  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • sundberg84S sundberg84
    @fhenryco - if you are experience changes it might help adding a wait(); or delay(); to get a more stable reading. If something is using power just as you read it might be strange values.
    This is one of my sketches (DHT + Bat): https://github.com/sundberg84/MySensors2.0.0/blob/master/NorrHumAs/NorrHumAs.ino and im using the voltage divider to A0 to measure the battery.
    fhenrycoF
    fhenrycoF
    fhenryco
    @sundberg84 thanks,
    the delay 500 has a big effect , now i get 116% hence a battery voltage=3.5V, while the multimeter gives it 3V ! may be the internal reference is not 1.1V in my low cost chinese pro mini 3.3v .
    BTW i did not understand why you have also a delay 500 after reading the analog pin, i would have thought that a delay before reading the analog pin is sufficient ... (?)
    • fhenrycoF fhenryco
      @sundberg84 thanks,
      sundberg84S
      sundberg84S
      @fhenryco - could be the delay before is sufficient.
      • fhenrycoF
        fhenrycoF
        fhenryco
        wrote on last edited by fhenryco
        this morning , i get 102% , much closer to the actual value ... assuming that the ADC activity did not discharge my battery at an unprecedented level (i had this sketch working for two monthes with very little discharge of the battery before adding this battery monitoring functionality). I will know for sure if the battery level does not drop further in the coming days...i'm concerned that the delay 500 might produce non negligible battery consumption
          sundberg84S
          sundberg84S
          @fhenryco Its hard to reach a 100% correct value on the chinese clones. I get a 5% off probably all the time. Because of that I have added an average so I collect three values every 20min into an array and send the average every hour.
          • fhenrycoF
            fhenrycoF
            fhenryco
            ok, thanks again, something else i v been wondering about is why domoticz will show the temp + humidity sensor as a single sensor even though there are separate instructions
            for the presentation :
            present(CHILD_ID_HUM, S_HUM);
            and for the messages themselves
            what should be modified if i want domoticZ to treat the two sensors separately ? (this is for Yana, a speech recognition software that has a plugin for domoticZ, but apparantly is not able to handle several values for a given sensor).
            is it the sendSketchInfo("TemperatureAndHumidity", "1.1"); that needs to be replaced by two sendSketchInfo, one for temp and one for humidity ?
            fhenrycoF 1 Reply Last reply
              fhenrycoF
              fhenrycoF
              fhenryco
              @fhenryco apparantly something like send(msgTemp.setSensor(CHILD_ID_TEMP).set(temperature,1));
              send(msgHum.setSensor(CHILD_ID_HUM).set(humidity,1));
              should do the job ! going to try that
              but i'm surprised this is not done by default since msgHum and msgTemp are defined separately for each sensor Id
                fhenrycoF
                fhenrycoF
                fhenryco
                @fhenryco it did nothing different ... still have a single sensor temp+hum don't understand why ...
                  sundberg84S
                  sundberg84S
                  @fhenryco - Yes, and there is a trick to seperate them... and i if I remembe right @AWI is the one to ask.
                  Edit, found his post here: https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/13
                  • fhenrycoF
                    fhenrycoF
                    fhenryco
                    using V_text and S_info is a workaround to avoid grouping
                    • R
                      R
                      Rene046
                      i would like to ask something to ,
                      Now i have the battery level showing up in Domoticz what can i do to log the voltage in volts, should i add something inside the sketch or something in domoticz..
                      fhenrycoF AWIA 2 Replies Last reply
                      • R Rene046
                        fhenrycoF
                        fhenrycoF
                        fhenryco
                        @Rene046
                        This is the instruction in your sketch which allows to see the battery level of devices in domoticZ
                        But as you noticed , this is not reported in the logs. One possibility to see it in the Log is to as well send this batteryPcnt information with a send(msgbatt.set(batteryPcnt ,1);
                        provided you have defined
                        MyMessage msgbatt(CHILD_ID_BATT, V_TEXT);
                        In other words you send the battery info as if it was the info of an additional sensor sending text type info
                        which you also need to present in the presentation void with
                        present(CHILD_ID_BATT, S_INFO);
                        For instance if you already have two sensors in you sketch let's say temp and hum with ID =0 and 1 respectively you would give the battery level the next unused ID
                        CHILD_ID_BATT=2
                        There might be a simpler and more natural way but i don't know it .
                        • R Rene046
                          AWIA
                          AWIA
                          AWI
                          @Rene046 The "royal" way to report battery level is to define it as S_MULTIMETER and use it to report voltage. Domoticz will take the voltage and can graph it. i.e.
