  3. How to build raspberry gw 2.0.0
12 Posts 4 Posters 3.4k Views 3 Watching
    @Huczas the raspberry pi gateway was developed after 2.0 was released, that's why it doesn't exist in 2.0.
    You should not need to change anything in your sketches when upgrading from 2.0 to 2.1.1. Just upgrade the MySensors library and re-upload your sketches. The only exception I am aware of is that sketches using getConfig need to be changed to use getControllerConfig instead but that is easy to fix and is only needed if you get the error described in these threads:
    https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/2
    https://forum.mysensors.org/topic/5865/could-use-a-bid-help-to-get-started/15
    https://forum.mysensors.org/topic/4807/atmospheric-pressure-sensor/12
    HuczasH
    HuczasH
    Huczas
    @mfalkvidd libraries in Arduino IDE updatet to 2.1.1 sketch uploaded - no errors.
    in RPi3, latest version of gateway installed and when all is up I get this:
    mysgw: Starting gateway...
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=3
    mysgw: TSM:FAIL:PDT
    ^Cmysgw: Received SIGINT
    Do you have any guess on it? For me it looks like nothing is transmitting from node.
    My node code: http://pastebin.com/LCjF5Cm1 maybe something is wrong with that code.
    • HuczasH Huczas
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:PDT
      @Huczas the code used for the node should not affect the gateway's ability to initialize the radio. In case you haven't seen it, information on the log messages is available at https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details
      I don't know what could be wrong though. Have no experience with the raspberry pi gateway.
      HuczasH 1 Reply Last reply
        HuczasH
        HuczasH
        Huczas
        @mfalkvidd another thing, after changing version of gateway from 1.4 to 2.1.1:
        0_1486205151792_upload-3da97f77-7b96-4c77-a732-c2f831650525
        • pansenP
          pansenP
          pansen
          What's your ./configure command? Can you post a picture/photo of your wiring?
          Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
          • pansenP pansen
            HuczasH
            HuczasH
            Huczas
            @pansen
            ./configure --my-gateway=serial --my-serial-port=/dev/ttyAMA0 --my-serial-baudrate=115200 --my-transport=nrf24 --my-rf24-irq-pin=15
            Wiring was ok, and was working fine witch gw1.4 so - there is all ok, soldered well.
            0_1486372015325_upload-ed13d19f-5a9c-4daa-853b-08b80fe745d4
            Yesterday I connected gw2.1.1 on arduino uno - blue usb wire - it is working now, nodes are visible in my system, data is comming. If there well be no luck i will live in that way. It's just another thing behinde my speaker.
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              I think you need to configure a virtual serial port.
              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
              If the serial gateway doesn't work for you, you can try and configure the ethernet gateway. Is there a reason you want to use the serial gateway?
                HuczasH
                HuczasH
                Huczas
                @martinhjelmare don't know difference. Just have node using nrf24 and any configuration that will work would be ok for me.
                • pansenP
                  pansenP
                  pansen
                  wrote on last edited by pansen
                  For ethernet gateway listening on 0.0.0.0 (i.e. on all interfaces) and port 5003 you can try:
                  ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=13 --my-rf24-cs-pin=14
                  Check for
                  • Check for existance of spidev0.0 and replace if necessary
                  • Also check the pin numbers, CE has to be physical pin 8, CN has to be physical pin 10.
                  Also you need the latest dev version from git as far as I know.
                  For more info check my comment here: https://www.mysensors.org/build/orange
                  @martinhjelmare: whats the difference between the virtual one and the "real" one?
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Since everything is connected to the RPi and I guess you also run the controller on the same RPi, you don't need any extra hardware, it's just a matter of how you configure the software to interface.
                    If you configure a serial gateway, you configure your controller to connect to the virtual serial port. If you configure an ethernet gateway, you configure your controller to connect to a tcp socket on the correct port on localhost. Of course it depends on the controller what connection options are available.
                    • pansenP pansen
                      Check for
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @pansen
                      This is more a guess, but I think the real one (GPIO) is only for the interface between radio and serial gateway program. The virtual is for the interface between serial gateway program and controller. Serial interfaces are exclusive to one program at a time. Someone should verify what I just said though.
