  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • D
    DavidZH
    @GertSanders : Ive downloaded the files and boards.txt. I noticed you've made a distinction between the 28p DIP and the 32p TQFP. But in the boards.txt I can find no differences besides that the high fuse bits are global for the 28p version and individual (but all the same!) for the 32p version.
    Does that have a reason?
    • D DavidZH
      GertSandersG
      GertSandersG
      GertSanders
      @DavidZH
      No particular reason, I did not spend as much effort in defining the options for the 32-pin package as I did for the 28-pin package.
      When my free time becomes mine again, I will be able to take this up again. For now I have to be content with a relatively short online presence every week.
      D 1 Reply Last reply
      • GertSandersG GertSanders
        @DavidZH
        DavidZH
        @GertSanders
        No worries! It just caught my eye and was wondering. I'll keep an eye on this as I'm finalising my node network and have to choose a bootloader about now.
        • petewillP
          petewillP
          petewill
          @GertSanders I am finally getting around to trying some of these bootloaders. Thanks for making them! Would you mind posting the latest .zip file to the openhardware site? I started with those files and was getting the same errors as others mentioned. As I got further down this thread I noticed I was missing some files. :)
          Thanks again for making these!
            @petewill,
            The site will still unpack zips and extract the content. I could disable this, but it would make it harder to upload large projects.
            Like @GertSanders propose, allowing (and not uppacking) rar-files might be a better solution.
            hekH 1 Reply Last reply
              @petewill,
              Ok... rar and gz files is now allowed. They will be categorised as "design" files.
              • GertSandersG
                GertSandersG
                GertSanders
                I have added my atmega328 directory in a RAR file and uploaded it to the site.
                This compressed file contains a directory structure that contains all bootloaders I use, and the extra files needed to make most of those available from the Arduino IDE.
                To use it:
                Close the Arduino IDE
                Unpack the RAR file
                Open the IDE
                This compressed file needs to be unpacked inside the "hardware" directory which sits inside the Arduino Sketches directory. If you do not have a "hardware" directory inside the Arduino Sketches directory, then you need to make this first.
                Then go inside the "hardware" directory and there unpack the RAR file.
                My directory structure looks like this:
                [Arduino]
                   [hardware]
                      [atmega328p]
                         [avr]
                            [bootloaders]
                               [myoptiboot]
                                  ... all the HEX files ...
                            [variants]
                               [28PinBoard]
                                  pins_arduino.h
                               [32PinBoard]
                                  pins_arduino.h
                               [40PinBoard]
                                  pins_arduino.h
                               [44PinBoard]
                                  pins_arduino.h
                            boards.txt
                            platform.txt
                  Samuel235
                  I'm finally managing to update my Arduino IDE and would like to ask how you have your boards.txt setup. Do you have your boards.txt file that is zipped up in your config zip file just located in the avr folder without running the default boards.txt file or are we supposed to merge your boards file with the original one? Back when i was developing my own boards, i seem to remember just running your board file without any of the default files....
                  Is this correct or do we merge them?
                  • petewillP
                    petewillP
                    petewill
                    @GertSanders Awesome, thank you for uploading it as a .rar!!! So easy now :)
                    @Samuel235 You should be able to just copy the entire folder from the .rar file into your Arduino folder. I had to create a "Hardware" folder as it didn't exist. I'm on Windows 10 and it looks like this:
                    0_1486996741780_upload-d2b37622-9cf3-4539-9cb1-6f9ab39f1cf3
                    After closing/re-opening the Arduino IDE it looks like this:
                    0_1486996924662_upload-3cf12bfa-0444-4cd7-8a19-537fdf63a738
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      The boards .txt and platform.txt files are not complete yet, and I still need to check and change the pins_arduino.h boards for the 40 and 44 pin atmega's. That is still on my to do list, but the structure is there already. I'm still learning from other hardware deployments how to define this in a practical way. Hopefully by sharing this will be improved.
                        Samuel235
                        #127
                        @petewill - I do that, however i do already have the hardware folder (and its a clean install of windows and arduino IDE) and then inside the hardware folder i have the boards.txt file (the default one, the list that shows in the IDE without installing gertsanders'. So, i either need to put the new one in there and rename the old or to merge the two together.
                        Or am i getting this completely wrong some how?