                          definitions: MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                          in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
                          sending: send(voltageMsg.set(lastVoltage,2)); //send battery in Volt 2 decimal places
                          • R
                            R
                            Rene046
                            @ fhenryco
                            Cant get it to work, if you have time could help with my sketch.
                            // Enable debug prints
                            #define CHILD_ID_HUM 0
                            #define CHILD_ID_TEMP 1
                            #define CHILD_ID_BATTERY 4
                            unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                            #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
                            #define SKETCH_VERSION "2.1"                    // Your version
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            boolean metric = true;
                            MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
                            //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
                            #define VBAT_PER_BITS 0.0041055718475073313782991202346
                            #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
                            #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
                              present(CHILD_ID_BATTERY, S_INFO);
                              //present(CHILD_ID_BATTERY, S_CUSTOM);
                              if (isnan(temperature)) {
                                lastTemp = temperature;
                                if (!metric) {
                                Serial.print("T: ");
                              if (isnan(humidity)) {
                                  lastHum = humidity;
                                  Serial.print("H: ");
                                  Serial.println(humidity);
                              batM();
                               delay(500);
                               // Battery monitoring reading
                               delay(500);
                               // Calculate the battery in %
                               if (batLoop > 2) {
                               if (batteryPcnt > 100) {
                                 batteryPcnt=100;
                                   batLoop = 0;
                                 batLoop++;
                            My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
                            im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
                            Hope to add a soil moisture sensor and baro sensor in future.
                            p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
                            R fhenrycoF 2 Replies Last reply
                            • R Rene046
                              @ fhenryco
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                                  if (!metric) {
                                    lastHum = humidity;
                                batM();
                                 delay(500);
                                 delay(500);
                                 if (batLoop > 2) {
                                   batteryPcnt=100;
                                     batLoop = 0;
                                   batLoop++;
                              R
                              R
                              Rene046
                              O i forget to tell im running the latest gateway from Mysensor.
                              • R Rene046
                                @ fhenryco
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                    if (!metric) {
                                      lastHum = humidity;
                                  batM();
                                   delay(500);
                                   delay(500);
                                   if (batLoop > 2) {
                                     batteryPcnt=100;
                                       batLoop = 0;
                                     batLoop++;
                                fhenrycoF
                                fhenrycoF
                                fhenryco
                                @Rene046
                                not
                                but
                                send(msgbatt.set(batteryPcnt ,1));
                                also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
                                send(msgbatt.set(batteryPcnt ,2));
                                • R
                                  R
                                  Rene046
                                  thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
                                  #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
                                  #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
                                      if (!metric) {
                                        lastHum = humidity;
                                    batM();
                                     delay(500);
                                     delay(500);
                                     if (batLoop > 2) {
                                       batteryPcnt=100;
                                         batLoop = 0;
                                       batLoop++;
                                  R AWIA Arnold ŠlepetisA 3 Replies Last reply
                                  • R Rene046
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                        if (!metric) {
                                          lastHum = humidity;
                                      batM();
                                       delay(500);
                                       delay(500);
                                       if (batLoop > 2) {
                                         batteryPcnt=100;
                                           batLoop = 0;
                                         batLoop++;
                                    R
                                    R
                                    Rene046
                                    And my serial monitor is going wild .lol
                                    41815 MCO:SLP:WUP=-1
                                    Battery percent: 95 %
                                    Battery Average (Send): -12 %
                                    45359 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:244
                                    45403 !TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=1,st=NACK:-12.00
                                    45410 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    45415 MCO:SLP:TPD
                                    45417 MCO:SLP:WUP=-1
                                    47962 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:20.0
                                    T: 20.00
                                    48007 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.6
                                    H: 49.60
                                    Battery percent: -49 %
                                    49014 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    49020 MCO:SLP:TPD
                                    49022 MCO:SLP:WUP=-1
                                    51567 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=4,st=NACK:49.2
                                    H: 49.20
                                    Battery percent: -26 %
                                    52575 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    52582 MCO:SLP:TPD
                                    • R
                                      R
                                      Rene046
                                      And it seems like instead of real voltage i seen percentage in the log
                                      • R Rene046
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                            if (!metric) {
                                              lastHum = humidity;
                                          batM();
                                           delay(500);
                                           delay(500);
                                           if (batLoop > 2) {
                                             batteryPcnt=100;
                                               batLoop = 0;
                                             batLoop++;
                                        AWIA
                                        AWIA
                                        AWI
                                        @Rene046 if you send V_VOLTAGE you should use the voltage level not the percentage.
                                        R 1 Reply Last reply
                                        • AWIA AWI
                                          R
                                          R
                                          Rene046
                                          @AWI
                                          hi could you explain how..
                                          12.5k
