  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • fhenrycoF fhenryco
    @fhenryco it did nothing different ... still have a single sensor temp+hum don't understand why ...
    sundberg84S
    sundberg84S
    @fhenryco - Yes, and there is a trick to seperate them... and i if I remembe right @AWI is the one to ask.
    Edit, found his post here: https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/13
    • fhenrycoF
      fhenrycoF
      fhenryco
      wrote on last edited by fhenryco
      using V_text and S_info is a workaround to avoid grouping
      • R
        R
        Rene046
        i would like to ask something to ,
        Now i have the battery level showing up in Domoticz what can i do to log the voltage in volts, should i add something inside the sketch or something in domoticz..
        fhenrycoF AWIA 2 Replies Last reply
        • R Rene046
          fhenrycoF
          fhenrycoF
          fhenryco
          @Rene046
          This is the instruction in your sketch which allows to see the battery level of devices in domoticZ
          But as you noticed , this is not reported in the logs. One possibility to see it in the Log is to as well send this batteryPcnt information with a send(msgbatt.set(batteryPcnt ,1);
          provided you have defined
          MyMessage msgbatt(CHILD_ID_BATT, V_TEXT);
          In other words you send the battery info as if it was the info of an additional sensor sending text type info
          which you also need to present in the presentation void with
          present(CHILD_ID_BATT, S_INFO);
          For instance if you already have two sensors in you sketch let's say temp and hum with ID =0 and 1 respectively you would give the battery level the next unused ID
          CHILD_ID_BATT=2
          There might be a simpler and more natural way but i don't know it .
          • R Rene046
            AWIA
            AWIA
            AWI
            @Rene046 The "royal" way to report battery level is to define it as S_MULTIMETER and use it to report voltage. Domoticz will take the voltage and can graph it. i.e.
            definitions: MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
            in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
            sending: send(voltageMsg.set(lastVoltage,2)); //send battery in Volt 2 decimal places
            • R
              R
              Rene046
              @ fhenryco
              Cant get it to work, if you have time could help with my sketch.
              // Enable debug prints
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              #define CHILD_ID_BATTERY 4
              unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
              #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
              #define SKETCH_VERSION "2.1"                    // Your version
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = true;
              MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
              //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
              #define VBAT_PER_BITS 0.0041055718475073313782991202346
              #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
              #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
                present(CHILD_ID_BATTERY, S_INFO);
                //present(CHILD_ID_BATTERY, S_CUSTOM);
                present(CHILD_ID_HUM, S_HUM);
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  Serial.print("T: ");
                if (isnan(humidity)) {
                    lastHum = humidity;
                    Serial.print("H: ");
                    Serial.println(humidity);
                batM();
                 delay(500);
                 // Battery monitoring reading
                 delay(500);
                 // Calculate the battery in %
                 if (batLoop > 2) {
                 if (batteryPcnt > 100) {
                   batteryPcnt=100;
                     batLoop = 0;
                   batLoop++;
              My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
              im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
              Hope to add a soil moisture sensor and baro sensor in future.
              p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
              R fhenrycoF 2 Replies Last reply
              • R Rene046
                @ fhenryco
                DHT dht;
                float lastTemp;
                float lastHum;
                    if (!metric) {
                      lastHum = humidity;
                  batM();
                   delay(500);
                   delay(500);
                   if (batLoop > 2) {
                     batteryPcnt=100;
                       batLoop = 0;
                     batLoop++;
                R
                R
                Rene046
                O i forget to tell im running the latest gateway from Mysensor.
