  3. Home security and automation project
4 Posts 3 Posters 2.1k Views 1 Watching
  • R Offline
    R Offline
    rheslip
    My home sensor network is documented here:
    part 1 - http://rheslip.blogspot.ca/2014/09/mysensors-internet-of-things-project.html
    part 2 - http://rheslip.blogspot.ca/2014/09/the-mysensor-iot-project-part-2-some.html
    I implemented a custom network controller using a Mega1284 (lots of SRAM and flash) and a dedicated Mega328 to run the sensor gateway code. A cheap ENC28J20 SPI ethernet module connects to my LAN and the internet. I monitor what's happening with a web page on the LAN and Twitter when I'm not at home. Works really well!
    It was easy to get the sensor nodes working by modifying the example sketches. I used the sample node.js controller code as a guide to write the Mega1284 controller sketch.
    Still lots of things to do and ideas for expanding the network. I would never have attempted something this complex from scratch - kudos to the mysensors crew on a fantastic project!!!
    Rich
    B 1 Reply Last reply
    • R rheslip
      Rich
      B Offline
      B Offline
      bjornhallberg
      @rheslip Looks great! I see you're using the less common "mini / smd" version of the nrf24 pcb. Is it working as intended in terms of range and all?
      • hekH Offline
        hekH Offline
        Cool. Thanks for sharing!
        • R Offline
          R Offline
          rheslip
          I have only used that radio for one node so far - one of the LCD clocks. Its only about 30ft from the controller but it does go though a couple of walls. Communication is pretty much 100% at that range. I used the larger antenna radios for the longer distances - e.g. the garage which is 50ft or so and about 4 walls but its very consistent.
          Rich
