  3. Newbie problem
Newbie problem
14 Posts 3 Posters 4.8k Views 3 Watching
  • R Offline
    R Offline
    Redpages
    wrote on last edited by Redpages
    Hi guys,
    I'm trying to make my first mysensors ethernet gateway, but somehow I'm in trouble.
    I have Arduino Uno r3 plus w5100 ethernet shield + nrf24l01 radio. My code is the following:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,100,12   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    And this is my error:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:FAIL:CNT=1
    0;255;3;0;9;TSM:FAIL:PDT
    0;255;3;0;9;TSM:FAIL:RE-INIT
    0;255;3;0;9;TSM:FAIL:CNT=2
    0;255;3;0;9;TSM:FAIL:CNT=3
    0;255;3;0;9;TSM:FAIL:CNT=4
    I tried simple w5100 demo webserver sketch, everything works. Tried nrf24l01 without a shield with blink sensor example and connetcted to ports 9,10,11,12,13 and it seems working. But when the shield and the radio are together I can't even ping the gateway.
    And have the error above.
    What did I wrong?
    Regrds,
    Janos
    Boots33B 1 Reply Last reply
    • R Offline
      R Offline
      Redpages
      • R Redpages
        @Redpages use the wiring guide on https://www.mysensors.org/build/ethernet_gateway
        The wiring is different from other sensors because the ethernet shield has problems with sharing SPI.
        R 1 Reply Last reply
          R Offline
          R Offline
          Redpages
          • R Redpages
            R Offline
            R Offline
            Redpages
            @Redpages
            • R Redpages
              Hi guys,
               * LED purposes:
              #define MY_SOFTSPI
              // Enable to UDP
              What did I wrong?
              Regrds,
              Janos
              Boots33B Offline
              Boots33B Offline
              Boots33
              @Redpages Make sure you are using the correct wiring and also you should comment out the line
              //#define MY_W5100_SPI_EN 4
              That line is stopping soft spi
              • Boots33B Boots33
                R Offline
                R Offline
                Redpages
                @Boots33
                The wiring is correct, it's a hard wired shield. As you can see above that line is uncommented.
                Thx
                Janos
                Boots33B R 2 Replies Last reply
                • R Redpages
                  @Boots33
                  Thx
                  Janos
                  Boots33B Offline
                  Boots33B Offline
                  Boots33
                  @Redpages You need to comment it out. it is not needed for the shield and will stop spi from being used
                  • R Redpages
                    @Boots33
                    Thx
                    Janos
                    R Offline
                    R Offline
                    Redpages
                    @Redpages
                    The problem is that the Ethernet shield is not responding even to a simple ping. And it should even without a radio. If I load web server demo sketch everything is fine.
                    I tried to disconnect nrf, changed spi ports, triple checked wiring.
                    Janos
                    • Boots33B Boots33
                      R Offline
                      R Offline
                      Redpages
                      @Boots33
                      You are the hero of the day! Thank you. I was about to use my 3kg hammer to demonstrate something lol. Awesome. It works now!
                      Thank you,
                      Janos
                      • R Redpages
                        @Redpages
                        Janos
                        Boots33B Offline
                        Boots33B Offline
                        Boots33
                        @Redpages the gateway will not work with the shield if you do not comment out that line. and the wiring should be as below. Ignore the extra power module.
                        • R Offline
                          R Offline
                          Redpages
                          the log is now beautiful:
                          0;255;3;0;9;TSM:INIT:TSP OK
                          0;255;3;0;9;TSM:INIT:GW MODE
                          IP: 192.168.100.12
                          0;255;3;0;9;MCO:BGN:STP
                          0;255;3;0;9;Eth: connect
                          IP: 192.168.100.12
                          thank you,
                          Janos
                          • R Redpages
                            IP: 192.168.100.12
                            IP: 192.168.100.12
                            thank you,
                            Janos
                            Boots33B Offline
                            Boots33B Offline
                            Boots33
                            @Redpages well done. let the fun begin :)
                            • Boots33B Boots33
                              R Offline
                              R Offline
                              Redpages
                              @Boots33
                              I have a 10 pin nrf but the wiring is the same. It works now. That linechange did the trick!
                              Janos
                              12.2k