                        EDIT: It was a mistake on my own part but will leave this comment here for anyone to see and to not make the same mistake as myself:
                        I was attempting to put it inside of the "arduino" folder that was inside of the hardware folder. My own fault XD
                          Samuel235
                            Samuel235
                            I'm slightly confused here...
                            I'm using a arduino nano, hooked it up to avrdude and read the fuses as Low:FF, High:DA, Extended:05. I then burn new fuses of Low:FF, High:DE and Extended:07. Burnt fine, so i go into arduino IDE and select the bootloader for 32pin, TQFP, 8MHz external crystal 38K4 D13 and then burn bootloader. I get a little warning but that is only because of the new IDE issues with extended bits ("You probably want to use 0xfd instead of 0x05 (double check with your datasheet first)."). But now the LED on the nano is blinking rapid then stop, then blinking rapid and then stop. I can't upload a sketch to the nano either now. I can however burn the old bootloader back on and upload like normal. What could be the issue here?
                            It almost seems like there is something wrong with the bootloader as it is uploading to it but the LED is blinking weirdly. May not be the bootloader itself, could just be some corruption as it gets uploaded....
                            GertSandersG 2 Replies Last reply
                            • S Samuel235
                              GertSandersG
                              GertSandersG
                              GertSanders
                              #130
                              @Samuel235
                              If you are using a nano, what crystal is mounted on it ? Fast flashing indicates the processor is running faster then the expected 8MHz (expected by the timing routines of the bootloader). Could it be a 16MHz model ?
                              In that case you could try to upload a sketch at a higher speed: 76K8 baud.
                              Or you can try to load the bootloader for 16MHz/D13 (which in effect is the standard bootloader of an Arduino).
                              S 1 Reply Last reply
                              • S Samuel235
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @Samuel235
                                It also seems the nano is in a reset loop. I'm at work so I can not check my Mac for the fuse settings I use.
                                  @Samuel235
                                  Samuel235
                                  #132
                                  @GertSanders Soon as i say the fast flashing I instantly thought that its running quicker than needed, but i had no idea about the resetting that you have pointed out, so thanks for pointing that one out. The reason i didn't even bother trying the 16MHz settings in fuses would be that because when i read the fuses of the arduino before i did anything, it indicated that it was running with fuses of 8MHz and the blink sketch was perfectly timed on those settings.... Could it be a miss read on the fuse settings maybe? Should i read at a slower speed when using avrdude?
                                  The crystal is so small on the nano and i can't even see the engraving with a microscope properly either.
                                  I can confirm that the 16MHz bootloader is working perfectly on this nano. Thanks.
                                  • D
                                    DavidZH
                                    @GertSanders
                                    I have been running your bootloader for all my nodes now and that works very well.
                                    But there is something that surprised me. When I compile the next sketch and compare that with the Moteino bootloader it's substantially larger.
                                    ** Outdoor sensor v1.0 Measuring temperature, humdity, pressure and light level
                                    **  Calculating a weather forecast with the height comensated air pressure.
                                    **      powered by a solar panel and a 1000mAh Li-Ion battery.
                                    ** Scraped together by D Hille. MySensors library by Henrik Ekblad et al.
                                    **      Heat index calculation from DHT library by Adafruit
                                    **      MAX44009 bij Rob Tillaart
                                    **      Weather forecast based on AN3914 by Freescale
                                    //                    MySensors definitions
                                    //#define MY_DEBUG                      // Enable debug prints (6 kb flash space)
                                    //#define MY_DEBUG_VERBOSE_SIGNING      // Comment out when no signing is used or when everything is OK (3 kb flash space)
                                    #define MY_BAUD_RATE 57600            // Set serial baudrate
                                    #define MY_RADIO_RFM69                // Enable and select radio type attached
                                    //#define MY_IS_RFM69HW                 // Comment out when using standard RFM69W
                                    #define MY_NODE_ID 110                 // Delete to use automatic ID assignment
                                    //#define MY_CORE_ONLY
                                    //                        Transport
                                    //#define MY_TRANSPORT_WAIT_READY_MS 1000 //Start the node even if no connection to the GW could be made (disable for sensor nodes).
