  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • R
    R
    Rene046
    i would like to ask something to ,
    Now i have the battery level showing up in Domoticz what can i do to log the voltage in volts, should i add something inside the sketch or something in domoticz..
    fhenrycoF AWIA 2 Replies Last reply
    • R Rene046
      fhenrycoF
      fhenrycoF
      fhenryco
      @Rene046
      This is the instruction in your sketch which allows to see the battery level of devices in domoticZ
      But as you noticed , this is not reported in the logs. One possibility to see it in the Log is to as well send this batteryPcnt information with a send(msgbatt.set(batteryPcnt ,1);
      provided you have defined
      MyMessage msgbatt(CHILD_ID_BATT, V_TEXT);
      In other words you send the battery info as if it was the info of an additional sensor sending text type info
      which you also need to present in the presentation void with
      present(CHILD_ID_BATT, S_INFO);
      For instance if you already have two sensors in you sketch let's say temp and hum with ID =0 and 1 respectively you would give the battery level the next unused ID
      CHILD_ID_BATT=2
      There might be a simpler and more natural way but i don't know it .
      • R Rene046
        AWIA
        AWIA
        AWI
        @Rene046 The "royal" way to report battery level is to define it as S_MULTIMETER and use it to report voltage. Domoticz will take the voltage and can graph it. i.e.
        definitions: MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
        in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
        sending: send(voltageMsg.set(lastVoltage,2)); //send battery in Volt 2 decimal places
        • R
          R
          Rene046
          @ fhenryco
          Cant get it to work, if you have time could help with my sketch.
          // Enable debug prints
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define CHILD_ID_BATTERY 4
          unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
          #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
          #define SKETCH_VERSION "2.1"                    // Your version
          DHT dht;
          float lastTemp;
          float lastHum;
          boolean metric = true;
          MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
          //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
          #define VBAT_PER_BITS 0.0041055718475073313782991202346
          #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
          #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
            present(CHILD_ID_BATTERY, S_INFO);
            //present(CHILD_ID_BATTERY, S_CUSTOM);
            present(CHILD_ID_HUM, S_HUM);
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("T: ");
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("H: ");
                Serial.println(humidity);
            batM();
             delay(500);
             // Battery monitoring reading
             delay(500);
             // Calculate the battery in %
             if (batLoop > 2) {
             if (batteryPcnt > 100) {
               batteryPcnt=100;
                 batLoop = 0;
               batLoop++;
          My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
          im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
          Hope to add a soil moisture sensor and baro sensor in future.
          p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
          R fhenrycoF 2 Replies Last reply
          • R Rene046
            @ fhenryco
            DHT dht;
            float lastTemp;
            float lastHum;
                if (!metric) {
                  lastHum = humidity;
              batM();
               delay(500);
               delay(500);
               if (batLoop > 2) {
                 batteryPcnt=100;
                   batLoop = 0;
                 batLoop++;
            R
            R
            Rene046
            O i forget to tell im running the latest gateway from Mysensor.
