT at the same time !
    You would then have to think of an intelligent way of handling what happens when the INPUT see events :
    Do you have to transmit it to the gateway, wait for a reply, and then fall back to a "fail" mode if the gateway doesn't reply after a delay ?
    Do you prefer handling the event simply by turning ON/OFF the output, and just inform the gateway of what happening ? this way, even if the bus is down, your device will continue to work... but you're loosing the benefits of having an intelligent controller/gateway that can make decisions...
    H
    H
    hausinger
    @napo7
    Hi @napo7
    Yes, i would prefer handling it direct on the nodes. Not only ON/OFF, also dimmer (1 short press on the push button - Light on (last value) + turn on power supply of the lamps (Relais=1), 1 short press on the push button - light off + turn power supply off of the lamps (Relais=0), 1 Long press on the bush putton - dimming). The Gateway (and Controller) should be able to do the same Thing, if the bus is ok. But if it fials, i could use it localy and so i'm not in a dark room.
    • P pjr
      @kimot Would it be hard to write CANbus version of the transport class based on rs485 implementation? Is there some extra things you need to handle on top of "basic serial communication"?
      N
      N
      napo7
      @pjr
      If we want to use CAN drivers instead of RS485 drivers, we don't have to add anything to the code.
      We will benefit of CAN drivers capabilities, but we still have to write some code to handle collisions.
      If we want to use a CAN CONTROLLER, yes, there is more to do :we must setup the CAN controller each time the board start-up : this is needed to tell the CAN controller on which kind of message we must listen to, what is our ID (CAN controller do all the filtering job...), etc...
      • P
        P
        pjr
        wrote on last edited by pjr
        @napo7 and if we use CAN CONTROLLER it does all the needed collision avoiding, detection and "resending" and it dont need to be written in the transport class? Only the initalization of the CAN CONTROLLER needs to be added?
        Is there much difference in communication reliability if we use CAN DRIVER vs. RS485 DRIVER currently without modifying the rs485 transport class?
        • N
          N
          napo7
          Yes, the CAN controller handles all this stuff (collision detection and resending...)
          So, yes, only CAN initialization has to be added.
          In facts, NO, without adding code, there will be no difference between between the two drivers. I haven't looked at the class, but if we use a CAN driver, the goal is to use its advantages to "allow" collisions and handle them better.
          • G
            G
            gonzalonal
            Hi everyone. Have there been any developments regarding CAN Bus Controller integration to MySensors Library?
            K 1 Reply Last reply
            • G gonzalonal
              K
              K
              kimot
              wrote on last edited by kimot
              @gonzalonal
              Yes I am.
              But I have got a lot of other works, so It's going slowly.
              The problem is, that CAN can transfer only 29 bits ID ( 3 bytes + 5 bits ) and max. 8 bytes of data.
              MySensors message has got max. 32 bytes ( 7 bytes header and 25 bytes of data ).
              I must either send MySensors message like 3 packets of CAN messages or limit properties of MySensors protocol.
              Now I am working on second variant.
              I am able code to one CAN message:
              6 bits - destination
              6 bis - sender
              (gateway, broadcast, 62 nodes - it is enough for me for one bus. I plane three buses and gateway can " translate " or "expand" nodes ID from and to controller )
              1 bit - RACK
              1 bit - IS ACK
              3 bits - command
              6 bits - type ( MY sensors has 56 types max. now )
              6 bits - sensor id ( only 64 sensors per node ... )
              3 bits - payload type ( int, uint, long .... )
              The sum of these is not 29, but 32 so I am using a little "hacking" data length field in CAN frame to obtain additional 3 bits.
              For data I have got 8 bytes.
              It is enough for conventional data types from char to floating point.
              Only text messages are limited to 8 bytes. But for us, old boys, who remember old DOS file names, it is enough.
              In this time, I am able send and receive packets in that format between nodes and now I am working on transfer RS485 library to CAN library.
              The problem is, that RS485 library sends destination address, node id, length of message and then MySensors message, witch "surprisingly" contain again destination and sender bytes. A little bit redundant for me.
              So I must remove some fields from MySensors message, put it to CAN ID and send only payload in CAN data fields.
              When I receive CAN message, I must again assemble correct MySensors message format and put it to MySensors system.
              But unfortunately only documentation is library code itself :o(
              I try a "stress test" like here:
              https://forum.mysensors.org/topic/5051/rs485-stress-test
              I send 10 000 messages from two nodes to "gateway" ( 22kbps ).
              Result - zero messages lost.
              But it is expectable with CAN.
              • P
                P
                pjr
                @kimot what hw you are using? MCP2515 + MCP2551?
                • P pjr
                  K
                  K
                  kimot
                  @pjr
                  This module.
                  http://www.ebay.com/itm/Arduino-MCP2515-CAN-Bus-Module-TJA1050-Receiver-SPI-Module-/311520457612?hash=item488810f38c:g:g8MAAOSwu4BVzbWC
                    A Former User
                    I'm really interested in the solution you are working on (can bus with mysensors). I would like as much as possible to avoid a wireless network but I still would like to use the "mysensors" libraries and protocol. As this project as a lot of users it's a warranty of longevity.
