  3. Sensebender Gateway with NRF24 PA and Hardsigning and Encryption
24 Posts 5 Posters 7.3k Views 4 Watching
    meddie
    Hi together,
    i think i need some help, i have an old mysensor Ethernet Gateway i thin it Version 1.2. It is some time gone since i build it.
    But i didnt anything with the controller because i waited to the signing, ota and encryption.
    Now i bought the sensebender gateway and the w5100 ethernet modul. But wich sketch i should use.
    I dont understand, maybe somebody have some tips for me or maybe a complete sketch.
    Thanks a lot in advance.
    Greets Eddie
    • M meddie
      Hi together,
      Greets Eddie
      @meddie see https://www.mysensors.org/hardware/sensebender-gateway under the sections "Default sketch" and "Other configurations".
        meddie
        yes i did it, but i hoped to find a ready sketch. But i didnt!
        I just puted from all the sketches i needed the parts of Code together. Could you please check, if my code would work correctly ot even i did some mistakes.
        Thanks a lot!
        * Version 1.0 - Henrik EKblad
        * This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
        * - Inclusion button should be connected to SW2
        * LEDs on board (default assignments):
        * - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
        * - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
        * - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
        * - Red   : ERR - Fast blink on error during transmission error or recieve crc error
        * - Blue  : free - (use with LED_BLUE macro)
        #include <stdint.h>
        #include <pins_arduino.h>
        #define SKETCH_VERSION "0.2"
        #define MY_OTA_FIRMWARE_FEATURE
        #define MY_SIGNING_ATSHA204
        #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
        #define MY_GATEWAY_W5100
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
        #define MY_SOFTSPI
        #ifndef MY_RF24_CE_PIN
        #define MY_RF24_CE_PIN 5
        #ifndef MY_RF24_CS_PIN
        #define MY_RF24_CS_PIN 6
        // Enable to UDP
        //#define MY_USE_UDP
        #define MY_IP_ADDRESS 192,168,178,66   // If this is disabled, DHCP is used to retrieve address
        #define MY_PORT 5003
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
        #include <Ethernet.h>
        #include <SD.h>
        #include <drivers/ATSHA204/ATSHA204.cpp>
        Sd2Card card;
        #define EEPROM_VERIFICATION_ADDRESS 0x01
        static uint8_t num_of_leds = 5;
        static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
        void preHwInit()
        	pinMode(MY_SWC1, INPUT_PULLUP);
        	pinMode(MY_SWC2, INPUT_PULLUP);
        	if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
        		return;
        	uint8_t tests = 0;
        	for (int i=0; i< num_of_leds; i++) {
        		pinMode(leds[i], OUTPUT);
        	uint8_t led_state = 0;
        	if (digitalRead(MY_SWC1)) {
        		while (!Serial) {
        			digitalWrite(LED_BLUE, led_state);
        			led_state ^= 0x01;
        			delay(500);
        		} // Wait for USB to be connected, before spewing out data.
        	digitalWrite(LED_BLUE, LOW);
        	if (Serial) {
        		Serial.println("Sensebender GateWay test routine");
        		Serial.print("Mysensors core version : ");
        		Serial.println(MYSENSORS_LIBRARY_VERSION);
        		Serial.print("GateWay sketch version : ");
        		Serial.println("----------------------------------");
        		Serial.println();
        	if (testSha204()) {
        		digitalWrite(LED_GREEN, HIGH);
        		tests++;
        	if (testSDCard()) {
        		digitalWrite(LED_YELLOW, HIGH);
        		tests++;
        	if (testEEProm()) {
        		digitalWrite(LED_ORANGE, HIGH);
        		tests++;
        	if (testAnalog()) {
        		digitalWrite(LED_BLUE, HIGH);
        		tests++;
        	if (tests == 4) {
        		while(1) {
        			for (int i=0; i<num_of_leds; i++) {
        				digitalWrite(leds[i], HIGH);
        				delay(200);
        				digitalWrite(leds[i], LOW);
        		while (1) {
        			digitalWrite(LED_RED, HIGH);
        			delay(200);
        			digitalWrite(LED_RED, LOW);
        			delay(200);
        bool testSha204()
        	uint8_t ret_code;
        	if (Serial) {
        		Serial.print("- > SHA204 ");
        	atsha204_init(MY_SIGNING_ATSHA204_PIN);
        	ret_code = atsha204_wakeup(rx_buffer);
        	if (ret_code == SHA204_SUCCESS) {
        		ret_code = atsha204_getSerialNumber(rx_buffer);
        			if (Serial) {
        				Serial.println(F("Failed to obtain device serial number. Response: "));
        			if (Serial) {
