  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • F
    F
    Fabien
    Ok :
    sudo apt-get --purge remove modemmanager
    • tbowmoT tbowmo
      @MLs
      have you installed the mysensors board files? And chosen the Sensebender Gateway as target platform?
      (Seems that you are using Arduino/Genuino Zero as target?)
      MLs
      wrote on last edited by MLs
      #145
      @tbowmo
      Hi i get same error whit Sensebender Ga
      Arduino:1.8.0 (Windows 10), Kort:"Sensebender Gateway"
      Sketch uses 46720 bytes (17%) of program storage space. Maximum is 262144 bytes.
      No device found on COM4
      Invalid version found: 1.04
      option enabled in File -> Preferences.```
      But serial monitor works fine with COM4
      //Mattias
      D 1 Reply Last reply
      • M MLs
        @tbowmo
        //Mattias
        Disca
        @MLs In Device Manager what com port is assigned to the sensebender GW? Have you manually installed the inf file?
        com4 is likely the last com port you used in the arduino interface not the one assigned to the GW.
        • D Disca
          MLs
          #147
          @Disca
          No, I have not installed or selected com port.
          Device Manager COM4
          As I understood it so Windows 10 would fix everything, right?
          //Mattias
          • F
            F
            Fabien
            @tbowmo : It's better for seeing debug from start.
            But there is 2 bugs :
            • When you want to upload sketch. /dev/ttyACM0 disapear (and D4 goes off) afterunplu/plug it works for uploading sketch (D4 off) but at the end of uplaod ArduinoIDE makes a soft reset and /dev/ttyACM0 disapear. Works fine after plus/unplug (D4 ON)
            • When pressing reset /dev/ttyACM0 disapear (and D4 goes off). Works fine after plug/unplug
            • M MLs
              @Disca
              Device Manager COM4
              //Mattias
              Disca
              @MLs mmm not sure then, it works for me on Windows 7 with 1.8.1 (slightly newer version?)
              • tbowmoT
                tbowmoT
                tbowmo
                @MLs
                I don't have windows installed, so I'm sorry that I can't help with windows specifics.
                • tbowmoT tbowmo
                  @MLs
                  MLs
                  @tbowmo
                  Now, I think it feels like hardware failure more than software errors. Will try tomorrow on my second computer with Windows 7 and see if there is any difference.
                  //Mattias
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Fabien
                    I added a couple of udev rules, to stop modemmanager take control over the device
                    ACTION!="add|change|move", GOTO="local_usb_device_blacklist_end"
                    SUBSYSTEM!="usb", GOTO="local_usb_device_blacklist_end"
                    ENV{DEVTYPE}!="usb_device",  GOTO="local_usb_device_blacklist_end"
                    ATTRS{idVendor}=="1209", ENV{ID_MM_DEVICE_IGNORE}="1"
                    LABEL="local_usb_device_blacklist_end"
                    Add the above to this file /etc/udev/rules.d/mysensors.rules
                    As the USB is native in the arm processor, then it will re-enumerate on the USB port whenever a reset condition occurs. When you press the reset button it will act as a unplug / plug operation (you can see this in dmesg)
                    When uploading to the gateway, it will reset itself to enter bootloader.. The bootloader will have another VID/PID combo (VID:1209, PID:6448) than during normal operation (VID:1209, PID:6449).
                    I have never seen the problems that you are having, where you need to fysically unplug / plug the device, after you have pressed the reset button (or uploaded a new firmware). And I have uploaded firmware (and pressed the reset button) quite some times :)
                    Also please note, that if you double tap the reset button, the gateway will enter bootloader mode, and wait for a new sketch to be sent.
                    • F
                      F
                      Fabien
                      @tbowmo : Same with udev rules (but this file is not necessary because modemmanger is not installed).
                      I try to power SBGW with usb, D4 goes ON. After pressing reset, D4 goes OFF and never goes on (I must unplug/plu usb power). Do you have the same with your board ? Perhaps a problem with bootloader ?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #154
                        @Fabien
                        D4 is the yellow LED, and the only place it is used is in the onboard selftest routine.
                        In my setup, D5 turns on when plugging in the device. If I hit reset one time, it momentarily switches off D5, and then back on. if I hit reset twice, it stays off (bootloader is activated)
                        The above is done on my RFM69 debug gateway, so the sketch is for RFM69, but otherwise a standard SensebenderGatewaySerial sketch
                        Have you checked dmesg, when plugging in, and when hitting the reset button?
                        Have you tried with another USB cable? Have you tried with another computer?
                        • F
                          F
                          Fabien
                          I try with 2 different USB cable and 2 computer (1 laptop and 1 desktop). Same problem. With a charger too. And sorry for the mistake, it's D5 (orange)
                          On log
                          [ 4788.031324] usb 1-8: USB disconnect, device number 6
                          • F
                            F
                            Fabien
                            Thank you @scalz !
                            You must have a very well calibrated printer to print it correctly. First try fails (oozing due to overtemp)
                            Other side tomorrow !
                            • D Disca
                              MLs
                              @Disca
                              Where did you find the drivers for sensebender GW for Windows 7?
                              //Mattias
                              tbowmoT 1 Reply Last reply
                              • M MLs
                                @Disca
                                //Mattias
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @MLs
                                Check the product page on mysensors.org
                                https://www.mysensors.org/hardware/sensebender-gateway
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Fabien
                                  D5 is used by arduino to signal USB serial rx/TX activity.
                                  Can you post the log lines from dmesg, from when you insert the usb cable, to after you have pressed the reset button?
                                  • tbowmoT tbowmo
                                    @MLs
                                    MLs
                                    @tbowmo
                                    I tried to update the drivers in Device Manager / sense bender GW but it failed to install the computer said.
                                    Therefore, I asked one who wrote that he was using Windows 7
                                    //Mattias
                                      #161
                                      @MLs
                                      I'm also still using win7 x64 for my dev and that worked for me.
                                      Auto install through the Device Manager does not work, nor right-clicking and installing the .inf through Explorer.
                                      You have to force the install and select the location of the .inf in Device Manager. Then it will ask you if you agree about the driver supplier. Of course you're! And you should be able to see it in Device Manager.
                                      • D
                                        Dany
                                        There are example program for W5100? The original GatewayW5100 program uses SOFTSPI, different NRF CE/CSN pins? Will work with this hardware properly?
                                        • scalzS scalz
                                          @MLs
                                          MLs
                                          @scalz
                                          Heh've tried both in the device manager and manually. Device Manager, I get an error message.
                                          And manually, nothing happens.
                                          //Mattias
