  3. Domoticz
  4. Serial Gateway connect problem ttyAMA0
11 Posts 4 Posters 7.5k Views 3 Watching
  • bjacobseB
    bjacobseB
    bjacobse
    how many different USB devices do you have connected to your RPI2?
    Mine using RPI3 is connected to dev/ttyUSB0
    what happens when you type in a command prompt dmesg | grep tty?
     dmesg |grep tty
    [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x206ad9b smsc95xx.macaddr=B8:27:EB:06:AD:9B bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.001343] console [tty1] enabled
    [    1.893707] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
    [   21.511692] systemd[1]: Cannot add dependency job for unit getty-static.service, ignoring: Unit getty-static.service failed to load: No such file or directory.
    [   21.769044] systemd[1]: Starting system-getty.slice.
    [   21.775173] systemd[1]: Created slice system-getty.slice.
    [   33.592862] usb 1-1.4: cp210x converter now attached to ttyUSB1
    [   33.603346] usb 1-1.3: ch341-uart converter now attached to ttyUSB0
    You find something like this:
    • lrtsenarL
      lrtsenarL
      lrtsenar
      wrote on last edited by lrtsenar
      This :
      0_1486332218660_upload-dc9673dc-b693-48f4-871c-5fbca09aa933
      But I'm not using USB to serial converter, I'm only using native serial GPIO Tx/Rx pins like I said in my 1st post.
      K bjacobseB 2 Replies Last reply
      • lrtsenarL lrtsenar
        Hi all,
        Using Mysensors 2.11, latest version of Domoticz (3.58.77), Arduino pro mini 5V directly connected to RPI2 through Tx/Rx connection (having carefully made a voltage divider for 3.3 V Rx on RPI2), have compiled SerialGateway with following parameters :
        0_1486163187143_upload-a7d023e6-ec73-428a-9a00-0936a051df99
        No connection to Serial Gateway (even after waiting for hours ) :
        0_1486163349709_upload-81bdad53-aa16-4e69-9907-b07e369c64dc
        So I tried to lock the ttyAMA0 in order to see if Domoticz is really tries to connect to ttyAMA0, so have locked ttyAMA0 :
        0_1486163122930_upload-3121397d-a0a6-4c8b-a944-573e869ad493
        And Domoticz is happy with this (as after a restart of Dmz service) !
        0_1486163299460_upload-c5703d3c-8d71-4a9e-9775-39c8b9f6e452
        No error seen...
        I suspect Domoticz doesn't try to connect to ttyAMA0. I already fully disabled the serial boot ability and log on ttyAMA0 in RPI (systemctrl diasble,sudo systemctl stop getty.target, /boot/cmdline.txt does'nt contain any ttyAMA0 reference, disable serial-getty@ttyAMA0.service, ...)
        The same hardware is fully functional with my old SD Card (Rasbian/Mysensors installed 1 year ago) !
        Is anybody knows what's wrong
        K
        K
        kimot
        @lrtsenar
        By default ttyAMA0 is configured like system console for Linux on Raspberry.
        Do you disable it?
        http://www.instructables.com/id/Read-and-write-from-serial-port-with-Raspberry-Pi/
          This :
          K
          K
          kimot
          @lrtsenar
          console [ttyAMA0] enabled
          I think, that this is issue.....
          It is used by system.
          lrtsenarL 1 Reply Last reply
          • K kimot
            @lrtsenar
            lrtsenarL
            lrtsenarL
            lrtsenar
            @kimot
            After folowing your link, dmesg displays :
            0_1486335983940_upload-d22dbac5-5ecd-4d50-9b44-ee70b7d64dd1
            And :
            0_1486336890405_upload-4226c005-294c-4c8d-9de7-27e26a6467bb
            Now, sems console uses only tty1 but problem persists :-(
            • lrtsenarL
              lrtsenarL
              lrtsenar
                This :
                bjacobseB
                bjacobseB
                bjacobse
                @lrtsenar But I'm not using USB to serial converter, I'm only using native serial GPIO Tx/Rx pins like I said in my 1st post.
                I overlooked this info
                • pansenP
                  pansenP
                  pansen
                  Maybe it's a rights problem, can you sudo minicom it? Your domoticz user should be added to the group allowing access to ttys. For me it's group uucp.
                  Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                  K 1 Reply Last reply
                  • pansenP pansen
                    K
                    K
                    kimot
                    @pansen
                    I Think, that it is "dialout" group.
                    Or try start Domoticz: sudo ./domoticz
                    But I found informations, that handle of "tty"s depends on Rapsbian version too.
                    "Because OS version jessie has changed to using systemd, the file /etc/initab no longer exists. You must use the systemd command systemctl to stop getty.target that is attached to /dev/ttyAMA0
                    pi@raspberrypi:~ $ sudo systemctl stop getty.target
                    NOTE: This will release ttyAMA0 until you reboot/restart the raspberry pi. After you reboot you will have to give the command again."
                    And for the best - on RPI3 ttyAMA0 is connected to Bluetooth and gpio is ttyS0 and is software emulated.
                    • bjacobseB
                      bjacobseB
                      bjacobse
                      Did you try to this?
                      sudo nano /boot/config.txt
                      Add to the end:
                      enable_uart=1
                      sudo nano /boot/cmdline.txt
                      Remove everything and add this:
                      dwc_otg.lpm_enable=0 console=tty1 elevator=deadline net.ifnames=0 root=/dev/mmcblk0p2 rootfsty
                      Taken from here:
                      https://community.openhab.org/t/has-anyone-gotten-razberry-working-with-openhab-2/12539/11
