  3. No new node possible
22 Posts 6 Posters 7.1k Views 4 Watching
  • G Offline
    G Offline
    gloob
    wrote on last edited by gloob
    I have a problem with my network. I can not connect any new nodes to the network.
    The gateway shows the following error:
    0;255;3;0;9;Client 0: 0;0;3;0;5;1
    0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:CKU:OK,FCTRL
    And on the node i see:
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:FPAR
    16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2025 !TSM:FPAR:NO REPLY
    2027 TSM:FPAR
    2029 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4038 !TSM:FPAR:NO REPLY
    4040 TSM:FPAR
    4042 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6051 !TSM:FPAR:NO REPLY
    6053 TSM:FPAR
    6055 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8065 !TSM:FPAR:FAIL
    8067 TSM:FAIL:CNT=1
    8069 TSM:FAIL:PDT
    18073 TSM:FAIL:RE-INIT
    18075 TSM:INIT
    18083 TSM:INIT:TSP OK
    18085 TSM:FPAR
    18087 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20097 !TSM:FPAR:NO REPLY
    20099 TSM:FPAR
    20101 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22110 !TSM:FPAR:NO REPLY
    22112 TSM:FPAR
    22114 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24123 !TSM:FPAR:NO REPLY
    24125 TSM:FPAR
    24127 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26136 !TSM:FPAR:FAIL
    26138 TSM:FAIL:CNT=2
    26140 TSM:FAIL:PDT
    36143 TSM:FAIL:RE-INIT
    36145 TSM:INIT
    36153 TSM:INIT:TSP OK
    36155 TSM:FPAR
    36157 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    37013 TSF:MSG:READ,200-200-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    38166 !TSM:FPAR:NO REPLY
    38168 TSM:FPAR
    38170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    Any ideas if this problem is related to the controller (FHEM) or to MySensors?
    • G Offline
      G Offline
      gloob
      Existing nodes work without any problem:
      0;255;3;0;9;!TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
      0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
      0;255;3;0;9;TSF:MSG:READ,196-196-0,s=1,c=1,t=0,pt=7,l=5,sg=0:22.4
      0;255;3;0;9;TSF:MSG:READ,196-196-0,s=2,c=1,t=1,pt=2,l=2,sg=0:45
      0;255;3;0;9;TSF:MSG:READ,196-196-0,s=199,c=1,t=38,pt=7,l=5,sg=0:2.922
      0;255;3;0;9;TSF:MSG:READ,196-196-0,s=255,c=3,t=0,pt=1,l=1,sg=0:73
      Even when I set a fixed None ID in the sketch it will not join the network.
      When the node is sending a request, I see an update in the debug log of the gateway. So the message gets send correctly.
      • G gloob
        T Offline
        T Offline
        tekka
        wrote on last edited by tekka
        @gloob Looks like you have a power issue on your GW hardware:
        Try adding a larger cap on the radio or replace the power supply.
        • G Offline
          G Offline
          gloob
          actually I already have a cap next to the radio and the power is supplied by a ams1117 but I will try to change the power supply of the WeMos.
          The strange thing is, that all other nodes (6 with temp, hum and battery) are working without any problems. I only get this issue with new nodes.
          Will it help to set the node ID manually in the node sketch?
          • G gloob
            T Offline
            T Offline
            tekka
            @gloob cap size gw and nodes? Antenna type?
            G 1 Reply Last reply
            • T tekka
              G Offline
              G Offline
              gloob
              @tekka
              The gateway has a 47µF cap and the nodes use 10uF.
              For the gateway I use a NRF24L01-SMD PA+LNA radio module and the nodes use "normal" NRF24L01 modules without PA+LNA.
              • F Offline
                F Offline
                flopp
                On a NOT working node try with a nRF from a WORKING node.
                Place the NOT working node on the same location as a WORKING
                • G Offline
                  G Offline
                  gloob
                  I did this test also. When I flash a node that was working before with a new ID, it will not join the network.
                  When I flash it back, to use the old static ID, it is working again without any problems.
                  Currently I think it is a problem with the WeMos pro mini. I will try it with an other WeMos when it arrives from china.
                  F 1 Reply Last reply
                  • G gloob
                    F Offline
                    F Offline
                    flopp
                    @gloob
                    Do you have to allow new Nodes in your controller?