                                    #define MY_TRANSPORT_STATE_RETRIES 1
                                    #define MY_TRANSPORT_MAX_TSM_FAILURES    (2u)
                                    #define MY_TRANSPORT_TIMEOUT_EXT_FAILURE_STATE (60*1000ul)
                                    //                        Security
                                    //#define MY_SIGNING_ATSHA204
                                    //#define MY_SIGNING_SOFT
                                    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 0,.serial = {0xD0,0xB1,0x90,0x99,0xC3,0x03,0x08,0xD1,0x34}}}
                                    //                    Sensor definitions
                                    #define BATTERY_POWERED
                                    #define battUpdater 300           //Number of TX actions to count before a new battery status update is sent.
                                    #define MY_DEFAULT_TX_LED_PIN 5   // Comment out when no LED is attached.
                                    #define SENSOR_TYPE 3
                                    // Sensor types:
                                    // 0.: no climate sensor attached
                                    // 1.: RFM69 on-die               Temperature sensor on the RFM69 module (whole integers only)
                                    // 2.: DS18B20                    Dallas one-wire sensor(data pin D14)
                                    // 3.: HTU21D                     Temp/humidity (I2C)
                                    // 4.: BME280                     Temp/humidity/pressure (I2C) (node will wake every minute to keep up with trend measureing)
                                    #define SENSOR_UPDATE 2           // Time in minutes the sensor sends an update
                                    //#define LIGHT_SENSOR_PRESENT      // Comment out when not present. (I2C) (Light sensor will update every 60 seconds.)
                                    //#define INTERRUPT_SENSOR_PRESENT  // Comment out when not present (e. g. motion sensor connect to D3)
                                    #define alti 57                  //altitude offset to compensate the barometric pressure
                                    //                  Debug definitions
                                    //#define LOCAL_DEBUG                              //Comment out to switch all debug messages off (saves 2 kb flash)
                                    #ifdef MY_DEBUG                                  //Differentiate between global debug including radio and local debug
                                      #define LOCAL_DEBUG                            //for the sketch alone.
                                    #ifdef LOCAL_DEBUG
                                      #define Sprint(a) (Serial.print(a))            // Macro as substitute for serial debug. Will be an empty macro when
                                      #define Sprintln(a) (Serial.println(a))        // debug is switched off
                                      #define Sprint(a)
                                      #define Sprintln(a)
                                    #include <Button.h>
                                    //#include <SparkFunBME280.h>
                                    //#include <MAX44009.h>                           // Uncomment library used in sketch
                                    #include <Adafruit_HTU21DF.h>
                                    //#include <OneWire.h>
                                    //#include <DallasTemperature.h>
                                    #include <Vcc.h>
                                    #define BMEaddr 0x76
                                    #define Max44099Addr 0x4A
                                    #define sketchName "sensorNode(living)"
                                    #define sketchVer "1.0"
                                    #define sensorPowerPin 20
                                    #define digitalSensorPin 14
                                    #define analogSensorPin A0
                                    #define oneWireBusPin 14
                                    #define interruptPin 3
                                    #define altSensorPin 18
                                    #define altAnalogPin A4
                                    #define sensorPowerPin 6
                                    #define chanTemp 0
                                    #define chanHum 1
                                    #define chanHeat 2
                                    #define chanBaro 3
                                    #define chanDelta 4
                                    #define chanLight 5
                                    #define chanRate 6
                                    #define chanInterrupt 8
                                    #define PULLUP false
                                    #define INVERT false
                                    #define bounceTime 20
                                    #define sleepWait 500           //Time to wait in ms before node sleeps (to be able to receive notification messages).
                                    bool battPower = true;
                                    unsigned long currTime = 0;
                                    unsigned long sleepTime = (60000 * SENSOR_UPDATE);
                                    unsigned long lastSensorUpdate;
                                    unsigned long nextSensor;
                                    unsigned long measureTime;
                                    int wakeReason = -1;
                                    int sendLoop = 0;
                                    bool updated = false;
                                    bool ACKed = false;
                                    int sensorFunc = 0;
                                    float sensorData = 0.0;
                                    float heatTemp = 0.0;
                                    float heatHum = 0.0;
                                    bool interruptState = false;
                                    bool lastInterrupt = false;
                                    bool sensorPresent = false;
                                    bool lightPresent = false;
                                    bool interruptPresent = false;
                                    int minuteCount = 0;
                                    bool firstRound = true;
                                    float pressureAvg;               // average value is used in forecast algorithm.
                                    float pressureAvg2;              // average after 2 hours is used as reference value for the next iteration.