                • R Rene046
                  @ fhenryco
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                      if (!metric) {
                        lastHum = humidity;
                    batM();
                     delay(500);
                     delay(500);
                     if (batLoop > 2) {
                       batteryPcnt=100;
                         batLoop = 0;
                       batLoop++;
                  fhenrycoF
                  fhenrycoF
                  fhenryco
                  @Rene046
                  not
                  but
                  send(msgbatt.set(batteryPcnt ,1));
                  also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
                  send(msgbatt.set(batteryPcnt ,2));
                  • R
                    R
                    Rene046
                    thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                    #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
                    #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
                    #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
                        if (!metric) {
                          lastHum = humidity;
                      batM();
                       delay(500);
                       delay(500);
                       if (batLoop > 2) {
                         batteryPcnt=100;
                           batLoop = 0;
                         batLoop++;
                    R AWIA Arnold ŠlepetisA 3 Replies Last reply
                    • R Rene046
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                          if (!metric) {
                            lastHum = humidity;
                        batM();
                         delay(500);
                         delay(500);
                         if (batLoop > 2) {
                           batteryPcnt=100;
                             batLoop = 0;
                           batLoop++;
                      R
                      R
                      Rene046
                      And my serial monitor is going wild .lol
                      41815 MCO:SLP:WUP=-1
                      Battery percent: 95 %
                      Battery Average (Send): -12 %
                      45359 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:244
                      45403 !TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=1,st=NACK:-12.00
                      45410 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      45415 MCO:SLP:TPD
                      45417 MCO:SLP:WUP=-1
                      47962 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:20.0
                      T: 20.00
                      48007 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.6
                      H: 49.60
                      Battery percent: -49 %
                      49014 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      49020 MCO:SLP:TPD
                      49022 MCO:SLP:WUP=-1
                      51567 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=4,st=NACK:49.2
                      H: 49.20
                      Battery percent: -26 %
                      52575 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      52582 MCO:SLP:TPD
                      • R
                        R
                        Rene046
                        And it seems like instead of real voltage i seen percentage in the log
                        • R Rene046
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                              if (!metric) {
                                lastHum = humidity;
                            batM();
                             delay(500);
                             delay(500);
                             if (batLoop > 2) {
                               batteryPcnt=100;
                                 batLoop = 0;
                               batLoop++;
                          AWIA
                          AWIA
                          AWI
                          @Rene046 if you send V_VOLTAGE you should use the voltage level not the percentage.
                          R 1 Reply Last reply
                          • AWIA AWI
                            R
                            R
                            Rene046
                            @AWI
                            hi could you explain how..
                            • R
                              R
                              Rene046
                              I still cant get it to work, No voltage reading or logging.
                              I there nobody trying to build a equal sensor.
                              maybe someone who could rework my sketch. or having a working sketch where i could delete some sensors from.
                              kind regards and greetings from the Netherlands.
                              AWIA 1 Reply Last reply
                              • R Rene046
                                AWIA
                                AWIA
                                AWI
                                @Rene046 I would be happy to help you but need some information on your circuit:
                                • How are you powering your Arduino? Through an (onboard) regulator or directly from battery?
                                • The internal reference can only be used up to 1.1V, you seem to be having a voltage divider which has a resulting voltage of > 1.1 V ?
                                • I do not understand your averaging algorithm, why are you not taking an average of the latest x readings?
                                My suggestion would be to use a different external reference (output of the dc-dc boost converter/ Vcc?) to measure the voltage.
                                • R
                                  R
                                  Rene046
                                  Hi Awi
                                  Thanks that you want to help,
                                  Im powering it by a lipo battery 1 cell using an dc-dc boost converter to get 5 volts
                                  i would like to see what this lipo is doing during a day. this lipo will be charged by an solar panel 6 volt 300ma still waiting for that panel.
                                  You are absolutely right with my voltage divider it's at 1.9 volt while lipo is at 4.2 volt
                                  I'm not a hero in elektronics , just starting to play with it. so to start i should make an voltage divider that gives me aprox 1,1 volt max at 4,2 volt.
                                  I changed the voltages divider now from 270k-100k
                                  giving me 1.07 volt at 4.2 volt lipo
                                  i'm totally open for any other design you could give, i just used some code from others that was excepted by demoticz.
                                  If you like you could send me an sample how you would do it or change my sketch ..
                                  today i also received my BMP180 and BH1750 i want to include in the future..
                                  • R
                                    R
                                    Rene046
                                    wrote on last edited by AWI
                                    #28
                                    my serial monitor is now making a bit more cense voltage is about 0,10 volt off
                                    but maybe i do something wrong with calculation.
