  3. How to connect two devices to the same pins?
3 Posts 2 Posters 1.3k Views 1 Watching
  • I Offline
    I Offline
    infinity101
    Hi all!
    So today I received my Arduino toys from China, together with two Arduino Nanos, two NRF24L01 and an ethernet shield.
    Soooo, I've run into a (small) problem. Excuse the silly question, but how do I connect two devices to the same PINs on the Arduino?
    Specifically, I want to follow this instruction: http://www.mysensors.org/build/ethernet_gateway
    My Arduino has two GND and one 5V and one 3.3V output PIN, so that's no problem -- but how do I connect pins 11, 12, and 13 (MOSI, MISO, SCK) to both the ethernet shield and the radio at the same time?
    Is a breadboard neccessary for this?
    Many thanks for your help, it's greatly appreciated!
    • hekH Offline
      hekH Offline
      If you don't want to solder breadboard is probably the cleanest solution.
      In times of desperation it has happened that I have squeezed in a male pin into the back of another.. but nothing I can recommend.
      • I Offline
        I Offline
        infinity101
        Thank you very much! I've ordered a breadboard and will try to get it running when I received it :-)
        12.2k