        				Serial.print(F("Ok (serial : "));
        				for (int i=0; i<9; i++) {
        					if (rx_buffer[i] < 0x10) {
        					Serial.print(rx_buffer[i], HEX);
        				Serial.println(")");
        			return true;
        		if (Serial) {
        			Serial.println(F("Failed to wakeup SHA204"));
        	return false;
        bool testSDCard()
        	if (Serial) {
        		Serial.print("- > SD CARD ");
        	if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
        		if (Serial) {
        			Serial.println("SD CARD did not initialize!");
        		if (Serial) {
        			Serial.print("SD Card initialized correct! - ");
        			Serial.print("type detected : ");
        			switch(card.type()) {
        			case SD_CARD_TYPE_SD1:
        				Serial.println("SD1");
        			case SD_CARD_TYPE_SD2:
        				Serial.println("SD2");
        			case SD_CARD_TYPE_SDHC:
        				Serial.println("SDHC");
        			default:
        				Serial.println("Unknown");
        		return true;
        	return false;
        bool testEEProm()
        	uint8_t eeprom_d1, eeprom_d2;
        	SerialUSB.print(" -> EEPROM ");
        	Wire.begin();
        	eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
        	delay(500);
        	eeprom_d1 = ~eeprom_d1; // invert the bits
        	i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
        	delay(500);
        	eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
        	if (eeprom_d1 == eeprom_d2) {
        		SerialUSB.println("PASSED");
        		i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
        		return true;
        	SerialUSB.println("FAILED!");
        	return false;
        bool testAnalog()
        	int bat_detect = analogRead(MY_BAT_DETECT);
        	Serial.print("-> analog : ");
        	Serial.print(bat_detect);
        	if (bat_detect < 400 || bat_detect > 650) {
        		Serial.println(" Failed");
        		return false;
        	Serial.println(" Passed");
        	return true;
        • tbowmoT
          tbowmoT
          tbowmo
          @meddie
          You should be able to use the "stock" GatewayW5100 sketch.
          I see in the code that you posted above, that you have enabled OTA support. That doesn't make sense in a gateway, and specially not in the sensebender gw, as there is no support for OTA on arm processors yet.
            meddie
            wrote on last edited by meddie
            thank you for your answers! I tried the GatewayW5100 Sketch but i get an error
            C:\Users\Meddie\AppData\Local\Temp\arduino_build_19882\sketch\GatewayW5100.ino.cpp:1:21: fatal error: Arduino.h: No such file or directory
             #include <Arduino.h>
            compilation terminated.
            exit status 1``````
            Where i have to pu the Arduino.h file?
            I have already copied the files from drivers folder to the arduino ide drivers folder and i copied the whole mysensors-master folder to the libraries folder in the arduino ide.
            I got this error only if i select the sensebender Gatewas as board, when i select arduino uno i can compile witheout errors.
            When i switch in the ide to the Sensebender GW Board i get this text in the console:
            The current selected board needs the core 'arduino:arduino' that is not installed.```
            • tbowmoT
              tbowmoT
              tbowmo
              @meddie
              Which version of mysensors board definition files, and arduino ditto for SAMD do you have installed? (Have a look in the board manager)
              The newest Mysensors SAMD files (1.0.4) is only compatible up to Arduino SAMD 1.6.11, as the Arduino folks have made some changes again to their core again.
                meddie
                I have installed the 1.0.4 Version. But the Arduino IDE is 1.8.1
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @meddie
                  Not the arduino IDE, but Arduino SAMD board support files.. These can be installed through the board manager.
                  Sorry this was not made clear in the setup instructions..
                    meddie
                    Oh, ok i did not installed them. Just in moment i install the arduino sam Boards (32-bits ARM Cortex.m3) Version 1.6.11
                    is that correct?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @meddie
                      No, you need to choose Arduino SAMD boards (32-bits ARM Cortex-M0) version 1.6.11
                        meddie
                        AAAAAH! I am so stupid! I read all the Time SAM and didnt seen the D at the end. Sorry sorry sorry.
                        Yes it works now!!!