                                    float dP_dt;
                                    const int LAST_SAMPLES_COUNT = 5;
                                    float lastPressureSamples[LAST_SAMPLES_COUNT];
                                    bool startUp = true;
                                    bool metric = true;
                                    int battStatCounter = 0;
                                    const float VccMin = 1.8;                   // Minimum expected Vcc level, in Volts.
                                    const float VccMax = 3.0;                   // Maximum expected Vcc level, in Volts.
                                    const float VccCorrection = 1.0/1.0;      // Measured Vcc by multimeter divided by reported Vcc
                                    //                  Library declarations
                                    //  Uncomment necessary declarations.
                                    //RFM69 wireless;
                                    //OneWire OWB(oneWireBusPin);
                                    //DallasTemperature DS18(&OWB);
                                    //DeviceAddress DS18address;
                                    Adafruit_HTU21DF HTU = Adafruit_HTU21DF();
                                    //BME280 BME;
                                    //Max44009 lightMax(Max44099Addr);
                                    //Button reedContact(interruptPin, PULLUP, INVERT, bounceTime);
                                    MyMessage msgHum(chanHum, V_HUM);
                                    MyMessage msgTemp(chanTemp, V_TEMP);
                                    //MyMessage msgBaro(chanBaro, V_PRESSURE);
                                    //MyMessage msgTrend(chanUniversal, V_VAR5);
                                    //MyMessage msgLight(chanLight, V_LEVEL);
                                    //MyMessage msgIntr(chanInterrupt, V_TRIPPED);
                                    Vcc vcc(VccCorrection);
                                    //                  Error messages
                                      #if (defined INTERRUPT_SENSOR_PRESENT && defined LIGHT_SENSOR_PRESENT && SENSOR_TYPE >= 4)
                                        #error Motion sensor can anly be combined with either I2C OR one-wire sensors, not both.
                                      #if (defined INTERRUPT_SENSOR_PRESENT && (defined LIGHT_SENSOR_PRESENT || SENSOR_TYPE == 4) && defined BATTERY_POWERED)
                                        #error Interrupt sensor is not compatible with trend sensors like 'baro' and 'light' because the timer will misalign.
                                      #if (SENSOR_TYPE > 4)
                                        #error Not a valid sensor type!
                                    void before(void)
                                      Serial.println("\nReading config...");
                                      #ifndef BATTERY_POWERED
                                        battPower = false;
                                      sensorFunc = SENSOR_TYPE;
                                      #ifdef LIGHT_SENSOR_PRESENT
                                        lightPresent = true;
                                      #ifdef INTERRUPT_SENSOR_PRESENT
                                        interruptPresent = true;
                                        lastInterrupt = reedContact.read();
                                      #if (defined MY_SIGNING_SOFT || defined MY_SIGNING_ATSHA204)
                                        #define sendPause 100
                                        #define sendPause 50
                                    void setup(void)
                                      pinMode(sensorPowerPin, OUTPUT);       //switch on the sensor power
                                      digitalWrite(sensorPowerPin, HIGH);
                                      wait(50);                              //wait 50 ms for the sensors to settle.
                                      switch (sensorFunc) {
                                        case 0:
                                        case 1:
                                          sensorPresent = true;
                                        case 2:
                                          //DS18.begin();
                                          //DS18.getAddress(DS18address, 0);
                                          //DS18.setResolution(DS18address, 10);
                                        case 3:
                                          HTU.begin();
                                        case 4:
                                          //startBME();
                                          sleepTime = 60000;
                                      #if (lightPresent)
                                        sleepTime = 60000;
                                        sleepTime = 30000;              //for the sketch alone.
