  3. Problem with mysensor library on Arduino IDE Running on Raspi
raspberry pilibraryarduino nano
11 Posts 4 Posters 5.7k Views 3 Watching
  • bobbybobbybobbyB
    bobbybobbybobbyB
    bobbybobbybobby
    Hello!
    Can someone please help me with adding the MySensors library to Arduino IDE running on my raspi? I am trying the get it to work for a week now but can't figure it out..
    What do I have to download and place where?
    Please help before I throw out all my newly bought sensors.. 😭
    Greetings,
    Bob!
      How far did you come on the raspberry guide?
      https://www.mysensors.org/build/raspberry
      bobbybobbybobbyB 1 Reply Last reply
        bobbybobbybobbyB
        bobbybobbybobbyB
        bobbybobbybobby
        @hek
        Hi Hek! I don't want to make an PiGateway only a arduino ide programmer with MySensors library.
        So that I can program sensors with my RasPi!
        I followed the how to on the following URL:
        http://razzpisampler.oreilly.com/ch10.html
        The only part where I got an error was with the following lines:
        cd alamode-setup
        sudo ./setup
        • tbowmoT
          tbowmoT
          tbowmo
          @bobbybobbybobby
          That guide will install arduino 1.0.1 on your RPI, which isn't compatible with the latest mysensors core library.
          head over to arduino.cc under their download section and grab the linux arm version.
          after you have downloaded it to your raspberry pi, you need to unpack the archive with:
          tar xf <filename-of-archive>
          This will create a new directory with the name of the file from before, enter this with cd <name-of-directory>, and issue the command ./arduino
          (This was a super extreme quick guide to get arduino up on an arm platform..)
          • tbowmoT tbowmo
            @bobbybobbybobby
            bobbybobbybobbyB
            bobbybobbybobbyB
            bobbybobbybobby
            @tbowmo
            Thanks for your reply
            i needed a little more info on how to instal ide on linux/arm on a RPI
            so i found the how to on the folowing url:
            http://duinorasp.hansotten.com/arduino-1-6-x-for-raspberry-pi-jessie/
            but i now get an error..
            root@raspberrypi:/home/pi# dpkg -i arduino-core_1.6.5_all.deb arduino_1.6.5_all.deb
            dpkg: fout bij verwerken van archief arduino-core_1.6.5_all.deb (--install):
            krijg geen toegang tot archief: Bestand of map bestaat niet
            dpkg: fout bij verwerken van archief arduino_1.6.5_all.deb (--install):
            Fouten gevonden tijdens verwerken van:
            what do i do wrong?
            • pansenP
              pansenP
              pansen
              wrote on last edited by pansen
              please translate anything into English. not everyone understands Dutch.
              Why don't you try what @tbowmo suggested? His steps are quite clear... Besides, you are trying to install a version which is 2 major versions behind the newest one.
              Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
              • pansenP pansen
                bobbybobbybobbyB
                bobbybobbybobbyB
                bobbybobbybobby
                @pansen
                And
                @tbowmo
                Thanks for helping me! I really appreciate it! Sorry for not being clear in what I wrote.
                @tbowmo i don't know mutch about command line so that's why I was looking further with the info about arm version and all.
                • bobbybobbybobbyB bobbybobbybobby
                  @pansen
                  And
                  @tbowmo
                  bobbybobbybobbyB
                  bobbybobbybobbyB
                  bobbybobbybobby
                  @bobbybobbybobby said in Problem with mysensor library on Arduino IDE Running on Raspi:
                  @pansen
                  And
                  @tbowmo
                  i think i got a little bit further.. but get an error..
                  pi@raspberrypi:~ $ cd arduino-1.8.1
                  pi@raspberrypi:~/arduino-1.8.1 $ ./arduino
                  /home/pi/arduino-1.8.1/java/bin/java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
                  this time without dutch ;-)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @bobbybobbybobby
                    have you tried to search google for that missing file?
                    I get a couple of hist on raspberrypi.org's forum
                    https://www.raspberrypi.org/forums/viewtopic.php?f=27&t=12403
                    https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=11671
                    They seem to contain some info..
                    ps. I had @Yveaux help me translate your dutch error messages :) But was trying to reproduce the installation steps you found on one of my test rpi's before posting any updates in this thread..
                      @pansen
                      And
                      @tbowmo
                      bobbybobbybobbyB
                      bobbybobbybobbyB
                      bobbybobbybobby
                      @bobbybobbybobby
                      @pansen and @tbowmo fimaly i got arduino ide running on my rpi!!! i was trying this for about a weeks now.
                      thanks for the support.
                        @bobbybobbybobby
                        bobbybobbybobbyB
                        bobbybobbybobbyB
                        bobbybobbybobby