                        Thank you very much!
                          meddie
                          Ok, next problem:
                          the sketch Gateway5100 can be compiled but i get an error on uploding them.
                          I have a Win 10 PC, the GW is detected by os and in the device manager i can see a usb device Com Port 3. When i connect the GW to the PC and start the serial monitor i get some lines.
                          I think the communication should work.
                          This is the output:
                          Arduino: 1.8.1 (Windows 10), Board: "Sensebender Gateway"
                          C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\meddie\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\meddie\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\meddie\Documents\Arduino\libraries -fqbn=MySensors:samd:mysensors_gw_native -vid-pid=0X1209_0X6949 -ide-version=10801 -build-path C:\Users\meddie\AppData\Local\Temp\arduino_build_739214 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.openocd.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.avrdude.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0 -verbose C:\Program Files (x86)\Arduino\examples\MySensors\GatewayW5100\GatewayW5100.ino
                          C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\meddie\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\meddie\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\meddie\Documents\Arduino\libraries -fqbn=MySensors:samd:mysensors_gw_native -vid-pid=0X1209_0X6949 -ide-version=10801 -build-path C:\Users\meddie\AppData\Local\Temp\arduino_build_739214 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.openocd.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.avrdude.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino8 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0 -verbose C:\Program Files (x86)\Arduino\examples\MySensors\GatewayW5100\GatewayW5100.ino
                          Using board 'mysensors_gw_native' from platform in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4
                          Using core 'arduino' from platform in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11
                          Detecting libraries used...
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp" -o "nul"
                          ..."C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI\SPI.cpp" -o "nul"
                          Generating function prototypes...
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions  -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\preproc\ctags_target_for_gcc_minus_e.cpp"
                          "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\preproc\ctags_target_for_gcc_minus_e.cpp"
                          Compiling sketch...
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp.o"
                          Compiling libraries...
                          Compiling library "Ethernet"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\Dhcp.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dhcp.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\Dns.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dns.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\Ethernet.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Ethernet.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\EthernetClient.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetClient.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\EthernetServer.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetServer.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\EthernetUdp.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetUdp.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\utility\socket.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\socket.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src\utility\w5100.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\w5100.cpp.o"
                          Compiling library "MySensors-master"
                          Compiling library "Wire"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire\Wire.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Wire\Wire.cpp.o"
                          Compiling library "SPI"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet\src" "-IC:\Program Files (x86)\Arduino\libraries\MySensors-master" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI" "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI\SPI.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\SPI\SPI.cpp.o"
                          Compiling core...
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10801 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD  -D__SAMD21G18A__ -DUSB_VID=0x1209 -DUSB_PID=0x6949 -DUSBCON '-DUSB_MANUFACTURER="MySensors.org"' '-DUSB_PRODUCT="Sensebender GW"' "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0/CMSIS/Device/ATMEL/" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\cores\arduino" "-IC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw" "C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw\variant.cpp" -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\variant.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs  "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\core.a" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\USB\USBCore.cpp.o"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc"  "-LC:\Users\meddie\AppData\Local\Temp\arduino_build_739214" -Os -Wl,--gc-sections -save-temps  "-TC:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\variants\mysensors_gw/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.elf" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\sketch\GatewayW5100.ino.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dhcp.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Dns.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\Ethernet.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetClient.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetServer.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\EthernetUdp.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\socket.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Ethernet\utility\w5100.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\Wire\Wire.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\libraries\SPI\SPI.cpp.o" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/core\core.a" -Wl,--end-group
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.elf" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.bin"
                          "C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom  "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.elf" "C:\Users\meddie\AppData\Local\Temp\arduino_build_739214/GatewayW5100.ino.hex"
                          Multiple libraries were found for "Ethernet.h"
                           Used: C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet
                           Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
                          Using library Ethernet at version 1.1.2 in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.4\libraries\Ethernet
                          Using library MySensors-master at version 2.1.1 in folder: C:\Program Files (x86)\Arduino\libraries\MySensors-master
                          Using library Wire at version 1.0 in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\Wire
                          Using library SPI at version 1.0 in folder: C:\Users\meddie\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.11\libraries\SPI
                          Sketch uses 43960 bytes (16%) of program storage space. Maximum is 262144 bytes.
                          An error occurred while uploading the sketch```
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @meddie
                            I'm not sure how things work on windows..