                                      batteryStats();
                                      Serial.println("\nDone. \n\nStarting program.\n");
                                      currTime = millis();
                                      Serial.println("Start radio and sensors");
                                      sendSketchInfo(sketchName, sketchVer);
                                      Sprint("\nPresent ");
                                      if (sensorFunc >= 1) {
                                        wait(sendPause);
                                        present(chanTemp, S_TEMP, "Climate", true);
                                        Sprint("temperature");
                                      if (sensorFunc >= 3) {
                                        wait(sendPause);
                                        present(chanHum, S_HUM);
                                        Sprint(", humidity");
                                        //wait(sendPause);
                                        //present(chanHeat ,S_TEMP);
                                        //Sprint(", heatindex");
                                      if (sensorFunc == 4) {
                                        wait(sendPause);
                                        present(chanBaro, S_BARO);
                                        Sprint(", barometric");
                                        wait(sendPause);
                                        present(chanDelta, S_CUSTOM);
                                        Sprint(" and rate");
                                      Sprintln(" sensor.");
                                      if (lightPresent) {
                                        wait(sendPause);
                                        present(chanLight, S_LIGHT_LEVEL, "Light", true);
                                        Sprintln("\nLightsensor ");
                                        if (sensorFunc < 4) {
                                          wait(sendPause);
                                          present(chanRate, S_CUSTOM);
                                          Sprintln("with rate ");
                                        Sprintln("presented.");
                                      if (interruptPresent) {
                                        wait(sendPause);
                                        present(chanInterrupt, S_MOTION, "Motion", true);
                                        Sprintln("Interrupt sensor presented.");
                                      wait(sendPause);
                                    void loop(void)
                                      if (wakeReason < 0) {
                                        Serial.println("Reading sensors...");
                                          case 0:
                                          case 1:
                                            updateRFM();
                                          case 2:
                                            updateDS18();
                                          case 3:
                                            updateHTU();
                                          case 4:
                                            if (sendLoop <= 0) {
                                              updateBME();
                                              updated = true;
                                            else {
                                              Sprint("\nTrend: ");
                                              updateTrend();
                                              sendLoop--;
                                        if (lightPresent) {
                                          updateMAX();
                                          if (sensorFunc <= 3) {
                                            updateTrend();
                                        wakeReason = 0;
                                        Sprintln("\nSensors updated...");
                                      else if (wakeReason == 1) {
                                        updateInterrupt();
                                        wakeReason = 0;
                                      if (battStatCounter >= battUpdater) {
                                        batteryStats();
                                      if (updated) {
                                        sendLoop = SENSOR_UPDATE;
                                        updated = false;
                                      if (millis() >= currTime + sleepWait) {
                                        startUp = false;
                                        sleepSensor();
                                    void updateInterrupt()
                                      Sprintln("\nInterrupt: ");
                                      interruptState = reedContact.read();
                                      wait(50);
                                      if (interruptState == !lastInterrupt) {
                                        send(msgIntr.setSensor(chanInterrupt).set(interruptState),true);
                                        lastInterrupt = interruptState;
                                      Sprint("Door/window is ");
                                      if (interruptState) {
                                        Sprintln("opened.");
                                      else {
                                        Sprintln("closed");
                                    void updateRFM()
                                      Sprintln("\nRFM: ");
                                      sensorData = wireless.readTemperature();
                                      wait(20);
                                      send(msgTemp.set(sensorData, 0));
                                      Sprint("Temperature: \t"); Sprint(sensorData); Sprintln(" sent.");
                                      battStatCounter++;*/
                                    void updateDS18()
                                      Sprintln("\nOne-wire: ");
                                      DS18.requestTemperatures();
                                      sensorData = DS18.getTempCByIndex(0);
                                      wait(20);
                                      send(msgTemp.set(sensorData, 2));
                                      battStatCounter++;
                                      Sprint("Temperature: "); Sprint(sensorData); Sprintln(" sent.");*/
                                    void updateHTU()
                                      Sprintln("\nHTU: ");
                                      sensorData = HTU.readTemperature();
                                      heatTemp = sensorData;
                                      wait(20);
                                      send(msgTemp.set(sensorData, 1));
                                      sensorData = HTU.readHumidity();
                                      heatHum = sensorData;
                                      wait(sendPause);
                                      send(msgHum.set(sensorData, 1));
                                      Sprint("Humidity: \t"); Sprint(sensorData); Sprintln(" sent.");
                                      //wait(sendPause);