            • R Rene046
              @ fhenryco
              DHT dht;
              float lastTemp;
              float lastHum;
                  if (!metric) {
                    lastHum = humidity;
                batM();
                 delay(500);
                 delay(500);
                 if (batLoop > 2) {
                   batteryPcnt=100;
                     batLoop = 0;
                   batLoop++;
              fhenrycoF
              fhenrycoF
              fhenryco
              @Rene046
              not
              but
              send(msgbatt.set(batteryPcnt ,1));
              also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
              send(msgbatt.set(batteryPcnt ,2));
              • R
                R
                Rene046
                thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
                DHT dht;
                float lastTemp;
                float lastHum;
                #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
                #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
                #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
                    if (!metric) {
                      lastHum = humidity;
                  batM();
                   delay(500);
                   delay(500);
                   if (batLoop > 2) {
                     batteryPcnt=100;
                       batLoop = 0;
                     batLoop++;
                R AWIA Arnold ŠlepetisA 3 Replies Last reply
                • R Rene046
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                      if (!metric) {
                        lastHum = humidity;
                    batM();
                     delay(500);
                     delay(500);
                     if (batLoop > 2) {
                       batteryPcnt=100;
                         batLoop = 0;
                       batLoop++;
                  R
                  R
                  Rene046
                  And my serial monitor is going wild .lol
                  41815 MCO:SLP:WUP=-1
                  Battery percent: 95 %
                  Battery Average (Send): -12 %
                  45359 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:244
                  45403 !TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=1,st=NACK:-12.00
                  45410 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  45415 MCO:SLP:TPD
                  45417 MCO:SLP:WUP=-1
                  47962 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:20.0
                  T: 20.00
                  48007 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.6
                  H: 49.60
                  Battery percent: -49 %
                  49014 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  49020 MCO:SLP:TPD
                  49022 MCO:SLP:WUP=-1
                  51567 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=4,st=NACK:49.2
                  H: 49.20
                  Battery percent: -26 %
                  52575 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  52582 MCO:SLP:TPD
                  • R
                    R
                    Rene046
                    And it seems like instead of real voltage i seen percentage in the log
                    • R Rene046
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                          if (!metric) {
                            lastHum = humidity;
                        batM();
                         delay(500);
                         delay(500);
                         if (batLoop > 2) {
                           batteryPcnt=100;
                             batLoop = 0;
                           batLoop++;
                      AWIA
                      AWIA
                      AWI
                      @Rene046 if you send V_VOLTAGE you should use the voltage level not the percentage.
                      R 1 Reply Last reply
                      • AWIA AWI
                        R
                        R
                        Rene046
                        @AWI
                        hi could you explain how..
                        • R
                          R
                          Rene046
                          I still cant get it to work, No voltage reading or logging.
                          I there nobody trying to build a equal sensor.
                          maybe someone who could rework my sketch. or having a working sketch where i could delete some sensors from.
                          kind regards and greetings from the Netherlands.
                          AWIA 1 Reply Last reply
                          • R Rene046
                            AWIA
                            AWIA
                            AWI
                            @Rene046 I would be happy to help you but need some information on your circuit:
                            • How are you powering your Arduino? Through an (onboard) regulator or directly from battery?
                            • The internal reference can only be used up to 1.1V, you seem to be having a voltage divider which has a resulting voltage of > 1.1 V ?
                            • I do not understand your averaging algorithm, why are you not taking an average of the latest x readings?
                            My suggestion would be to use a different external reference (output of the dc-dc boost converter/ Vcc?) to measure the voltage.
                            • R
                              R
                              Rene046
                              Hi Awi
                              Thanks that you want to help,
                              Im powering it by a lipo battery 1 cell using an dc-dc boost converter to get 5 volts
                              i would like to see what this lipo is doing during a day. this lipo will be charged by an solar panel 6 volt 300ma still waiting for that panel.
                              You are absolutely right with my voltage divider it's at 1.9 volt while lipo is at 4.2 volt
                              I'm not a hero in elektronics , just starting to play with it. so to start i should make an voltage divider that gives me aprox 1,1 volt max at 4,2 volt.
                              I changed the voltages divider now from 270k-100k
                              giving me 1.07 volt at 4.2 volt lipo
                              i'm totally open for any other design you could give, i just used some code from others that was excepted by demoticz.
                              If you like you could send me an sample how you would do it or change my sketch ..
                              today i also received my BMP180 and BH1750 i want to include in the future..
                              • R
                                R
                                Rene046
                                wrote on last edited by AWI
                                #28
                                my serial monitor is now making a bit more cense voltage is about 0,10 volt off
                                but maybe i do something wrong with calculation.
                                percentage is still something wrong with
                                by the way i'm not shure with the low voltage of an 16850 lipo at 3.6 volt ...