                              meddie
                              me again, today i installed the arduino ide on a other pc and it works now i could compile and upload the sketch. But when i user the Gateway5100 Sketch and put as ip Adresse 172.16.0.25 i could not ping the gateway.
                              Do i have to config the pins that connected to the ethernet modul? A similar problem i had with my nrf24 modul when i connect it the gateway dont start. (i dont get any data on the serial port)
                              Thank you a lot!
                              Greets Eddie
                                meddie
                                i did it! The gateway has worked fine all the time! When i have uploaded the GatewayW5100 Sketch and connected the Eternet Module and the NRF24 Modul, then i didnt get anythin on Serial Monitor but i think its correct so, because FHEM (my Controller) shows me that the Sensebender Gateway is connected and added one new Device.
                                Then i tried to upload the Sketch from second post, and get some errors, i had to delete this Line
                                then i could compile and upload the sketch but i get three warnings:
                                c:/users/meddie/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes
                                I dont know what this means, but it looks like the gateway is working. FHEM continues showing as connected!
                                Do you know what this warning does mean?
                                Thanks a lot!
                                • magpernM
                                  magpernM
                                  magpern
                                  Is it correct, that if you want to enable ATSHA204A chip in gateway, you need to enable this in MyConfig.h?
                                  //#define MY_SIGNING_ATSHA204
                                  If I do, I get a lot of compile errors, see below, if I don't enable it, it compiles fine. It is development branch (I guess...). Setting up the environment is quite the trial and error
                                  In file included from C:\Users\aaa\Documents\Arduino\libraries\MySensors\examples\SensebenderGatewaySerial\SensebenderGatewaySerial.ino:86:0:
                                  C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
                                   static uint8_t device_pin;
                                  In file included from C:\Users\aaa\Documents\Arduino\libraries\MySensors/MySensors.h:166:0,
                                                   from C:\Users\aaa\Documents\Arduino\libraries\MySensors\examples\SensebenderGatewaySerial\SensebenderGatewaySerial.ino:84:
                                  C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
                                  C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
                                  C:\Users\aaa\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:23:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
                                   static void swi_set_signal_pin(uint8_t is_high)
                                  and a lot more...
                                  AnticimexA 1 Reply Last reply
                                  • magpernM magpern
                                    and a lot more...
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @Magnus-Pernemark normally, you don't change MyConfig.h, you just use it as reference. And then you set your defines in your sketch prior to include mysensors.h.
                                    I think there was a problem in the official release that the SenseBender gw sketch included some files for self testing that is not really needed (or more correctly, it included them without considering the atsha flag), so you can probably strip them from the sketch or conditionally include them. I believe it was fixed on beta. But perhaps it is still in there.
                                    magpernM 1 Reply Last reply
                                    • AnticimexA Anticimex
                                      magpernM
                                      magpernM
                                      magpern
                                      @Anticimex Ah, I was under the impression that the SenseBender Gateway, came with default serial sketch without signing and you had to enable signing by your self if you want it. And some how in MyConfig.h (not MySensors.h) this sounded like something that needs to be changed (comment said so).
                                       * @def MY_SIGNING_ATSHA204
                                      * For any signing related functionality to be included, this define or @ref MY_SIGNING_SOFT has to
                                       * be enabled.
                                      So after configuring the ATSHA chip and uploading the serialgateway to the GW, without altering any code, it will start using the ATSHA chip and reject those without?
                                      Is it the same with Sensebender Micro? If it has a ATSHA chip it will use it, if it doesn't it will not?
                                      I run the development branch code, 2.2.2-beta
                                      • magpernM magpern
                                         * be enabled.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @Magnus-Pernemark no, it is not enabled by default. But the SenseBender gw sketch also include self test logic used in the factory that test atsha204a communication. But this code is always included, so if you do enable the signing using atsha204a, it includes some code twice. So the sketch would only include the atsha stuff if the define isn't set.
                                          magpernM
                                          magpernM
                                          magpern
                                          @Anticimex I'm sorry, my vacation brain just cannot comprehend all these terms (I don't think it would even if I wasn't on vecaction :) My four hour experience with c/c++ surely has its limits).
                                          Is it safe to say, the GW sketch does not use the ATSHA chip, and the sketch needs some modification for it to start using it?
                                          In the mean-time, I'll try it out with the default sketch. It looks like the GW and the bender are talking to each other