                                      //send(msgHeat.set(computeHeatIndex(heatTemp, heatHum), 1));
                                      //Sprint("Heatindex sent.");
                                      battStatCounter++;
                                    void updateBME()
                                      /*Sprintln("\nBME: ");
                                      BME.begin();
                                      wait(100);
                                      sensorData = (BME.readFloatPressure()/pow(1-(alti/44330.0),5.255)/100);
                                      if (!startUp) {
                                        trend(sensorData);
                                        send(msgBaro.set(sensorData,1));
                                        Sprint("Pressure: \t"); Sprint(sensorData); Sprintln(" sent.");
                                      if (!(minuteCount < 35 && firstRound)) {
                                        wait(sendPause);
                                        send(msgTrend.set(dP_dt,2));
                                        Sprint("Trend: \t\t"); Sprint(dP_dt); Sprintln(" sent.");
                                      wait(sendPause);
                                      sensorData = BME.readTempC();
                                      send(msgTemp.set(sensorData,1));
                                      wait(sendPause);
                                      sensorData = BME.readFloatHumidity();
                                      send(msgHum.set(sensorData,1));
                                      wait(sendPause);
                                    float computeHeatIndex(float tempInput, float humInput)       //Function derived from Adafruit DHT library
                                      /*// Using both Rothfusz and Steadman's equations
                                      // http://www.wpc.ncep.noaa.gov/html/heatindex_equation.shtml
                                      float hiFar;
                                      float tempFar = tempInput * 1.8 + 32;
                                      hiFar = 0.5 * (tempFar + 61.0 + ((tempFar - 68.0) * 1.2) + (humInput * 0.094));
                                      if (hiFar > 79) {
                                        hiFar = -42.379 +
                                                 2.04901523 * tempFar +
                                                10.14333127 * humInput +
                                                -0.22475541 * tempFar*humInput +
                                                -0.00683783 * pow(tempFar, 2) +
                                                -0.05481717 * pow(humInput, 2) +
                                                 0.00122874 * pow(tempFar, 2) * humInput +
                                                 0.00085282 * tempFar*pow(humInput, 2) +
                                                -0.00000199 * pow(tempFar, 2) * pow(humInput, 2);
                                        if((humInput < 13) && (tempFar >= 80.0) && (tempFar <= 112.0))
                                          hiFar -= ((13.0 - humInput) * 0.25) * sqrt((17.0 - abs(tempFar - 95.0)) * 0.05882);
                                        else if((humInput > 85.0) && (tempFar >= 80.0) && (tempFar <= 87.0))
                                          hiFar += ((humInput - 85.0) * 0.1) * ((87.0 - tempFar) * 0.2);
                                      return (hiFar - 32) * 0.55555;*/
                                    void updateTrend()
                                      /*if (sensorFunc == 4) {
                                       * Sprint("BME -> ");
                                        BME.begin();
                                        wait(100);
                                      else if (lightPresent) {
                                        Sprint("MAX -> ");
                                        sensorData = lightMax.getLux();
                                      trend(sensorData);*/
                                    void updateMAX()
                                      /*Sprintln("\nLight: ");
                                        trend(sensorData);
                                      send(msgLight.set(sensorData,1));
                                      Sprint("Light: \t"); Sprint(sensorData); Sprintln(" sent.");
                                          wait(sendPause);
                                          Sprint("Trend: \t"); Sprint(dP_dt); Sprintln(" sent.");
                                    void sleepSensor()
                                      if (battPower) {
                                        Serial.println("\nSleep the sensor.");
                                        wait(50);
                                        unsigned long lightsOut = (sleepTime - (millis() - currTime));
                                          if (sensorPresent) {
                                            wakeReason = sleep(1, CHANGE, lightsOut);
                                          else {
                                            wakeReason = sleep(1, CHANGE, 0);
                                        else {
                                          //digitalWrite(sensorPowerPin, LOW);      //Disabled because of the I2C pull ups on the HTU board
                                          sleep(lightsOut);                         //causing a 140uA load in sleep. Without, sleep drain is 5uA.
                                          wakeReason = -1;
                                          //digitalWrite(sensorPowerPin, HIGH);
                                          wait(50);
                                        Sprint("Wake reason: ");Sprintln(wakeReason);
                                      else if (millis() >= currTime + sleepTime) {
                                        wakeReason = -1;
                                    /*void startBME()
                                      BME.settings.commInterface = I2C_MODE;
                                      BME.settings.I2CAddress = BMEaddr;
                                      BME.settings.runMode = 1;            //  1, Single mode
                                      BME.settings.tStandby = 0;           //  0, 0.5ms
                                      BME.settings.filter = 0;             //  0, filter off
                                      BME.settings.tempOverSample = 1;
                                      BME.settings.pressOverSample = 1;
                                      BME.settings.humidOverSample = 1;
                                      BME.begin();
                                    float getLastPressureSamplesAverage()
                                      float lastPressureSamplesAverage = 0;
                                      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                                        lastPressureSamplesAverage += lastPressureSamples[i];
                                      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                                      return lastPressureSamplesAverage;
                                    void trend(float pressure)
                                      int index = minuteCount % LAST_SAMPLES_COUNT;                 // Calculate the average of the last 5 minutes.
