  3. livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz
135 Posts 31 Posters 135.4k Views 44 Watching
  • DJONvlD DJONvl
    сегодня доделал Livolo+esp8266 пришлось помучаться с программой и схемой питания но все заработало[0_1485259118390_livolo_esp.mp4](Uploading 100%)
    jirmJ
    jirmJ
    jirm
    wrote on last edited by jirm
    #73
    @DJONvl
    Woow !
    Livolo+Esp8266 working ??? ... sounds very good.
    But we can not see the video seems you try to upload here ... :-(
    • DJONvlD DJONvl
      DJONvlD
      DJONvlD
      DJONvl
      @DJONvl said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
      https://youtu.be/8euAeVB86CQ
      jirmJ aivsA maxtoxM 3 Replies Last reply
      • DJONvlD DJONvl
        jirmJ
        jirmJ
        jirm
        #75
        @DJONvl
        Yesss @DJONvl . Thats is !!!! .
        You got it !!!
        Please can you post all the details about how you are do it ??
        How you are managed to achieve enough power from Livolo ??
        How you wired the esp8266 and where on the livolo switch ??
        You can post the schematic ??
        Please, all details you can...
        Regards
        • DJONvlD DJONvl
          aivsA
          aivsA
          aivs
          @DJONvl
          Esp потребляет более 350мА.
          Покажешь схему питания?
          Esp consumes more then 350mA.
          Can you show power schematic?
            Markhill
            For the AU/US plate, can anyone confirm that this is the correct wiring for
            SW1 = Switch Right on/off
            SW2 = Switch Left on/off
            SS1 = Right Status on/off
            SS2 = Left Status on /off
            GND = Ground
              Markhill
              For power, I found these on the board. The 12V accutally read 14.86V for the two Switch gang and 14.10V for the 1 gang switch. This was me using the multimeter connecting with ground.
              1 Gang Switch even have indication of the board
              2 Gang Switch
              Nca78N 1 Reply Last reply
              • M Markhill
                2 Gang Switch
                @Markhill for switching on/off the relays it's not that simple. On the 'main' board there is a decoder connected to 3 pins or the MCU and on the 2x7 header.
                Check in one of my messages above for the pin out on the header.
                • Nca78N Nca78
                  Markhill
                  @Nca78 Hi, I was thinking of using this to connect to the switch. The guy sell this for about $15.00US each
                  The controller require external power 5-12v. I was thinking of using power from the switch.
                  • Nca78N
                    @Markhill it cannot work, this board needs external power because the ESP8266 he is using is too power hungry, the switch cannot provide enough power. And this board is sized for EU switch it will not work with US or US/AU switch.
                    I'm working on 3 buttons and 4 buttons version with atmega and nrf24, power from the swith is enough so it's just a plug&play replacement. I'm testing the 3 buttons switch at the moment (same layout than 1 button in which only the center button is connected). It will be cheaper than 15$ if you solder it yourself, if you don't want to do smd soldering we can probably find a solution for pre-assembled boards.
                    M A 2 Replies Last reply
                    • Nca78N Nca78
                      Markhill
                      @Nca78 I'm in. Plug and play, same size, no external power and cheaper too. When will it be ready?
                      Btw, your board will be able fit on a 3 buttons and 4 buttons too right? I got them.
                      Will it provide status feed back, control remotely on phone app or ioBroker and is there any coding required?
                        Samuel235
                        Keep us updated on your development, i'm working on a double relay module for lighting but i doubt its going to fit inside of a single gang wall box.
                        MySensors 2.1.1
                        • M Markhill
                          @Markhill I have made 2 boards, one for 1/3 buttons, one for 4 buttons.
                          It will be a MySensors actuator so yes status feedback etc.
                          I'll make a script for basic switch function and probably a few extra things two. I'm planning to use 3 button switches in my home to command 2 light circuits with the top and bottom buttons, and AC with center button (not using the relay). I have included 2 extra leds on center button for that, to select different modes of AC.
                          The 4 buttons version uses sx1509 extender to have more advanced feedback like breathing/flashing LEDs but it's probably not in a final form yet, it will take more time to be ready.
                            Markhill
                            wrote on last edited by Markhill
                            #85
                            Here are pictures of the US/AU 2 switch main board
                            Here is a 4 gang US/AU
                            Here is a 3 Gang US/AU
                            • Nca78N Nca78
                              Markhill
                              @Nca78 said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
                              Can you send me the 1/3 buttons so I can test it?
                              The switch I use at home is a 3 gang 2 way. That is one light control by two switches. Will your board still work with these?
                              • M Markhill
                                I don't know about the 2 way switches so don't have one to check. But in my home I will just connect one side to a normal switch and use switch on the other side as radio switch only without the relay.
                                You want a 1/3 switch PCB ? Where do you live ?
                                  Samuel235
                                  Do you guys happen to know what the capacitive touch button part is called? I'm trying to look for some of these on the internet and getting nothing relevant coming up. Just the little glass/acrylic parts of the livolo switches that recognise your touch.
                                  MySensors 2.1.1
                                  • S Samuel235
                                    @Samuel235 there is no "capacitive touch button part", the touch function is managed directly by the IC of the board.
                                    So they just have an electrode (big circle of copper) connected to an IC pin and a plastic circle glued to it to have more even light from the led.
                                    What I am using is TTP223N (N version is more sensible) which is both very cheap and very easy to use
                                    S 1 Reply Last reply
                                    • Nca78N Nca78
                                      Samuel235
                                      #90
                                      Not sure I completely get what you mean, but I will have a search for how these little IC's work. Their datasheet looks pretty nice tbh, small, low cost, easy to get. Do they basically look for a 'press' on their input and then output 1 or 0 to a MCU, one on each button too, correct?
                                      MySensors 2.1.1
                                      • S Samuel235
                                        @Samuel235 They just have one output. You can have them work in "toggle" mode (press to set output high, press again to set output low) or in "normal" mode (default behavior) then output is high when touch is detected.
                                        So yes, one ttp223 on each button. You can use other ics (TTP224 with 4 touch inputs for example) but I prefer TTP223 as you can put it very close to the touch electrode to avoid interferences.
                                        TTP223 is the IC that is used in all the cheap "one touch button" breakout boards on ebay/aliexpress/...
                                        S A 2 Replies Last reply
                                        • Nca78N Nca78
                                          Samuel235
                                          #92
                                          @Nca78 - These little beauties are perfect! I feel a light switch project coming on myself.... How is your development coming on?
                                          Have you seen this: https://forum.mysensors.org/topic/4317/us-decora-style-wall-switch
                                          Looks like it could be neat. But, not touch. Not sure what i would prefer tbh. Either way, i have myself a dual relay board that i'm in the finishing touches too before posting it up here and on Openhardware.IO.
                                          How're you going about your switching, are you switching AC in the light switch, powering this from AC or DC or are you powering by battery and emitting wireless signals to the gateway to then switch relays not connected to this board?
                                          MySensors 2.1.1