                                20412 MCO:SLP:WUP=-1
                                22921 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:17.8
                                T: 17.80
                                22929 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.4
                                H: 35.40
                                23939 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.53
                                Battery voltage: 3.53 V
                                Battery percent: -10 %
                                23946 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                23954 MCO:SLP:TPD
                                23955 MCO:SLP:WUP=-1
                                26465 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:36.1
                                H: 36.10
                                27473 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.52
                                Battery voltage: 3.52 V
                                Battery percent: -12 %
                                27481 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                27489 MCO:SLP:TPD
                                and here the latest sketch
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                    if (!metric) {
                                      lastHum = humidity;
                                  batM();
                                   delay(500);
                                   delay(500);
                                   send(msgbatt.set(Vbat ,2));
                                   Serial.print("Battery voltage: "); Serial.print(Vbat); Serial.println(" V");
                                   if (batLoop > 2) {
                                     batteryPcnt=100;
                                       batLoop = 0;
                                     batLoop++;
                                • R Rene046
                                  T: 17.80
                                  H: 35.40
                                  23954 MCO:SLP:TPD
                                  H: 36.10
                                  27489 MCO:SLP:TPD
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                      if (!metric) {
                                        lastHum = humidity;
                                    batM();
                                     delay(500);
                                     delay(500);
                                     if (batLoop > 2) {
                                       batteryPcnt=100;
                                         batLoop = 0;
                                       batLoop++;
                                  R
                                  R
                                  Rene046
                                  #29
                                  @Rene046 said in reporting battery to domoticZ:
                                  im feeding with 3.60 volts at that moment.
                                  • R Rene046
                                    AWIA
                                    AWIA
                                    AWI
                                    #30
                                    @Rene046 The 1.1V internal reference is not calibrated and can be 10% off, So you need to do some calibration yourself.
                                    (b.t.w. I cleaned your postings a little. Please make sure you use the code markings in the right way, i.e. put them on a new line). To get you going I rewrote the battery routine. Changes:
                                    • no real need to average the readings if you give it time to stabilize.
                                    • got rid of the "volt per bit" constant
                                    • added a "reference value:" for calibration, you can calculate it from the measured voltage and reported voltage.
                                    // battery calculations
                                    void batM(){
                                    	const float vRef = 4.2/ 1.1 ;							// actual value for max reading, adjust with help of measured voltage
                                    	delay(500);
                                    	int sensorValue = analogRead(BATTERY_SENSE_PIN);   		// sensorValue is 0..1023 where 1023 == vRef
                                    	float vBat = sensorValue * vRef / 1024 ;
                                    	send(msgbatt.set(vBat ,2));
                                    	Serial.print("Battery voltage: "); Serial.print(vBat); Serial.println(" V");
                                    	int batteryPcnt = static_cast<int>(((vBat-VMIN)/(VMAX-VMIN))*100.);
                                    	sendBatteryLevel( batteryPcnt) ;
                                    • R
                                      R
                                      Rene046
                                      Thanks that looks way better.
                                      I just changed
                                      into
                                      const float vRef = 4.2/ 1.07 ;
                                      because this is what i measure with my multimeter with 4.2 volt battery and measuring my voltage divider i have 1.07 volt
                                      Giving me strange results something must be bad ..... my multimeter ?? it should be closer to 4.2 ? i guess
                                      Battery voltage: 3.92 V
                                      14842 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                      Battery percent: 53 %
                                      14850 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      14856 MCO:SLP:TPD
                                      14858 MCO:SLP:WUP=-1
                                      17367 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.4
                                      T: 19.40
                                      17376 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:48.5
                                      H: 48.50
                                      17885 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                                      17893 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                      17900 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      17906 MCO:SLP:TPD```
                                      • R Rene046
                                        I just changed
                                        into
                                        14856 MCO:SLP:TPD
                                        T: 19.40
                                        H: 48.50
                                        AWIA
                                        AWIA
                                        AWI
                                        @Rene046 You should still compensate for the 1.1 offset. What you should do is calculate the vRef from the measured battery voltage and the real voltage.
                                        • R Rene046
                                          DHT dht;
                                          float lastTemp;
                                          float lastHum;
                                              if (!metric) {
                                                lastHum = humidity;
                                            batM();
                                             delay(500);
                                             delay(500);
                                             if (batLoop > 2) {
                                               batteryPcnt=100;
                                                 batLoop = 0;
                                               batLoop++;
                                          Arnold ŠlepetisA
                                          Arnold ŠlepetisA
                                          Arnold Šlepetis
                                          wrote on last edited by Arnold Šlepetis
                                          #33
                                          @Rene046 what resistors do you use to measure battery. VBAT_PER_BITS is not just 4.2/1023. Personally I am using 1m and 300k it gives me up to 4.77V
                                          12.5k