                                      lastPressureSamples[index] = pressure;
                                      minuteCount++;
                                      if (minuteCount > 185)
                                        minuteCount = 6;
                                      if (minuteCount == 5)
                                        pressureAvg = getLastPressureSamplesAverage();
                                        Sprint("First average: "); Sprint(pressureAvg);
                                      else if (minuteCount == 35)
                                        float lastPressureAvg = getLastPressureSamplesAverage();
                                        float change = (lastPressureAvg - pressureAvg);
                                        if (firstRound)                                             // first time initial 3 hour
                                          dP_dt = change * 2;                                       // note this is for t = 0.5hour
                                          dP_dt = change / 1.5;                                     // divide by 1.5 as this is the difference in time from 0 value.
                                      else if (minuteCount == 65)
                                        if (firstRound)                                             //first time initial 3 hour
                                          dP_dt = change;                                           //note this is for t = 1 hour
                                          dP_dt = change / 2;                                       //divide by 2 as this is the difference in time from 0 value
                                      else if (minuteCount == 95)
                                          dP_dt = change / 1.5;                                     // note this is for t = 1.5 hour
                                          dP_dt = change / 2.5;                                     // divide by 2.5 as this is the difference in time from 0 value
                                      else if (minuteCount == 125)
                                        pressureAvg2 = lastPressureAvg;                             // store for later use.
                                          dP_dt = change / 2;                                       // note this is for t = 2 hour
                                          dP_dt = change / 3;                                       // divide by 3 as this is the difference in time from 0 value
                                      else if (minuteCount == 155)
                                          dP_dt = change / 2.5;                                     // note this is for t = 2.5 hour
                                          dP_dt = change / 3.5;                                     // divide by 3.5 as this is the difference in time from 0 value
                                      else if (minuteCount == 185)
                                          dP_dt = change / 3;                                       // note this is for t = 3 hour
                                          dP_dt = change / 4;                                       // divide by 4 as this is the difference in time from 0 value
                                        pressureAvg = pressureAvg2;                                 // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                                        firstRound = false;                                         // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
                                      Sprint(F("\tForecast at minute "));
                                      Sprint(minuteCount);
                                      Sprint(F(" dP/dt = "));
                                      Sprint(dP_dt);
                                      Sprint(F("hPa/h --> "));*/
                                    void batteryStats()
                                      if (battPower) {
                                        float battPct = vcc.Read_Perc();
                                        float battVolt = vcc.Read_Volts();
                                        wait(50);
                                        sendBatteryLevel(battPct);
                                        Sprint("Battery level: "); Sprint(battVolt); Sprintln("V.\n");
                                        wait(50);
                                    void sendBattLevel()
                                      /*Serial.println("\nBattery: ");
                                      int ADread = analogRead(batteryPin);
                                      int battPcnt = map(ADread, 570, 704, 0, 100);  //Usable voltage range from 3.4 to 4.2V
                                      battPcnt = constrain(battPcnt, 0, 100);        //Charging keeps it at 100%
                                      sendBatteryLevel(battPcnt);
                                      Sprint("\nADread\t"); Sprint(ADread); Sprint("\t"); Sprintln(battPcnt);
                                      battStatCounter = 0;*/
                                    GertSanders ATMega328p 32p TFQP, 8MHz, 38400baud
                                    Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
                                    Sketch uses 16,680 bytes (51%) of program storage space. Maximum is 32,256 bytes.
                                    Global variables use 942 bytes (45%) of dynamic memory, leaving 1,106 bytes for local variables. Maximum is 2,048 bytes.
                                    LowPowerLab Moteino 16MHz
                                    Sketch uses 14,264 bytes (44%) of program storage space. Maximum is 31,744 bytes.
                                    Global variables use 890 bytes of dynamic memory.
                                    In this sketch the size difference doesn't matter that much. But when I introduce signing it will get tight.
                                    Any thoughts?
                                    (This is a standard sketch which I adapt for every node by commenting out the parts I do not need. So it might seem large for a simple temperature node. It is...).
