  3. Gateway in Client Mode and 2 Controller?
7 Posts 5 Posters 2.2k Views 5 Watching
  • ThomasDrT
    ThomasDrT
    ThomasDr
    wrote on last edited by ThomasDr
    Hallo,
    can a Gateway in Client Mode connect to 2 Controller?
    regards
    ThomasD
      Nope, not possible.
      • CorvlC
        CorvlC
        Corvl
        Just checking if I have the same question, since I am not sure about "client mode".
        Is it possible to controll the ethernet gateway with 2 vera's ?
        Cor
        • CorvlC Corvl
          Cor
          FotoFieberF
          FotoFieberF
          FotoFieber
          @Corvl
          At least for the internal messages like time and node_id assignment it would be impossible to have multiple gateways.
          What about bridging the two veras? http://wiki.micasaverde.com/index.php/Bridged_Mios_Engines
          • CorvlC
            CorvlC
            Corvl
            @ Fotofieber;
            I have bridges both vera's. What I want is the other vera ( too far away for a z-wave device) to be able to switch on and off the main vera. ( in case it freezes).
            I have now build a second ethernet controller , which is near the main vera. So I was just wondering if I could controll a node ( relais) via the ethernet gateway which is than on both vera's.
            Cor
            • L
              L
              LastSamurai
              Well as far as I understand it you can use MQTT (and the MQTT gateway) with serveral controllers as long as they can understand MQTT.
              • L LastSamurai
                FotoFieberF
                FotoFieberF
                FotoFieber
                @LastSamurai
                As long as the veras don't try to be the main controller at the same time.