                    @kimot : your trials seems great, did you have the change of getting further?
                    • ? A Former User
                      K
                      K
                      kimot
                      @gasuter
                      I think I am able sending data from node to gateway (GW) and through it to controller.
                      There is limited data space in CAN message, so I must avoid sending long strings and send all as possible like integers, longs, floats etc. It is not problem when sending from node to GW, because in the message header is field, which describes type of payload and according GW code, I assume, it can translate it to strings for controller correctly.
                      But problem is, when GW receives data from controller. Payload is always string and I must convert it to int, long, float and sometimes short string for sending it through CAN bus to the node. But from serial protocol GW can not recognize, what type of this payload is. I think I need to built some translation table for each serial protocol TYPE to variable type.
                      But maybe each controller sends different type of data for the same sensor value (0, 1 x "on", "off" ).
                      Or better something "smart" like "when there is a dot and not letter in string, it is float", "if there are only numbers, it is int or long" ....
                      • wallyllamaW
                        wallyllamaW
                        wallyllama
                        Sorry to hijack a bit, but j1708 looks like it can do bit level collision detection with a max485, it means controlling the DE line. More work than CANBus?
                        • wallyllamaW wallyllama
                          K
                          K
                          kimot
                          #23
                          @wallyllama
                          I look at j1708 spec. and I think, that this protocol was born long before CAN.
                          It uses MAX485 bus drivers that way, that CAN bus drivers can works at higher speeds and better now.
                          And I must say, I can see better multimaster implementation for RS485 bus than j1708 ( clever addressing, bus arbitration, CRC instead of simple SUM etc. ) And there is AVR libraries so you do not start from scratch. For J1708 I can not find any.
                            A friend of mine who works a lot with can bus told me that j1939 supports multi pack when bigger payloads are needed
                              K
                              K
                              kimot
                              #25
                              @gohan
                              Thanks for your message.
                              All CAN controllers can send max 8 bytes of data, so longer messages must be divided to multiple packets. J1939 works this way too. That is what I do not want. With heavy traffic especially GW must again assemble packets to complete message, but packet of one message will not come one by one. Packets will be coming mixed from different nodes and GW must assemble them in memory to complete message from each node. So you for example has 30 messages in different state of completion. Some of them has received 1 packet and waiting for 2nd , some has 2nd and waiting for 3rd. ....
                              I am concerned that it does not work for ATmega328, and must be used processor with more RAM.
                              D 1 Reply Last reply
                                I understand your concerns, but can bus is made more for industrial purposes. Maybe you need to find a more powerful replacement for the ATmega328
                                  A Former User
                                  @kimot Thank you very much for your reply. It's sounds great and more I read about bus for IOT more I think Can is the best solution. But still the problem with the data length bother me. The more hack and tricks we have to add to a system the more problem we can have.
                                  I made a little research on internet about Can and found that there is a new version called CAN FD that is actually compatible with CAN 2 but it can be used at a higher speed between to CAN FD nodes (but that is not really interesting us for our use). The real plus is that you can send data up to 64 bytes. And I think that could be the solution of the problem, no?
                                  http://www.microchip.com/wwwproducts/en/MCP2561FD
                                    Agricultural vehicles now use ISOBUS (extension of j1939) that can send icons and images to the displays. Maybe you can take a look at it
                                    • ? A Former User
                                      K
                                      K
                                      kimot
                                      #29
                                      @gasuter
                                      CAN FD looks good, until you start to looking for IO chips.
                                      MCP2561FD is only CAN bus transceiver ( like MAX485 ) with higher speed ability, then traditional CAN bus drivers.
                                      It has no logic "on board".
                                      You need something like MCP2517.
                                      But try find datasheet, prices etc. for this chip.
                                      I think, it will be very expensive way for us, like standard CAN several years ago was.
                                      Nca78N 1 Reply Last reply
                                        Better performance usually means more expensive 😁. Maybe for the moment we just need to find a good way to make rs485 perform a little better
                                        wallyllamaW 1 Reply Last reply
                                          wallyllamaW
                                          wallyllamaW
                                          wallyllama
                                          @gohan this is exactly why i brought up j1708, it is a hardware spec(can be any software on top), that uses max485 chips, you drive the de line instead of tx and it allows you to "see" collisions on the line. It would need a layer that does retransmits, but i dont see why the mysensors rs485 code clouldnt ride on top of that. There is an id that is utransmitted first that all nodes have to watch for which is duplicated efforst as the mysensors layer has that.
                                          I see it like this pseudo code:
                                          All nodes listen for an id,
                                          if none, then start transmitting,
                                          watching for dominant bits in between bits that hint someone else is transmitting, if collision back off for random time.
                                          if no collision transmit full message as normal mysensors message
                                          Other nodes must listen until message ends then they can start a transmit after random interval.
                                          The secret is really in tying tx (it looks like) low and control de, re is enables always so you can see other bits. Once a node has the bus, everyone shuts up until it is done. You only decides "who has the floor" and how to know when they relinquish it.
                                          J1708 is 9600 baud, which may be ok, but ill bet it would work at higher speeds.