                                    percentage is still something wrong with
                                    by the way i'm not shure with the low voltage of an 16850 lipo at 3.6 volt ...
                                    20412 MCO:SLP:WUP=-1
                                    22921 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:17.8
                                    T: 17.80
                                    22929 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.4
                                    H: 35.40
                                    23939 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.53
                                    Battery voltage: 3.53 V
                                    Battery percent: -10 %
                                    23946 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    23954 MCO:SLP:TPD
                                    23955 MCO:SLP:WUP=-1
                                    26465 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:36.1
                                    H: 36.10
                                    27473 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.52
                                    Battery voltage: 3.52 V
                                    Battery percent: -12 %
                                    27481 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                    27489 MCO:SLP:TPD
                                    and here the latest sketch
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                        if (!metric) {
                                          lastHum = humidity;
                                      batM();
                                       delay(500);
                                       delay(500);
                                       send(msgbatt.set(Vbat ,2));
                                       Serial.print("Battery voltage: "); Serial.print(Vbat); Serial.println(" V");
                                       if (batLoop > 2) {
                                         batteryPcnt=100;
                                           batLoop = 0;
                                         batLoop++;
                                    • R Rene046
                                      T: 17.80
                                      H: 35.40
                                      23954 MCO:SLP:TPD
                                      H: 36.10
                                      27489 MCO:SLP:TPD
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                          if (!metric) {
                                            lastHum = humidity;
                                        batM();
                                         delay(500);
                                         delay(500);
                                         if (batLoop > 2) {
                                           batteryPcnt=100;
                                             batLoop = 0;
                                           batLoop++;
                                      R
                                      R
                                      Rene046
                                      #29
                                      @Rene046 said in reporting battery to domoticZ:
                                      im feeding with 3.60 volts at that moment.
                                      • R Rene046
                                        AWIA
                                        AWIA
                                        AWI
                                        #30
                                        @Rene046 The 1.1V internal reference is not calibrated and can be 10% off, So you need to do some calibration yourself.
                                        (b.t.w. I cleaned your postings a little. Please make sure you use the code markings in the right way, i.e. put them on a new line). To get you going I rewrote the battery routine. Changes:
                                        • no real need to average the readings if you give it time to stabilize.
                                        • got rid of the "volt per bit" constant
                                        • added a "reference value:" for calibration, you can calculate it from the measured voltage and reported voltage.
                                        // battery calculations
                                        void batM(){
                                        	const float vRef = 4.2/ 1.1 ;							// actual value for max reading, adjust with help of measured voltage
                                        	delay(500);
                                        	int sensorValue = analogRead(BATTERY_SENSE_PIN);   		// sensorValue is 0..1023 where 1023 == vRef
                                        	float vBat = sensorValue * vRef / 1024 ;
                                        	send(msgbatt.set(vBat ,2));
                                        	Serial.print("Battery voltage: "); Serial.print(vBat); Serial.println(" V");
                                        	int batteryPcnt = static_cast<int>(((vBat-VMIN)/(VMAX-VMIN))*100.);
                                        	sendBatteryLevel( batteryPcnt) ;
                                        • R
                                          R
                                          Rene046
                                          Thanks that looks way better.
                                          I just changed
                                          into
                                          const float vRef = 4.2/ 1.07 ;
                                          because this is what i measure with my multimeter with 4.2 volt battery and measuring my voltage divider i have 1.07 volt
                                          Giving me strange results something must be bad ..... my multimeter ?? it should be closer to 4.2 ? i guess
                                          Battery voltage: 3.92 V
                                          14842 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                          Battery percent: 53 %
                                          14850 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          14856 MCO:SLP:TPD
                                          14858 MCO:SLP:WUP=-1
                                          17367 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.4
                                          T: 19.40
                                          17376 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:48.5
                                          H: 48.50
                                          17885 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                                          17893 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                          17900 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          17906 MCO:SLP:TPD```
                                          12.5k