                    • G Offline
                      G Offline
                      gloob
                      Inclusion mode is set on the controller. But I think I don't have to activate this in the controller if the node has a static ID.
                      rejoe2R 1 Reply Last reply
                      • G gloob
                        rejoe2R Offline
                        rejoe2R Offline
                        rejoe2
                        @gloob: FHEM also requires to have inclusion mode active when NODE_ID is assigned in the sketch.
                        • G Offline
                          G Offline
                          gloob
                          But even when I set FHEM to inclusion_mode = 1, I get this error.
                          I would assume that the node finds the parent without a running controller if the node ID and parent ID are static.
                          • G gloob
                            rejoe2R Offline
                            rejoe2R Offline
                            rejoe2
                            You already tried to restart the node after turning inclusion mode on?
                            As long as the parent node is present, the node will send it's messages towards this one, but I'm not sure if this (esp. the presentation()) really needs the controller to answer accordingly.
                            Other: are you using MQTT?
                            • G Offline
                              G Offline
                              gloob
                              Yes I also tried to restart the node when inclusing mode is on and I don't use MQTT.
                              • rejoe2R Offline
                                rejoe2R Offline
                                rejoe2
                                Don't have no further idea, but maybe it is really HW-related wrt to this post: https://forum.mysensors.org/topic/6063/solved-mqtt-esp8266-gateway-issue.
                                Indicates some kind of incompability between the MySensors-libs 2.1.1 and the Wemos D1 mini defs, other variants of the ESP8266 may be affected, too. MySensors versions between 2.0.0-beta and 2.1.1 have issues with the nrf-part, so downgrading is not the best idea either.
                                Do you have the possibility to make tests with a serial GW or at least use the WIFI-GW in a "fake serial mode" (don't really know whether this is possible or not)?
                                • G Offline
                                  G Offline
                                  gloob
                                  So the other thread mentions to go back to 2.0.0
                                  I will try this today and give feedback.
                                  • rejoe2R Offline
                                    rejoe2R Offline
                                    rejoe2
                                    wrote on last edited by rejoe2
                                    When downgrading I would expect trouble wrt. to the nrf part (other thread is about other RF-chip). Did you try to use the GW as fake serial GW or at least tried to analyse serial output more in depth?
                                    Btw.: Another user reported having trouble including new nodes with a network-GW, see here: https://forum.mysensors.org/topic/6149/ethernet-gateway-shows-up-on-vera-but-doens-t-want-to-include-devices. As this is the 3rd in very short time, most likely problems will be solved pretty soon.
                                    EDIT: found even a 4th, pretty similar one: https://forum.mysensors.org/topic/6118/problem-connecting-to-gateway
                                    Pretty astonishing, because the recent days I built a RS485-GW using the 2.1.1-libs without trouble wrt. including some testnodes in FHEM.
                                    the only problems I ran into where the neccessity to assingne node ID's manually and I had to restart the other serial GW; this one stopped receiving regular updates from my nrf-nodes.
                                    Very strange...
                                    • ร Offline
                                      ร Offline
                                      รอเรือ
                                      And here is a 5th similar issue I believe: https://forum.mysensors.org/topic/6147/tsm-fpar-no-reply
                                      • G Offline
                                        G Offline
                                        gloob
                                        Thanks for your support. For me it seems that we have some general problems at the moment.
                                        I will try the following things later:
                                        #define MY_NODE_ID 10
                                        #define MY_PARENT_NODE_ID 0
                                        1. use dev version of 2.1.1
                                        2. downgrade to 2.0.0 or less to check if the hardware is working without any problems
                                        3. use a serial gateway or try to use my WeMos in serial mode
                                        These are the topics with a similar error (just as a summary for myself):
                                        Edit: does anybody have an idea how to use a ESP as serial gateway?
                                        • rejoe2R Offline
                                          rejoe2R Offline
                                          rejoe2
                                          Wrt to using the ESP as serial GW: I only did some short test some time ago, but the serial output seemed to be pretty similar to what I would expect from a regular serial GW. So I would at first just rty to use the USB port and change the definition in FHEM.
                                          You could also try to use the dev version before downgrading. At first look, there seems not to be a specific fix wrt. this problem, but you never know...
                                          12.0k
