  3. W5100 Gateway hangs /freezes after some time.
23 Posts 7 Posters 6.5k Views 5 Watching
  • webstorW Offline
    webstorW Offline
    webstor
    Hi guys,
    I'm having the "interesting" error, that my gateway which is connected via Lan (Uno+W5100 module) keeps hanging after some time.
    It isn't even pingable.
    Reseting it and everything works fine.
    It is not a thermal problem. I removed the case to make sure.
    There are 5 senors connected to this gateway.
    The code I am using is this one:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    //#define MY_IP_ADDRESS 192,168,66,242   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    #define MY_GATEWAY_MAX_CLIENTS 20
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 66, 240
    // Flash leds on rx/tx/err
    //#define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
     // Serial.println(MCUSR);
    // MCUSR=0;
    Thanks for your help.
    • K Offline
      K Offline
      korttoma
      This is probably not the issue but I found it strange that you would need to connect 20 clients:
      How many controllers do you have? Maybe you could try with 2 just to rule out this as your issue.
      I don't know if there is any limit to what you can use but 20 sound like allot.
      Please also check the version of Arduino AVR Boards you are using from your Boards Manager. I think there is some issue if you use anything newer than version 1.6.11.
      • Tomas
      • S Offline
        Yes there is a limit, if i remember well it's 4 connections.
        • webstorW Offline
          webstorW Offline
          webstor
          4 connections? Wow that isn't much.
          Is the limit because of hardware limitations?
          If the answer is yes, then I could use an raspberry pi with more "power" compared to the arduino.
          Thanx.
          • S Offline
            yes, w5100 should have 4connec max, and maybe the latest w5200/5500 have more (maybe 8?).
            Plus, i think ethernet lib is not async which does not help for handling more connec at same time..
            • webstorW Offline
              webstorW Offline
              webstor
              Thanx for your answer.
              That means, if I would use an raspberrypi as a gateway that could support devices?
              I would like to have only 1 gateway for each floor and I plan to have about 20 sensors connected to each gateway .
              Thanx.
              rejoe2R Boots33B 2 Replies Last reply
              • webstorW webstor
                Thanx.
                rejoe2R Offline
                rejoe2R Offline
                rejoe2
                @webstor said in W5100 Gateway hangs /freezes after some time.:
                Thanx.
                Is there any benefit in using one GW for each floor? Imo it s best, to just have one MySensors network covering the entire building. To avoid problems wrt. to RF-coverage it is better to use some of the nodes also as repeater.
                As far as I understood, there is no limitation below 254 about the number of Nodes connected to one GW. Isn't the MAX_CLIENTS-definition targeting towards the maximum number of controllers to make use of the GW?
                Kind regards
                • webstorW Offline
                  webstorW Offline
                  webstor
                  yes there is. There is no signal getting through between the ground and the first floor.
                  rejoe2R 1 Reply Last reply
                  • webstorW webstor
                    rejoe2R Offline
                    rejoe2R Offline
                    rejoe2
                    OK, that's an argument.
                    When starting with MySensors, I had similar problems, but using some caps and nrf+pa+lna-modules helped a lot. Keep in mind, you will also have some receiving problems if the distance on the same floor is to big...
                    • webstorW Offline
                      webstorW Offline
                      webstor
                      Sorry but we are drifting away from the main problem.
                      • webstorW webstor
                        Thanx.
                        Boots33B Offline
                        Boots33B Offline
                        Boots33
                        @webstor Are you confusing controllers with nodes ?
                        comment out the line line
                        and see if it still locks up.
                        Your 20 nodes will still connect ok
                        • webstorW Offline
                          webstorW Offline
                          webstor
                          Ok.
                          I will try that when I come home from work.
                          • webstorW Offline
                            webstorW Offline
                            webstor
                            Looks good. I will keep you up to date if the error appears again.
                            Thanx.-
                            • webstorW Offline
                              webstorW Offline
                              webstor
                              It stopped crashing.
                              But the problems just switched.
                              Only one device is communicating with the Gateway. The other devices aren't working anymore. My Relays and one temp and hum sensor are not communicating any more.
                              And they are 5 meters away from the Gw.
                              Boots33B 1 Reply Last reply
                              • webstorW webstor
                                Boots33B Offline
                                Boots33B Offline
                                Boots33
                                @webstor I am pretty sure that will be some other problem.
                                as far as i am aware #define MY_GATEWAY_MAX_CLIENTS is not a setting for the number of nodes connected and is not needed in a standard Ethernet gateway with one controller, the default setting of 1 is all you need. I am running a w5100 gateway and am able to connect to multiple nodes without that line.
                                If you un-comment it do your nodes then connect as per normal again?
                                Maybe you could make a new post about #define MY_GATEWAY_MAX_CLIENTS and see if one of the MySensors devs can give a definite answer.
                                Have you tried fitting a larger capacitor to the nrf power connections. When I updated to v2.1.1 I had two nodes that were usually very stable start to loose connection now and then. I replaced the 4.7uf with a 47uf and now they are working well again.
                                • webstorW Offline
                                  webstorW Offline
                                  webstor
                                  ok, starts to crash again. I replaced the whole hardware aswell.
                                  Yes if I uncomment them, the nodes connect normal.
                                  I'm not using v.2.1.1, my nodes and gateways are on v.2.0.0
                                  The next step will be to use an esp8266 as gateway instead of the arduino uno.
                                  Thanx.
                                  • webstorW Offline
                                    webstorW Offline
                                    webstor
                                    I upgraded to 2.1.1 and I keep testing.
                                    • webstorW Offline
                                      webstorW Offline
                                      webstor
                                      Ok, running on 2.1.1 and commented out the following lines:
                                      and
                                      is running now for three days and looks good that it will keep it that way.
                                      thanx guys.
                                      • FraidF Offline
                                        FraidF Offline
                                        Fraid
                                        I have the same issue, W5100 gateway freeze, seen my update to MySensor 2.1.1.
                                        I use a static IP otherway it's the same code as @webstor I did removed both line and still gateway freeze (one day max ). Unlike @websor if I reset, gateway doesn't come back. I have to unplug the usb power.
                                        I only have five sensor, with only one battery powered. I used IDE 1.8.2 and AVR 1.6.18. Everything was working well with MySensor 2.0.0, IDE 1.6.9 , AVR 1.6.15. Any idea what could I look at ?
                                          wrote on last edited by gohan
                                          Try to restore previous versions of avr and mysensors one at a time and see if you see any changes. Did you check how much free memory it reports after you compiled?
                                          12.1k