                                    • D DavidZH
                                      @GertSanders
                                      //                        Transport
                                      //                        Security
                                      // Sensor types:
                                      #ifdef LOCAL_DEBUG
                                        #define Sprint(a)
                                        #define Sprintln(a)
                                      #include <Button.h>
                                      #include <Vcc.h>
                                      #define chanTemp 0
                                      #define chanHum 1
                                      #define chanHeat 2
                                      #define chanBaro 3
                                      #define chanDelta 4
                                      #define chanLight 5
                                      #define chanRate 6
                                      int sendLoop = 0;
                                      bool ACKed = false;
                                      int sensorFunc = 0;
                                      float dP_dt;
                                      bool metric = true;
                                      //RFM69 wireless;
                                      //BME280 BME;
                                      //                  Error messages
                                      void before(void)
                                          battPower = false;
                                      void setup(void)
                                          case 0:
                                          case 1:
                                          case 2:
                                            //DS18.begin();
                                          case 3:
                                            HTU.begin();
                                          case 4:
                                            //startBME();
                                            sleepTime = 60000;
                                        #if (lightPresent)
                                          sleepTime = 60000;
                                        batteryStats();
                                          wait(sendPause);
                                          wait(sendPause);
                                          //wait(sendPause);
                                          wait(sendPause);
                                          wait(sendPause);
                                        if (lightPresent) {
                                          wait(sendPause);
                                            wait(sendPause);
                                          wait(sendPause);
                                        wait(sendPause);
                                      void loop(void)
                                            case 0:
                                            case 1:
                                              updateRFM();
                                            case 2:
                                              updateDS18();
                                            case 3:
                                              updateHTU();
                                            case 4:
                                                updateBME();
                                                updated = true;
                                              else {
                                                updateTrend();
                                                sendLoop--;
                                          if (lightPresent) {
                                            updateMAX();
                                              updateTrend();
                                          wakeReason = 0;
                                          updateInterrupt();
                                          wakeReason = 0;
                                          batteryStats();
                                        if (updated) {
                                          updated = false;
                                          startUp = false;
                                          sleepSensor();
                                        wait(50);
                                        else {
                                          Sprintln("closed");
                                      void updateRFM()
                                        wait(20);
                                      void updateDS18()
                                        wait(20);
                                        battStatCounter++;
                                      void updateHTU()
                                        wait(20);
                                        wait(sendPause);
                                        //wait(sendPause);
                                        battStatCounter++;
                                      void updateBME()
                                        BME.begin();
                                        wait(100);
                                        if (!startUp) {
                                          trend(sensorData);
                                          wait(sendPause);
                                        wait(sendPause);
                                        wait(sendPause);
                                        wait(sendPause);
                                        float hiFar;
                                        if (hiFar > 79) {
                                          hiFar = -42.379 +
                                      void updateTrend()
                                          BME.begin();
                                          wait(100);
                                          Sprint("MAX -> ");
                                      void updateMAX()
                                          trend(sensorData);
                                            wait(sendPause);
                                      void sleepSensor()
                                        if (battPower) {
                                          wait(50);
                                            else {
                                          else {
                                            wakeReason = -1;
                                            wait(50);
                                          wakeReason = -1;
                                      /*void startBME()
                                        BME.begin();
                                        minuteCount++;
                                          minuteCount = 6;
                                        Sprint(dP_dt);
                                      void batteryStats()
                                        if (battPower) {
                                          wait(50);
                                          wait(50);
                                      Any thoughts?
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @DavidZH
                                      Do you also get these differences when compiling for both 16Mhz ? In this case one node is 16MHz (Moteino) and the second is 8MHz.
                                      Apart from that I have no clue why this would result in different sizes.
                                      • D
                                        DavidZH
                                        I have tried with your bootloader on 16MHz and 8 MHz with crystal.
                                        8MHz, crystal, 1V8
                                        16MHz, crystal, 1V8
                                        Sketch uses 16,694 bytes (51%) of program storage space. Maximum is 32,256 bytes.
                                        So the 16Mhz file is actally even a bit bigger. I also tried if changing the BOD voltage would change anything, but nope on that.
                                        Might be something to look into in a spare hour.
                                        • mar.conteM
                                          mar.conteM
                                          mar.conte
                                          hy,
                                          can anyone tell me what is the word near cpu 8mhz-38k4-d13 etc..??
                                          tanks
                                          M.C.
